	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-A32/A32 Pro]]></title>
		<pubDate>Fri, 06 Nov 2026 19:42:51 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[KC868-A32 Malfunction After Seven Months of Continuous Operation]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9715</link>
			<pubDate>Mon, 03 Aug 2026 08:52:35 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9788">sson6203</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9715</guid>
			<description><![CDATA[<span style="color: #000000;" class="mycode_color">Hello,</span><br />
<span style="color: #000000;" class="mycode_color">I am an installation engineer in South Korea, and I have built a room control system using the KC868-A32.</span><br />
<span style="color: #000000;" class="mycode_color">The KC868-A32 board has been powered on continuously for approximately seven months without being turned off, and it has been used to control the lighting system.</span><br />
<span style="color: #000000;" class="mycode_color">Today, the lights suddenly stopped working properly. Whenever I turned the lights on, they turned off again shortly afterward.</span><br />
<span style="color: #000000;" class="mycode_color">I built the system to communicate with the board remotely via MQTT. The MQTT connection status showed that it was connected normally.</span><br />
<span style="color: #000000;" class="mycode_color">However, when I checked the “Monitor” page on the board’s web interface, the input and output status indicators were not displayed, unlike during normal operation.</span><br />
<span style="color: #000000;" class="mycode_color">Finally, I performed a factory reset, and everything started working normally again.</span><br />
<span style="color: #000000;" class="mycode_color">Could you please advise what may have caused this issue and how I can prevent it from happening again?</span><br />
<span style="color: #000000;" class="mycode_color">Do I need to continue performing a factory reset whenever this issue occurs, or is there another recommended solution?</span><br />
<span style="color: #000000;" class="mycode_color">Thank you.</span><br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10302" target="_blank" title="">KakaoTalk_Photo_2026-08-03-09-50-14.png</a> (Size: 21.84 KB / Downloads: 233)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10303" target="_blank" title="">KakaoTalk_Photo_2026-08-03-09-50-25.png</a> (Size: 21.58 KB / Downloads: 203)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10304" target="_blank" title="">KakaoTalk_Photo_2026-08-03-09-51-29 001.png</a> (Size: 11.97 KB / Downloads: 228)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10305" target="_blank" title="">KakaoTalk_Photo_2026-08-03-09-51-29 002.png</a> (Size: 20.41 KB / Downloads: 210)
			<content:encoded><![CDATA[<span style="color: #000000;" class="mycode_color">Hello,</span><br />
		</item>
		<item>
			<title><![CDATA[Digital input GND]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9223</link>
			<pubDate>Fri, 10 Apr 2026 01:35:44 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10718">Korenktom</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9223</guid>
<br />
I have a question about the wiring diagram of the Kincony KC868 A32 board. The board has 32 digital inputs, where each group of 8 inputs shares one GND pin.<br />
<br />
My question is: Does it matter which GND I use for the signal inputs, or do I need to follow a specific mapping - for example, inputs 1-8 only against the GND designated for that group? Or can I use just one GND pin for all 32 inputs?<br />
<br />
Thank you for clarification.]]></description>
<br />
<br />
<br />
Thank you for clarification.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A32 : PSU 24VDC]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8825</link>
			<pubDate>Wed, 17 Dec 2025 20:50:02 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=976">nicolouts</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8825</guid>
<br />
Could I use a PSU 24VDC to supply power to kc868-a32 rev 1.4?<br />
<br />
Thanks in advance<br />
<br />
Regards<br />
<br />
Nicolouts]]></description>
<br />
<br />
<br />
Regards<br />
<br />
Nicolouts]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-32 arduino ide]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8623</link>
			<pubDate>Fri, 03 Oct 2025 16:28:07 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9629">martin</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8623</guid>
			<description><![CDATA[I have a new KC868-32. With USB connection, I loaded the exemple"01-control-one-relay" code from arduino ide. On the serial monitor I get the correct responses: "open relay 2 success" . But nothing happen on the board in reality. The relay is not switching. Do you know what could be the reason?  Thank you very much indeed]]></description>
			<content:encoded><![CDATA[I have a new KC868-32. With USB connection, I loaded the exemple"01-control-one-relay" code from arduino ide. On the serial monitor I get the correct responses: "open relay 2 success" . But nothing happen on the board in reality. The relay is not switching. Do you know what could be the reason?  Thank you very much indeed]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[A32 pro and IFTTT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8324</link>
			<pubDate>Sat, 19 Jul 2025 05:43:08 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=4507">fdcemb5</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8324</guid>
			<description><![CDATA[I have configured IFTTT to send an SMS once DI1 is True, but it doesn't send an SMS when DI1 is True. I changed DI to false it was the same result. <br />
<br />
I did test 4G SIM7600 and it worked perfectly. It can send the test SMS and can make test call. But in IFTTT configuration, it does'nt send SMS or make call.]]></description>
			<content:encoded><![CDATA[I have configured IFTTT to send an SMS once DI1 is True, but it doesn't send an SMS when DI1 is True. I changed DI to false it was the same result. <br />
<br />
I did test 4G SIM7600 and it worked perfectly. It can send the test SMS and can make test call. But in IFTTT configuration, it does'nt send SMS or make call.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[A32 Pro]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8288</link>
			<pubDate>Thu, 03 Jul 2025 04:20:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8288</guid>
			<description><![CDATA[I have flashed the A32 Pro with Kincony firmware and signed in, enabled auto-discovery, but I cannot see the device in Home Assistant. Is there any additional step required to integrate the A32 Pro with Home Assistant?]]></description>
			<content:encoded><![CDATA[I have flashed the A32 Pro with Kincony firmware and signed in, enabled auto-discovery, but I cannot see the device in Home Assistant. Is there any additional step required to integrate the A32 Pro with Home Assistant?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Wired ZigBee 3.0 integration with HA]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8285</link>
			<pubDate>Wed, 02 Jul 2025 06:40:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8285</guid>
			<description><![CDATA[I am trying to integrate a wired ZigBee  3.0 gateway, but I encountered an error during the integration phase, as illustrated in the attached screenshot]]></description>
			<content:encoded><![CDATA[I am trying to integrate a wired ZigBee  3.0 gateway, but I encountered an error during the integration phase, as illustrated in the attached screenshot]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC 868 A32]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8145</link>
			<pubDate>Sun, 08 Jun 2025 18:26:52 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=3518">SP9HYX</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8145</guid>
			<description><![CDATA[Good day<br />
Some time ago I bought KC868 A32 and today I tried to connect to the board for the second time. I updated the driver Regarding CH341. On one of the laptops I have W11 and on the other W10/<br />
1. I am trying to scan AP via wifi and it is not on two laptops and a phone (there is no such network - kv868)<br />
2. I am doing a scan (IP scanner) through the router and directly connected to the laptop socket - no effect.<br />
3. I am trying to scan if UPD Scan will show the board but it does not see it<br />
Please help.]]></description>
			<content:encoded><![CDATA[Good day<br />
Please help.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[create cover buttons for two relay using MQTT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8113</link>
			<pubDate>Tue, 27 May 2025 14:28:37 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8113</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7699" target="_blank" title="">mqtt-cover-HA-config-yaml.png</a> (Size: 52.75 KB / Downloads: 897)
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>mqtt:<br />
  cover:<br />
      name: "MQTT Cover"<br />
      command_topic: 'A32PRO/DCDA0C7B8568/SET'<br />
      state_topic: 'A32PRO/DCDA0C7B8568/STATE'<br />
     # availability:<br />
     # - topic: "home-assistant/cover/availability"<br />
      qos: 0<br />
      retain: true<br />
      payload_open: '{"output1":{"value":true}}'<br />
      payload_close: '{"output2":{"value":true}}'<br />
      payload_stop: '{"output1":{"value":false}, "output2":{"value":false}}'<br />
<br />
      value_template: &gt;<br />
        {% if value_json.output1.value and not value_json.output5.value %}<br />
          open<br />
        {% elif value_json.output5.value and not value_json.output1.value %}<br />
          closed<br />
        {% elif not value_json.output1.value and not value_json.output5.value %}<br />
          stopped<br />
        {% else %}<br />
          unknown<br />
        {% endif %}<br />
<br />
      state_opening: "open"<br />
      state_closing: "closed"<br />
      state_stopped: "stopped"<br />
<br />
      payload_available: "online"<br />
      payload_not_available: "offline"<br />
      optimistic: false<br />
<br />
<br />
  switch:<br />
   - name: 'a32pro-kcs-output-1'<br />
     unique_id: a32pro-kcs-output-1<br />
     payload_on:  '{"output1":{"value":true}}'<br />
     payload_off:  '{"output1":{"value":false}}'<br />
     value_template: '{{ value_json.output1.value }}'<br />
     state_on: true<br />
     state_off: false<br />
<br />
   - name: 'a32pro-kcs-output-2'<br />
     unique_id: a32pro-kcs-output-2<br />
     payload_on:  '{"output2":{"value":true}}'<br />
     payload_off:  '{"output2":{"value":false}}'<br />
     value_template: '{{ value_json.output2.value }}'<br />
     state_off: false</code></div></div>]]></description>
  cover:<br />
      qos: 0<br />
      retain: true<br />
<br />
          open<br />
          closed<br />
          stopped<br />
        {% else %}<br />
          unknown<br />
        {% endif %}<br />
<br />
<br />
<br />
<br />
  switch:<br />
<br />
     state_off: false</code></div></div>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A32 Shutter with percentage]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8083</link>
			<pubDate>Fri, 16 May 2025 18:55:18 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8656">Mert</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8083</guid>
I have a <span style="font-weight: bold;" class="mycode_b">KC868-A32</span> device, and I would like to use it for <span style="font-weight: bold;" class="mycode_b">roller shutter (blind) control</span>, ideally with integration into <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>.<br />
I’ve tried using <span style="font-weight: bold;" class="mycode_b">ESPHome</span>, but the outputs were only recognized as <span style="font-weight: bold;" class="mycode_b">switches</span>, not as <span style="font-weight: bold;" class="mycode_b">covers</span>.<br />
My questions:<br />
<ol type="1" class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">How can I use my KC868-A32 for roller shutter control, including percentage-based position control?</span><br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Which firmware is best suited for this purpose: ESPHome, Tasmota, or Tuya?</span><br />
</li>
</ol>
]]></description>
My questions:<br />
</li>
</li>
</ol>
		</item>
		<item>
			<title><![CDATA[Relay type - Can I use DC?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8026</link>
			<pubDate>Tue, 29 Apr 2025 01:41:11 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8504">polarkreis</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8026</guid>
			<description><![CDATA[Can I use 24V DC instead of 230V AC on relays?<br />
<br />
I would like to use them to activate my 24VDC activated contactor (and then contactor would let 230V AC to pass through).]]></description>
			<content:encoded><![CDATA[Can I use 24V DC instead of 230V AC on relays?<br />
<br />
I would like to use them to activate my 24VDC activated contactor (and then contactor would let 230V AC to pass through).]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Rated power]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8015</link>
			<pubDate>Fri, 25 Apr 2025 03:02:28 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8478">tidek1507</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8015</guid>
			<description><![CDATA[Hi<br />
<br />
I have a question about A32 PRO. What is the maximum power consumption of this device?<br />
<br />
Thanks]]></description>
			<content:encoded><![CDATA[Hi<br />
<br />
<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Kc-868-a32 uart]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7952</link>
			<pubDate>Sat, 19 Apr 2025 02:51:58 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7518">wchpikus</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7952</guid>
			<description><![CDATA[Hello<br />
What ping are used to rs485?<br />
Failed config<br />
<br />
uart: [source /config/esphome/rolety-kc868-a32.yaml:27]<br />
  - id: uart_modbus<br />
    baud_rate: 9600<br />
    tx_pin: 9<br />
    <br />
    This pin cannot be used on ESP32s and is already used by the flash interface (function: Flash Data 1).<br />
    rx_pin: 8<br />
<br />
Regards]]></description>
			<content:encoded><![CDATA[Hello<br />
Failed config<br />
<br />
    tx_pin: 9<br />
    <br />
    rx_pin: 8<br />
<br />
Regards]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC 868-A32]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7946</link>
			<pubDate>Wed, 16 Apr 2025 18:02:34 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6126">simona</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7946</guid>
			<description><![CDATA[i am trying to enable one of my A32 Board modbus slave using the firmware if i go to protocol&gt; general it will log me out .What is the issue. Other boards work well but one doesnt]]></description>
			<content:encoded><![CDATA[i am trying to enable one of my A32 Board modbus slave using the firmware if i go to protocol&gt; general it will log me out .What is the issue. Other boards work well but one doesnt]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[A32PRO - multiple 1-wire]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7819</link>
			<pubDate>Mon, 17 Mar 2025 22:49:35 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7060">RichieNa</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7819</guid>
I use A32PRO with software version v3.4.0 only via KCS web page and then to Loxone. I also bought several DS18B20 sensors with A32PRO, but only later I found out that I can only connect 1+1 piece to W1 and W2. I found a few posts here that solve this via ESP HOME, but I never used them.. How to get support for multiple sensors at once into an already running A32PRO without disrupting my existing settings? Or how can I make a backup of my program in A32PRO, in case something gets disrupted.<br />
Sorry for the noob question, but I have never worked with ESP HOME and I am afraid that I will ruin the existing installation, on which part of my house is already running.<br />
<br />
I found these threads here on the forum:<br />
<a href="https://www.kincony.com/forum/showthread.php?tid=2290" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=2290</a><br />
<a href="https://www.kincony.com/forum/showthread.php?tid=7300&amp;highlight=DS18B20" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread...ht=DS18B20</a><br />
<a href="https://www.kincony.com/forum/showthread.php?tid=7514&amp;highlight=1wire" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread...ight=1wire</a><br />
Can I use one of them to get support for multiple DS18B20 sensors into the KCS firmware and subsequently into Loxone?<br />
<br />
Thank you]]></description>
<br />
<br />
Thank you]]></content:encoded>
		</item>
	</channel>
</rss>
