	<channel>
		<title><![CDATA[Smart Home Automation Forum - B4M]]></title>
		<pubDate>Sun, 15 Nov 2026 02:28:41 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[4-20mA loop voltage consideration]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9730</link>
			<pubDate>Tue, 11 Aug 2026 14:21:07 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11278">Armsp0</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9730</guid>
			<description><![CDATA[Although the B4 and B4M devices allow connection of a 24Vdc supply it is not clear to me that the 4-20 mA analog inputs allow use of a 24 volt loop supply. The example drawings show 12 volt supply devices connected and I am concerned that I may damage the inputs by using a 24vdc loop. Please advise what is acceptable.]]></description>
			<content:encoded><![CDATA[Although the B4 and B4M devices allow connection of a 24Vdc supply it is not clear to me that the 4-20 mA analog inputs allow use of a 24 volt loop supply. The example drawings show 12 volt supply devices connected and I am concerned that I may damage the inputs by using a 24vdc loop. Please advise what is acceptable.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Questions on the B4M]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9633</link>
			<pubDate>Thu, 16 Jul 2026 19:07:11 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11244">agentofkaos</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9633</guid>
			<description><![CDATA[I have a bunch of questions about the B4M that I don't see in any of the docs:<br />
<br />
What is rated DC V and A range for the MOSFET relays?  I'd like to use it for 5-24V, no more than 2A.  <br />
<br />
Can the B8M relays can handle mixed voltages/references? Like 12V on one relay and 24V on a different one?<br />
<br />
What wire gauge size range do the relay terminals accept?<br />
<br />
What is the power supply rating (V, A) in the B4M bundle B power supply?<br />
<br />
With the KDS v3 firmware: does the B4M will present its relays over the network to Home Assistant (via auto discovery)?<br />
<br />
If I connect several DS18B20 temperature sensors to the B4M one wire interfaces will these be automatically presented to Home Assistant as temp sensors across the network or will have to code the Home Assistant presentation and auto-discovery on the B4M? <br />
<br />
Thanks for any help.]]></description>
			<content:encoded><![CDATA[I have a bunch of questions about the B4M that I don't see in any of the docs:<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Thanks for any help.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[RS485 issue]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9535</link>
			<pubDate>Wed, 24 Jun 2026 19:10:38 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11087">haipt2489</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9535</guid>
			<description><![CDATA[Hi Kincony,<br />
I have bought some of your B4M modules, and try to use the RS485 port.<br />
I try to run the code here: <a href="https://www.kincony.com/forum/showthread.php?tid=8934" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=8934<br />
</a><br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>/*<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 39<br />
#define RS485_TXD 38<br />
<br />
<br />
void setup() {<br />
  Serial.begin(115200);<br />
  while (!Serial);<br />
<br />
  <br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B8M!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  } else <br />
  {<br />
    Serial.println("RS485 is not available");<br />
  }<br />
<br />
  delay(2000);<br />
}</code></div></div><br />
<br />
but cannot receive the data from RS485 port. The log shows that port is not available.<br />
Can you help me troubleshoot this issue?<br />
<br />
Best regards,<br />
Hai Pham]]></description>
			<content:encoded><![CDATA[Hi Kincony,<br />
</a><br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  } else <br />
  {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
<br />
Best regards,<br />
Hai Pham]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[B4M Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9247</link>
			<pubDate>Sat, 18 Apr 2026 10:23:11 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9247</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9635" target="_blank" title="">B4M_wiring.jpg</a> (Size: 283.6 KB / Downloads: 457)
		</item>
		<item>
			<title><![CDATA[B4M Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9246</link>
			<pubDate>Sat, 18 Apr 2026 10:11:39 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9246</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9618" target="_blank" title="">KinCony-B4M-Smart-Controller-diagram.png</a> (Size: 1.73 MB / Downloads: 400)
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-11 digital INPUT trigger OUTPUT directly]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8927</link>
			<pubDate>Wed, 14 Jan 2026 12:05:21 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8927</guid>
 *<br />
 * This program reads 4 input states from a PCF8574 I/O expander and <br />
 * controls a corresponding 4-channel relay module. When an input pin <br />
 * is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 *<br />
 * Pin Definitions:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 * - PCF8575 I2C Address: 0x24<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
#include &lt;PCF8574.h&gt;<br />
<br />
// I2C pins<br />
#define SDA 8<br />
#define SCL 18<br />
<br />
// PCF8575 I2C address<br />
#define INPUT_I2C_ADDRESS 0x24 &nbsp;&nbsp;<br />
<br />
// Create PCF8575 object<br />
PCF8574 pcf8574_IN(INPUT_I2C_ADDRESS);<br />
<br />
  Wire.begin(SDA, SCL);<br />
<br />
<br />
    pcf8574_IN.pinMode(P0, INPUT);<br />
    pcf8574_IN.pinMode(P1, INPUT);<br />
    pcf8574_IN.pinMode(P2, INPUT);<br />
    pcf8574_IN.pinMode(P3, INPUT);<br />
&nbsp;&nbsp;&nbsp;&nbsp;  pcf8574_IN.pinMode(P4, OUTPUT);<br />
    pcf8574_IN.pinMode(P5, OUTPUT);<br />
    pcf8574_IN.pinMode(P6, OUTPUT);<br />
    pcf8574_IN.pinMode(P7, OUTPUT);<br />
<br />
  // Initialize PCF8575<br />
  pcf8574_IN.begin();<br />
<br />
  // Turn off all relays first (assuming LOW activates the relay)<br />
  for (int i = 4; i &lt; 8; i++) {<br />
    pcf8574_IN.digitalWrite(i, HIGH);  // Set to HIGH to turn off the relay<br />
  }<br />
<br />
  delay(50);<br />
}<br />
<br />
void loop() {<br />
<br />
  if (pcf8574_IN.digitalRead(0)) pcf8574_IN.digitalWrite(4, HIGH); else pcf8574_IN.digitalWrite(4, LOW);<br />
  delay(50);<br />
  if (pcf8574_IN.digitalRead(1)) pcf8574_IN.digitalWrite(5, HIGH); else pcf8574_IN.digitalWrite(5, LOW);     &nbsp;&nbsp;<br />
  delay(50);<br />
  if (pcf8574_IN.digitalRead(2)) pcf8574_IN.digitalWrite(6, HIGH); else pcf8574_IN.digitalWrite(6, LOW);<br />
  delay(50);<br />
  if (pcf8574_IN.digitalRead(3)) pcf8574_IN.digitalWrite(7, HIGH); else pcf8574_IN.digitalWrite(7, LOW);<br />
  delay(50);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9004" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 846 bytes / Downloads: 387)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9005" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 199.42 KB / Downloads: 473)
 *<br />
 *<br />
 */<br />
<br />
<br />
// I2C pins<br />
#define SDA 8<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
  delay(50);<br />
}<br />
<br />
void loop() {<br />
<br />
  delay(50);<br />
  delay(50);<br />
  delay(50);<br />
  delay(50);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8928</link>
			<pubDate>Wed, 14 Jan 2026 12:04:09 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8928</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9006" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 399)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9007" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 202.58 KB / Downloads: 425)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8929</link>
			<pubDate>Wed, 14 Jan 2026 12:02:55 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8929</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 15<br />
#define RXD_PIN 16<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9008" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 427)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8930</link>
			<pubDate>Wed, 14 Jan 2026 12:01:47 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8930</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9009" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 437)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9010" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 191.06 KB / Downloads: 455)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8931</link>
			<pubDate>Wed, 14 Jan 2026 12:00:42 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8931</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 */<br />
<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9011" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 464)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9012" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 193.65 KB / Downloads: 406)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8932</link>
			<pubDate>Wed, 14 Jan 2026 11:59:29 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8932</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9013" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 498)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9014" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 219.15 KB / Downloads: 394)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8933</link>
			<pubDate>Wed, 14 Jan 2026 11:58:03 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8933</guid>
 * ESP32 GPIO State Reader<br />
 * Reads the state of GPIO47, GPIO48, GPIO7, GPIO40, GPIO0, and GPIO5<br />
 * and prints the results to the serial monitor.<br />
 * <br />
 */<br />
<br />
#define GPIO_13  13<br />
#define GPIO_40  40<br />
#define GPIO_14  14<br />
#define GPIO_48  48<br />
#define GPIO_0 &nbsp;&nbsp;0<br />
#define GPIO_47  47<br />
#define GPIO_17  17<br />
#define GPIO_21  21<br />
<br />
<br />
    Serial.begin(115200); // Initialize serial communication at 115200 baud rate<br />
    <br />
    // Set GPIOs as input<br />
    pinMode(GPIO_13, INPUT);<br />
    pinMode(GPIO_40, INPUT);<br />
    pinMode(GPIO_14, INPUT);<br />
    pinMode(GPIO_48, INPUT);<br />
    pinMode(GPIO_0, INPUT);<br />
    pinMode(GPIO_47, INPUT);<br />
    pinMode(GPIO_17, INPUT);<br />
    pinMode(GPIO_21, INPUT);            <br />
}<br />
<br />
void loop() {<br />
    // Read GPIO states<br />
    int state_13 = digitalRead(GPIO_13);<br />
    int state_40 = digitalRead(GPIO_40);<br />
    int state_14  = digitalRead(GPIO_14);<br />
    int state_48 = digitalRead(GPIO_48);<br />
    int state_0  = digitalRead(GPIO_0);<br />
    int state_47 = digitalRead(GPIO_47);<br />
    int state_17 = digitalRead(GPIO_17);<br />
    int state_21 = digitalRead(GPIO_21);<br />
<br />
    // Print GPIO states to the serial monitor<br />
    Serial.printf("GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO0: %d, GPIO47: %d, GPIO17: %d, GPIO21: %d&#92;n",<br />
                  state_13, state_40, state_14, state_48, state_0, state_47, state_17, state_21);<br />
    <br />
    delay(1000); // Read GPIO states every second<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9015" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 685 bytes / Downloads: 460)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9016" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 184.01 KB / Downloads: 413)
 * <br />
 */<br />
<br />
<br />
<br />
    <br />
}<br />
<br />
void loop() {<br />
<br />
    <br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8934</link>
			<pubDate>Wed, 14 Jan 2026 11:55:13 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8934</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9017" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 428)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9018" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 190.13 KB / Downloads: 414)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8935</link>
			<pubDate>Wed, 14 Jan 2026 11:53:54 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8935</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18  <br />
<br />
<br />
void setup(void) <br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9019" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 421)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9020" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 192.69 KB / Downloads: 440)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B4M]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8936</link>
			<pubDate>Wed, 14 Jan 2026 11:52:37 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8936</guid>
 *<br />
 * Description:<br />
 * This Arduino program reads the state of a 16-channel PCF8574 I/O expander<br />
 * and prints the state of all input pins to the Serial Monitor. The state of <br />
 * each pin is represented as a bit in a 8-bit value, where each bit corresponds <br />
 * to an input pin. The program prints the input state in binary format.<br />
 *<br />
 * - SDA: GPIO 21<br />
 * - SCL: GPIO 22<br />
 */<br />
<br />
#include "Arduino.h"<br />
#include "PCF8574.h"<br />
<br />
// Define I2C pins<br />
<br />
// Set I2C address<br />
PCF8574 pcf8574_IN1(0x24); // The I2C address of the PCF8575<br />
<br />
<br />
<br />
    pcf8574_IN1.pinMode(P0, INPUT);<br />
    pcf8574_IN1.pinMode(P1, INPUT);<br />
    pcf8574_IN1.pinMode(P2, INPUT);<br />
    pcf8574_IN1.pinMode(P3, INPUT);<br />
<br />
    pcf8574_IN1.begin(); // Initialize the PCF8575<br />
<br />
    Serial.println("KinCony F4 4 channel input state 0:ON  1:OFF");<br />
}<br />
<br />
void loop() {<br />
    uint16_t state = 0;<br />
<br />
    // Read the state of each pin (assuming 16 pins)<br />
    for (int pin = 0; pin &lt; 4; pin++) {<br />
        if (pcf8574_IN1.digitalRead(pin)) {<br />
            state |= (1 &lt;&lt; pin); // Set the bit for the active pin<br />
        }<br />
    }<br />
<br />
    Serial.println(state, BIN); // Print the state of inputs in binary<br />
<br />
    delay(500); // Delay 500ms<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9021" target="_blank" title="">2-digital-input.zip</a> (Size: 879 bytes / Downloads: 439)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9022" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 199.52 KB / Downloads: 446)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
    }<br />
<br />
<br />
		</item>
	</channel>
</rss>
