Made by KinCony IoT: https://www.kincony.com
Program functionality:
This program uses ESP32-S3 to read inputs from PCA9555 I/O expander chip (I2C address 0x24)
for channels 1-16, and control corresponding relays using PCF8575 I/O expander chip (I2C address 0x22)
for controlling 16 relays (1-16). When input (DI) is triggered (LOW), corresponding relay (OUTPUT) is activated (LOW).
#include <PCA95x5.h>
#include <Wire.h>
#include <PCF8575.h>
// Initialize the PCA9555 objects for reading inputs (channels 1-16)
PCA9555 input_ioex1; // For channels 1-16 (I2C address 0x24)
// Set I2C address of the PCF8575 module for output relays
#define I2C_ADDRESS 0x22
PCF8575 pcf8575_R1(I2C_ADDRESS);
delay(10);
// Initialize I2C bus: SDA=GPIO8, SCL=GPIO18, 100kHz
Wire.begin(8, 18, 100000);
// Initialize PCF8575 for outputs
pcf8575_R1.begin();
// Turn off all relays initially (set all pins HIGH - relay OFF)
pcf8575_R1.write(i, HIGH);
// Configure input PCA9555 (for inputs 1-16)
input_ioex1.attach(Wire, 0x24);
input_ioex1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
input_ioex1.direction(PCA95x5::Direction::IN_ALL);
delay(50);
// Read input states from XL9535 (inputs 1-16)
uint16_t inputs_1_16 = input_ioex1.read();
// Control outputs based on inputs
// When input is LOW, set corresponding output to LOW (activate relay)
for (int channel = 0; channel < 16; channel++) {
if (!(inputs_1_16 & (1 << channel))) {
pcf8575_R1.write(channel, LOW); // Input triggered, activate relay
} else {
pcf8575_R1.write(channel, HIGH); // Input not triggered, deactivate relay
delay(100);
9-input-trigger-output.zip (Size: 997 bytes / Downloads: 96)
9-input-trigger-output.ino.merged.zip (Size: 197.75 KB / Downloads: 104)
