08-29-2021, 09:12 AM
Bonjour
Comment puis-je avoir un contact mono stable sur le module KC868 s’il vous plaît ?
Merci
Merci
Contact mono stable
Bonjour
Comment puis-je avoir un contact mono stable sur le module KC868 s’il vous plaît ? Merci
08-29-2021, 11:52 PM
what's your means?
08-30-2021, 03:11 PM
Je voudrais avoir un contact d’une seconde environ
08-30-2021, 06:12 PM
Je voudrais temporiser le relais
08-31-2021, 02:03 AM
can you write in English? now i don't understand your words.
08-31-2021, 05:38 AM
Yes, sorry, I'd like to have a one-second timed contact to create an impulse
08-31-2021, 10:14 AM
if you using KC868-H32B , just set in network webpage, there is a momentary time option can be set for 1-10000 second.
08-31-2021, 03:16 PM
Ok, thanks, I'll watch that tonight
08-31-2021, 05:39 PM
I don't have an H32B module but an H32L and in the web page I can't find a timer for relays
09-01-2021, 12:03 AM
if you use H32L, you can create scene mode in phone app, add action relay1 ON -> delay 1S -> relay1 OFF is ok.
| 1 Guest(s) |
