	<channel>
		<title><![CDATA[Smart Home Automation Forum - Development]]></title>
		<pubDate>Wed, 18 Nov 2026 12:21:28 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[450 Hz allowed on input?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9930</link>
			<pubDate>Mon, 02 Nov 2026 15:08:12 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=12267">Mikkel88</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9930</guid>
			<description><![CDATA[<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Hi KinCony,</span></span><br />
<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">I am using the KC868-A8v3.1 with an ESP32-S3.</span></span><br />
<br />
<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">I want to connect a YF-B10 water flow sensor generating approximately 450 Hz pulses at maximum flow.</span></span><br />
<br />
<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Can AI1 (GPIO7) or AI2 (GPIO6) be used as a digital pulse counter input with ESP32 PCNT?</span></span><br />
<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Specifically:</span></span><br />
<ol type="1" class="mycode_list"><li><span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Is there any RC filtering or other circuitry between the AI terminal and the ESP32 GPIO?</span></span><br />
</li>
<li><span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Can the analog input circuit reliably pass 450 Hz pulses?</span></span><br />
</li>
<li><span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Can you provide an example of using AI1/GPIO7 as a pulse counter with ESPHome or ESP-IDF?</span></span><br />
</li>
</ol>
<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Thank you.</span></span>]]></description>
			<content:encoded><![CDATA[<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Hi KinCony,</span></span><br />
<br />
<br />
</li>
</li>
</li>
</ol>
<span style="font-size: large;" class="mycode_size"><span style="font-family: Times New Roman;" class="mycode_font">Thank you.</span></span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[getting the A8A inputs to work?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9838</link>
			<pubDate>Fri, 18 Sep 2026 21:49:21 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11841">bboett</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9838</guid>
			<description><![CDATA[Hello!<br />
<br />
i have a Kincony A8 i finally try to get working....<br />
the relais i got working, but the inputs don't.... <br />
i flashed from esphome the follwoing:<br />
<br />
esphome:<br />
  friendly_name: relais_wohnung<br />
<br />
esp32:<br />
  variant: esp32<br />
  board: esp32dev<br />
  framework:<br />
    type: arduino<br />
<br />
# I2C Bus für die Relais-Ansteuerung<br />
i2c:<br />
  sda: GPIO4<br />
  scl: GPIO5<br />
  scan: true<br />
<br />
pcf8574:<br />
  - id: pcf8574_hub_in_1<br />
    address: 0x22<br />
    pcf8575: false<br />
<br />
binary_sensor:<br />
  - platform: gpio<br />
    name: "A8 Input 1"<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
      inverted: true<br />
<br />
    name: "A8 Input 2"<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    name: "A8 Input 3"<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    name: "A8 Input 4"<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    name: "A8 Input 5"<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    name: "A8 Input 6"<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    name: "A8 Input 7"<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    name: "A8 Input 8"<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
<br />
      <br />
logger:<br />
<br />
api:<br />
  encryption:<br />
    key: "*****"<br />
<br />
ota:<br />
  - platform: esphome<br />
<br />
<br />
ethernet:<br />
  type: LAN8720<br />
  mdc_pin: GPIO23<br />
  mdio_pin: GPIO18<br />
  clk:<br />
    mode: CLK_OUT<br />
    pin: 17<br />
  phy_addr: 0<br />
<br />
<br />
<br />
i tried to put common the pin 3, on GND, then 12V, then GND again.... i tried directly to put 12V or GND, when inversed, with a wire directly to the contacts, not a peep? what am i doing wrong?<br />
i thought that electrically speaking i go 12V to the houe bell switch, back to the input entry, and put the 12V- GND on common? but that simply doesn't do it?]]></description>
			<content:encoded><![CDATA[Hello!<br />
<br />
<br />
esphome:<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
i2c:<br />
  sda: GPIO4<br />
  scl: GPIO5<br />
  scan: true<br />
<br />
pcf8574:<br />
    address: 0x22<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
<br />
      <br />
logger:<br />
<br />
api:<br />
  encryption:<br />
    key: "*****"<br />
<br />
ota:<br />
<br />
<br />
ethernet:<br />
  type: LAN8720<br />
  clk:<br />
    mode: CLK_OUT<br />
    pin: 17<br />
  phy_addr: 0<br />
<br />
<br />
<br />
i thought that electrically speaking i go 12V to the houe bell switch, back to the input entry, and put the 12V- GND on common? but that simply doesn't do it?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[kc868-A16S3 v3.2]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9770</link>
			<pubDate>Thu, 27 Aug 2026 04:59:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9315">5310h</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9770</guid>
			<description><![CDATA[I have a KC868-A16 V3.2 (ESP32-S3) board powered from the supplied 12 V KinCony adapter. I successfully flashed the official A16V3 ESPHome YAML from this forum.<br />
In the ESPHome web page, outputs 1 and 2 show ON (and I also tried all outputs ON), but none of the 16 on-board output indicator LEDs light. No load is connected.<br />
With output 1 ON, I also measure 0 V between output terminal 1 and the red <br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>+12/24V</code></div></div> terminal for the 1–8 bank.<br />
Please confirm the exact required power wiring for both output banks on V3.2, and whether the output LEDs should light with only the board powered and an output switched ON. I can provide photos if needed.]]></description>
			<content:encoded><![CDATA[I have a KC868-A16 V3.2 (ESP32-S3) board powered from the supplied 12 V KinCony adapter. I successfully flashed the official A16V3 ESPHome YAML from this forum.<br />
Please confirm the exact required power wiring for both output banks on V3.2, and whether the output LEDs should light with only the board powered and an output switched ON. I can provide photos if needed.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868 A8 + Home Assistant + DS18B20+]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9634</link>
			<pubDate>Thu, 16 Jul 2026 20:48:56 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11240">Наиль</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9634</guid>
			<description><![CDATA[Good afternoon! I bought two KC868 A8 and KC868 A16 boards to use with Home Assistant. I found configuration files for these boards on a forum, and all the inputs/outputs work, but I can't connect the sensors. Help please.]]></description>
			<content:encoded><![CDATA[Good afternoon! I bought two KC868 A8 and KC868 A16 boards to use with Home Assistant. I found configuration files for these boards on a forum, and all the inputs/outputs work, but I can't connect the sensors. Help please.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Request for 230VAC LEDs / Downlight]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9501</link>
			<pubDate>Wed, 17 Jun 2026 14:08:37 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11032">benoitd54</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9501</guid>
			<description><![CDATA[Hello, <br />
<br />
I'm currently building my house and i'm planning to be able to adjust the lighting in all my rooms (30 zones).<br />
<br />
I came across your DIN rail modules, which I think are perfect. Great job!! <br />
<br />
However, a have a quick question: how can I dim 230VAC dimmable LED spotlights / downlight from 0% to 100% without any flickering and which the real 0% (using a triac?) ? <br />
<br />
Best regards<br />
<br />
Benoit]]></description>
			<content:encoded><![CDATA[Hello, <br />
<br />
<br />
<br />
<br />
Best regards<br />
<br />
Benoit]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Best Practices for Scaling IoT Projects with ESP32 & DevOps?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9286</link>
			<pubDate>Tue, 21 Apr 2026 19:42:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10769">loral</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9286</guid>
			<description><![CDATA[Hi everyone,<br />
I’ve been working on a few ESP32-based automation projects recently (mostly using ESPHome + Home Assistant), and I’m now reaching a point where things are getting more complex, multiple devices, integrations, and frequent updates.<br />
While the hardware side (like KC868 boards) is quite flexible, managing firmware updates, monitoring, and deployment across multiple nodes is becoming a challenge.<br />
That got me thinking about bringing DevOps concepts into IoT development, things like:<ul class="mycode_list"><li>CI/CD pipelines for firmware updates <br />
</li>
<li>Version control for configurations (ESPHome / Arduino) <br />
</li>
<li>Automated testing before deploying to live devices <br />
</li>
<li>Monitoring uptime and performance across nodes <br />
</li>
</ul>
I recently came across some discussions about teams using accurate DevOps Services Sharjah to manage scalable infrastructures, especially for automation-heavy environments. It seems like a similar approach could be useful even for advanced DIY or semi-professional IoT setups.<br />
Would love to hear from the community:<ul class="mycode_list"><li>Are you using any DevOps-style workflows for your ESP32 or KinCony projects? <br />
</li>
<li>How do you manage updates across multiple devices? <br />
</li>
<li>Any tools or best practices for maintaining stability at scale? <br />
</li>
<li>Has anyone tried integrating GitOps or containerized services with their IoT backend? <br />
</li>
</ul>
Looking forward to learning from your experiences. Thanks in advance!]]></description>
			<content:encoded><![CDATA[Hi everyone,<br />
</li>
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</ul>
Looking forward to learning from your experiences. Thanks in advance!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Change in Web Interface?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9086</link>
			<pubDate>Wed, 04 Mar 2026 04:13:51 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10041">Borg357</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9086</guid>
			<description><![CDATA[I was wondering about a slight change in the User Interface to your RF Settings screens?<br />
<br />
For each IR or RF thats learned, can you place in a field that will let us "nickname" the learned code command?   For example, I might have 100+ IR commands, and I would have to write down what #32 IR is..  But if you let me put in input on this line at number 32.. I could place in "Front room Fan, Turn ON".<br />
<br />
This would eliminate me having to create a spreadsheet just to find which one is my command..<br />
<br />
Thank you<br />
<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9244" target="_blank" title="">Screenshot 2026-03-03 at 11.36.22 AM.png</a> (Size: 241.55 KB / Downloads: 476)
			<content:encoded><![CDATA[I was wondering about a slight change in the User Interface to your RF Settings screens?<br />
<br />
<br />
<br />
Thank you<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[How can I control 170 small 6V bulbs with MOSFET outputs (PWM dimming)]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8972</link>
			<pubDate>Fri, 30 Jan 2026 14:55:03 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10327">hwang</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8972</guid>
I am building a lighting control system for about <span style="font-weight: bold;" class="mycode_b">170 mini incandescent bulbs</span>.<br />
Load<ul class="mycode_list"><li>Bulbs: <span style="font-weight: bold;" class="mycode_b">6V, 0.2A each</span><br />
</li>
<li>Total: ~170 bulbs<br />
</li>
</ul>
Hardware Plan<br />
I plan to use multiple <span style="font-weight: bold;" class="mycode_b">Kincony KC868-A32M</span> (32-channel MOSFET output controllers) to get enough channels.<br />
Wiring Idea<br />
I want to use a common +6V bus and low-side MOSFET switching:<br />
<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>+6V bus → bulb → MOSFET output → GND</code></div></div>All controllers and the 6V supply will share a common ground.<br />
<br />
Questions<br />
<ol type="1" class="mycode_list"><li>Is this the correct wiring method for KC868-A32M outputs?<br />
</li>
<li>Can these MOSFET channels support <span style="font-weight: bold;" class="mycode_b">PWM dimming</span> for incandescent bulbs, or only ON/OFF?<br />
</li>
<li>What is the best way to control multiple KC868-A32M boards from a <span style="font-weight: bold;" class="mycode_b">PC</span> (LAN/MQTT/Modbus)?<br />
</li>
<li>Any important power or wiring concerns for a 170-bulb system?<br />
<br />
</li>
</ol>
Thanks for any advice!]]></description>
</li>
</li>
</ul>
Hardware Plan<br />
Wiring Idea<br />
<br />
<br />
Questions<br />
</li>
</li>
</li>
<br />
</li>
</ol>
Thanks for any advice!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Adding dashboard for kfs firmware]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8968</link>
			<pubDate>Tue, 27 Jan 2026 08:53:00 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10302">mazjed</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8968</guid>
			<description><![CDATA[Hi im new user<br />
I knew that  <span style="font-weight: bold;" class="mycode_b"><a href="https://www.kincony.com/forum/forumdisplay.php?fid=75" target="_blank" rel="noopener" class="mycode_url">"KCS" firmware</a></span> is not an open source .<br />
so its up on your developers to consider adding a way to implement selfe edited dash board on the   <a href="https://www.kincony.com/forum/showthread.php?tid=8870" target="_blank" rel="noopener" class="mycode_url">KC868</a> itself<br />
im sure it will be A large jump on your firmware <br />
<br />
sourcecode   <a href="https://github.com/ayushsharma82/ESP-DASH" target="_blank" rel="noopener" class="mycode_url">https://github.com/ayushsharma82/ESP-DASH</a><br />
<br />
<br />
<br />
withe love<br />
<img src="https://www.kincony.com/forum/images/smilies/heart.png" alt="Heart" title="Heart" class="smilie smilie_16" /><br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9093" target="_blank" title="">preview-dark.png</a> (Size: 349.15 KB / Downloads: 467)
			<content:encoded><![CDATA[Hi im new user<br />
<br />
<br />
<br />
<br />
withe love<br />
		</item>
		<item>
			<title><![CDATA[KC868-COLB Network Connection]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8870</link>
			<pubDate>Sat, 03 Jan 2026 09:20:59 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10016">danielyoud401@gmail.com</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8870</guid>
<br />
My KC868-COLB is no longer visible on my network,<br />
<br />
The UDP Blue LED and Server Yellow LED are flashing on and off together for approx 2 sec on, 2 sec off.<br />
<br />
I have tried pressing and holding the Ethernet M button as described in the user guide but the LED's are not lighting up to switch modes. Nothing happens when i hold this button in.<br />
<br />
Is there a way to do a reset on this board?]]></description>
<br />
<br />
<br />
<br />
Is there a way to do a reset on this board?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-COLB Analog Sensor Data in Home Assistant]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8799</link>
			<pubDate>Mon, 08 Dec 2025 21:08:54 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8799</guid>
			<description><![CDATA[Hi<br />
<br />
I have configured MQTT in home assistant, and connected my KC868-COLB and KC868-H32B boards successfully to home assistant.<br />
<br />
I am able to control relay outputs on KC868-H32B, and can see digital inputs on KC868-COLB change when connecting . However Analog Inputs are staying at 0.0V. I am using a 0-5VDC sensor and have confirmed i am getting a valid signal from the sensor using a multimeter (0-2.5 Bar Pressure sensor, reading goes up to 0.5V when i blow into sensor)<br />
<br />
I am using YAML code from <a href="https://www.kincony.com/mqtt-input-module-home-assistant.html" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/mqtt-input-modul...stant.html</a>, with device ID entered in<br />
<br />
<br />
  sensor:<br />
    - name: COLB-A1<br />
      unique_id: COLB-A1<br />
      state_topic: COLB/99e80c000000c11d13155107/state<br />
      unit_of_measurement: "V"<br />
      value_template: "{{ value_json.A1.value }} "<br />
<br />
What else do i need to do to get a reading to register on home assistant?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8806" target="_blank" title="">Screenshot 2025-12-08 210824.jpg</a> (Size: 4.18 KB / Downloads: 341)
			<content:encoded><![CDATA[Hi<br />
<br />
<br />
<br />
<br />
<br />
  sensor:<br />
<br />
		</item>
		<item>
			<title><![CDATA[KC868-COLB Tuya Integration]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8791</link>
			<pubDate>Sat, 06 Dec 2025 07:52:26 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10003">danielyoud2@gmail.com</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8791</guid>
			<description><![CDATA[I have connected my KC868-COLB to wifi and verified connection to my router, entered Tuya Licence details sent through, generated the QR Code and connected device to Tuya App. It is always showing as offline in Tuya app and I cannot get it connected. I have also tried just with ethernet, and with both ethernet and wifi connected.<br />
<br />
What else do i need to do to get my device online in Tuya App?]]></description>
			<content:encoded><![CDATA[I have connected my KC868-COLB to wifi and verified connection to my router, entered Tuya Licence details sent through, generated the QR Code and connected device to Tuya App. It is always showing as offline in Tuya app and I cannot get it connected. I have also tried just with ethernet, and with both ethernet and wifi connected.<br />
<br />
What else do i need to do to get my device online in Tuya App?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Delay Relay]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8580</link>
			<pubDate>Wed, 24 Sep 2025 14:36:35 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9281">abbasgts</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8580</guid>
			<description><![CDATA[Subject: Request: Sequential 8-relay example for F8 (ESP32-S3), 1.5s step, reverse on shutdown<br />
<br />
Message:<br />
Hello KinCony team,<br />
<br />
I am using the KinCony F8 (ESP32-S3) board with the PCF8575 I/O expander to control 8 relays. I would like to have an Arduino example that performs the following:<br />
  •  Sequential ON: Relay1 → Relay8, with 1.5 seconds delay between each relay.<br />
  •  Sequential OFF: Relay8 → Relay1, with the same 1.5 seconds delay.<br />
  •  Arduino IDE, using I2C with SDA = GPIO8, SCL = GPIO18, and PCF8575 address = 0x24 (please confirm).<br />
<br />
My questions are:<br />
1. What is the exact GPIO mapping for each relay on the F8 hardware revision?<br />
2. Do you have an official Arduino example implementing this sequence?<br />
3. If there is a recommended library or header file for this board, could you please share the link?<br />
<br />
Here is a sample code I tested so far (for reference):<br />
#include &lt;Wire.h&gt;<br />
#include &lt;PCF8575.h&gt;<br />
<br />
#define I2C_SDA 8<br />
#define I2C_SCL 18<br />
#define PCF8575_ADDR 0x24<br />
<br />
PCF8575 pcf(PCF8575_ADDR);<br />
const uint8_t RELAY_PINS[8] = {P0, P1, P2, P3, P4, P5, P6, P7};<br />
<br />
void setup() {<br />
  Serial.begin(115200);<br />
  if (!pcf.begin(I2C_SDA, I2C_SCL)) {<br />
    Serial.println("PCF8575 not found!");<br />
    while (1);<br />
  }<br />
    pcf.write(RELAY_PINS[i], HIGH);  // OFF at start<br />
  }<br />
}<br />
<br />
void loop() {<br />
  // Sequential ON<br />
    Serial.print("Relay ON: "); Serial.println(i+1);<br />
    pcf.write(RELAY_PINS[i], LOW);<br />
    delay(1500);<br />
  }<br />
<br />
  // Sequential OFF<br />
  for (int i = 7; i &gt;= 0; i--) {<br />
    Serial.print("Relay OFF: "); Serial.println(i+1);<br />
    pcf.write(RELAY_PINS[i], HIGH);<br />
    delay(1500);<br />
  }<br />
}]]></description>
			<content:encoded><![CDATA[Subject: Request: Sequential 8-relay example for F8 (ESP32-S3), 1.5s step, reverse on shutdown<br />
<br />
Message:<br />
<br />
<br />
<br />
<br />
<br />
<br />
    while (1);<br />
  }<br />
  }<br />
}<br />
<br />
void loop() {<br />
    delay(1500);<br />
  }<br />
<br />
    delay(1500);<br />
  }<br />
}]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A8: Read voltage on Analog Input A1 to A4 not working?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8561</link>
			<pubDate>Wed, 17 Sep 2025 17:26:17 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9525">svdstra</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8561</guid>
			<description><![CDATA[Since the Inputs A1 to A4 have an internal pull up resistor the analog voltage should read 3V when the input is open. For some reason I am unable to read the voltage of a open input and it returns 0.075V.<br />
<br />
Am I correct that the reading should read around 3V because of the internal Pull-up resistor?<br />
<br />
The input config is:<br />
<br />
sensor:<br />
  - platform: adc<br />
    pin: GPIO14<br />
    name: "Analog Input A1"<br />
    update_interval: 5s<br />
<br />
What am I doing wrong?]]></description>
			<content:encoded><![CDATA[Since the Inputs A1 to A4 have an internal pull up resistor the analog voltage should read 3V when the input is open. For some reason I am unable to read the voltage of a open input and it returns 0.075V.<br />
<br />
<br />
<br />
sensor:<br />
    pin: GPIO14<br />
<br />
What am I doing wrong?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Stepper Motor]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8491</link>
			<pubDate>Thu, 04 Sep 2025 23:54:09 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9451">Cityslicker</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8491</guid>
			<description><![CDATA[I have a Kincony KC868 A16 board and want to control a stepper motor with variable speed.<br />
<br />
I have connected the board up to the stepper motor driver, software works with another ESP32 board. <br />
<br />
But I do not get a pulses out of the GPIO pins. <br />
<br />
Do I need to set any other parameters to get the pulses out of the GPIO pins ?<br />
<br />
Thanks]]></description>
			<content:encoded><![CDATA[I have a Kincony KC868 A16 board and want to control a stepper motor with variable speed.<br />
<br />
<br />
<br />
<br />
Thanks]]></content:encoded>
		</item>
	</channel>
</rss>
