CO16 ESPHome yaml for home assistant with tuya
  friendly_name: KinCony CO16
  name_add_mac_suffix: true
  min_version: 2026.5.3
  variant: esp32s3
  flash_size: 16MB
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: y
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
ota:
  - platform: esphome
# ESPHome does not support Ethernet and Wi-Fi at the same time. Remove this
# block before adding a wifi: configuration.
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
  clock_speed: 16MHz
  interface: spi2
web_server:
  port: 80
external_components:
  - source:
      type: git
      ref: v1.4.0
    components:
      - nx3l4051
      - nx3l4051_max31865
  - source:
      type: git
      ref: v1.3.1
  sda: GPIO8
  scl: GPIO18
  frequency: 100kHz
  - id: co16_relay_hub
    address: 0x22
    pcf8575: true
xl9535:
  - id: co16_input_hub
    address: 0x24
ads1115:
  - id: co16_adc_01_04
    address: 0x48
  - id: co16_adc_05_08
    address: 0x49
  - id: co16_adc_09_12
    address: 0x4B
  - id: co16_adc_13_16
    address: 0x4A
nx3l4051:
  - id: co16_pt100_mux
    pin_s1: GPIO7
    pin_s2: GPIO21
    pin_s3: LOW
    delay: 20ms
globals:
  - id: co16_pt100_channel
    type: uint8_t
    restore_value: false
    initial_value: "0"
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: 8svouhd9lziyz5py
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
    name: "CO16 Output 01"
    restore_mode: ALWAYS_OFF
      pcf8574: co16_relay_hub
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "co16_output_01"
    name: "CO16 Output 02"
      mode: OUTPUT
    dp_id: 2
    internal: true
    bind_switch_id: "co16_output_02"
    name: "CO16 Output 03"
      mode: OUTPUT
    dp_id: 3
    internal: true
    bind_switch_id: "co16_output_03"
    name: "CO16 Output 04"
      mode: OUTPUT
    dp_id: 4
    internal: true
    bind_switch_id: "co16_output_04"
    name: "CO16 Output 05"
      number: 4
      mode: OUTPUT
    dp_id: 5
    internal: true
    bind_switch_id: "co16_output_05"
    name: "CO16 Output 06"
      number: 5
      mode: OUTPUT
    dp_id: 6
    internal: true
    bind_switch_id: "co16_output_06"
    name: "CO16 Output 07"
      number: 6
      mode: OUTPUT
    dp_id: 101
    internal: true
    bind_switch_id: "co16_output_07"
    name: "CO16 Output 08"
      number: 7
      mode: OUTPUT
    dp_id: 102
    internal: true
    bind_switch_id: "co16_output_08"
    name: "CO16 Output 09"
      number: 8
      mode: OUTPUT
    dp_id: 103
    internal: true
    bind_switch_id: "co16_output_09"
    name: "CO16 Output 10"
      number: 9
      mode: OUTPUT
    dp_id: 104
    internal: true
    bind_switch_id: "co16_output_10"
    name: "CO16 Output 11"
      number: 10
      mode: OUTPUT
    dp_id: 105
    internal: true
    bind_switch_id: "co16_output_11"
    name: "CO16 Output 12"
      number: 11
      mode: OUTPUT
    dp_id: 106
    internal: true
    bind_switch_id: "co16_output_12"
    name: "CO16 Output 13"
      number: 12
      mode: OUTPUT
    dp_id: 107
    internal: true
    bind_switch_id: "co16_output_13"
    name: "CO16 Output 14"
      number: 13
      mode: OUTPUT
    dp_id: 108
    internal: true
    bind_switch_id: "co16_output_14"
    name: "CO16 Output 15"
      number: 14
      mode: OUTPUT
    dp_id: 109
    internal: true
    bind_switch_id: "co16_output_15"
    name: "CO16 Output 16"
      number: 15
      mode: OUTPUT
    dp_id: 110
    internal: true
    bind_switch_id: "co16_output_16"
    name: "CO16 Input 01"
      xl9535: co16_input_hub
    dp_id: 111
    bind_binary_sensor_id: co16_input_01
    internal: true
    name: "CO16 Input 02"
    dp_id: 112
    bind_binary_sensor_id: co16_input_02
    internal: true
    name: "CO16 Input 03"
    dp_id: 113
    bind_binary_sensor_id: co16_input_03
    internal: true
    name: "CO16 Input 04"
    dp_id: 114
    bind_binary_sensor_id: co16_input_04
    internal: true
    name: "CO16 Input 05"
      number: 4
    dp_id: 115
    bind_binary_sensor_id: co16_input_05
    internal: true
    name: "CO16 Input 06"
      number: 5
    dp_id: 116
    bind_binary_sensor_id: co16_input_06
    internal: true
    name: "CO16 Input 07"
      number: 6
    dp_id: 117
    bind_binary_sensor_id: co16_input_07
    internal: true
    name: "CO16 Input 08"
      number: 7
    dp_id: 118
    bind_binary_sensor_id: co16_input_08
    internal: true
    name: "CO16 Input 09"
      number: 10
    dp_id: 119
    bind_binary_sensor_id: co16_input_09
    internal: true
    name: "CO16 Input 10"
      number: 11
    dp_id: 120
    bind_binary_sensor_id: co16_input_10
    internal: true
    name: "CO16 Input 11"
      number: 12
    dp_id: 121
    bind_binary_sensor_id: co16_input_11
    internal: true
    name: "CO16 Input 12"
      number: 13
    dp_id: 122
    bind_binary_sensor_id: co16_input_12
    internal: true
    name: "CO16 Input 13"
      number: 14
    dp_id: 123
    bind_binary_sensor_id: co16_input_13
    internal: true
    name: "CO16 Input 14"
      number: 15
    dp_id: 124
    bind_binary_sensor_id: co16_input_14
    internal: true
    name: "CO16 Input 15"
      number: 16
    dp_id: 125
    bind_binary_sensor_id: co16_input_15
    internal: true
    name: "CO16 Input 16"
      number: 17
    dp_id: 126
    bind_binary_sensor_id: co16_input_16
    internal: true
  # The default filters expose the terminal measurements as 0-10 V.
  # For a 4-20 mA channel, replace its filters with: [{multiply: 10.0}]
  # and change the unit/device class to mA/current.
  - platform: ads1115
    ads1115_id: co16_adc_01_04
    multiplexer: A0_GND
    gain: 4.096
    name: "CO16 Analog Input 01"
    unit_of_measurement: V
    device_class: voltage
    state_class: measurement
    accuracy_decimals: 2
    update_interval: 5s
    filters:
      - lambda: 'return x <= 0.0025f ? 0.0f : x;'
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A1_GND
    gain: 4.096
    name: "CO16 Analog Input 02"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A2_GND
    gain: 4.096
    name: "CO16 Analog Input 03"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A3_GND
    gain: 4.096
    name: "CO16 Analog Input 04"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    ads1115_id: co16_adc_05_08
    multiplexer: A0_GND
    gain: 4.096
    name: "CO16 Analog Input 05"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A1_GND
    gain: 4.096
    name: "CO16 Analog Input 06"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A2_GND
    gain: 4.096
    name: "CO16 Analog Input 07"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A3_GND
    gain: 4.096
    name: "CO16 Analog Input 08"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    ads1115_id: co16_adc_09_12
    multiplexer: A0_GND
    gain: 4.096
    name: "CO16 Analog Input 09"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A1_GND
    gain: 4.096
    name: "CO16 Analog Input 10"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A2_GND
    gain: 4.096
    name: "CO16 Analog Input 11"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A3_GND
    gain: 4.096
    name: "CO16 Analog Input 12"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    ads1115_id: co16_adc_13_16
    multiplexer: A0_GND
    gain: 4.096
    name: "CO16 Analog Input 13"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A1_GND
    gain: 4.096
    name: "CO16 Analog Input 14"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A2_GND
    gain: 4.096
    name: "CO16 Analog Input 15"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: ads1115
    multiplexer: A3_GND
    gain: 4.096
    name: "CO16 Analog Input 16"
    update_interval: 5s
    filters:
      - multiply: 5.16696
      - clamp:
          min_value: 0.0
          max_value: 10.0
  - platform: nx3l4051_max31865
    mux_id: co16_pt100_mux
    internal: true
    clk_pin: GPIO11
    mosi_pin: GPIO10
    miso_pin: GPIO12
    cs_pin: GPIO14
    reference_resistance: 400 ohm
    rtd_nominal_resistance: 100 ohm
    rtd_wires: 3
    mains_filter: 50 Hz
    update_interval: never
  - platform: template
    name: "CO16 PT100 01"
    unit_of_measurement: "°C"
    device_class: temperature
    name: "CO16 PT100 02"
    name: "CO16 PT100 03"
    name: "CO16 PT100 04"
interval:
  - interval: 10s
    then:
      - repeat:
          count: 4
          then:
            - nx3l4051.select:
                channel: !lambda return id(co16_pt100_channel);
            - component.update: co16_pt100_reader
            - delay: 70ms
            - lambda: |-
                const float value = id(co16_pt100_reader).state;
                switch (id(co16_pt100_channel)) {
                  case 0:
                    id(co16_pt100_01).publish_state(value);
                    break;
                  case 1:
                    id(co16_pt100_02).publish_state(value);
                    break;
                  case 2:
                    id(co16_pt100_03).publish_state(value);
                    break;
                  default:
                    id(co16_pt100_04).publish_state(value);
                    break;
                id(co16_pt100_channel) = (id(co16_pt100_channel) + 1) % 4;
esphome yaml download:
.txt   CO16-HA-with-Tuya.txt (Size: 21.48 KB / Downloads: 46)
