09-09-2024, 12:31 AM
Hi there,
I am writing a TCP string driver for our AV system and I have the board going, and the inputs/outputs work, I am getting feedback.
However, if i send commands quickly it seems to be able to easily overwhelm the board and it crashes - it will reset and work again after a short while.
I'd understand if it was a lot of packets, but I'm literally sending 1 a second and that's enough to crash the board - it should be able to handle this faster than I can click without issues?
I am only sending one string at a time, either all on, all off, or a multi-on which does a bitwise operation on the AV side and sends the correct string.
Can you advise why this is?
Thanks
Thanks
