06-23-2025, 05:35 AM
* Description:
* This Arduino program reads the state of 128 digital inputs using 8 PCF8575 I/O expanders.
* Each PCF8575 reads 16 input channels. The input states are printed to the Serial Monitor
* as binary strings grouped by chip.
* I2C Pin Definitions:
* - SDA: GPIO 12
* - SCL: GPIO 11
* PCF8575 Addresses:
* - Input 1~16 : 0x27
* - Input 17~32 : 0x26
* - Input 33~48 : 0x23
* - Input 49~64 : 0x22
* - Input 65~80 : 0x25
* - Input 81~96 : 0x24
* - Input 97~112 : 0x21
* - Input113~128 : 0x20
* Input Status Legend:
* - 0: ON (Active)
* - 1: OFF (Inactive / Pulled HIGH)
#include <Wire.h>
#include <PCF8575.h>
// Define I2C pins
#define I2C_SDA 12
#define I2C_SCL 11
// Define PCF8575 I2C addresses
PCF8575 pcf_inputs[8] = {
PCF8575(0x27), // Input 1-16
PCF8575(0x26), // Input 17-32
PCF8575(0x23), // Input 33-48
PCF8575(0x22), // Input 49-64
PCF8575(0x25), // Input 65-80
PCF8575(0x24), // Input 81-96
PCF8575(0x21), // Input 97-112
PCF8575(0x20) // Input 113-128
Wire.begin(I2C_SDA, I2C_SCL);
Serial.println("KinCony F128 128 channel input state 0:ON 1:OFF");
// Initialize all PCF8575 modules
for (int i = 0; i < 8; i++) {
pcf_inputs[i].begin();
// Iterate through all 8 chips
for (int chip = 0; chip < 8; chip++) {
Serial.print("Input ");
Serial.print((chip * 16) + 1);
Serial.print("~");
Serial.print((chip + 1) * 16);
Serial.print(": ");
// Read and print the state of all 16 pins on current chip
for (int pin = 0; pin < 16; pin++) {
int state = pcf_inputs[chip].read(pin);
Serial.print(state);
Serial.println();
Serial.println("--------------------------------------------------");
delay(1000); // Delay 1 second between reads
2-digital-input.zip (Size: 1,019 bytes / Downloads: 393)
2-digital-input.ino.merged.zip (Size: 192.36 KB / Downloads: 406)
