	<channel>
		<title><![CDATA[Smart Home Automation Forum - Suggestions and feedback on KinCony's products]]></title>
		<pubDate>Sat, 21 Nov 2026 20:06:28 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[Recommended Dimmer for LED Bulbs Using 0–10V Analog Outputs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9926</link>
			<pubDate>Sun, 01 Nov 2026 15:08:24 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=3298">stansvec</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9926</guid>
<br />
I have a few KinCony devices with 0–10V analog outputs (KinCony D16 Dimmer, etc.), and I was disappointed to discover that they don't work well with most LED light bulbs when used with an SSR relay, as recommended. The main problems were that the LED bulbs wouldn't turn off completely, even when the brightness was set to 0%, and there was noticeable flickering. Surprisingly, I found that even other devices on the market, such as the Shelly Pro 2PM Dimmer, suffer from various flickering issues (I tried two different units with the same results).<br />
<br />
I had almost given up on finding a reliable solution for dimming LED light bulbs until I came across this product:  <a href="https://th.aliexpress.com/item/1005008626144271.html" target="_blank" rel="noopener" class="mycode_url">Skydance S1-L RF+ 0/1-10V Push AC Triac Dimmer</a>. It's an AC TRIAC dimmer that can be controlled via a 0–10V analog signal, making it suitable for use with KinCony devices that provide 0–10V analog outputs (dimmers, ...).<br />
<br />
I've just tested it with two E27 LED bulbs and three GU5.3 bulbs, connected to a KinCony KC868-AIO, and the results were impressive. This is by far the smoothest LED bulb dimming I've ever experienced. I hope sharing a product link doesn't violate any forum rules, but I thought this might be useful to others struggling with LED bulb dimming on KinCony devices.]]></description>
<br />
<br />
<br />
I've just tested it with two E27 LED bulbs and three GU5.3 bulbs, connected to a KinCony KC868-AIO, and the results were impressive. This is by far the smoothest LED bulb dimming I've ever experienced. I hope sharing a product link doesn't violate any forum rules, but I thought this might be useful to others struggling with LED bulb dimming on KinCony devices.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Need Advice for New 3-Floor Smart Home Construction Using KinCony Controllers (Nepal)]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9514</link>
			<pubDate>Thu, 18 Jun 2026 22:47:03 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11059">jitendra</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9514</guid>
			<description><![CDATA[Hi everyone ❤️,<br />
I am from Nepal and will start building my new house this month. another controller, which is best for 2 floors, there are many channels needed for 50 channel need for 2 floors  <br />
I already have a KinCony AIO controller and would like to plan the smart home wiring before construction begins.<br />
I have attached my floor plan. Could you please suggest:<ul class="mycode_list"><li>Best switch type (momentary/dry contact)<br />
</li>
<li>I want to bypass the switch also <br />
</li>
<li>I place the floor-wise DB box and want to install it <br />
</li>
<li>Recommended sensors (presence, motion, door, water leak, smoke, etc.)<br />
</li>
<li>RS485 wiring recommendations<br />
</li>
<li>Any important things I should install now for future expansion<br />
</li>
</ul>
Any suggestions or examples would be greatly appreciated.<br />
Thank you very much! ?<br />
Jitendra<br />
Nepal ??<br />
By the way, I lived in Japan. If any person from Nepal wants to import easily,<br /><!-- start: postbit_attachments_attachment -->
<img src="https://www.kincony.com/forum/images/attachtypes/pdf.png" title="Adobe Acrobat PDF" border="0" alt=".pdf" />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10079" target="_blank" title="">Top Floor Plan.pdf</a> (Size: 10.63 KB / Downloads: 250)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10080" target="_blank" title="">Second Floor Plan (1).pdf</a> (Size: 46.44 KB / Downloads: 252)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10081" target="_blank" title="">Ground Floor Plan.pdf</a> (Size: 48.52 KB / Downloads: 234)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10082" target="_blank" title="">First Floor Plan (1).pdf</a> (Size: 53.51 KB / Downloads: 228)
			<content:encoded><![CDATA[Hi everyone ❤️,<br />
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
Jitendra<br />
Nepal ??<br />
		</item>
		<item>
			<title><![CDATA[Add uptime to board information]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9288</link>
			<pubDate>Fri, 24 Apr 2026 14:23:14 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7488">twostar</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9288</guid>
			<description><![CDATA[Would it be possible to add an uptime counter to the KC868 front page?  At the moment it displays system time, IP address, etc, but not how long it's been running.  The reason I'd like to know is that I keep getting sensors going offline briefly and then back online again and I don't know if it's the board rebooting or something else.]]></description>
			<content:encoded><![CDATA[Would it be possible to add an uptime counter to the KC868 front page?  At the moment it displays system time, IP address, etc, but not how long it's been running.  The reason I'd like to know is that I keep getting sensors going offline briefly and then back online again and I don't know if it's the board rebooting or something else.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony Cloud Functions]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9149</link>
			<pubDate>Sat, 21 Mar 2026 16:44:52 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10602">Mihai845</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9149</guid>
			<description><![CDATA[Good day,<br />
<br />
I would like to suggest adding different views option to the KinCony Cloud devices. <br />
It will improve a lot the user experience if we would be able to expand the Device as a list to see the Status of selected inputs/outputs or to be able to view as split screens different devices in a similar way would monitor security cameras for example. <br />
With present view option it's needed to enter each device separately to view or control the outputs, not being able to see what happens with other devices.<br />
<br />
In my case I am using 7 x A16v3, split in 3 Electrical Panels, to control the lights and windows stores in one building and would be much better to be able to see all the selected inputs/outputs combined in one page and also to be able to group or sort them in different views.<br />
<br />
Thank you]]></description>
			<content:encoded><![CDATA[Good day,<br />
<br />
<br />
<br />
Thank you]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[E16V3 - Dimensions compatibility with domestic electrical enclosures]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9147</link>
			<pubDate>Fri, 20 Mar 2026 16:34:32 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10281">ldebacker</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9147</guid>
			<description><![CDATA[The E16V3 can't be nicely integrated in domestic electrical enclosures.<br />
<br />
This forces cutting the plastic of the enclosures, which is not nice.<br />
<br />
It would be good to have a cover compatible with those standardized enclosures:<br />
- Width equal to a number of standard module (18mm I think)<br />
- Height of the prominent part = 45 mm.<br />
<br />
BRs,<br />
<br />
Laurent]]></description>
			<content:encoded><![CDATA[The E16V3 can't be nicely integrated in domestic electrical enclosures.<br />
<br />
<br />
<br />
BRs,<br />
<br />
Laurent]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[E16V3 - Cover electrical insulation]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9146</link>
			<pubDate>Fri, 20 Mar 2026 16:22:39 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9146</guid>
The cover of the E16V3 seems to be coated metal.<br />
<br />
Rigid or semi-rigid wires are screwed on the terminal block , with the risk that the tip of the wire will touch the cover.<br />
<br />
Although the coated layer isolates the cover from the wire, this layer is very thin and the wire could scratch the coating so that the cover could quickly be submitted to high voltage.<br />
<br />
There should be additional isolation between the terminal block and the cover, such as a plastic strip glued to the cover.<br />
<br />
BRs,<br />
<br />
<br />
<br />
<br />
<br />
BRs,<br />
<br />
		</item>
		<item>
			<title><![CDATA[Github ... finally?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9145</link>
			<pubDate>Fri, 20 Mar 2026 15:46:44 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=1639">spacerunner</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9145</guid>
<br />
Being a long time user of Koncony products now, I wonder why not move the Kincony products codebase to GitHub?<br />
<br />
I know this is asked a lot for existing projects / companies. But it would be a great, much more efficient experience for most, if not even all Kincony users / customers.<br />
<br />
Most users today use GitHub, engineers do anyway. As well as the directly connected technologies, for example ESPHome and Tasmota.<br />
<br />
I am confident that this would open a much wider audience on Kinconys products, make issues and pull requests possible and much, much more.<br />
<br />
Do you see a chance of this happening?<br />
<br />
Bet wishes,<br />
Stefan]]></description>
<br />
<br />
<br />
<br />
<br />
<br />
Bet wishes,<br />
Stefan]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[LED dimmer but not 0-10V but PWM]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9081</link>
			<pubDate>Sun, 01 Mar 2026 17:26:28 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9452">Jan_W</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9081</guid>
			<description><![CDATA[Could You consider making ESP32-S3 LED dimmer module but <span style="font-weight: bold;" class="mycode_b">not </span>with 0-10V outputs (like DM16), but MOSFET with PWM Analog Outputs?<br />
<br />
0-10V is great, but it makes everything more complicated when I just want to dimm multiple individual LEDs from single DC source - additional multiple dimmable drivers etc.<br />
<br />
We have nice product from Polish manufacturer - boneIO ESP DImmer LED gen 2 with 8x PWM outputs. It costs 110&#36; and is great, I just wanted to have all from Kincony and cannot find anything like this <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" /><br />
<br />
<a href="https://store.boneio.eu/product/boneio-dimmer-led-gen-2/?v=288404204e3d" target="_blank" rel="noopener" class="mycode_url">https://store.boneio.eu/product/boneio-d...8404204e3d</a><br />
<br />
Please consider making product like this. I think it will be very popular on the Polish market (this boneIO is almost always sold out).<br />
<br />
Thanks!]]></description>
			<content:encoded><![CDATA[Could You consider making ESP32-S3 LED dimmer module but <span style="font-weight: bold;" class="mycode_b">not </span>with 0-10V outputs (like DM16), but MOSFET with PWM Analog Outputs?<br />
<br />
<br />
<br />
<br />
<br />
Thanks!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[E16V3 - Documentation issues]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9071</link>
			<pubDate>Sun, 22 Feb 2026 19:59:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9071</guid>
<br />
There are 2 issues with the documentation of the 4 dip switches to set the slave ID on the bus.<br />
Let's call, from left to right, the 4 dip switches respecively A0 A1 A2 A3.<br />
<br />
1/ <br />
The documentation mentions that when A3 is in OFF state, this means the outputs are controlled by the input terminals (and when in ON state, it is controlled by MODBUS).<br />
It is actually the reverse: When A3 is in OFF state, the device is controlled by MODBUS.<br />
<br />
2/<br />
The documentation specifies that when identifying the slave id, the value of the slave id is:  (A0 * 1  + A1 * 2 + A2 * 4) + 10.<br />
so: A0=ON A1=OFF A2= OFF should give  slave ID  (1 * 1 + 0 * 2 + 0 * 4 ) + 10 = 11 (according to the table in the documentation)<br />
<br />
It is actually the reverse: from trials/errors, the formula to apply seems to be (A0 * 4 + A1 * 2 + A2 * 1) + 10<br />
so: A0=ON A1=OFF A2= OFF is, in reality slave ID  (1 * 4 + 0 * 2 + 0 * 1 ) + 10 = 14 (from experience).]]></description>
<br />
<br />
1/ <br />
<br />
2/<br />
<br />
so: A0=ON A1=OFF A2= OFF is, in reality slave ID  (1 * 4 + 0 * 2 + 0 * 1 ) + 10 = 14 (from experience).]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[E16V3 - No reply if command issued just after another command to another device on th]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9070</link>
			<pubDate>Sun, 22 Feb 2026 19:48:10 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9070</guid>
<br />
I have 2 E16V3 installed as 2 different slaves on the same modbus.<br />
<br />
When I send a command to each in isolation, I  receive a response within a few milli-seconds from the E16V3.<br />
<br />
But when I send a command to the second E16V3 immediately after successful response from the first one, then I never receive the response from the second device.<br />
<br />
It seems that the second E16V3 is puzzled by the activity on the bus that is not intended to himself.<br />
<br />
I have to retry the command to the second E16V3, or wait (20 miliseconds for example) before sending the command to the second E16V3<br />
<br />
I can help troubleshooting further if needed.<br />
<br />
BRs,<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
BRs,<br />
<br />
		</item>
		<item>
			<title><![CDATA[E16V3 - LED operations]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9031</link>
			<pubDate>Mon, 09 Feb 2026 01:10:57 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9031</guid>
<br />
On the E16V3, is there a way to reduce the intensity of the LEDs (throuh a modbus register setting, for example) ?<br />
<br />
Thanks in advance,<br />
<br />
BRs,<br />
<br />
<br />
<br />
<br />
BRs,<br />
<br />
		</item>
		<item>
			<title><![CDATA[E16V3 - Noise reduction]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9030</link>
			<pubDate>Sun, 08 Feb 2026 18:58:17 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9030</guid>
<br />
The E16V3 works great so far.<br />
<br />
I would just like to suggest an enhancement for future versions...<br />
<br />
The relays, when changing state, generate some noise, which is normal.<br />
However, the added cover is metallic, and it resonates quite a lot when the relays are changing state.<br />
<br />
May be some internal isolation could be added to reduce the noise levels ?<br />
<br />
Thanks in advance for considering the suggestion.<br />
<br />
Best regards,<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Best regards,<br />
<br />
		</item>
		<item>
			<title><![CDATA[E16V3 - baudrate change]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8980</link>
			<pubDate>Tue, 03 Feb 2026 00:40:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8980</guid>
<br />
Is there a way to change the default RS485 baudrate (which is 38400 bps) ?<br />
<br />
Any existing register to change the RS485 parameters ?<br />
<br />
Thanks in advance !]]></description>
<br />
<br />
<br />
Thanks in advance !]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[E16v3 - CE]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8979</link>
			<pubDate>Tue, 03 Feb 2026 00:35:12 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8979</guid>
I have seen the CE certificate for the Kincony products here: <a href="https://www.kincony.com/images/patent/CCJS.2411163.pdf" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/images/patent/CCJS.2411163.pdf</a><br />
This certificate mentions The Kincony V2, but not the V3.<br />
Where can I find the certificate for the V3?<br />
		</item>
		<item>
			<title><![CDATA[Feedback: Product line dimensions vs. german cabinet standards and integration densit]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8905</link>
			<pubDate>Tue, 13 Jan 2026 04:02:33 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10211">mkai</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8905</guid>
			<description><![CDATA[Hey there, <br />
<br />
First: I find the Kinkony products very compelling and find it amazing what product lines you built always following the open approach of open hardware with schematics and software support for ESPHome!<br />
<br />
I want to use several actors in my future house to control 230V and Roller/Shutters with ESPHome, but there are some drawbacks preventing me. I'd like to share my thoughts - maybe for your future products <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" /><br />
<br />
- The actors should be installed in a "standard german electrical cabinet" following the standard "DIN 43880:1988-12".<br />
- This standard defines division units (DU) of 17.5mm for DIN-rail devices. The standard cabinet provides a width of 12 DU (12x 17.5 = 210mm) per slot.<br />
- All common smart home devices in Germany follow these standards, e.g., HomeMaticIP Wired, Loxone and KNX. These units are available in 2, 4, 6 or 12 division units to maximize the space utilization in cabinets and provide around 1 relay per DU.<br />
- For my Smart Home, I need a bunch of 230V actors supporting 10A (roller shutter) and 16A relays (switchable sockets / lights) and don't have much space left in the existing cabinets, so integration density is crucial. <br />
<br />
<br />
- Your product line: <br />
-- I find the <a href="https://shop.kincony.com/products/kincony-f16-16ch-esp32-s3-removable-relay-board?variant=44251712323749" target="_blank" rel="noopener" class="mycode_url">F16</a> very compelling, but it exceeds the maximum width of my cabinet slots (262mm F16 vs. 210mm (12DU) cabinet). Costs are ~15 USD/relay.<br />
-- The <a href="https://shop.kincony.com/products/kincony-f8-8ch-esp32-s3-removable-relay-board" target="_blank" rel="noopener" class="mycode_url">F8</a> on the other hand would fit with its 195mm, but only provides a overall poor integration density of 8 relays / 12 DU and has a higher cost per relay (~20 USD/relay). <br />
-- <a href="https://shop.kincony.com/products/kc868-a8v3-esp32-s3-8-channel-relay-module?variant=45601236484261" target="_blank" rel="noopener" class="mycode_url">KC868-A8v3</a> comes with 8x 10A relays, width: 148mm(9 DU), integration density: 8 relays/9DU;  costs: 8USD/relay<br />
   Q: Can't find the schematics for the v3 version. Is there a single PCB variant supporting V12 and V24 power supply (as opposed to the v1 versions where the relays are either 12V or 24V)<br />
<br />
<br />
--&gt; My conclusion: At the current state none of the products really match by requirements, so I want to share some thoughts:<br />
<br />
<br />
Summing up my requirements for the ideal cabinet 230V actor:<br />
- 24V power supply<br />
- Device width following 6 or 12 DU DIN Rail widths<br />
- LAN connection (POE would be nice, but 24V power is also available in the cabinet)<br />
- 23<span style="font-weight: bold;" class="mycode_b">0</span>V outputs: 10 / 16 A relays  <span style="font-weight: bold;" class="mycode_b">(edit: was 23V, intended: 230V)</span><br />
- Inputs: Every relay should have one corresponding opto-coupled dry contact input (24-capable)<br />
- Stand-only functionality: Should work without active connection to the home controller / home assistant. <br />
- High integration density: 1 Relay per 1 DU (17.5mm) as provided by competitors (Loxone, Homematic, KNX)<br />
- NO need for additional interfaces (CAN, Tuya, SDCard, analogue in, etc.). <br />
- costs should not exceed 15USD/ relay<br />
- Housing with proper cover is a must. LEDs should indicate active relays. A display does not matter. An additional RGB-LED showing a general device health-status (power okay, ESPHome connected/disconnected) should be enough.  <br />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">Additional (unstructured) feedback: </span><br />
- I like the idea of having input overrides as the switches in the F-series. But for using them as a roller-shutter actor this can lead to severe problems (powering both up -and down of the roller-shutter at once). While accessing the device by software there will be an mutual lock of Up/Down ESPHome (already provided in their sources). <br />
Could you consider replacing the "permanent switches" with buttons and program a software-behaviour like "hold them for momentary-override" or "double click for permanent on/off"?<br />
- The connectors used in your products are rather large. Could you consider using connectors with a smaller footprints? The reduced size could be used for additional relays on this side of the board (especially good for 12 DU units (6 DU for inputs/power and 6 DU for 4 additional relays).<br />
- Did you know that the company Waveshare (e.g., Modbus POE Eth Relay &copy;) has a nice concept of DIN-rail devices with 2xEthernet/RJ45 POE-in and POE-out? This allows for device chaining, which is super cool for tight cabinet spaces <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" /><br />
- Product selector: <br />
-- Please make separate a selection for 12V and 24V. <br />
-- Filter by size / length<br />
<br />
My background: Electrical Engineer (PCB design / FPGA). Designed several Atmega 328-based devices for my cabinet and want to upgrade for better HomeAssitant integration. I have many more ideas and would be happy to discuss, if you are interested <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" /><br />
<br />
<br />
Best Regards, sorry for the long post and keep up your good work!<br />
<br />
Martin]]></description>
			<content:encoded><![CDATA[Hey there, <br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Martin]]></content:encoded>
		</item>
	</channel>
</rss>
