	<channel>
		<title><![CDATA[Smart Home Automation Forum - DM32]]></title>
		<pubDate>Sat, 31 Oct 2026 12:13:52 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[DM32 ESPHome yaml for home assistant without tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9128</link>
			<pubDate>Tue, 17 Mar 2026 08:50:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9128</guid>
  friendly_name: dm32<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO1<br />
  mosi_pin: GPIO2<br />
  miso_pin: GPIO41<br />
  cs_pin: GPIO42<br />
  interrupt_pin: GPIO43<br />
  reset_pin: GPIO44<br />
<br />
uart:<br />
  - id: uart_1 # RS485<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 39<br />
    rx_pin: 38<br />
<br />
  - id: dac_uart<br />
    rx_pin: 4<br />
    tx_pin: 6<br />
    baud_rate: 115200<br />
    stop_bits: 1<br />
    data_bits: 8<br />
    parity: NONE<br />
    debug:<br />
<br />
modbus:<br />
  uart_id: dac_uart<br />
<br />
modbus_controller:<br />
  - address: 1<br />
    update_interval: 5s<br />
<br />
i2c:<br />
  - id: bus_a<br />
    sda: 8<br />
    scl: 18<br />
    scan: true<br />
    frequency: 400kHz<br />
<br />
text_sensor:<br />
  - platform: ethernet_info<br />
    ip_address:<br />
      name: ESP IP Address<br />
      address_0:<br />
        name: ESP IP Address 0<br />
      address_1:<br />
        name: ESP IP Address 1<br />
      address_2:<br />
        name: ESP IP Address 2<br />
      address_3:<br />
        name: ESP IP Address 3<br />
      address_4:<br />
        name: ESP IP Address 4<br />
    dns_address:<br />
      name: ESP DNS Address<br />
    mac_address:<br />
      name: ESP MAC Address<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());<br />
<br />
output:<br />
  # CH1 (0x0FA0 / 4000)<br />
  - platform: modbus_controller<br />
    address: 0x0FA0<br />
    value_type: U_WORD<br />
    write_lambda: |-<br />
      // state = 0.0 ~ 1.0 → 0 ~ 4095<br />
      uint16_t reg = (uint16_t) round(x * 4095.0);<br />
      return reg;<br />
<br />
  # CH2 (0x0FA1 / 4001)<br />
    address: 0x0FA1<br />
      return reg;<br />
<br />
  # CH3<br />
    address: 0x0FA2<br />
      return reg;<br />
<br />
  # CH4<br />
    address: 0x0FA3<br />
      return reg;<br />
<br />
  # CH5<br />
    address: 0x0FA4<br />
      return reg;<br />
<br />
  # CH6<br />
    address: 0x0FA5<br />
      return reg;<br />
<br />
  # CH7<br />
    address: 0x0FA6<br />
      return reg;<br />
<br />
  # CH8<br />
    address: 0x0FA7<br />
      return reg;<br />
<br />
  # CH9<br />
    address: 0x0FA8<br />
      return reg;<br />
<br />
  # CH10<br />
    address: 0x0FA9<br />
      return reg;<br />
<br />
  # CH11<br />
    address: 0x0FAA<br />
      return reg;<br />
<br />
  # CH12<br />
    address: 0x0FAB<br />
      return reg;<br />
<br />
  # CH13<br />
    address: 0x0FAC<br />
      return reg;<br />
<br />
  # CH14<br />
    address: 0x0FAD<br />
      return reg;<br />
<br />
  # CH15<br />
    address: 0x0FAE<br />
      return reg;<br />
<br />
  # CH16<br />
    address: 0x0FAF<br />
      return reg;<br />
<br />
  # CH17 (0x0FB0 / 4016)<br />
    address: 0x0FB0<br />
      return reg;<br />
<br />
  # CH18<br />
    address: 0x0FB1<br />
      return reg;<br />
<br />
  # CH19<br />
    address: 0x0FB2<br />
      return reg;<br />
<br />
  # CH20<br />
    address: 0x0FB3<br />
      return reg;<br />
<br />
  # CH21<br />
    address: 0x0FB4<br />
      return reg;<br />
<br />
  # CH22<br />
    address: 0x0FB5<br />
      return reg;<br />
<br />
  # CH23<br />
    address: 0x0FB6<br />
      return reg;<br />
<br />
  # CH24<br />
    address: 0x0FB7<br />
      return reg;<br />
<br />
  # CH25<br />
    address: 0x0FB8<br />
      return reg;<br />
<br />
  # CH26<br />
    address: 0x0FB9<br />
      return reg;<br />
<br />
  # CH27<br />
    address: 0x0FBA<br />
      return reg;<br />
<br />
  # CH28<br />
    address: 0x0FBB<br />
      return reg;<br />
<br />
  # CH29<br />
    address: 0x0FBC<br />
      return reg;<br />
<br />
  # CH30<br />
    address: 0x0FBD<br />
      return reg;<br />
<br />
  # CH31<br />
    address: 0x0FBE<br />
      return reg;<br />
<br />
  # CH32 (0x0FBF / 4031)<br />
    address: 0x0FBF<br />
      return reg;<br />
<br />
light:<br />
  - platform: monochromatic<br />
    name: "DAC CH1"<br />
    output: dac_ch1_out<br />
    default_transition_length: 0s<br />
<br />
    name: "DAC CH2"<br />
    output: dac_ch2_out<br />
<br />
    name: "DAC CH3"<br />
    output: dac_ch3_out<br />
<br />
    name: "DAC CH4"<br />
    output: dac_ch4_out<br />
<br />
    name: "DAC CH5"<br />
    output: dac_ch5_out<br />
<br />
    name: "DAC CH6"<br />
    output: dac_ch6_out<br />
<br />
    name: "DAC CH7"<br />
    output: dac_ch7_out<br />
<br />
    name: "DAC CH8"<br />
    output: dac_ch8_out<br />
<br />
    name: "DAC CH9"<br />
    output: dac_ch9_out<br />
<br />
    name: "DAC CH10"<br />
    output: dac_ch10_out<br />
<br />
    name: "DAC CH11"<br />
    output: dac_ch11_out<br />
<br />
    name: "DAC CH12"<br />
    output: dac_ch12_out<br />
<br />
    name: "DAC CH13"<br />
    output: dac_ch13_out<br />
<br />
    name: "DAC CH14"<br />
    output: dac_ch14_out<br />
<br />
    name: "DAC CH15"<br />
    output: dac_ch15_out<br />
<br />
    name: "DAC CH16"<br />
    output: dac_ch16_out<br />
<br />
    name: "DAC CH17"<br />
    output: dac_ch17_out<br />
<br />
    name: "DAC CH18"<br />
    output: dac_ch18_out<br />
<br />
    name: "DAC CH19"<br />
    output: dac_ch19_out<br />
<br />
    name: "DAC CH20"<br />
    output: dac_ch20_out<br />
<br />
    name: "DAC CH21"<br />
    output: dac_ch21_out<br />
<br />
    name: "DAC CH22"<br />
    output: dac_ch22_out<br />
<br />
    name: "DAC CH23"<br />
    output: dac_ch23_out<br />
<br />
    name: "DAC CH24"<br />
    output: dac_ch24_out<br />
<br />
    name: "DAC CH25"<br />
    output: dac_ch25_out<br />
<br />
    name: "DAC CH26"<br />
    output: dac_ch26_out<br />
<br />
    name: "DAC CH27"<br />
    output: dac_ch27_out<br />
<br />
    name: "DAC CH28"<br />
    output: dac_ch28_out<br />
<br />
    name: "DAC CH29"<br />
    output: dac_ch29_out<br />
<br />
    name: "DAC CH30"<br />
    output: dac_ch30_out<br />
<br />
    name: "DAC CH31"<br />
    output: dac_ch31_out<br />
<br />
    name: "DAC CH32"<br />
    output: dac_ch32_out<br />
<br />
pcf8574:<br />
  - id: pcf8574_hub_1 # for input channel 1-16<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
  - id: pcf8574_hub_2 # for input channel 17-32<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
switch:<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
binary_sensor:<br />
  - platform: gpio<br />
    pin:<br />
      pcf8574: pcf8574_hub_1<br />
      number: 8<br />
      mode: INPUT<br />
      inverted: true<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      pcf8574: pcf8574_hub_2<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
  ## pull-up resistance on PCB<br />
    pin:<br />
      number: 47<br />
<br />
    pin:<br />
      number: 48<br />
<br />
    pin:<br />
      number: 7<br />
<br />
    pin:<br />
      number: 40<br />
<br />
    pin:<br />
      number: 13<br />
      inverted: false<br />
<br />
    pin:<br />
      number: 14<br />
<br />
    pin:<br />
      number: 21<br />
<br />
ads1115:<br />
  - address: 0x48<br />
<br />
sensor:<br />
  - platform: ads1115<br />
    multiplexer: 'A0_GND'<br />
    gain: 6.144<br />
    resolution: 16_BITS<br />
<br />
    multiplexer: 'A1_GND'<br />
    gain: 6.144<br />
<br />
    multiplexer: 'A2_GND'<br />
    gain: 6.144<br />
<br />
    multiplexer: 'A3_GND'<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80</code></div></div> esphome yaml file download: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9360" target="_blank" title="">esphome_dm32.txt</a> (Size: 17.6 KB / Downloads: 316)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 39<br />
    rx_pin: 38<br />
<br />
    rx_pin: 4<br />
    tx_pin: 6<br />
    stop_bits: 1<br />
    data_bits: 8<br />
    parity: NONE<br />
    debug:<br />
<br />
modbus:<br />
<br />
  - address: 1<br />
<br />
i2c:<br />
  - id: bus_a<br />
    sda: 8<br />
    scl: 18<br />
    scan: true<br />
<br />
text_sensor:<br />
    ip_address:<br />
      address_0:<br />
      address_1:<br />
      address_2:<br />
      address_3:<br />
      address_4:<br />
    dns_address:<br />
    mac_address:<br />
<br />
font:<br />
<br />
display:<br />
    address: 0x3C<br />
    lambda: |-<br />
<br />
output:<br />
      return reg;<br />
<br />
      return reg;<br />
<br />
  # CH3<br />
      return reg;<br />
<br />
  # CH4<br />
      return reg;<br />
<br />
  # CH5<br />
      return reg;<br />
<br />
  # CH6<br />
      return reg;<br />
<br />
  # CH7<br />
      return reg;<br />
<br />
  # CH8<br />
      return reg;<br />
<br />
  # CH9<br />
      return reg;<br />
<br />
  # CH10<br />
      return reg;<br />
<br />
  # CH11<br />
      return reg;<br />
<br />
  # CH12<br />
      return reg;<br />
<br />
  # CH13<br />
      return reg;<br />
<br />
  # CH14<br />
      return reg;<br />
<br />
  # CH15<br />
      return reg;<br />
<br />
  # CH16<br />
      return reg;<br />
<br />
      return reg;<br />
<br />
  # CH18<br />
      return reg;<br />
<br />
  # CH19<br />
      return reg;<br />
<br />
  # CH20<br />
      return reg;<br />
<br />
  # CH21<br />
      return reg;<br />
<br />
  # CH22<br />
      return reg;<br />
<br />
  # CH23<br />
      return reg;<br />
<br />
  # CH24<br />
      return reg;<br />
<br />
  # CH25<br />
      return reg;<br />
<br />
  # CH26<br />
      return reg;<br />
<br />
  # CH27<br />
      return reg;<br />
<br />
  # CH28<br />
      return reg;<br />
<br />
  # CH29<br />
      return reg;<br />
<br />
  # CH30<br />
      return reg;<br />
<br />
  # CH31<br />
      return reg;<br />
<br />
      return reg;<br />
<br />
light:<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
switch:<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 47<br />
<br />
    pin:<br />
      number: 48<br />
<br />
    pin:<br />
      number: 7<br />
<br />
    pin:<br />
      number: 40<br />
<br />
    pin:<br />
      number: 13<br />
<br />
    pin:<br />
      number: 14<br />
<br />
    pin:<br />
      number: 21<br />
<br />
ads1115:<br />
<br />
sensor:<br />
    gain: 6.144<br />
<br />
    gain: 6.144<br />
<br />
    gain: 6.144<br />
<br />
    gain: 6.144<br />
<br />
web_server:<br />
		</item>
		<item>
			<title><![CDATA[DM32 ESP32-S3 IO pins define]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9019</link>
			<pubDate>Tue, 03 Feb 2026 08:35:00 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9019</guid>
			<description><![CDATA[SDA:GPIO8<br />
SCL:GPIO18<br />
<br />
PCF8575: (input1-16): i2c address:0x22 by B16-core<br />
<br />
P8:input1<br />
P9:input2<br />
P10:input3<br />
P11:input4<br />
P12:input5<br />
P13:input6<br />
P14:input7<br />
P15:input8<br />
<br />
P0:input9<br />
P1:input10<br />
P2:input11<br />
P3:input12<br />
P4:input13<br />
P5:input14<br />
P6:input15<br />
P7:input16<br />
<br />
PCF8575: (input17-32): i2c address:0x24<br />
<br />
P0:input17<br />
P1:input18<br />
P2:input19<br />
P3:input20<br />
P4:input21<br />
P5:input22<br />
P6:input23<br />
P7:input24<br />
<br />
P8:input25<br />
P9:input26<br />
P10:input27<br />
P11:input28<br />
P12:input29<br />
P13:input30<br />
P14:input31<br />
P15:input32<br />
<br />
ADS1115 (4CH ADC): i2c address:0x48<br />
Analog input (A1: DC 0-5v)<br />
Analog input (A2: DC 0-5v)<br />
Analog input (A3: DC 4-20mA)<br />
Analog input (A4: DC 4-20mA)<br />
<br />
24C02 EPROM i2c address: 0x50<br />
DS3231 RTC i2c address: 0x68<br />
<br />
1-wire (pull-up resistance on PCB): <br />
1-wire1:GPIO47<br />
1-wire2:GPIO48<br />
1-wire3:GPIO7<br />
1-wire4:GPIO40<br />
<br />
free GPIOs:<br />
GPIO13<br />
GPIO14<br />
GPIO21<br />
<br />
-----------------------<br />
Ethernet (W5500) I/O define:<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO38<br />
TXD:GPIO39<br />
<br />
Tuya module:<br />
RXD:GPIO17<br />
TXD:GPIO16<br />
<br />
Tuya network button: Tuya module's P28<br />
Tuya network LED: Tuya module's P16<br />
<br />
ARM CPU TXD:GPIO4<br />
ARM CPU RXD:GPIO6<br />
<br />
<br />
SD Card:<br />
SPI-MOSI:GPIO10<br />
SPI-SCK:GPIO11<br />
SPI-MISO:GPIO12<br />
SPI-CS:GPIO9<br />
SD-Detect: GPIO5]]></description>
			<content:encoded><![CDATA[SDA:GPIO8<br />
SCL:GPIO18<br />
<br />
<br />
P8:input1<br />
P9:input2<br />
P10:input3<br />
P11:input4<br />
P12:input5<br />
P13:input6<br />
P14:input7<br />
P15:input8<br />
<br />
P0:input9<br />
P1:input10<br />
P2:input11<br />
P3:input12<br />
P4:input13<br />
P5:input14<br />
P6:input15<br />
P7:input16<br />
<br />
<br />
P0:input17<br />
P1:input18<br />
P2:input19<br />
P3:input20<br />
P4:input21<br />
P5:input22<br />
P6:input23<br />
P7:input24<br />
<br />
P8:input25<br />
P9:input26<br />
P10:input27<br />
P11:input28<br />
P12:input29<br />
P13:input30<br />
P14:input31<br />
P15:input32<br />
<br />
<br />
<br />
1-wire3:GPIO7<br />
<br />
free GPIOs:<br />
GPIO13<br />
GPIO14<br />
GPIO21<br />
<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO38<br />
TXD:GPIO39<br />
<br />
Tuya module:<br />
RXD:GPIO17<br />
TXD:GPIO16<br />
<br />
<br />
<br />
<br />
SD Card:<br />
SPI-CS:GPIO9<br />
SD-Detect: GPIO5]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9010</link>
			<pubDate>Tue, 03 Feb 2026 08:31:57 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9010</guid>
			<description><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>#include &lt;Wire.h&gt;<br />
#include "PCF8575.h"<br />
<br />
#define I2C_SDA 8<br />
#define I2C_SCL 18<br />
<br />
PCF8575 pcf8575_IN1(0x22); // DI1–DI16<br />
PCF8575 pcf8575_IN2(0x24); // DI17–DI32<br />
<br />
uint8_t pin_order_dm16[16] = {<br />
    8, 9, 10, 11, 12, 13, 14, 15,<br />
    0, 1, 2, 3, 4, 5, 6, 7<br />
};<br />
<br />
uint8_t pin_order_ext[16] = {<br />
    0, 1, 2, 3, 4, 5, 6, 7,<br />
    8, 9, 10, 11, 12, 13, 14, 15<br />
};<br />
<br />
void setup() {<br />
    Serial.begin(115200);<br />
    Wire.begin(I2C_SDA, I2C_SCL);<br />
<br />
    pcf8575_IN1.begin();<br />
    pcf8575_IN2.begin();<br />
<br />
    Serial.println("DI1–DI32 (0=ON 1=OFF)");<br />
}<br />
<br />
void loop() {<br />
    Serial.print("DI1–DI32: ");<br />
<br />
    // DI1–DI16<br />
    for (int i = 0; i &lt; 16; i++) {<br />
        Serial.print(pcf8575_IN1.read(pin_order_dm16[i]));<br />
        Serial.print(" ");<br />
    }<br />
<br />
    // DI17–DI32<br />
        Serial.print(pcf8575_IN2.read(pin_order_ext[i]));<br />
    }<br />
<br />
    Serial.println();<br />
    delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9148" target="_blank" title="">2-digital-input.zip</a> (Size: 547 bytes / Downloads: 440)
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9149" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 197.89 KB / Downloads: 418)
			<content:encoded><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>#include &lt;Wire.h&gt;<br />
<br />
<br />
<br />
};<br />
<br />
};<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
    // DI1–DI16<br />
    }<br />
<br />
    // DI17–DI32<br />
    }<br />
<br />
    delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-01 32 Channel DAC output by digital input buttons]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9009</link>
			<pubDate>Tue, 03 Feb 2026 08:30:43 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9009</guid>
			<description><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>#include &lt;Adafruit_PCF8575.h&gt;<br />
<br />
// Define Modbus RTU frame format constants<br />
#define MODBUS_READ_COILS 0x01<br />
#define MODBUS_READ_REGISTERS 0x03<br />
#define MODBUS_WRITE_SINGLE_REGISTER 0x06<br />
#define MODBUS_WRITE_MULTIPLE_REGISTERS 0x10<br />
<br />
/* Example for 16 input buttons that are connected from the GPIO expander pins to ground.<br />
 * Note the buttons must be connected with the other side of the switch to GROUND. There is<br />
 * a built in pull-up 'resistor' on each input, but no pull-down resistor capability.<br />
 */<br />
<br />
#define DM_NUMS 32 // change for 16, 32 for KinCony DM16, DM32 Smart Dimmer Controller<br />
<br />
<br />
#define SDA_PIN 8<br />
#define SCL_PIN 18<br />
#define ADDRESS_PCF8575   &nbsp;&nbsp;0x22<br />
#define ADDRESS_PCF8575_2 &nbsp;&nbsp;0x24<br />
<br />
#define ST_RX &nbsp;&nbsp;4 ////ESP32_RCV<br />
#define ST_TX &nbsp;&nbsp;6 ///ESP32_SEND<br />
typedef enum{KEY_RELEASE=0,KEY_SHORT_PRESSED,KEY_LONG_PRESSED}KEY_STATUS;<br />
<br />
typedef struct{<br />
  uint8_t key_index;<br />
  KEY_STATUS key_status;<br />
  long key_time_start;<br />
  long key_time_rec;<br />
  long key_press_time;<br />
  int16_t key_press_cnt; ////Send serial data once every 100 ms<br />
  int16_t key_press_cnt_old;<br />
  float current_light; ///Percentage of 0–4095<br />
}KEY_PRESS_PROP;<br />
<br />
KEY_PRESS_PROP key_press_prop[32] = {0};<br />
<br />
<br />
Adafruit_PCF8575 pcf,pcf2;<br />
HardwareSerial myst_serial(1);<br />
<br />
TwoWire myI2c = TwoWire(0);<br />
ushort dm_num = DM_NUMS;<br />
<br />
// Modbus CRC16 Calculation function<br />
uint16_t modbus_crc16(uint8_t *data, uint16_t length) {<br />
  uint16_t crc = 0xFFFF;<br />
  <br />
  for (uint16_t i = 0; i &lt; length; i++) {<br />
    crc ^= data[i];<br />
    for (uint8_t j = 0; j &lt; 8; j++) {<br />
      if (crc &amp; 0x0001) {<br />
        crc = (crc &gt;&gt; 1) ^ 0xA001;<br />
      } else {<br />
        crc = crc &gt;&gt; 1;<br />
      }<br />
    }<br />
  }<br />
  return crc;<br />
}<br />
<br />
/**<br />
 * Send a Modbus RTU frame<br />
 * <br />
 * @param serial HardwareSerial object<br />
 * @param address Slave address (1-247)<br />
 * @param function function code<br />
 * @param data <br />
 * @param dataLen<br />
 */<br />
void send_modbus_frame(HardwareSerial &amp;serial, uint8_t address, uint8_t function, <br />
                      const uint8_t *data, uint16_t dataLen) {<br />
  // Create a transmit buffer<br />
  uint16_t totalLen = 1 + 1 + dataLen + 2; // address + function code + data + CRC<br />
  uint8_t buffer[totalLen];<br />
  <br />
  buffer[0] = address;<br />
  buffer[1] = function;<br />
  <br />
  memcpy(&amp;buffer[2], data, dataLen);<br />
  <br />
  uint16_t crc = modbus_crc16(buffer, 2 + dataLen);<br />
  <br />
  // Add CRC (low byte first)<br />
  buffer[2 + dataLen] = crc &amp; 0xFF;      // CRC low byte<br />
  buffer[3 + dataLen] = (crc &gt;&gt; 8) &amp; 0xFF; // CRC high byte<br />
  <br />
  // Send the complete frame<br />
  for (uint16_t i = 0; i &lt; totalLen; i++) {<br />
    serial.write(buffer[i]);<br />
  }<br />
  <br />
  // Flush the transmit buffer to ensure all data is sent<br />
  serial.flush();<br />
}<br />
<br />
// Encapsulate commonly used Modbus functions<br />
<br />
/**<br />
 * Send a Read Holding Registers request<br />
 * <br />
 * @param serial <br />
 * @param address <br />
 * @param startReg <br />
 * @param numRegs<br />
 */<br />
void modbus_read_registers(HardwareSerial &amp;serial, uint8_t address, <br />
                          uint16_t startReg, uint16_t numRegs) {<br />
  uint8_t data[4];<br />
  <br />
  <br />
  data[0] = (startReg &gt;&gt; 8) &amp; 0xFF; // High byte of the register address<br />
  data[1] = startReg &amp; 0xFF;        // Low byte of the register address<br />
  data[2] = (numRegs &gt;&gt; 8) &amp; 0xFF;  // High byte of the register count<br />
  data[3] = numRegs &amp; 0xFF;       &nbsp;&nbsp;// Low byte of the register count<br />
  <br />
  send_modbus_frame(serial, address, MODBUS_READ_REGISTERS, data, sizeof(data));<br />
}<br />
<br />
/**<br />
 * <br />
 * @param regAddress <br />
 * @param value<br />
 */<br />
void modbus_write_single_register(HardwareSerial &amp;serial, uint8_t address,<br />
                                uint16_t regAddress, uint16_t value) {<br />
  <br />
  data[0] = (regAddress &gt;&gt; 8) &amp; 0xFF; // High byte of the register address<br />
  data[1] = regAddress &amp; 0xFF;        // Low byte of the register address<br />
  data[2] = (value &gt;&gt; 8) &amp; 0xFF;      // High byte of the data<br />
  data[3] = value &amp; 0xFF;           &nbsp;&nbsp;// Low byte of the<br />
  <br />
  send_modbus_frame(serial, address, MODBUS_WRITE_SINGLE_REGISTER, data, sizeof(data));<br />
}<br />
<br />
/**<br />
 * <br />
 * @param values <br />
 * @param numRegs <br />
 */<br />
void modbus_write_multiple_registers(HardwareSerial &amp;serial, uint8_t address,<br />
                                 &nbsp;&nbsp;uint16_t startReg, const uint16_t *values,<br />
                                 &nbsp;&nbsp;uint16_t numRegs) {<br />
<br />
  uint8_t byteCount = numRegs * 2;<br />
  uint8_t data[5 + byteCount];<br />
  <br />
<br />
  data[0] = (startReg &gt;&gt; 8) &amp; 0xFF;  <br />
  data[1] = startReg &amp; 0xFF;       &nbsp;&nbsp;<br />
  data[2] = (numRegs &gt;&gt; 8) &amp; 0xFF; &nbsp;&nbsp;<br />
  data[3] = numRegs &amp; 0xFF;     &nbsp;&nbsp;<br />
  data[4] = byteCount;              <br />
  <br />
<br />
  for (uint8_t i = 0; i &lt; numRegs; i++) {<br />
    data[5 + i*2] = (values[i] &gt;&gt; 8) &amp; 0xFF; &nbsp;&nbsp;<br />
    data[6 + i*2] = values[i] &amp; 0xFF;          <br />
  }<br />
  <br />
  send_modbus_frame(serial, address, MODBUS_WRITE_MULTIPLE_REGISTERS, data, sizeof(data));<br />
}<br />
<br />
  myI2c.begin(SDA_PIN,SCL_PIN,100000);<br />
  myst_serial.begin(115200,SERIAL_8N1,ST_RX,ST_TX);///RXPIN FIRST<br />
<br />
  while (!Serial) { delay(10); }<br />
  Serial.println("Adafruit PCF8575 button read test");<br />
<br />
  if (!pcf.begin(ADDRESS_PCF8575, &amp;myI2c)) {<br />
    Serial.println("err:DMxx Couldn't find 1_PCF8575!");<br />
    while (1);<br />
  }<br />
  else Serial.println("Find 1_PCF8575!");<br />
<br />
  if(dm_num==32)<br />
  {<br />
    if (!pcf2.begin(ADDRESS_PCF8575_2, &amp;myI2c)) {<br />
    Serial.println("DM32 Couldn't find 2_PCF8575"); <br />
    }<br />
    else Serial.println("Find 2_PCF8575!");<br />
  }<br />
 &nbsp;&nbsp;<br />
<br />
  for (uint8_t p=0; p&lt;DM_NUMS; p++) {<br />
    pcf.pinMode(p, INPUT_PULLUP);<br />
    if(dm_num==32) pcf2.pinMode(p-16, INPUT_PULLUP);<br />
    <br />
    key_press_prop[p].key_index = p+1;<br />
    key_press_prop[p].key_status = KEY_RELEASE;<br />
    key_press_prop[p].key_press_time = 0;<br />
  }<br />
<br />
  Serial.println("Now, starting!"); <br />
<br />
<br />
}<br />
<br />
<br />
<br />
static uint16_t input_value_old[2] = {0xffff,0xffff};<br />
uint16_t input_value[2] = {0} ;<br />
int8_t current_operator_key = -1;<br />
int8_t key_index = -1,key_index_last = -1;<br />
int16_t key_press_cnt_old = 0;<br />
uint16_t write_value=0;<br />
<br />
static int8_t get_key_press(int8_t chip,uint16_t key_value)<br />
{<br />
  if(key_value == 0xffff || key_value == 0) return -1;<br />
<br />
  for(int16_t i=0;i&lt;16;i++) <br />
  {<br />
    if((key_value &amp; (1&lt;&lt;i) ) == 0)  return (chip==0)?i:i+16; <br />
  }<br />
}<br />
<br />
static uint16_t getKeycode()<br />
{<br />
  uint16_t input_value = 0,tmp_value;<br />
  uint8_t h_value = 0 ,l_value = 0;<br />
  tmp_value = pcf.digitalReadWord();<br />
  h_value = tmp_value&gt;&gt;8;<br />
  l_value = tmp_value&amp;0xff;<br />
  input_value = (l_value&lt;&lt;8 ) | h_value;<br />
<br />
  return input_value;<br />
}<br />
<br />
static uint16_t getKeycode2()<br />
{<br />
  tmp_value = pcf2.digitalReadWord();<br />
  input_value = (l_value ) | (h_value&lt;&lt;8);<br />
<br />
}<br />
<br />
static void checkKeyPress(int8_t chip);<br />
<br />
static uint16_t key_old_arr[2] = {0};<br />
<br />
void loop() { <br />
<br />
  input_value[0] = getKeycode(); <br />
  /*if(key_old_arr[0] != input_value[0] )<br />
  {<br />
    key_old_arr[0] = input_value[0];<br />
    Serial.printf("input0:%d&#92;r&#92;n",input_value[0]);<br />
  }*/<br />
  <br />
  checkKeyPress(0);<br />
<br />
  if(dm_num == 32)<br />
  {<br />
    delay(10);<br />
    input_value[1] = getKeycode2();<br />
    checkKeyPress(1);<br />
    /*if(key_old_arr[1] != input_value[1] )<br />
    {<br />
      key_old_arr[1] = input_value[1];<br />
      Serial.printf("input1:%d&#92;r&#92;n",input_value[1]);<br />
    }*/<br />
  }<br />
  <br />
<br />
<br />
  delay(10); // a short debounce delay<br />
}<br />
<br />
static void checkKeyPress(int8_t chip)<br />
{<br />
  uint8_t start_index = (chip==0)?0:16;<br />
  if(input_value_old[chip] != input_value[chip])<br />
  {<br />
    input_value_old[chip] = input_value[chip];<br />
    if(input_value[chip] == 0xffff)<br />
    {<br />
      Serial.printf("key is released!");<br />
     &nbsp;&nbsp;<br />
      key_index_last = key_index = -1;<br />
<br />
      for (uint8_t p=start_index; p&lt;16+start_index; p++) ///all key status init.<br />
      {<br />
        key_press_prop[p].key_time_start = 0;<br />
        key_press_prop[p].key_time_rec = 0;<br />
        key_press_prop[p].key_press_cnt = 0;<br />
        key_press_prop[p].key_press_cnt_old = 0;<br />
      }<br />
    }<br />
    else ///key press<br />
    {<br />
      //Serial.printf("input_value = %04X &#92;r&#92;n",input_value);<br />
      key_index = get_key_press(chip,input_value[chip]);<br />
      if(key_index &gt;= 0) <br />
      {<br />
        key_index_last = key_index;<br />
        Serial.printf("key %02d # is pressed! &#92;r&#92;n",key_index+1); <br />
        current_operator_key = key_index;<br />
        key_press_prop[current_operator_key].key_status = KEY_SHORT_PRESSED;<br />
        key_press_prop[current_operator_key].key_time_start = millis();<br />
        key_press_prop[current_operator_key].key_press_time = 0;<br />
      }<br />
    }<br />
  }<br />
  else<br />
  {<br />
    if(input_value[chip] != 0xffff) ///LONG PRESS!<br />
    {<br />
      //Serial.printf("key long pressed! &#92;r&#92;n");<br />
<br />
      if(key_index &gt;= 0 &amp;&amp; key_index_last == key_index) <br />
      { <br />
        //Serial.printf("key long pressed! key_index = %d&#92;r&#92;n",key_index);<br />
<br />
        key_press_prop[current_operator_key].key_status = KEY_LONG_PRESSED;<br />
        key_press_prop[current_operator_key].key_time_rec = millis();<br />
        key_press_prop[current_operator_key].key_press_time = key_press_prop[current_operator_key].key_time_rec - key_press_prop[current_operator_key].key_time_start;<br />
        key_press_prop[current_operator_key].key_press_cnt = (key_press_prop[current_operator_key].key_press_time % 4080 ) / 100; ////100MS发一次<br />
<br />
        //Serial.printf("key long time = %d, cnt = %d &#92;r&#92;n",key_press_prop[current_operator_key].key_press_time,key_press_prop[current_operator_key].key_press_cnt);<br />
<br />
        if(key_press_prop[current_operator_key].key_press_cnt_old != key_press_prop[current_operator_key].key_press_cnt)<br />
        {<br />
          key_press_prop[current_operator_key].key_press_cnt_old = key_press_prop[current_operator_key].key_press_cnt;<br />
          /////send st_tx information.<br />
          key_press_prop[current_operator_key].current_light = (float)key_press_prop[current_operator_key].key_press_cnt * 100.0f;<br />
          write_value = (uint16_t) key_press_prop[current_operator_key].current_light;<br />
<br />
          Serial.printf("key_long_press_time = %d, current_light = %d &#92;r&#92;n",key_press_prop[current_operator_key].key_press_time,write_value);<br />
<br />
          modbus_write_multiple_registers(myst_serial,1,4000+current_operator_key,&amp;write_value,1);<br />
<br />
<br />
        }<br />
      }<br />
    }<br />
  }<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9146" target="_blank" title="">1-dac-32ch.zip</a> (Size: 2.95 KB / Downloads: 438)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9147" target="_blank" title="">1-dac-32ch.ino.merged.zip</a> (Size: 205.71 KB / Downloads: 438)
			<content:encoded><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>#include &lt;Adafruit_PCF8575.h&gt;<br />
<br />
<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
  <br />
      } else {<br />
      }<br />
    }<br />
  }<br />
  return crc;<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  <br />
  <br />
  <br />
  <br />
  <br />
  }<br />
  <br />
}<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
  <br />
  <br />
  <br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  <br />
  <br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  <br />
<br />
  <br />
<br />
  }<br />
  <br />
}<br />
<br />
<br />
<br />
    while (1);<br />
  }<br />
<br />
  {<br />
    }<br />
  }<br />
 &nbsp;&nbsp;<br />
<br />
    <br />
  }<br />
<br />
<br />
<br />
}<br />
<br />
<br />
<br />
<br />
{<br />
<br />
  {<br />
  }<br />
}<br />
<br />
{<br />
<br />
}<br />
<br />
{<br />
<br />
}<br />
<br />
<br />
<br />
<br />
  {<br />
  }*/<br />
  <br />
<br />
  {<br />
    delay(10);<br />
    {<br />
    }*/<br />
  }<br />
  <br />
<br />
<br />
}<br />
<br />
{<br />
  {<br />
    {<br />
     &nbsp;&nbsp;<br />
<br />
      {<br />
      }<br />
    }<br />
    {<br />
      {<br />
      }<br />
    }<br />
  }<br />
  else<br />
  {<br />
    {<br />
<br />
      { <br />
<br />
<br />
<br />
        {<br />
<br />
<br />
<br />
<br />
        }<br />
      }<br />
    }<br />
  }<br />
<br />
		</item>
		<item>
			<title><![CDATA[DM8 DM16 DM32 PC software using USB-RS485 adapter]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9008</link>
			<pubDate>Tue, 03 Feb 2026 08:27:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9008</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9144" target="_blank" title="">DMxx_pc.png</a> (Size: 31.14 KB / Downloads: 357)
PC software download:<!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9145" target="_blank" title="">DMxx_SIMPLE1220.zip</a> (Size: 1.66 MB / Downloads: 440)
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9018</link>
			<pubDate>Tue, 09 Sep 2025 11:36:21 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9018</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
// Initialize the display using the software I2C method (SCL = IO39, SDA = IO38)<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9164" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.12 KB / Downloads: 659)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9165" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 201.24 KB / Downloads: 643)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9017</link>
			<pubDate>Tue, 09 Sep 2025 11:34:19 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9017</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 16<br />
#define RXD_PIN 17<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9162" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 685)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9163" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 184.93 KB / Downloads: 666)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9016</link>
			<pubDate>Tue, 09 Sep 2025 11:32:40 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9016</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO1<br />
 * - MOSI: GPIO2<br />
 * - MISO: GPIO41<br />
 * - CS: GPIO42<br />
 * - RST: GPIO44<br />
 * - INT: GPIO43<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9160" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 606)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9161" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 188.93 KB / Downloads: 666)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9015</link>
			<pubDate>Tue, 09 Sep 2025 11:31:29 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9015</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9158" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 666)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9159" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 191.08 KB / Downloads: 638)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9014</link>
			<pubDate>Tue, 09 Sep 2025 11:01:40 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9014</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9156" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 603)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9157" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 221.25 KB / Downloads: 608)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9013</link>
			<pubDate>Tue, 09 Sep 2025 11:00:30 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9013</guid>
 *<br />
 * GPIO Status Monitoring<br />
 *<br />
 * This program monitors the status (high or low) of multiple GPIO pins on the ESP32-S3.<br />
 * It prints the status of the pins to the serial monitor whenever a change is detected.<br />
 *<br />
 * GPIO Pins Monitored:<br />
 * - GPIO 40<br />
 * - GPIO 7<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 13<br />
 * - GPIO 14<br />
 * - GPIO 21<br />
 * - GPIO 0<br />
 *<br />
 * Hardware Requirements:<br />
 * - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing<br />
 */<br />
<br />
#define GPIO_PIN_40 40<br />
#define GPIO_PIN_7 7<br />
#define GPIO_PIN_48 48<br />
#define GPIO_PIN_47 47<br />
#define GPIO_PIN_13 13<br />
#define GPIO_PIN_14 14<br />
#define GPIO_PIN_21 21<br />
#define GPIO_PIN_0 0<br />
<br />
// Store the previous state of the GPIO pins<br />
bool prevState[8] = {false, false, false, false, false, false, false, false};<br />
<br />
  // Initialize serial communication for debugging purposes<br />
  Serial.begin(115200); // Initialize the serial monitor at 115200 baud<br />
  while (!Serial);      // Wait for the serial monitor to open<br />
<br />
  // Initialize GPIO pins as inputs<br />
  pinMode(GPIO_PIN_40, INPUT);<br />
  pinMode(GPIO_PIN_7, INPUT);<br />
  pinMode(GPIO_PIN_48, INPUT);<br />
  pinMode(GPIO_PIN_47, INPUT);<br />
  pinMode(GPIO_PIN_13, INPUT);<br />
  pinMode(GPIO_PIN_14, INPUT);<br />
  pinMode(GPIO_PIN_21, INPUT);<br />
  pinMode(GPIO_PIN_0, INPUT);<br />
<br />
  Serial.println("GPIO Status Monitoring Started");<br />
}<br />
<br />
void loop() {<br />
  // Read the current state of each GPIO pin<br />
  bool currentState[8];<br />
  currentState[0] = digitalRead(GPIO_PIN_40);<br />
  currentState[1] = digitalRead(GPIO_PIN_7);<br />
  currentState[2] = digitalRead(GPIO_PIN_48);<br />
  currentState[3] = digitalRead(GPIO_PIN_47);<br />
  currentState[4] = digitalRead(GPIO_PIN_13);<br />
  currentState[5] = digitalRead(GPIO_PIN_14);<br />
  currentState[6] = digitalRead(GPIO_PIN_21);<br />
  currentState[7] = digitalRead(GPIO_PIN_0);<br />
<br />
  // Check for changes in GPIO pin states<br />
    if (currentState[i] != prevState[i]) {<br />
      // Print the pin number and its new state if it has changed<br />
      Serial.print("GPIO ");<br />
      Serial.print(i == 0 ? GPIO_PIN_40 : <br />
                 &nbsp;&nbsp;i == 1 ? GPIO_PIN_7 : <br />
                 &nbsp;&nbsp;i == 2 ? GPIO_PIN_48 : <br />
                 &nbsp;&nbsp;i == 3 ? GPIO_PIN_47 : <br />
                 &nbsp;&nbsp;i == 4 ? GPIO_PIN_13 : <br />
                 &nbsp;&nbsp;i == 5 ? GPIO_PIN_14 : <br />
                 &nbsp;&nbsp;i == 6 ? GPIO_PIN_21 : GPIO_PIN_0);<br />
      Serial.print(" changed to ");<br />
      Serial.println(currentState[i] ? "HIGH" : "LOW");<br />
      // Update the previous state<br />
      prevState[i] = currentState[i];<br />
    }<br />
  }<br />
<br />
  // Delay to avoid flooding the serial monitor<br />
  delay(100); // Adjust the delay as needed<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9154" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 1.04 KB / Downloads: 648)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9155" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 179.57 KB / Downloads: 604)
 *<br />
 *<br />
 *<br />
 * - GPIO 40<br />
 * - GPIO 7<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 13<br />
 * - GPIO 14<br />
 * - GPIO 21<br />
 * - GPIO 0<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
    }<br />
  }<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9012</link>
			<pubDate>Tue, 09 Sep 2025 10:59:21 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9012</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B16!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9152" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 588)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9153" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 184.34 KB / Downloads: 660)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for DM32]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9011</link>
			<pubDate>Tue, 09 Sep 2025 10:53:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9011</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18 <br />
<br />
<br />
void setup(void) <br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9150" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 608)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9151" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 190.05 KB / Downloads: 668)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
	</channel>
</rss>
