	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-A6]]></title>
		<pubDate>Sun, 08 Nov 2026 02:59:28 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[How Do You Handle Relay Control When Wi-Fi Goes Down?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9931</link>
			<pubDate>Mon, 02 Nov 2026 16:54:29 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=12270">brianallen</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9931</guid>
			<description><![CDATA[Hi everyone,<br />
<br />
I'm working on a home automation setup using a KinCony ESP32 relay board with Home Assistant. Most of my automations currently run through Home Assistant, but I'm wondering what happens when the Wi-Fi or server connection goes down.<br />
<br />
I'd like basic functions such as lights and switches to keep working locally, even if Home Assistant becomes temporarily unavailable.<br />
<br />
Is it possible to configure the relays to work independently using ESPHome, or would it be better to handle this directly in the ESP32 code?<br />
<br />
I'd be interested to hear how others have set up reliable local control, especially if you've managed to combine physical wall switches with Home Assistant automations.<br />
<br />
Any examples or suggestions would be appreciated. Thanks!        <a href="https://wheelielife.io/" target="_blank" rel="noopener" class="mycode_url"><span style="color: #ffffff;" class="mycode_color">wheelie life</span></a>]]></description>
			<content:encoded><![CDATA[Hi everyone,<br />
<br />
<br />
<br />
<br />
<br />
Any examples or suggestions would be appreciated. Thanks!        <a href="https://wheelielife.io/" target="_blank" rel="noopener" class="mycode_url"><span style="color: #ffffff;" class="mycode_color">wheelie life</span></a>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A6 Analog inputs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9847</link>
			<pubDate>Mon, 28 Sep 2026 19:42:28 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11936">Tomas4289</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9847</guid>
			<description><![CDATA[Hi. What is the situation regarding the analog inputs on the KC868-A6? Are all four 0–5V, or are two 0–5V and two 4–20mA? The reason I ask is that the system block diagram labels two as 0–5V and two as 4–20mA inputs, whereas the wiring diagram shows all four as 0–5V inputs.<!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10568" target="_blank" title="">KC868-A6 system block diagram.png</a> (Size: 429.8 KB / Downloads: 138)
<!-- end: postbit_attachments_attachment --><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10567" target="_blank" title="">KC868-A6 schematic.png</a> (Size: 48.99 KB / Downloads: 146)
			<content:encoded><![CDATA[Hi. What is the situation regarding the analog inputs on the KC868-A6? Are all four 0–5V, or are two 0–5V and two 4–20mA? The reason I ask is that the system block diagram labels two as 0–5V and two as 4–20mA inputs, whereas the wiring diagram shows all four as 0–5V inputs.<!-- start: postbit_attachments_attachment -->
		</item>
		<item>
			<title><![CDATA[kc868-a6 analog input]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9843</link>
			<pubDate>Tue, 22 Sep 2026 07:22:45 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9662">Diskstain</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9843</guid>
			<description><![CDATA[How do you connect a thermistor to an analog input?]]></description>
			<content:encoded><![CDATA[How do you connect a thermistor to an analog input?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A6 Lora]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9658</link>
			<pubDate>Thu, 23 Jul 2026 15:46:04 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11278">Armsp0</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9658</guid>
			<description><![CDATA[I have a KC868-6 V1.3 board. I live in New Zealand where AS923 requires 915Mhz frequency. Can the SX1262 board be used in place of the SX1278 module? Pinouts may be different firmware might need modification?]]></description>
			<content:encoded><![CDATA[I have a KC868-6 V1.3 board. I live in New Zealand where AS923 requires 915Mhz frequency. Can the SX1262 board be used in place of the SX1278 module? Pinouts may be different firmware might need modification?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-a6  2 analog outputs (DAC)]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9484</link>
			<pubDate>Sun, 14 Jun 2026 18:26:54 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11011">bikovalexand</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9484</guid>
			<description><![CDATA[Hello, I'm working on a project that uses both outputs of a KC868-a6 v1.33 controller (0-10 V DAC). I'm writing the program in OpenPLC Editor.<br />
The signal on both outputs changes proportionally, but not from 0-10 V, only from 0-3.3 V. What could be the problem?<br />
 I tried downloading the latest version of KCS (v.2.2.20) to the controller, connecting to it via WiFi, and changing the output values. They output from 0 V to 3.3 V. I understand the LM258DR should amplify the signal by three times? Perhaps it's not working?<br />
Thank you]]></description>
			<content:encoded><![CDATA[Hello, I'm working on a project that uses both outputs of a KC868-a6 v1.33 controller (0-10 V DAC). I'm writing the program in OpenPLC Editor.<br />
Thank you]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Digital Input de-bounce]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9422</link>
			<pubDate>Mon, 01 Jun 2026 21:33:00 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10939">l0v4szl</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9422</guid>
			<description><![CDATA[Hello!<br />
<br />
I have a Kincony A6 V 1.4Sp motherboard.<br />
I collect pulses from water meters on the Digital input and process them with domoticz.<br />
These operate with reed sensors and there is noise in them.<br />
<br />
Can I count on firmware that handles de-bounce? I would need a value of 1000ms.<br />
<br />
Is there any input on the device in ESPeasy where a pulse counter can be recognized via GPIO?<br />
<br />
Thank you!]]></description>
			<content:encoded><![CDATA[Hello!<br />
<br />
<br />
<br />
<br />
Thank you!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A6v3 ESP32-S3 6 channel LoRa relay module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9106</link>
			<pubDate>Fri, 06 Mar 2026 06:36:10 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=485">mcdave</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9106</guid>
			<description><![CDATA[Hello admin,<br />
I am using the <span style="font-weight: bold;" class="mycode_b">KinCony KC868-A6v3 and  kincony ALR lora </span>board and developing custom firmware with Arduino / PlatformIO.<br />
The <span style="font-weight: bold;" class="mycode_b">SSD1306 OLED works with the factory firmware</span>, but when I upload my own firmware the LCD stays blank.<br />
Could you please tell me:<br />
<ol type="1" class="mycode_list"><li>What <span style="font-weight: bold;" class="mycode_b">GPIO pins are used for the OLED I2C (SDA / SCL)?</span><br />
</li>
<li>What is the <span style="font-weight: bold;" class="mycode_b">I2C address (0x3C or 0x3D)?</span><br />
</li>
<li>Do we need to <span style="font-weight: bold;" class="mycode_b">initialize any IO expander or controller before using the OLED?</span><br />
</li>
<li>Do you have a <span style="font-weight: bold;" class="mycode_b">simple Arduino example to initialize the onboard OLED?</span><br />
</li>
</ol>
Thank you.]]></description>
			<content:encoded><![CDATA[Hello admin,<br />
</li>
</li>
</li>
</li>
</ol>
Thank you.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Rs485 addresses for KC868-A6 relays]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9066</link>
			<pubDate>Sun, 22 Feb 2026 00:01:52 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10461">Yuriy</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9066</guid>
			<description><![CDATA[Hello everyone!<br />
Please, help me, what are the Rs485 addresses (for ESPhome firmware) of the KC868-A6 relays?<br />
<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>switch:<br />
- platform: modbus_controller<br />
  modbus_controller_id: modbus_device<br />
  name: "Relay rs485"<br />
  register_type: coil<br />
  address: ???????????????<br />
  bitmask: 1</code></div></div><br />
Thank you in advance.]]></description>
			<content:encoded><![CDATA[Hello everyone!<br />
<br />
Thank you in advance.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A6 with KC868-HAv2]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9046</link>
			<pubDate>Thu, 12 Feb 2026 00:08:51 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10412">TMM</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9046</guid>
<br />
I have C868-A6 and KC868-HAv2 module,<br />
with the latest Kincony firmware, but I can't find on IFTTT tab how to set action with MODBUS-HA protocol.<br />
It possible to setup with this configuration?<br />
<br />
Digital inputs works well.]]></description>
<br />
<br />
Digital inputs works well.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A6: Any accessible GPIO without hardware modification?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9044</link>
			<pubDate>Wed, 11 Feb 2026 22:26:54 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10332">syme</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9044</guid>
<br />
On the KC868-A6 board, there are no directly accessible GPIOs like on the KC868-A6 v3.<br />
Is it possible to reuse or repurpose some GPIOs without soldering or desoldering components?<br />
I was considering IO13 from the internal serial port (P17 interface), but I’m unsure because the CPU schematic shows IO13 as not connected (marked with a red cross).<br />
Are there any other GPIOs that might be available?<br />
<br />
Thanks in advance for your help.<br /><!-- start: postbit_attachments_attachment -->
<img src="https://www.kincony.com/forum/images/attachtypes/pdf.png" title="Adobe Acrobat PDF" border="0" alt=".pdf" />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9176" target="_blank" title="">KC868-A6-schematic.pdf</a> (Size: 576.02 KB / Downloads: 495)
<br />
<br />
		</item>
		<item>
			<title><![CDATA[цифровые входы DI-1-6 на KinCony KC868-A6]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8976</link>
			<pubDate>Sun, 01 Feb 2026 11:30:17 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10341">AlexeyAris</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8976</guid>
			<description><![CDATA[Здравствуйте! Прошу прислать пример скетча на Arduino IDE для контроллера KinCony KC868-A6<br />
Датчик сухого контакта подключен к цифровому входу DI-1 и GND в контроллере KinCony KC868-A6.<br />
При замыкании сухого контакта Реле 1 включается<br />
При размыкании сухого контакта Реле 1 выключается<br />
Напряжение на контакте DI-1 составляет 11 В. Это нормальное напряжение?]]></description>
			<content:encoded><![CDATA[Здравствуйте! Прошу прислать пример скетча на Arduino IDE для контроллера KinCony KC868-A6<br />
Напряжение на контакте DI-1 составляет 11 В. Это нормальное напряжение?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[ompatibility of ACS712 with KC868‑A6 ADC Inputs (Arduino)]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8975</link>
			<pubDate>Sat, 31 Jan 2026 01:13:55 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8975</guid>
<br />
I want to measure the presence of current on a 220 V device (≤16 A) using my KC868‑A6.<br />
<br />
I have a 20 A ACS712 current sensor (analog output 0–5 V). I plan to use Arduino code directly. Before connecting it, I would like to know:<br />
<ol type="1" class="mycode_list"><li>Are the analog inputs (ADC) of the KC868‑A6 (GPIO 36/39/34/35) compatible with a signal from a 20 A ACS712 when using Arduino code?<br />
</li>
<li>Is any filtering or signal conditioning required to ensure the ADC reads it correctly?<br />
</li>
<li>Are there any special precautions regarding ground or reference to get a reliable reading?<br />
</li>
</ol>
     4. Are there other current sensors that would be more suitable for detecting the presence of current on a 220 V device with the KC868‑A6?<br />
<br />
Thank you in advance for your help.<br />
<br />
Best regards]]></description>
<br />
<br />
</li>
</li>
</li>
</ol>
<br />
<br />
Best regards]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Help needed: Bricked A6 v1.3 board]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8974</link>
			<pubDate>Sat, 31 Jan 2026 00:00:45 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10331">schma</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8974</guid>
			<description><![CDATA[<span style="font-weight: bold;" class="mycode_b">Hi everyone,</span><br />
I'm seeking some technical advice on reviving an <span style="font-weight: bold;" class="mycode_b">A6 v1.3 board</span> (ESP32-based).<br />
<span style="font-weight: bold;" class="mycode_b">The situation:</span> The board was running ESPHome perfectly. However, following a Wi-Fi AP migration and some "beginner mistakes" within Home Assistant, I’ve lost all connectivity to the device.<br />
<span style="font-weight: bold;" class="mycode_b">The problem:</span><ul class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">No OTA:</span> Since the Wi-Fi credentials are now incorrect, I cannot access it over the air.<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Serial flashing fails:</span> I am unable to upload new firmware via the onboard USB port.<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Hardware status:</span> The onboard USB-to-Serial chip seems functional (it's recognized by the OS), but there is zero communication with the ESP32 SoC itself. It won't enter bootloader mode or accept any flash commands.<br />
</li>
</ul>
<span style="font-weight: bold;" class="mycode_b">My questions:</span><br />
<ol type="1" class="mycode_list"><li>Is there a way to "force" this specific board into flash mode if the auto-reset circuit is failing?<br />
</li>
<li>Can I bypass the onboard serial chip and flash the SoC directly using an <span style="font-weight: bold;" class="mycode_b">external FTDI programmer</span>? If so, does anyone have the pinout for the RX/TX/IO0/EN pads on this v1.3 board?<br />
</li>
<li>Are there any specific recovery tools or "low-level" utilities (besides esptool.py) that you would recommend to "wake up" a non-responsive ESP32?<br />
</li>
</ol>
I would appreciate any tips or schematics to help me save this board!<br />
<span style="font-weight: bold;" class="mycode_b">Thanks in advance!</span>]]></description>
			<content:encoded><![CDATA[<span style="font-weight: bold;" class="mycode_b">Hi everyone,</span><br />
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</ol>
<span style="font-weight: bold;" class="mycode_b">Thanks in advance!</span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A6 - how to connect an optocoupler]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8839</link>
			<pubDate>Tue, 23 Dec 2025 05:44:01 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10095">itpraktyk</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8839</guid>
			<description><![CDATA[Hi!<br />
<br />
I would like connect to the KC868-A6-V1.4SP an optocoupler - similar to <a href="https://pl.aliexpress.com/item/1005008446930626.html" target="_blank" rel="noopener" class="mycode_url">https://pl.aliexpress.com/item/1005008446930626.html</a> . My goal is to detect and react for switching 230V power in monitored circuit.<br />
<br />
I flashed the KC868-A6 board with ESPHome - for now with default configuration.<br />
<br />
Can someone help me understand<br />
- from which pin should I take a power source for low voltage optocoupler side <br />
- where to connect its output to the KC868-A6 board<br />
- what I have to add to the ESPHome configuraiton?<br />
<br />
			<content:encoded><![CDATA[Hi!<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[PCF8574 INT pin on KC868-A6 — Is it connected to ESP32? Schematic request.]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8790</link>
			<pubDate>Sat, 06 Dec 2025 02:31:59 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9999">Asil</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8790</guid>
I am using the KC868-A6 board and reading digital inputs through the PCF8574.<br />
I need to know whether the <span style="font-weight: bold;" class="mycode_b">INT (nINT) pin of the PCF8574</span> is connected to any GPIO pin of the onboard ESP32.<br />
I have checked the hardware documentation, but I could not find a clear answer.<br />
Some older forum posts suggest that the INT pin might <span style="font-weight: bold;" class="mycode_b">not</span> be connected at all, but I want to confirm this specifically for the KC868-A6.<br />
Could you please clarify:<br />
<ol type="1" class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">Is the PCF8574 INT pin connected to the ESP32 on the KC868-A6 board?</span><br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">If yes, which ESP32 GPIO pin is it wired to?</span><br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">If not, is there a pad or test point where the INT pin can be accessed so we can wire it manually?</span><br />
</li>
<li>If possible, could you share the related portion of the <span style="font-weight: bold;" class="mycode_b">schematic or PCB layout</span> showing the PCF8574 connections?<br />
</li>
</ol>
I want to use hardware interrupts instead of polling the inputs constantly, so knowing the actual connection would help a lot.<br />
Thank you very much!]]></description>
</li>
</li>
</li>
</li>
</ol>
Thank you very much!]]></content:encoded>
		</item>
	</channel>
</rss>
