	<channel>
		<title><![CDATA[Smart Home Automation Forum - B2]]></title>
		<pubDate>Sun, 04 Oct 2026 04:30:32 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[[arduino code examples for B2]-11 digital INPUT trigger OUTPUT directly]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9697</link>
			<pubDate>Sat, 25 Jul 2026 14:40:31 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9697</guid>
 &nbsp;&nbsp;Made by KinCony IoT<br />
 &nbsp;&nbsp;https://www.kincony.com<br />
<br />
 &nbsp;&nbsp;Demo: KinCony B2 DI Control Relay<br />
 &nbsp;&nbsp;Board: KinCony B2 (ESP32)<br />
<br />
 &nbsp;&nbsp;Digital Input 1 -&gt; GPIO6<br />
 &nbsp;&nbsp;Digital Input 2 -&gt; GPIO7<br />
<br />
 &nbsp;&nbsp;Relay 1 -&gt; GPIO4<br />
 &nbsp;&nbsp;Relay 2 -&gt; GPIO46<br />
*/<br />
<br />
// Digital Inputs<br />
#define DI1_PIN 6<br />
#define DI2_PIN 7<br />
<br />
// Relay Outputs<br />
#define RELAY1_PIN 4<br />
#define RELAY2_PIN 46<br />
<br />
// Relay logic (Active LOW)<br />
#define RELAY_ON  LOW<br />
#define RELAY_OFF HIGH<br />
<br />
// Store previous DI states<br />
int lastDI1State;<br />
int lastDI2State;<br />
<br />
void setup()<br />
{<br />
  // Configure digital inputs<br />
  pinMode(DI1_PIN, INPUT);<br />
  pinMode(DI2_PIN, INPUT);<br />
<br />
  // Configure relay outputs<br />
  pinMode(RELAY1_PIN, OUTPUT);<br />
  pinMode(RELAY2_PIN, OUTPUT);<br />
<br />
  // Turn OFF relays at startup<br />
  digitalWrite(RELAY1_PIN, RELAY_OFF);<br />
  digitalWrite(RELAY2_PIN, RELAY_OFF);<br />
<br />
  // Read initial input states<br />
  lastDI1State = digitalRead(DI1_PIN);<br />
  lastDI2State = digitalRead(DI2_PIN);<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
  // Read current DI states<br />
  int di1State = digitalRead(DI1_PIN);<br />
  int di2State = digitalRead(DI2_PIN);<br />
<br />
  // DI1 changed<br />
  if (di1State != lastDI1State)<br />
  {<br />
    lastDI1State = di1State;<br />
<br />
    if (di1State == HIGH)<br />
    {<br />
      digitalWrite(RELAY1_PIN, RELAY_ON);<br />
    }<br />
    else<br />
    {<br />
    }<br />
  }<br />
<br />
  // DI2 changed<br />
  if (di2State != lastDI2State)<br />
  {<br />
    lastDI2State = di2State;<br />
<br />
    if (di2State == HIGH)<br />
    {<br />
      digitalWrite(RELAY2_PIN, RELAY_ON);<br />
    }<br />
    else<br />
    {<br />
    }<br />
  }<br />
<br />
  // Small delay for stability<br />
  delay(10);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10293" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 728 bytes / Downloads: 133)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10294" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 180 KB / Downloads: 135)
<br />
<br />
<br />
*/<br />
<br />
<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
<br />
  {<br />
<br />
    {<br />
    }<br />
    else<br />
    {<br />
    }<br />
  }<br />
<br />
  {<br />
<br />
    {<br />
    }<br />
    else<br />
    {<br />
    }<br />
  }<br />
<br />
  delay(10);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9696</link>
			<pubDate>Sat, 25 Jul 2026 14:39:13 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9696</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
void setup() {<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10291" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 144)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10292" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 202.58 KB / Downloads: 126)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9695</link>
			<pubDate>Sat, 25 Jul 2026 14:38:12 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9695</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 15<br />
#define RXD_PIN 16<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
  Serial.begin(115200);<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10290" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 130)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9694</link>
			<pubDate>Sat, 25 Jul 2026 14:37:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9694</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10288" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 134)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10289" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 191.06 KB / Downloads: 152)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9693</link>
			<pubDate>Sat, 25 Jul 2026 14:36:03 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9693</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10286" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 120)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10287" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 193.65 KB / Downloads: 124)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9692</link>
			<pubDate>Sat, 25 Jul 2026 14:35:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9692</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10284" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 161)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10285" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 219.15 KB / Downloads: 167)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9691</link>
			<pubDate>Sat, 25 Jul 2026 14:33:45 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9691</guid>
<br />
 &nbsp;&nbsp;Demo: KinCony B2 GPIO State Monitor<br />
<br />
 &nbsp;&nbsp;1-Wire-1 -&gt; GPIO47<br />
 &nbsp;&nbsp;1-Wire-2 -&gt; GPIO48<br />
 &nbsp;&nbsp;1-Wire-3 -&gt; GPIO17<br />
 &nbsp;&nbsp;1-Wire-4 -&gt; GPIO40<br />
*/<br />
<br />
#define GPIO1_PIN 47<br />
#define GPIO2_PIN 48<br />
#define GPIO3_PIN 17<br />
#define GPIO4_PIN 40<br />
<br />
// Store previous GPIO states<br />
int lastState1;<br />
int lastState2;<br />
int lastState3;<br />
int lastState4;<br />
<br />
void setup()<br />
{<br />
  // Initialize serial monitor<br />
  Serial.println("KinCony B2 GPIO State Monitor");<br />
<br />
  // Configure GPIOs as inputs<br />
  // Change INPUT to INPUT_PULLUP if required by your hardware<br />
  pinMode(GPIO1_PIN, INPUT);<br />
  pinMode(GPIO2_PIN, INPUT);<br />
  pinMode(GPIO3_PIN, INPUT);<br />
  pinMode(GPIO4_PIN, INPUT);<br />
<br />
  // Read initial states<br />
  lastState1 = digitalRead(GPIO1_PIN);<br />
  lastState2 = digitalRead(GPIO2_PIN);<br />
  lastState3 = digitalRead(GPIO3_PIN);<br />
  lastState4 = digitalRead(GPIO4_PIN);<br />
<br />
  // Print initial states<br />
  Serial.printf("GPIO47 Initial: %d&#92;n", lastState1);<br />
  Serial.printf("GPIO48 Initial: %d&#92;n", lastState2);<br />
  Serial.printf("GPIO17 Initial: %d&#92;n", lastState3);<br />
  Serial.printf("GPIO40 Initial: %d&#92;n", lastState4);<br />
}<br />
<br />
void loop()<br />
{<br />
  int state;<br />
<br />
  // Check GPIO47<br />
  state = digitalRead(GPIO1_PIN);<br />
  if (state != lastState1)<br />
  {<br />
    lastState1 = state;<br />
    Serial.printf("GPIO47 Changed: %d&#92;n", state);<br />
  }<br />
<br />
  // Check GPIO48<br />
  state = digitalRead(GPIO2_PIN);<br />
  if (state != lastState2)<br />
  {<br />
    lastState2 = state;<br />
    Serial.printf("GPIO48 Changed: %d&#92;n", state);<br />
  }<br />
<br />
  // Check GPIO17<br />
  state = digitalRead(GPIO3_PIN);<br />
  if (state != lastState3)<br />
  {<br />
    lastState3 = state;<br />
    Serial.printf("GPIO17 Changed: %d&#92;n", state);<br />
  }<br />
<br />
  // Check GPIO40<br />
  state = digitalRead(GPIO4_PIN);<br />
  if (state != lastState4)<br />
  {<br />
    lastState4 = state;<br />
    Serial.printf("GPIO40 Changed: %d&#92;n", state);<br />
  }<br />
<br />
  delay(10);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10282" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 757 bytes / Downloads: 142)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10283" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 180.31 KB / Downloads: 134)
<br />
<br />
*/<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
  int state;<br />
<br />
  {<br />
  }<br />
<br />
  {<br />
  }<br />
<br />
  {<br />
  }<br />
<br />
  {<br />
  }<br />
<br />
  delay(10);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9690</link>
			<pubDate>Sat, 25 Jul 2026 14:32:30 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9690</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 39<br />
#define RS485_TXD 38<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10280" target="_blank" title="">4-RS485-Test.zip</a> (Size: 758 bytes / Downloads: 160)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10281" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 185.84 KB / Downloads: 135)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9689</link>
			<pubDate>Sat, 25 Jul 2026 14:30:52 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9689</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18  <br />
<br />
<br />
void setup(void) <br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10278" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 121)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10279" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 192.69 KB / Downloads: 126)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9688</link>
			<pubDate>Sat, 25 Jul 2026 14:29:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9688</guid>
<br />
 &nbsp;&nbsp;Demo: KinCony B2 Digital Input Read<br />
<br />
*/<br />
<br />
<br />
// Store previous input states<br />
int lastDI1State = HIGH;<br />
int lastDI2State = HIGH;<br />
<br />
void setup()<br />
{<br />
  Serial.println("KinCony B2 Digital Input Demo");<br />
<br />
  // Configure digital input pins<br />
  // Change INPUT to INPUT_PULLUP if your hardware requires internal pull-up<br />
  pinMode(DI1_PIN, INPUT_PULLUP);<br />
  pinMode(DI2_PIN, INPUT_PULLUP);<br />
<br />
<br />
  Serial.print("DI1 Initial State: ");<br />
  Serial.println(lastDI1State);<br />
<br />
  Serial.print("DI2 Initial State: ");<br />
  Serial.println(lastDI2State);<br />
}<br />
<br />
void loop()<br />
{<br />
  // Read current input states<br />
<br />
  // Check if DI1 state changed<br />
  {<br />
<br />
    Serial.print("DI1 Changed: ");<br />
    Serial.println(di1State);<br />
  }<br />
<br />
  // Check if DI2 state changed<br />
  {<br />
<br />
    Serial.print("DI2 Changed: ");<br />
    Serial.println(di2State);<br />
  }<br />
<br />
  delay(10);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10276" target="_blank" title="">2-digital-input.zip</a> (Size: 697 bytes / Downloads: 124)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10277" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 180.26 KB / Downloads: 119)
<br />
<br />
*/<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
<br />
  {<br />
<br />
  }<br />
<br />
  {<br />
<br />
  }<br />
<br />
  delay(10);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B2]-01 Turn ON/OFF OUTPUT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9687</link>
			<pubDate>Sat, 25 Jul 2026 14:28:06 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9687</guid>
<br />
 &nbsp;&nbsp;Demo: KinCony B2 Relay Control<br />
*/<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
  // Turn OFF both relays at startup<br />
}<br />
<br />
void loop()<br />
{<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  Serial.println("Relay 2 OFF");<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10274" target="_blank" title="">1-relay.zip</a> (Size: 450 bytes / Downloads: 119)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10275" target="_blank" title="">1-relay.ino.merged.zip</a> (Size: 179.96 KB / Downloads: 128)
<br />
*/<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
<br />
  delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[B2 Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9686</link>
			<pubDate>Sat, 25 Jul 2026 14:26:30 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9686</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10273" target="_blank" title="">KinCony-B2-smart-controller-diagram.png</a> (Size: 1.38 MB / Downloads: 120)
		</item>
		<item>
			<title><![CDATA[B2 ESPHome yaml for home assistant with tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9685</link>
			<pubDate>Sat, 25 Jul 2026 14:25:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9685</guid>
  friendly_name: b2<br />
  platformio_options:<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
external_components:<br />
  - source:<br />
      type: git<br />
      ref: v1.3.1<br />
<br />
# Enable logging<br />
logger: <br />
# &nbsp;&nbsp;hardware_uart: USB_SERIAL_JTAG<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO1<br />
  mosi_pin: GPIO2<br />
  miso_pin: GPIO41<br />
  cs_pin: GPIO42<br />
  interrupt_pin: GPIO43<br />
  reset_pin: GPIO44<br />
<br />
i2c:<br />
 &nbsp;&nbsp;- id: bus_a<br />
   &nbsp;&nbsp;sda: 8<br />
   &nbsp;&nbsp;scl: 18<br />
   &nbsp;&nbsp;scan: true<br />
<br />
uart:<br />
  - id: uart_1    #RS485<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 38<br />
    rx_pin: 39<br />
<br />
  - id: tuya_mcu_uart<br />
    tx_pin: GPIO14<br />
    rx_pin: GPIO13<br />
<br />
tuya_wifi_mcu:<br />
  # tuya mcu product id<br />
  product_id: qk4eefxayleh2x5s<br />
  uart_id: tuya_mcu_uart<br />
  wifi_reset_pin: 28<br />
  wifi_led_pin: 16<br />
<br />
switch:<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
  - platform: gpio<br />
    pin: 4<br />
    inverted: false<br />
    dp_id: 1<br />
    internal: true<br />
    # bind other switch, sync state<br />
    bind_switch_id: "b2_output01"<br />
<br />
    pin: 46<br />
    dp_id: 2<br />
    bind_switch_id: "b2_output02"    <br />
<br />
binary_sensor:<br />
    pin:<br />
      number: 6<br />
      inverted: true<br />
    dp_id: 111<br />
    bind_binary_sensor_id: b2_input01<br />
<br />
<br />
    pin:<br />
      number: 7<br />
    dp_id: 112<br />
    bind_binary_sensor_id: b2_input02<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 17<br />
<br />
    pin: <br />
      number: 40<br />
<br />
<br />
ads1115:<br />
  - address: 0x48<br />
sensor:<br />
  - platform: ads1115<br />
    multiplexer: 'A0_GND'<br />
    gain: 6.144<br />
    resolution: 16_BITS<br />
    update_interval: 5s<br />
    multiplexer: 'A1_GND'<br />
    gain: 6.144<br />
    multiplexer: 'A2_GND'<br />
    gain: 6.144<br />
    multiplexer: 'A3_GND'<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    i2c_id: bus_a<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 0, id(roboto), "KinCony B2");</code></div></div> download yaml file: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10272" target="_blank" title="">B2-HA-Tuya.txt</a> (Size: 3.58 KB / Downloads: 125)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
  - source:<br />
      type: git<br />
      ref: v1.3.1<br />
<br />
logger: <br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
i2c:<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 38<br />
    rx_pin: 39<br />
<br />
<br />
<br />
switch:<br />
<br />
    pin: 4<br />
    dp_id: 1<br />
<br />
    pin: 46<br />
    dp_id: 2<br />
<br />
    pin:<br />
      number: 6<br />
    dp_id: 111<br />
<br />
<br />
    pin:<br />
      number: 7<br />
    dp_id: 112<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 17<br />
<br />
    pin: <br />
      number: 40<br />
<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
		<item>
			<title><![CDATA[B2 ESPHome yaml for home assistant without tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9684</link>
			<pubDate>Sat, 25 Jul 2026 14:24:32 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9684</guid>
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
    <br />
<br />
logger: <br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
i2c:<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 38<br />
    rx_pin: 39<br />
<br />
<br />
switch:<br />
<br />
    pin: 4<br />
<br />
    pin: 46<br />
<br />
    pin:<br />
      number: 6<br />
<br />
    pin:<br />
      number: 7<br />
<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 17<br />
<br />
    pin: <br />
      number: 40<br />
<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10271" target="_blank" title="">B2-HA-Without-Tuya.txt</a> (Size: 2.35 KB / Downloads: 87)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
    <br />
<br />
logger: <br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
i2c:<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 38<br />
    rx_pin: 39<br />
<br />
<br />
switch:<br />
<br />
    pin: 4<br />
<br />
    pin: 46<br />
<br />
    pin:<br />
      number: 6<br />
<br />
    pin:<br />
      number: 7<br />
<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 17<br />
<br />
    pin: <br />
      number: 40<br />
<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
		<item>
			<title><![CDATA[B2 ESP32-S3 IO pins define]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9683</link>
			<pubDate>Sat, 25 Jul 2026 14:23:25 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9683</guid>
			<description><![CDATA[IIC Bus:<br />
<br />
SDA:GPIO8<br />
SCL:GPIO18<br />
<br />
24C02 EPROM i2c address: 0x50<br />
DS3231 RTC i2c address: 0x68<br />
SSD1306 display: i2c address:0x3c<br />
ADS1115 (4CH ADC): i2c address:0x48<br />
<br />
Analog input (A1: DC 0-5v)<br />
Analog input (A2: DC 0-5v)<br />
Analog input (A3: DC 4-20mA)<br />
Analog input (A4: DC 4-20mA)<br />
<br />
<br />
digital input-1:GPIO6<br />
digital input-2:GPIO7<br />
<br />
relay1:GPIO4<br />
relay2:GPIO46<br />
<br />
-----------------<br />
1-wire GPIOs (with pull-up resistance on PCB): <br />
1-wire-1:GPIO47<br />
1-wire-2:GPIO48<br />
1-wire-3:GPIO17<br />
1-wire-4:GPIO40<br />
<br />
<br />
Ethernet (W5500) I/O define:<br />
<br />
<br />
<br />
--------------------<br />
RS485: <br />
RXD:GPIO39<br />
TXD:GPIO38<br />
<br />
Tuya module:<br />
RXD:GPIO13<br />
TXD:GPIO14<br />
<br />
Tuya network button: Tuya module's P28<br />
Tuya network LED: Tuya module's P16<br />
SD Card:<br />
SPI-MOSI:GPIO10<br />
SPI-SCK:GPIO11<br />
SPI-MISO:GPIO12<br />
SPI-CS:GPIO9<br />
SPI-CD:GPIO5<br />
4G SIM7600<br />
RXD:GPIO16<br />
TXD:GPIO15]]></description>
			<content:encoded><![CDATA[IIC Bus:<br />
<br />
SDA:GPIO8<br />
SCL:GPIO18<br />
<br />
<br />
<br />
<br />
<br />
relay1:GPIO4<br />
relay2:GPIO46<br />
<br />
<br />
<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO39<br />
TXD:GPIO38<br />
<br />
Tuya module:<br />
RXD:GPIO13<br />
TXD:GPIO14<br />
<br />
SD Card:<br />
SPI-CS:GPIO9<br />
SPI-CD:GPIO5<br />
4G SIM7600<br />
RXD:GPIO16<br />
TXD:GPIO15]]></content:encoded>
		</item>
	</channel>
</rss>
