	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-A16]]></title>
		<pubDate>Wed, 25 Nov 2026 17:14:52 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[KCS debounce option for KC868-A16 v1.6]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9956</link>
			<pubDate>Wed, 18 Nov 2026 20:31:54 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=3894">tech1977</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9956</guid>
<br />
I have a KC868-A16 running KCS v2.2.20,<br />
integrated with Home Assistant via MQTT.<br />
<br />
Input 16 reads an auxiliary contact of a latching relay (Finder 20.22)<br />
to get the real ON/OFF state of a light. While the contact is closed<br />
(input ON), I occasionally get a false OFF lasting 1-2 seconds, then<br />
the input goes back to ON by itself. These glitches are published<br />
immediately via MQTT.<br />
<br />
I saw in this thread that you added an input debounce option<br />
("input delay time") to the KCS v3 firmware for the KC868-A16v3:<br />
<a href="https://www.kincony.com/forum/showthread.php?tid=9119" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9119</a><br />
<br />
My questions:<br />
1. Is there (or will there be) a KCS firmware with the same debounce<br />
  option for the KC868-A16 with ESP32 (not v3)?<br />
2. What is the maximum debounce time that can be set? In my case<br />
  I would need about 2-3 seconds.<br />
3. Is the debounce setting global or can it be set per input?<br />
4. If I upgrade from KCS v2 to v3, do the MQTT topics and the JSON<br />
  payload format (e.g. {"input16":{"value":true}}) stay the same?<br />
<br />
Thank you!]]></description>
<br />
<br />
<br />
<br />
My questions:<br />
<br />
Thank you!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16 – KCS v2.2.20 MQTT protocol documentation and availability (LWT)]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9915</link>
			<pubDate>Tue, 27 Oct 2026 22:41:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9915</guid>
			<description><![CDATA[Hello KinCony team,<br />
<br />
I am using a KC868-A16 (original ESP32 v1.6, not A16v3) with KCS firmware v2.2.20 (build date Apr 2 2026), integrated into Home Assistant via MQTT (Mosquitto broker). Everything works: I control the outputs with {"outputN":{"value":true/false}} on KC868_A16/&lt;serial&gt;/SET and I read inputs and outputs from KC868_A16/&lt;serial&gt;/STATE.<br />
<br />
I would like to use all the features of the board, so I have a few questions:<br />
<br />
1. Complete MQTT documentation<br />
Could you please send me the latest and complete MQTT protocol document for KCS v2.2.20? I need the full list of topics, commands and payload fields, including outputs, digital inputs, HT1–HT3 inputs, analog inputs (ADC), temperature/humidity sensors, RF 433 MHz, and any other parameter available via MQTT.<br />
<br />
2. Availability / Last Will (LWT)<br />
Does KCS v2 publish an availability or Last Will message (online/offline) when the board connects or disconnects from the broker? If yes, which topic and payload does it use? If not, is it possible to add it in a future firmware version?<br />
<br />
3. Home Assistant MQTT Auto Discovery<br />
Is Home Assistant MQTT auto discovery supported in KCS v2 for the KC868-A16, or only in KCS v3? If it is supported, where can I enable it?<br />
<br />
4. Pulse command with duration<br />
At the moment I use the "delay" output type in the web interface to create a pulse. Is there an MQTT command to send a pulse with a duration specified in the payload (for example "turn on output 5 for 300 ms"), so that the timing can be chosen per command?<br />
<br />
5. Other commands<br />
- Is there a command to request the full current state (refresh/query)?<br />
- Is there a toggle command for outputs?<br />
- Can the board publish its state periodically (heartbeat), and is the interval configurable?<br />
- Are STATE messages published with the retain flag, and can this be configured?<br />
<br />
6. Values for sensors not connected<br />
I see "temperature":-100 and "humidity":-100 for sensors that are not connected. Can you confirm that -100 always means "no sensor"?<br />
<br />
7. Firmware<br />
Is v2.2.20 the latest KCS v2 firmware for the KC868-A16? Is a changelog available?<br />
<br />
If you also have HTTP or TCP protocol documents for KCS v2, I would appreciate them too.]]></description>
			<content:encoded><![CDATA[Hello KinCony team,<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
7. Firmware<br />
<br />
If you also have HTTP or TCP protocol documents for KCS v2, I would appreciate them too.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[IFTTT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9865</link>
			<pubDate>Mon, 12 Oct 2026 21:48:46 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8059">newdos</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9865</guid>
<br />
I wanted to use KCS firmware and IFTTT to control a relay on and off, by using an adc input from a potentiometer which would act as the temp setpoint, then if actual temp measured by temp sensor was below the adc setpoint, it switches the relay on.   Problem seems to be you cannot use the actual adc value in ifttt to comapre to the temp sensor value(unless you tell me otherwise).  So it looks like I will have to use arduino code.  So my question would be how do i then monitor all the inputs, outputs, sdcvalues  and temp sensors etc.  Do I have to use home assistant or arduino web server Tasmota etc ??  no isea what is the best way to do this ?<br />
<br />
TIA]]></description>
<br />
<br />
TIA]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Update to latest esphome]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9853</link>
			<pubDate>Sat, 03 Oct 2026 03:10:17 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10077">Elgatoguiri</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9853</guid>
			<description><![CDATA[Hey,<br />
<br />
I've got a kinkony a16 board running esphome connected through ethernet cable to homeassistant.<br />
<br />
[*]Installation method Home Assistant OS:<br />
[*]Core 2025.9.4 <br />
[*]Supervisor 2026.09.3 <br />
[*]Operating System 16.2 <br />
<br />
[*]ESPHome Device Builder:<br />
  <br />
Current version: 2025.9.2<br />
<br />
[*]Everything works as expected but I need to update. I've updated esphome to 2026.9.1 without updating homeassistant and all the switches gone offline. I've done a restart then I just restored the previous system and all works again.<br />
<br />
[*]Does the board require some special settings for esphome 2026.9.1 ?<br />
<br />
Thanks!<br />
[*]]]></description>
			<content:encoded><![CDATA[Hey,<br />
<br />
<br />
<br />
  <br />
<br />
<br />
<br />
Thanks!<br />
[*]]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16 – Using AI3/AI4 (0–5V) as 4–20mA Inputs Without Replacing SMD Resistors]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9831</link>
			<pubDate>Mon, 14 Sep 2026 15:26:52 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11780">ramiavdiel</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9831</guid>
			<description><![CDATA[Hi KinCony,<br />
We are using the KC868-A16 and need four 4–20mA inputs.<br />
AI1 and AI2 are already configured for 4–20mA, while AI3 and AI4 are configured for 0–5V.<br />
We understand from the schematic that converting AI3/AI4 internally would normally require replacing the SMD resistors (5.1kΩ / 10kΩ network with the 0Ω / 150Ω configuration used on AI1/AI2).<br />
We would prefer not to modify or solder components on the PCB.<br />
We tested an external solution on AI3 by connecting a 220Ω resistor externally across the analog input and GND.<br />
With a 4–20mA pH output connected, the controller showed pH 2.41, and we measured approximately 1.460V at the AI3 input. After taking the existing internal resistor network into account and applying the appropriate conversion in our ESP32 firmware, we were able to obtain almost the same pH value.<br />
The measurement also appears electrically stable at the input.<br />
Our question: Is using an external resistor in this way a safe and recommended solution for continuously using AI3 and AI4 as 4–20mA inputs?<br />
Is there any disadvantage or protection/accuracy issue compared with changing the onboard resistors?<br />
If you recommend a different external solution that does not require PCB soldering, please let us know.<br />
Thank you.]]></description>
			<content:encoded><![CDATA[Hi KinCony,<br />
Thank you.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16 Outputs Y01-Y16: 12V LED works weakly when OFF and turns OFF when ON]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9815</link>
			<pubDate>Wed, 09 Sep 2026 23:53:03 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11726">miguelsa</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9815</guid>
			<description><![CDATA[I recently purchased a KC868-A16 and I am currently testing the outputs before integrating the board into an automation project.<br />
<br />
I am having an unexpected behavior with the Y1-Y16 outputs and would like to confirm whether this is normal or whether there may be an issue with the board or its configuration.<br />
<br />
I am powering the KC868-A16 with a 12V DC power supply through the DC input. I also connected the 12V+ from the power supply to the 12V+ terminals of both output terminal blocks, one for Y1-Y8 and another for Y9-Y16.<br />
<br />
For the load, I am testing a simple 12V LED with two wires, red (+) and black (-). I connect the red wire to 12V+ and the black wire to an output such as Y9.<br />
<br />
I initially tested the outputs using ESPHome with Home Assistant. I also tested the hardware independently using Arduino IDE and direct I2C communication with the PCF8574 at address 0x25, which controls Y09-Y16, so the behavior is not related to ESPHome or Home Assistant.<br />
<br />
With the Arduino test, I directly write 0xFF and 0xFE to the PCF8574 to toggle P0/Y09.<br />
<br />
The behavior is:<br />
P0 = HIGH / 0xFF<br />
Y9 measures approximately 10 to 11V<br />
The external 12V LED is always ON, but only at low brightness.<br />
<br />
P0 = LOW / 0xFE<br />
Y9 measures approximately 0V<br />
The external 12V LED turns OFF<br />
<br />
When I connect the same 12V LED directly between the 12V+ and GND terminals of the board, it lights at full brightness as expected.<br />
<br />
Therefore, the power supply and LED appear to be working correctly.<br />
<br />
I also tested several outputs, including Y1 and Y9, and they show the same behavior.<br />
<br />
Could someone from KinCony please clarify the expected electrical behavior of the Y1-Y16 MOSFET outputs on the KC868-A16?<br />
<br />
The board is a KC868-A16 Rev. 1.6.3<br />
I would appreciate any guidance regarding the correct wiring and the expected output voltage/current behavior for this revision.<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10510" target="_blank" title="">photo_2026-09-09_12-51-22.jpg</a> (Size: 475.27 KB / Downloads: 164)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10511" target="_blank" title="">photo_2026-09-09_12-51-46.jpg</a> (Size: 649.1 KB / Downloads: 169)
			<content:encoded><![CDATA[I recently purchased a KC868-A16 and I am currently testing the outputs before integrating the board into an automation project.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[KCS v3 - Remote modification of Timer/IFTTT rules from Home Assistant]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9519</link>
			<pubDate>Sat, 20 Jun 2026 06:27:18 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11040">vsadnik11</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9519</guid>
			<description><![CDATA[Hello KinCony Team,<br />
We are using a KC868-A16 controller with KCS v3 firmware and Home Assistant integration.<br />
Our project requires the following functionality:<ul class="mycode_list"><li>Home Assistant should be able to modify fountain schedules (pump and lighting operating times).<br />
</li>
<li>The schedules must be stored inside the KC868 controller.<br />
</li>
<li>If Home Assistant, MQTT broker, network, or Internet connection fails, the controller must continue operating autonomously according to the last received schedule.<br />
</li>
</ul>
We have already successfully tested:<ul class="mycode_list"><li>MQTT integration with Home Assistant<br />
</li>
<li>Scene Mode<br />
</li>
<li>Custom Protocol (UDP)<br />
</li>
<li>Local IFTTT rules<br />
</li>
<li>Local Timer rules<br />
</li>
</ul>
Our questions are:<br />
<ol type="1" class="mycode_list"><li>Is there any official API (HTTP, MQTT, TCP, UDP, Custom Protocol, etc.) that allows remote creation, modification, enabling/disabling, or updating of Timer rules from Home Assistant or another external system?<br />
</li>
<li>Is it possible to remotely modify Time-based IFTTT rules and save those changes permanently in controller memory?<br />
</li>
<li>Is there any documented method to upload a schedule configuration to the controller programmatically?<br />
</li>
<li>If this is not supported by KCS v3, what is the recommended KinCony solution for a system where schedules must remain operational after Home Assistant, MQTT, network, or Internet failure?<br />
</li>
</ol>
Another question:<br />
We can't find a way to create a schedule that works as a time range.<br />
For example:<ul class="mycode_list"><li>The pump turns ON at 09:00<br />
</li>
<li>The pump turns OFF at 23:00<br />
</li>
</ul>
or<ul class="mycode_list"><li>The light turns ON at 18:00<br />
</li>
<li>The light turns OFF at 23:00<br />
</li>
</ul>
If KCS has a built-in feature that allows us to create, modify, and activate such schedules programmatically, it would solve most of our requirements.<br />
In IFTTT, we can only create a rule such as:<ul class="mycode_list"><li>If time is 09:00 → turn pump ON<br />
</li>
</ul>
However, if communication with Home Assistant is lost at 09:05, the 09:00 event has already passed and the rule will not run again.<br />
For example:<ul class="mycode_list"><li>Pump schedule: 09:00 ON, 23:00 OFF<br />
</li>
<li>Home Assistant fails at 09:05<br />
</li>
<li>The controller switches to autonomous mode<br />
</li>
</ul>
In this situation, the pump will not turn ON because the 09:00 event was missed.<br />
Could you please explain the recommended way to implement autonomous operating schedules in KCS v3 when Home Assistant may become unavailable, but the controller must continue operating correctly according to its schedule?<br />
We are trying to avoid developing custom firmware and would like to use standard KCS v3 functionality if possible.<br />
Thank you very much for your support.]]></description>
			<content:encoded><![CDATA[Hello KinCony Team,<br />
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</ol>
</li>
</li>
</ul>
</li>
</li>
</ul>
</li>
</ul>
</li>
</li>
</li>
</ul>
Thank you very much for your support.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Wiegand]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9479</link>
			<pubDate>Sat, 13 Jun 2026 02:48:35 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6729">williemcvillage</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9479</guid>
			<description><![CDATA[Hi, is there a way to use any of the GPIOs of this board to connect a Wiegand reader?<br />
<br />
Thanks]]></description>
			<content:encoded><![CDATA[Hi, is there a way to use any of the GPIOs of this board to connect a Wiegand reader?<br />
<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[connect 2 KC868 to homeassistant with mqtt broker Mosquitto]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9448</link>
			<pubDate>Tue, 09 Jun 2026 16:33:15 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10009">guycaluwaerts</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9448</guid>
			<description><![CDATA[Dear,<br />
<br />
I try to integrate 2 Kincony boards ( KC868-A16 an KC868-AP) in Homeassistant by mqtt broker Mosquitto.<br />
<br />
For the board kc868-A16 I made the correct settings I think.<br />
<br />
Mqtt : enable<br />
broker address : mqtt://192.168.0.157<br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', Roboto, 'Helvetica Neue', Arial, 'PingFang SC', 'Hiragino Sans GB', 'Microsoft YaHei', sans-serif;" class="mycode_font">broker port : 1883</span></span><br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Helvetica Neue, Arial, PingFang SC, Hiragino Sans GB, Microsoft YaHei, sans-serif;" class="mycode_font">broker username : mqtt</span></span><br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Helvetica Neue, Arial, PingFang SC, Hiragino Sans GB, Microsoft YaHei, sans-serif;" class="mycode_font">broker password : 123</span></span><br />
<br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Helvetica Neue, Arial, PingFang SC, Hiragino Sans GB, Microsoft YaHei, sans-serif;" class="mycode_font">In the screen ' monitor' : status mqtt : connected.</span></span><br />
<br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Helvetica Neue, Arial, PingFang SC, Hiragino Sans GB, Microsoft YaHei, sans-serif;" class="mycode_font">My problem is the integration in homeassistant. I followed your tutorial, but at step 3, I don't understand how you imported the yaml files of your boards in the file editor.</span></span><br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Helvetica Neue, Arial, PingFang SC, Hiragino Sans GB, Microsoft YaHei, sans-serif;" class="mycode_font">Is it possible to explain how to import the yaml files for the boards KC868-A16 and KC868-AP ?</span></span><br />
<br />
<span style="color: #4d5259;" class="mycode_color"><span style="font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Helvetica Neue, Arial, PingFang SC, Hiragino Sans GB, Microsoft YaHei, sans-serif;" class="mycode_font">Second question : When I connect the secondboard ( KC868-AP), can I use the same settings for the mqtt broker ?<br />
</span></span><br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10017" target="_blank" title="">ScreenShot_9_06_2026_10_05_45.png</a> (Size: 10.08 KB / Downloads: 204)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10018" target="_blank" title="">ScreenShot_9_06_2026_10_06_07.png</a> (Size: 7.68 KB / Downloads: 273)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10019" target="_blank" title="">ScreenShot_9_06_2026_10_32_32.png</a> (Size: 25.37 KB / Downloads: 204)
			<content:encoded><![CDATA[Dear,<br />
<br />
<br />
<br />
Mqtt : enable<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[Las Firmware ?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9340</link>
			<pubDate>Mon, 18 May 2026 18:22:48 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7227">jltluc57</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9340</guid>
I currently have firmware version 2.2.12 on my KC868_A16 board.<br />
Is there a newer firmware version?<br />
<br />
Could you provide a link?<br />
<br />
Thank you]]></description>
<br />
<br />
Thank you]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[4x a16 modbus between]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9301</link>
			<pubDate>Sat, 02 May 2026 17:00:50 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7518">wchpikus</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9301</guid>
			<description><![CDATA[Hello.<br />
Esphome, is it possible to control some output in one controler using input from other controller using modbus?<br />
Via lan i can use post to webserver (bdw i can not find read status example using get).<br />
Somebody has some yaml example how to do connection like this?<br />
I like to set by software controlling light without cross switches cable between a16.<br />
Just set some script and connect input to script what will be toggle output in remote output with read state.<br />
Regards]]></description>
			<content:encoded><![CDATA[Hello.<br />
Regards]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Complete Home Assistant configuration.yaml with yaml anchor for mqtt integration A16]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9241</link>
			<pubDate>Fri, 17 Apr 2026 05:14:48 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6838">korl</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9241</guid>
			<description><![CDATA[Hello everyone,<br />
<br />
I see many people asking for configuration.yaml for A16, A6..etc.<br />
<br />
Every person is spending time, building their own yaml-file.<br />
<br />
Could you just provide a complete template for each board (A16, A6), that combines all switches, binary_sensors, ADCs, DACs, Temperature sensors... in one text block, combines as one device (with yaml anchor) ready to copy into Home Assistant configuration.yaml?<br />
<br />
I think it would make the boards more attractive, if there is an easier start for integration.<br />
<br />
Does anyone want to share their configuration.yaml?<br />
<br />
Best wishes]]></description>
			<content:encoded><![CDATA[Hello everyone,<br />
<br />
<br />
<br />
<br />
<br />
<br />
Best wishes]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Kincony KC868-A16 (ESP32) - I2C PCF8574 entities visible in HA but not responding (I2]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9133</link>
			<pubDate>Wed, 18 Mar 2026 01:41:10 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10573">bobbisasha</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9133</guid>
			<description><![CDATA[<span style="color: #000000;" class="mycode_color">Hi everyone,</span><br />
<span style="color: #000000;" class="mycode_color">I’m struggling with a <span style="font-weight: bold;" class="mycode_b">Kincony KC868-A16</span> board (ESP32-based) integrated with <span style="font-weight: bold;" class="mycode_b">ESPHome</span> in Home Assistant. I can see all the entities (switches and binary sensors) in my HA dashboard, but none of the physical relays or digital inputs are responding.</span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-weight: bold;" class="mycode_b">The Hardware:</span></span><ul class="mycode_list"><li><span style="color: #000000;" class="mycode_color">Board: Kincony KC868-A16 (V1.5 or similar with 4x PCF8574 IO Expanders).</span><br />
</li>
<li><span style="color: #000000;" class="mycode_color">Power: Externally powered with a stable <span style="font-weight: bold;" class="mycode_b">12V 2A</span> DC supply.</span><br />
</li>
<li><span style="color: #000000;" class="mycode_color">Checked with Multimeter: PCF8574 chips are correctly powered at <span style="font-weight: bold;" class="mycode_b">3.3V</span>.</span><br />
</li>
</ul>
<span style="color: #000000;" class="mycode_color"><span style="font-weight: bold;" class="mycode_b">The Problem:</span> When I toggle a switch in Home Assistant, the UI icon turns "ON" for a split second and then immediately reverts to "OFF". This suggests an I2C communication timeout or write failure. No physical "click" is heard from the relays, and LEDs don't light up.</span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-weight: bold;" class="mycode_b">ESPHome Logs:</span> The I2C scan successfully finds all 4 chips at the expected addresses:</span><ul class="mycode_list"><li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>Found device at address 0x21</code></div></div><span style="color: #000000;" class="mycode_color"> (Inputs)</span><br />
</li>
<li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>Found device at address 0x22</code></div></div><span style="color: #000000;" class="mycode_color"> (Inputs)</span><br />
</li>
<li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>Found device at address 0x24</code></div></div><span style="color: #000000;" class="mycode_color"> (Outputs/Relays)</span><br />
</li>
<li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>Found device at address 0x25</code></div></div><span style="color: #000000;" class="mycode_color"> (Outputs/Relays)</span><br />
</li>
</ul>
<span style="color: #000000;" class="mycode_color">Log output: </span><br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>[C][pcf8574:024]: PCF8574: Is PCF8575: NO, Address: 0x24</code></div></div><span style="color: #000000;" class="mycode_color"> However, when I trigger a relay, nothing happens physically.</span><br />
<br />
<span style="color: #000000;" class="mycode_color">here some .yaml config examples for my digital sensors and outputs: </span><br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>remote_receiver:<br />
  pin:<br />
    number: GPIO2<br />
    ignore_strapping_warning: true # Could this be interfering with I2C boot?<br />
<br />
remote_transmitter:<br />
  pin:<br />
    number: GPIO15<br />
    ignore_strapping_warning: true<br />
  carrier_duty_percent: 100%<br />
<br />
i2c:<br />
  sda: GPIO4<br />
  scl:<br />
    number: GPIO5<br />
    #ignore_strapping_warning: true<br />
  scan: true<br />
<br />
pcf8574:<br />
  - id: 'pcf8574_hub_out_1' # for output channel 1-8<br />
    address: 0x24<br />
  - id: 'pcf8574_hub_out_2' # for output channel 9-16<br />
    address: 0x25<br />
  - id: 'pcf8574_hub_in_1' # for input channel 1-8<br />
    address: 0x22<br />
  - id: 'pcf8574_hub_in_2' # for input channel 9-16<br />
    address: 0x21<br />
<br />
binary_sensor:<br />
  - platform: gpio<br />
    name: 'Digital Input 01'<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
      inverted: true<br />
    internal: false<br />
<br />
switch:<br />
    name: 'Ouput Relay 01'<br />
    restore_mode: RESTORE_DEFAULT_OFF<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
      inverted: false<br />
    internal: false</code></div></div>]]></description>
			<content:encoded><![CDATA[<span style="color: #000000;" class="mycode_color">Hi everyone,</span><br />
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</ul>
<br />
  pin:<br />
    number: GPIO2<br />
<br />
  pin:<br />
<br />
i2c:<br />
  sda: GPIO4<br />
  scl:<br />
    number: GPIO5<br />
  scan: true<br />
<br />
pcf8574:<br />
    address: 0x24<br />
    address: 0x25<br />
    address: 0x22<br />
    address: 0x21<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
switch:<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
    internal: false</code></div></div>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9087</link>
			<pubDate>Wed, 04 Mar 2026 10:53:53 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10512">kaobeiker</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9087</guid>
			<description><![CDATA[The A18v2 is configured with MQTT, but the device's own monitor shows the MQTT status as disconnected, and Home Assistant does not recognize the device.<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9245" target="_blank" title="">1.png</a> (Size: 21.89 KB / Downloads: 390)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9246" target="_blank" title="">2.png</a> (Size: 14.38 KB / Downloads: 353)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9247" target="_blank" title="">3.png</a> (Size: 11.14 KB / Downloads: 374)
			<content:encoded><![CDATA[The A18v2 is configured with MQTT, but the device's own monitor shows the MQTT status as disconnected, and Home Assistant does not recognize the device.<br /><!-- start: postbit_attachments_attachment -->
		</item>
		<item>
			<title><![CDATA[Ethernetproblems]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8896</link>
			<pubDate>Fri, 09 Jan 2026 23:42:28 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10196">Erik G</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8896</guid>
			<description><![CDATA[New unit!<br />
Installed KCS<br />
(Loaded .bin-file via USB, looks loading OK)<br />
Search withe IPScanner for the unit, dont find it!<br />
No LEDs is flashing at all on the net-cable<br />
Try to reset &gt;10sek with Dowload-button and/or Reset-button, nothing changes!<br />
Any other way to hardware-reset<br />
Any idea?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8920" target="_blank" title="">1.jpg</a> (Size: 235.68 KB / Downloads: 276)
			<content:encoded><![CDATA[New unit!<br />
Installed KCS<br />
		</item>
	</channel>
</rss>
