	<channel>
		<title><![CDATA[Smart Home Automation Forum - DM4]]></title>
		<pubDate>Mon, 26 Oct 2026 12:55:41 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[DM4 ESPHome yaml for home assistant without tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8994</link>
			<pubDate>Tue, 03 Feb 2026 08:17:05 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8994</guid>
  friendly_name: dm4<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
<br />
ota:<br />
  platform: esphome<br />
<br />
web_server:<br />
  port: 80<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO1<br />
  mosi_pin: GPIO2<br />
  miso_pin: GPIO41<br />
  cs_pin: GPIO42<br />
  interrupt_pin: GPIO43<br />
  reset_pin: GPIO44<br />
<br />
i2c:<br />
 &nbsp;&nbsp;- id: bus_a<br />
   &nbsp;&nbsp;sda: 8<br />
   &nbsp;&nbsp;scl: 18<br />
   &nbsp;&nbsp;scan: true<br />
<br />
text_sensor:<br />
  - platform: ethernet_info<br />
    ip_address:<br />
      name: ESP IP Address<br />
      address_0:<br />
        name: ESP IP Address 0<br />
      address_1:<br />
        name: ESP IP Address 1<br />
      address_2:<br />
        name: ESP IP Address 2<br />
      address_3:<br />
        name: ESP IP Address 3<br />
      address_4:<br />
        name: ESP IP Address 4<br />
    dns_address:<br />
      name: ESP DNS Address<br />
    mac_address:<br />
      name: ESP MAC Address<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());<br />
uart:<br />
  - id: uart_1    #RS485<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 38<br />
    rx_pin: 39<br />
<br />
switch:<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
<br />
pcf8574:<br />
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: false<br />
<br />
binary_sensor:<br />
  - platform: gpio<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
      inverted: true<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 17<br />
    pin: <br />
      number: 13<br />
      inverted: false<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 0<br />
<br />
ads1115:<br />
  - address: 0x48<br />
sensor:<br />
  - platform: ads1115<br />
    multiplexer: 'A0_GND'<br />
    gain: 6.144<br />
    resolution: 16_BITS<br />
    update_interval: 5s<br />
    multiplexer: 'A1_GND'<br />
    gain: 6.144<br />
    multiplexer: 'A2_GND'<br />
    gain: 6.144<br />
    multiplexer: 'A3_GND'<br />
    gain: 6.144<br />
<br />
mcp4728:<br />
  - id: dac_output<br />
<br />
output:<br />
- platform: mcp4728<br />
  mcp4728_id: dac_output<br />
  channel: A<br />
  vref: internal<br />
<br />
  channel: B<br />
<br />
  channel: C<br />
<br />
  channel: D<br />
<br />
light:<br />
  - platform: monochromatic<br />
    name: "DM4 DAC-1"<br />
    output: ac_dimmer_1<br />
    gamma_correct: 1.0<br />
<br />
    name: "DM4 DAC-2"<br />
    output: ac_dimmer_2<br />
<br />
    name: "DM4 DAC-3"<br />
    output: ac_dimmer_3<br />
<br />
    name: "DM4 DAC-4"<br />
    output: ac_dimmer_4<br />
    gamma_correct: 1.0</code></div></div><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9118" target="_blank" title="">HA.png</a> (Size: 197.6 KB / Downloads: 492)
esphome yaml file download: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9119" target="_blank" title="">DM4-HA-without Tuya.txt</a> (Size: 4.4 KB / Downloads: 268)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ota:<br />
<br />
web_server:<br />
  port: 80<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
i2c:<br />
<br />
text_sensor:<br />
    ip_address:<br />
      address_0:<br />
      address_1:<br />
      address_2:<br />
      address_3:<br />
      address_4:<br />
    dns_address:<br />
    mac_address:<br />
<br />
font:<br />
<br />
display:<br />
    address: 0x3C<br />
    lambda: |-<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 38<br />
    rx_pin: 39<br />
<br />
switch:<br />
<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 17<br />
    pin: <br />
      number: 13<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 0<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
mcp4728:<br />
<br />
output:<br />
  channel: A<br />
<br />
  channel: B<br />
<br />
  channel: C<br />
<br />
  channel: D<br />
<br />
light:<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[DM4 ESP32-S3 IO pins define]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8993</link>
			<pubDate>Tue, 03 Feb 2026 08:15:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8993</guid>
			<description><![CDATA[SDA:GPIO8<br />
SCL:GPIO18<br />
<br />
PCF8574: (input1-4): i2c address:0x24<br />
<br />
P0:input1<br />
P1:input2<br />
P2:input3<br />
P3:input4<br />
<br />
ADS1115 (4CH ADC): i2c address:0x48<br />
Analog input (A1: DC 0-5v)<br />
Analog input (A2: DC 0-5v)<br />
Analog input (A3: DC 4-20mA)<br />
Analog input (A4: DC 4-20mA)<br />
<br />
24C02 EPROM i2c address: 0x50<br />
DS3231 RTC i2c address: 0x68<br />
<br />
MCP4728 DAC i2c address: 0x60<br />
<br />
1-wire (pull-up resistance on PCB): <br />
1-wire1:GPIO47<br />
1-wire2:GPIO48<br />
1-wire3:GPIO17<br />
1-wire4:GPIO40<br />
<br />
free GPIOs:<br />
GPIO13<br />
GPIO14<br />
GPIO21<br />
<br />
-----------------------<br />
Ethernet (W5500) I/O define:<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO38<br />
TXD:GPIO39<br />
<br />
Tuya module:<br />
RXD:GPIO15<br />
TXD:GPIO16<br />
<br />
Tuya network button: Tuya module's P28<br />
Tuya network LED: Tuya module's P16<br />
<br />
SD Card:<br />
SPI-MOSI:GPIO10<br />
SPI-SCK:GPIO11<br />
SPI-MISO:GPIO12<br />
SPI-CS:GPIO9<br />
SD-Detect: GPIO5]]></description>
			<content:encoded><![CDATA[SDA:GPIO8<br />
SCL:GPIO18<br />
<br />
<br />
P0:input1<br />
P1:input2<br />
P2:input3<br />
P3:input4<br />
<br />
<br />
<br />
<br />
<br />
free GPIOs:<br />
GPIO13<br />
GPIO14<br />
GPIO21<br />
<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO38<br />
TXD:GPIO39<br />
<br />
Tuya module:<br />
RXD:GPIO15<br />
TXD:GPIO16<br />
<br />
<br />
SD Card:<br />
SPI-CS:GPIO9<br />
SD-Detect: GPIO5]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8987</link>
			<pubDate>Tue, 03 Feb 2026 08:12:43 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8987</guid>
 *<br />
 * GPIO Status Monitoring<br />
 *<br />
 * This program monitors the status (high or low) of multiple GPIO pins on the ESP32-S3.<br />
 * It prints the status of the pins to the serial monitor whenever a change is detected.<br />
 *<br />
 * GPIO Pins Monitored:<br />
 * - GPIO 40<br />
 * - GPIO 7<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 13<br />
 * - GPIO 14<br />
 * - GPIO 21<br />
 * - GPIO 0<br />
 *<br />
 * Hardware Requirements:<br />
 * - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing<br />
 */<br />
<br />
#define GPIO_PIN_40 40<br />
#define GPIO_PIN_7 7<br />
#define GPIO_PIN_48 48<br />
#define GPIO_PIN_47 47<br />
#define GPIO_PIN_13 13<br />
#define GPIO_PIN_14 14<br />
#define GPIO_PIN_21 21<br />
#define GPIO_PIN_0 0<br />
<br />
// Store the previous state of the GPIO pins<br />
bool prevState[8] = {false, false, false, false, false, false, false, false};<br />
<br />
void setup() {<br />
  // Initialize serial communication for debugging purposes<br />
  Serial.begin(115200); // Initialize the serial monitor at 115200 baud<br />
  while (!Serial);      // Wait for the serial monitor to open<br />
<br />
  // Initialize GPIO pins as inputs<br />
  pinMode(GPIO_PIN_40, INPUT);<br />
  pinMode(GPIO_PIN_7, INPUT);<br />
  pinMode(GPIO_PIN_48, INPUT);<br />
  pinMode(GPIO_PIN_47, INPUT);<br />
  pinMode(GPIO_PIN_13, INPUT);<br />
  pinMode(GPIO_PIN_14, INPUT);<br />
  pinMode(GPIO_PIN_21, INPUT);<br />
  pinMode(GPIO_PIN_0, INPUT);<br />
<br />
  Serial.println("GPIO Status Monitoring Started");<br />
}<br />
<br />
void loop() {<br />
  // Read the current state of each GPIO pin<br />
  bool currentState[8];<br />
  currentState[0] = digitalRead(GPIO_PIN_40);<br />
  currentState[1] = digitalRead(GPIO_PIN_7);<br />
  currentState[2] = digitalRead(GPIO_PIN_48);<br />
  currentState[3] = digitalRead(GPIO_PIN_47);<br />
  currentState[4] = digitalRead(GPIO_PIN_13);<br />
  currentState[5] = digitalRead(GPIO_PIN_14);<br />
  currentState[6] = digitalRead(GPIO_PIN_21);<br />
  currentState[7] = digitalRead(GPIO_PIN_0);<br />
<br />
  // Check for changes in GPIO pin states<br />
    if (currentState[i] != prevState[i]) {<br />
      // Print the pin number and its new state if it has changed<br />
      Serial.print("GPIO ");<br />
      Serial.print(i == 0 ? GPIO_PIN_40 : <br />
                 &nbsp;&nbsp;i == 1 ? GPIO_PIN_7 : <br />
                 &nbsp;&nbsp;i == 2 ? GPIO_PIN_48 : <br />
                 &nbsp;&nbsp;i == 3 ? GPIO_PIN_47 : <br />
                 &nbsp;&nbsp;i == 4 ? GPIO_PIN_13 : <br />
                 &nbsp;&nbsp;i == 5 ? GPIO_PIN_14 : <br />
                 &nbsp;&nbsp;i == 6 ? GPIO_PIN_21 : GPIO_PIN_0);<br />
      Serial.print(" changed to ");<br />
      Serial.println(currentState[i] ? "HIGH" : "LOW");<br />
      // Update the previous state<br />
      prevState[i] = currentState[i];<br />
    }<br />
  }<br />
<br />
  // Delay to avoid flooding the serial monitor<br />
  delay(100); // Adjust the delay as needed<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9106" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 1.04 KB / Downloads: 429)
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9107" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 179.57 KB / Downloads: 417)
 *<br />
 *<br />
 *<br />
 * - GPIO 40<br />
 * - GPIO 7<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 13<br />
 * - GPIO 14<br />
 * - GPIO 21<br />
 * - GPIO 0<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
    }<br />
  }<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8984</link>
			<pubDate>Tue, 03 Feb 2026 08:09:41 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8984</guid>
 KeyPressed on PIN1<br />
 by Mischianti Renzo &lt;http://www.mischianti.org&gt;<br />
<br />
 https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/<br />
*/<br />
<br />
#include "Arduino.h"<br />
#include "PCF8574.h"<br />
<br />
// Define I2C pins<br />
#define I2C_SDA 8 &nbsp;&nbsp;// SDA pin<br />
#define I2C_SCL 18  // SCL pin<br />
<br />
// Set i2c address<br />
PCF8574 pcf8574(0x24);<br />
unsigned long timeElapsed;<br />
void setup()<br />
{<br />
&nbsp;&nbsp;&nbsp;&nbsp;Wire.begin(I2C_SDA, I2C_SCL);<br />
    Serial.begin(115200);<br />
&nbsp;&nbsp;&nbsp;&nbsp;delay(1000);<br />
<br />
//&nbsp;&nbsp;&nbsp;&nbsp;pcf8574.pinMode(P0, OUTPUT);<br />
 pcf8574.pinMode(P0, INPUT);<br />
 pcf8574.pinMode(P1, INPUT);<br />
 pcf8574.pinMode(P2, INPUT);<br />
 pcf8574.pinMode(P3, INPUT);<br />
<br />
<br />
&nbsp;&nbsp;&nbsp;&nbsp;Serial.print("Init pcf8574...");<br />
&nbsp;&nbsp;&nbsp;&nbsp;if (pcf8574.begin()){<br />
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Serial.println("OK");<br />
&nbsp;&nbsp;&nbsp;&nbsp;}else{<br />
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Serial.println("KO");<br />
&nbsp;&nbsp;&nbsp;&nbsp;}<br />
}<br />
<br />
void loop()<br />
{<br />
 uint8_t val1 = pcf8574.digitalRead(P0);<br />
 uint8_t val2 = pcf8574.digitalRead(P1);<br />
 uint8_t val3 = pcf8574.digitalRead(P2);<br />
 uint8_t val4 = pcf8574.digitalRead(P3);<br />
<br />
 if (val1==LOW) Serial.println("KEY1 PRESSED");<br />
 if (val2==LOW) Serial.println("KEY2 PRESSED");<br />
 if (val3==LOW) Serial.println("KEY3 PRESSED");<br />
 if (val4==LOW) Serial.println("KEY4 PRESSED");<br />
<br />
&nbsp;&nbsp;&nbsp;&nbsp;delay(300);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9100" target="_blank" title="">2-digital-input.zip</a> (Size: 667 bytes / Downloads: 384)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9101" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 199.38 KB / Downloads: 393)
<br />
*/<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-01 4 Channel DAC output by digital input buttons]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8983</link>
			<pubDate>Tue, 03 Feb 2026 08:08:20 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8983</guid>
			<description><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>// Basic demo for configuring the MCP4728 4-Channel 12-bit I2C DAC<br />
#include &lt;Adafruit_MCP4728.h&gt;<br />
#include &lt;Wire.h&gt;<br />
<br />
Adafruit_MCP4728 mcp;<br />
<br />
TwoWire MYI2C = TwoWire(0);<br />
void setup(void) <br />
{<br />
  <br />
<br />
  while (!Serial)<br />
    delay(10); // will pause Zero, Leonardo, etc until serial console opens<br />
<br />
<br />
  Serial.println("Adafruit MCP4728 test!");<br />
<br />
  MYI2C.begin(I2C_SDA, I2C_SCL,100000);<br />
<br />
  // Try to initialize!<br />
  if (!mcp.begin(MCP4728_I2CADDR_DEFAULT,&amp;MYI2C)) {<br />
    Serial.println("Failed to find MCP4728 chip");<br />
    while (1) {<br />
      delay(10);<br />
    }<br />
  }<br />
<br />
  mcp.setChannelValue(MCP4728_CHANNEL_A, 4095);<br />
  mcp.setChannelValue(MCP4728_CHANNEL_B, 2048);<br />
  mcp.setChannelValue(MCP4728_CHANNEL_C, 1024);<br />
  mcp.setChannelValue(MCP4728_CHANNEL_D, 0);<br />
}<br />
<br />
void loop() { delay(1000); }</code></div></div> arduino ino file download: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9097" target="_blank" title="">1-dac-4ch.zip</a> (Size: 596 bytes / Downloads: 377)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9098" target="_blank" title="">1-dac-4ch.ino.merged.zip</a> (Size: 198.77 KB / Downloads: 390)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9099" target="_blank" title="">MCP4728.png</a> (Size: 123.11 KB / Downloads: 335)
			<content:encoded><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>// Basic demo for configuring the MCP4728 4-Channel 12-bit I2C DAC<br />
<br />
<br />
{<br />
  <br />
<br />
<br />
<br />
<br />
<br />
    while (1) {<br />
      delay(10);<br />
    }<br />
  }<br />
<br />
}<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8991</link>
			<pubDate>Tue, 09 Sep 2025 11:36:21 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8991</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
// Initialize the display using the software I2C method (SCL = IO39, SDA = IO38)<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9114" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.12 KB / Downloads: 641)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9115" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 201.24 KB / Downloads: 635)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8990</link>
			<pubDate>Tue, 09 Sep 2025 11:34:19 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8990</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 16<br />
#define RXD_PIN 17<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9112" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 631)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9113" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 184.93 KB / Downloads: 656)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8992</link>
			<pubDate>Tue, 09 Sep 2025 11:32:40 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8992</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO1<br />
 * - MOSI: GPIO2<br />
 * - MISO: GPIO41<br />
 * - CS: GPIO42<br />
 * - RST: GPIO44<br />
 * - INT: GPIO43<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9116" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 644)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9117" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 188.93 KB / Downloads: 643)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8989</link>
			<pubDate>Tue, 09 Sep 2025 11:31:29 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8989</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9110" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 604)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9111" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 191.08 KB / Downloads: 606)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8988</link>
			<pubDate>Tue, 09 Sep 2025 11:01:40 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8988</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9108" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 618)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9109" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 221.25 KB / Downloads: 647)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8985</link>
			<pubDate>Tue, 09 Sep 2025 10:59:21 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8985</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B16!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9102" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 579)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9103" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 184.34 KB / Downloads: 654)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM4]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8986</link>
			<pubDate>Tue, 09 Sep 2025 10:53:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8986</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18 <br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9104" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 578)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9105" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 190.05 KB / Downloads: 651)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
	</channel>
</rss>
