Threads: 1
I need help to control a 12V DC 5A motor (2 wires) to make it rotate in both directions. Is this possible with the KC868-A16?
On the other hand, is it possible to use the TTP223 touch sensors as inputs, which have a working voltage of 2.5 to 5.5V?
Threads: 881
1. yes, you can use KC868-A16 12v control your motor.
2. KC868-A16 digital input use for 0V or 12V.
Threads: 1
Thanks for your reply,
but the video you mentioned doesn't explain how to connect a 2-wire motor, it only explains how to use it for 3-wire motors. In my case, to change the direction you have to change from ++ and -- to +- to -+. I don't know what I mean.
I'm currently using the L298N motor controller module. Is it possible to do the same with this board? If not, can this controller be connected to it, and how?
Thanks!
Threads: 881
if you are suing DC motor. what's your L298 motor module interface? i2c or?
Threads: 881
KC868-A16 mosfet MAX support 10A, it can output DC12v to your moter. change direction just according to your software code.
