I'm looking for information on how to add an extra module for an SD card to my KC868-A6 board. What are the necessary steps to connect the module and program it properly? Is there any specific code I should use to ensure that data recording works correctly? I appreciate any guidance or resources that can assist me in this process.
How to Add an Extra Module for SD Card on the KC868-A6 Board?
if you write your own arduino code. you can use your KC868-A6 with KinCony ATF SD Card module.
KC868-A6 have a extender "serial port" on PCB. You can use these two pins connect with AFT module. just two boards connect with serial port. ![]() About ATF details , you can check at here: https://www.kincony.com/esp32-sd-card-module.html About ATF arduino demo source code , you can check at here: https://www.kincony.com/forum/forumdisplay.php?fid=57
| 1 Guest(s) |
![[Image: esp32-sd-card-pins.jpg]](https://www.kincony.com/images/ATF/esp32-sd-card-pins.jpg)
