	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-AIO]]></title>
		<pubDate>Tue, 15 Sep 2026 07:20:55 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[4 - 20 mA adc not giving correct values]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9237</link>
			<pubDate>Wed, 15 Apr 2026 06:06:59 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10350">upstream</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9237</guid>
			<description><![CDATA[I am testing the KC868-AIO 4-20 mA analog input with a Fluke 705 Loop Calibrator, but I am not getting correct values.<br />
<br />
Source voltage: 24 VDC<br />
Channel AI-16 (see red wire). Black wire is disconnected.<br />
<br />
Power source for signal is the same as the source for the AIO board.<br />
<br />
Monitor Configuration:<br />
<br />
Custom value1: 32<br />
Custom value2: 180<br />
<br />
Signal generated: 4.000 mA<br />
value provided: ~52 (it should be 32)<br />
<br />
Signal generated: 8.000 mA<br />
value provided: ~79 (it should be 69) <br />
<br />
Signal generated: 12.000 mA<br />
value provided: ~104 (it is close to what it should be at 106)<br />
<br />
Signal generated: 16.000 mA<br />
value provided: ~131 (it should be 143) <br />
<br />
Signal generated: 20.000 mA<br />
value provided: ~167 (it should be 180) <br />
<br />
Pictures:<br />
<a href="https://imgur.com/a/FcHsYcc" target="_blank" rel="noopener" class="mycode_url">705 Connection Example</a><br />
<a href="https://imgur.com/a/374nFbQ" target="_blank" rel="noopener" class="mycode_url">Connections Pic</a><br />
<a href="https://imgur.com/a/rZ3xPXP" target="_blank" rel="noopener" class="mycode_url">adc settings</a><br />
<a href="https://imgur.com/a/gmpiLjZ" target="_blank" rel="noopener" class="mycode_url">adc output</a><br />
<br />
Any idea what is going on?]]></description>
			<content:encoded><![CDATA[I am testing the KC868-AIO 4-20 mA analog input with a Fluke 705 Loop Calibrator, but I am not getting correct values.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Pictures:<br />
<br />
Any idea what is going on?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[OUTPUT DO1]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8848</link>
			<pubDate>Sat, 27 Dec 2025 20:09:55 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10121">Lupi84</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8848</guid>
			<description><![CDATA[The DO1 output physically shows a high state. After uploading new software, when logging in directly to the controller, the inputs and outputs are disabled, but DO1 physically remains on all the time. I have no idea what is causing this. I haven’t connected any relays to the outputs yet.]]></description>
			<content:encoded><![CDATA[The DO1 output physically shows a high state. After uploading new software, when logging in directly to the controller, the inputs and outputs are disabled, but DO1 physically remains on all the time. I have no idea what is causing this. I haven’t connected any relays to the outputs yet.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Modifying analog Inputs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8271</link>
			<pubDate>Thu, 26 Jun 2025 23:10:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8950">danmolna</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8271</guid>
			<description><![CDATA[Hi! <br />
I need 12pcs  0-5V analog inputs for a project and 16 DO. <br />
ESPHome. Home Assistant. <br />
<br />
As i see thist product is the most suitable from your catalogue. <br />
But it has 8 0-5V and 8 4-20mA AI-s. <br />
<br />
Is it possible to modify the 4-20mA inputs to 0-5V inputs by changing the resistances there to simmilar values like at the 0-5V inputs? <br />
<br />
<br />
Thanks!! <br />
<br />
Daniel]]></description>
			<content:encoded><![CDATA[Hi! <br />
<br />
<br />
<br />
<br />
Thanks!! <br />
<br />
Daniel]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[AIO pins 0-5v reading 3.150v]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8010</link>
			<pubDate>Thu, 24 Apr 2025 08:09:14 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8469">Honeybadger</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8010</guid>
			<description><![CDATA[I’m injecting 5v on the pins AI1-8 and they are supposed to read 0-5v but in Home Assistant they read 3.150v<br />
<br />
I used the pin 5v from the board to test it too, only reads 3.150v]]></description>
			<content:encoded><![CDATA[I’m injecting 5v on the pins AI1-8 and they are supposed to read 0-5v but in Home Assistant they read 3.150v<br />
<br />
I used the pin 5v from the board to test it too, only reads 3.150v]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Soil moisture sensors]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7951</link>
			<pubDate>Sat, 19 Apr 2025 02:03:21 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6811">xarouli5</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7951</guid>
			<description><![CDATA[I bought the next sensor to experiment:<br />
<br />
Soil Moisture Sensor <br />
<a href="https://a.aliexpress.com/_ExqUPDK" target="_blank" rel="noopener" class="mycode_url">https://a.aliexpress.com/_ExqUPDK</a><br />
<br />
Powered 3.3v, gnd and tried AO on AI (9-16) &amp; DO on DI (1-8). No change seen on inputs of AIO when I dipped sensor in water and out.<br />
<br />
Any ideas?]]></description>
			<content:encoded><![CDATA[I bought the next sensor to experiment:<br />
<br />
<br />
<br />
Any ideas?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[access control panel input number control OUTPUT by wiegand yaml for ESPhome]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7663</link>
			<pubDate>Fri, 21 Feb 2025 13:47:59 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7663</guid>
			<description><![CDATA[here is demo config file for access control panel. control OUTPUT1 or OUTPUT3 by INPUT NUMBER "101#" and "102#" by touch panel.<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7154" target="_blank" title="">AIO-wiegand-1.jpg</a> (Size: 395.36 KB / Downloads: 781)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7152" target="_blank" title="">AIO-wiegand-2.jpg</a> (Size: 263.77 KB / Downloads: 677)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7153" target="_blank" title="">wiegand.png</a> (Size: 80.94 KB / Downloads: 561)
<br />
esp32:<br />
  board: esp32dev<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
<br />
<br />
# Example configuration entry<br />
ethernet:<br />
  type: LAN8720<br />
  mdc_pin: GPIO23<br />
  mdio_pin: GPIO18<br />
  clk_mode: GPIO17_OUT<br />
  phy_addr: 0<br />
<br />
i2c:<br />
 &nbsp;&nbsp;- id: bus_a<br />
   &nbsp;&nbsp;sda: 4<br />
   &nbsp;&nbsp;scl: 16<br />
   &nbsp;&nbsp;scan: true<br />
<br />
pcf8574:<br />
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_out_in_3'  # for output channel 33-38  + (input 49-58)<br />
    i2c_id: bus_a<br />
    address: 0x26<br />
    pcf8575: true<br />
<br />
<br />
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16<br />
    i2c_id: bus_a<br />
    address: 0x21<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_in_2'  # for input channel 17-32<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_in_3'  # for input channel 33-48<br />
    i2c_id: bus_a<br />
    address: 0x23<br />
    pcf8575: true<br />
<br />
<br />
<br />
# Individual outputs<br />
switch:<br />
  - platform: gpio<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
      inverted: true<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
      <br />
      <br />
    pin:<br />
      pcf8574: pcf8574_hub_out_2<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      pcf8574: pcf8574_hub_out_in_3<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
<br />
cd74hc4067:<br />
  - id: cd74hc4067_1<br />
    pin_s0:<br />
      number: 8<br />
      mode: OUTPUT<br />
    pin_s1:<br />
      number: 9<br />
      mode: OUTPUT<br />
    pin_s2:<br />
      number: 10<br />
      mode: OUTPUT<br />
    pin_s3:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
<br />
<br />
<br />
sensor:<br />
<br />
  - platform: adc<br />
    pin: 36<br />
    update_interval: never<br />
    attenuation: 11db<br />
<br />
    pin: 39<br />
    update_interval: 50s<br />
<br />
    pin: 34<br />
<br />
    pin: 35<br />
<br />
  - platform: cd74hc4067<br />
    number: 0<br />
    sensor: adc36<br />
<br />
    number: 1<br />
    sensor: adc36<br />
<br />
    number: 2<br />
    sensor: adc36<br />
<br />
    number: 3<br />
    sensor: adc36<br />
<br />
    number: 4<br />
    sensor: adc36<br />
<br />
    number: 5<br />
    sensor: adc36<br />
<br />
    number: 6<br />
    sensor: adc36<br />
<br />
    number: 7<br />
    sensor: adc36<br />
<br />
    number: 8<br />
    sensor: adc36<br />
<br />
    number: 9<br />
    sensor: adc36<br />
<br />
    number: 10<br />
    sensor: adc36<br />
<br />
    number: 11<br />
    sensor: adc36<br />
<br />
    number: 12<br />
    sensor: adc36<br />
<br />
    number: 13<br />
    sensor: adc36<br />
<br />
    number: 14<br />
    sensor: adc36<br />
<br />
    number: 15<br />
    sensor: adc36<br />
<br />
<br />
<br />
# Individual inputs  <br />
binary_sensor:<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
      <br />
      <br />
    pin:<br />
      pcf8574: pcf8574_hub_in_2<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      pcf8574: pcf8574_hub_in_3<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
pca9685:<br />
    frequency: 500<br />
<br />
output:<br />
  - platform: pca9685<br />
    pca9685_id: 'pca9685_hub'<br />
    channel: 0<br />
<br />
    channel: 1<br />
<br />
    channel: 2<br />
<br />
    channel: 3<br />
<br />
    channel: 4<br />
<br />
    channel: 5<br />
<br />
    channel: 6<br />
<br />
    channel: 7<br />
<br />
    channel: 8<br />
<br />
    channel: 9<br />
<br />
    channel: 10<br />
<br />
    channel: 11<br />
<br />
    channel: 12<br />
<br />
    channel: 13<br />
<br />
    channel: 14<br />
<br />
    channel: 15<br />
<br />
<br />
light:<br />
  - platform: monochromatic<br />
    output: PWM0<br />
    output: PWM1<br />
    output: PWM2<br />
    output: PWM3<br />
    output: PWM4<br />
    output: PWM5<br />
    output: PWM6<br />
    output: PWM7<br />
    output: PWM8<br />
    output: PWM9<br />
    output: PWM10<br />
    output: PWM11<br />
    output: PWM12<br />
    output: PWM13<br />
    output: PWM14<br />
    output: PWM15<br />
<br />
  - platform: rgbw<br />
    red: PWM1<br />
    green: PWM2<br />
    blue: PWM3<br />
    white: PWM4<br />
<br />
wiegand:<br />
  - id: mykeypad<br />
    d0: GPIO14<br />
    d1: GPIO5<br />
    on_key:<br />
      - lambda: ESP_LOGI("KEY", "received key %d", x);<br />
    on_tag:<br />
      - lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());<br />
    on_raw:<br />
      - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);<br />
<br />
key_collector:<br />
  - id: pincode_reader<br />
    source_id: mykeypad<br />
    min_length: 3<br />
    max_length: 3<br />
    end_keys: "#"<br />
    end_key_required: true<br />
    back_keys: "*"<br />
    clear_keys: "C"<br />
#    allowed_keys: "0123456789"<br />
    timeout: 5s<br />
    on_progress:<br />
      - logger.log:<br />
          format: "input progress: '%s', started by '%c'"<br />
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]<br />
    on_result:<br />
      - logger.log:<br />
          format: "input result: '%s', started by '%c', ended by '%c'"<br />
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]<br />
<br />
      - if:<br />
          condition:<br />
            lambda: |-<br />
              return x=="101";<br />
          then:<br />
            switch.toggle: aio_light1<br />
<br />
      - if:<br />
          condition:<br />
            lambda: |-<br />
              return x=="102";<br />
          then:<br />
            switch.toggle: aio_light2<br />
<br />
    on_timeout:<br />
      - logger.log:<br />
          format: "input timeout: '%s', started by '%c'"<br />
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]</code></div></div><br />
<br />
ESPHome yaml file download:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7155" target="_blank" title="">KC868-AIO-ESPHome-wiegand.txt</a> (Size: 21.93 KB / Downloads: 441)
			<content:encoded><![CDATA[here is demo config file for access control panel. control OUTPUT1 or OUTPUT3 by INPUT NUMBER "101#" and "102#" by touch panel.<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
<br />
ethernet:<br />
  type: LAN8720<br />
  phy_addr: 0<br />
<br />
i2c:<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x26<br />
    pcf8575: true<br />
<br />
<br />
    i2c_id: bus_a<br />
    address: 0x21<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x23<br />
    pcf8575: true<br />
<br />
<br />
<br />
switch:<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
      <br />
      <br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
<br />
cd74hc4067:<br />
    pin_s0:<br />
      number: 8<br />
      mode: OUTPUT<br />
    pin_s1:<br />
      number: 9<br />
      mode: OUTPUT<br />
    pin_s2:<br />
      number: 10<br />
      mode: OUTPUT<br />
    pin_s3:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
<br />
<br />
<br />
sensor:<br />
<br />
    pin: 36<br />
<br />
    pin: 39<br />
<br />
    pin: 34<br />
<br />
    pin: 35<br />
<br />
    number: 0<br />
    sensor: adc36<br />
<br />
    number: 1<br />
    sensor: adc36<br />
<br />
    number: 2<br />
    sensor: adc36<br />
<br />
    number: 3<br />
    sensor: adc36<br />
<br />
    number: 4<br />
    sensor: adc36<br />
<br />
    number: 5<br />
    sensor: adc36<br />
<br />
    number: 6<br />
    sensor: adc36<br />
<br />
    number: 7<br />
    sensor: adc36<br />
<br />
    number: 8<br />
    sensor: adc36<br />
<br />
    number: 9<br />
    sensor: adc36<br />
<br />
    number: 10<br />
    sensor: adc36<br />
<br />
    number: 11<br />
    sensor: adc36<br />
<br />
    number: 12<br />
    sensor: adc36<br />
<br />
    number: 13<br />
    sensor: adc36<br />
<br />
    number: 14<br />
    sensor: adc36<br />
<br />
    number: 15<br />
    sensor: adc36<br />
<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
      <br />
      <br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
      <br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
pca9685:<br />
<br />
output:<br />
    channel: 0<br />
<br />
    channel: 1<br />
<br />
    channel: 2<br />
<br />
    channel: 3<br />
<br />
    channel: 4<br />
<br />
    channel: 5<br />
<br />
    channel: 6<br />
<br />
    channel: 7<br />
<br />
    channel: 8<br />
<br />
    channel: 9<br />
<br />
    channel: 10<br />
<br />
    channel: 11<br />
<br />
    channel: 12<br />
<br />
    channel: 13<br />
<br />
    channel: 14<br />
<br />
    channel: 15<br />
<br />
<br />
light:<br />
    output: PWM0<br />
    output: PWM1<br />
    output: PWM2<br />
    output: PWM3<br />
    output: PWM4<br />
    output: PWM5<br />
    output: PWM6<br />
    output: PWM7<br />
    output: PWM8<br />
    output: PWM9<br />
    output: PWM10<br />
    output: PWM11<br />
    output: PWM12<br />
    output: PWM13<br />
    output: PWM14<br />
    output: PWM15<br />
<br />
    red: PWM1<br />
    green: PWM2<br />
    blue: PWM3<br />
    white: PWM4<br />
<br />
wiegand:<br />
    d0: GPIO14<br />
    d1: GPIO5<br />
    on_key:<br />
    on_tag:<br />
    on_raw:<br />
<br />
    min_length: 3<br />
    max_length: 3<br />
    end_keys: "#"<br />
    timeout: 5s<br />
    on_progress:<br />
      - logger.log:<br />
    on_result:<br />
      - logger.log:<br />
<br />
      - if:<br />
          condition:<br />
            lambda: |-<br />
          then:<br />
<br />
      - if:<br />
          condition:<br />
            lambda: |-<br />
          then:<br />
<br />
    on_timeout:<br />
      - logger.log:<br />
<br />
		</item>
		<item>
			<title><![CDATA[Interfacing WS2812B led strips]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7524</link>
			<pubDate>Fri, 31 Jan 2025 05:36:08 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7494">Krushi</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7524</guid>
			<description><![CDATA[Hi I am using KC868 AIO installed for my smart home project, I would like to interface 4 ws2812b led strips how can I do that? Which of the pins can be used as data pins for the same. An example circuit and Yaml also will be appreciated.<br />
<br />
Regards<br />
Krushi]]></description>
			<content:encoded><![CDATA[Hi I am using KC868 AIO installed for my smart home project, I would like to interface 4 ws2812b led strips how can I do that? Which of the pins can be used as data pins for the same. An example circuit and Yaml also will be appreciated.<br />
<br />
Regards<br />
Krushi]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[DS18B20 longer distance]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7073</link>
			<pubDate>Sun, 17 Nov 2024 11:37:30 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6435">silicondt</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7073</guid>
			<description><![CDATA[Hello I have 10x DS18B20 temp sensors hooked up to KC868-AIO<br />
<br />
They are mostly around 50-70ft away from the KC868-AIO<br />
<br />
They are all home run cable back to KC868-AIO (star patern)<br />
<br />
The cable used is 18/3 OFC copper.<br />
<br />
I can only get them to work if hooked directly up short run without extending them.<br />
<br />
How can I get this setup to work? Resistors? If so what kind?<br />
<br />
Thanks]]></description>
			<content:encoded><![CDATA[Hello I have 10x DS18B20 temp sensors hooked up to KC868-AIO<br />
<br />
<br />
<br />
<br />
<br />
<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Connect DS18b20 temperature sensor to KC868-AIO]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7072</link>
			<pubDate>Sun, 17 Nov 2024 03:17:53 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6539">slava</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7072</guid>
			<description><![CDATA[I am trying to connect  DS18b20 temperature sensor to KC868-AIO and get sensor ID from ESPHome logs<br />
<br />
<span style="color: #00369b;" class="mycode_color">My configuration:</span><br />
<br />
<span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font"><span style="color: #00369b;" class="mycode_color">one_wire:<br />
  - pin: GPIO01<br />
    platform: gpio</span></span><br />
<br />
<br />
This is what I am getting:<br />
<br />
<span style="font-size: medium;" class="mycode_size"><span style="color: #dddddd;" class="mycode_color"><span style="font-family: SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace;" class="mycode_font">[10:58:55]<span style="color: #ff00ff;" class="mycode_color">[C][gpio.one_wire:020]: GPIO 1-wire bus:</span><br />
</span></span><span style="color: #dddddd;" class="mycode_color"><span style="font-family: SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace;" class="mycode_font">[10:58:55]<span style="color: #ff00ff;" class="mycode_color">[C][gpio.one_wire:021]:  Pin: GPIO1</span><br />
</span></span><span style="color: #c19e00;" class="mycode_color"><span style="font-family: SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace;" class="mycode_font">[10:58:55][W][gpio.one_wire:078]:  Found no devices!</span></span></span> <br />
<br />
<br />
<br />
<span style="font-size: medium;" class="mycode_size"><span style="color: #c19e00;" class="mycode_color"><span style="font-family: SFMono-Regular, Consolas, 'Liberation Mono', Menlo, Courier, monospace;" class="mycode_font"><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=6462" target="_blank" title="">20241116_104929.jpg</a> (Size: 2.56 MB / Downloads: 1107)
<!-- end: postbit_attachments_attachment --></span></span></span>]]></description>
			<content:encoded><![CDATA[I am trying to connect  DS18b20 temperature sensor to KC868-AIO and get sensor ID from ESPHome logs<br />
<br />
<br />
  - pin: GPIO01<br />
<br />
<br />
<br />
<br />
<br />
<br />
<!-- end: postbit_attachments_attachment --></span></span></span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-AIO connecting to ESPHome]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7041</link>
			<pubDate>Sun, 10 Nov 2024 13:36:10 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7041</guid>
			<description><![CDATA[I am trying to connect KC868-AIO to ESPHome. Home Assistant and ESPHome are installed on my QNAP server in separate docker containers. I connected KC868-AIO to my computer with a USB data cable but it does not show up in the list of the available ports. What is wrong?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=6402" target="_blank" title="">Screenshot 2024-11-09 213235.png</a> (Size: 141.9 KB / Downloads: 696)
			<content:encoded><![CDATA[I am trying to connect KC868-AIO to ESPHome. Home Assistant and ESPHome are installed on my QNAP server in separate docker containers. I connected KC868-AIO to my computer with a USB data cable but it does not show up in the list of the available ports. What is wrong?<br /><!-- start: postbit_attachments_attachment -->
		</item>
		<item>
			<title><![CDATA[Temp Sensors]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=6975</link>
			<pubDate>Sun, 03 Nov 2024 06:37:30 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=6975</guid>
			<description><![CDATA[Can anyone tell me if the KC868-AIO supports more than two temp sensors?<br />
<br />
From the videos it looks like it has two GPIO ports for temp sensors, but not sure if that means only can use two?<br />
Or can multiple temp sensors be hooked to each port ?<br />
<br />
We have a project that needs 4 temp sensors. Would we have to use analog temp sensors if we needed more than 2?<br />
<br />
Thanks!]]></description>
			<content:encoded><![CDATA[Can anyone tell me if the KC868-AIO supports more than two temp sensors?<br />
<br />
<br />
<br />
Thanks!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Interfacing multiple LED strips to the AIO board]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=6805</link>
			<pubDate>Sat, 28 Sep 2024 20:05:42 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=5024">telewizard13</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=6805</guid>
			<description><![CDATA[The AIO board Yaml file for Home Assistant creates "aio-Color-LED-1 to aio-Color-LED-16" outputs, and a single "aio-rgbw" output. How would these 17 different LED devices be connected to a AIO board? On the large AIO connection diagram I downloaded, you show a single LED strip connected to one of the two GPIO ports and a 1-wire humidity sensor connected to the other. Does another interface board need to be purchased and connected to the AIO board to control all these LED devices on the HA dashboard?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=6138" target="_blank" title="">Screen Shot 2024-09-28 at 8.04.34 AM.png</a> (Size: 123.15 KB / Downloads: 738)
			<content:encoded><![CDATA[The AIO board Yaml file for Home Assistant creates "aio-Color-LED-1 to aio-Color-LED-16" outputs, and a single "aio-rgbw" output. How would these 17 different LED devices be connected to a AIO board? On the large AIO connection diagram I downloaded, you show a single LED strip connected to one of the two GPIO ports and a 1-wire humidity sensor connected to the other. Does another interface board need to be purchased and connected to the AIO board to control all these LED devices on the HA dashboard?<br /><!-- start: postbit_attachments_attachment -->
		</item>
		<item>
			<title><![CDATA[4-20mah sensor wiring example]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=6707</link>
			<pubDate>Mon, 16 Sep 2024 21:26:10 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=5971">aucirc</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=6707</guid>
			<description><![CDATA[I'm considering the KC868-AIO - I need several water level sensors and interested in using the 4-20mah version of this (as the accuracy is better over longer distances)<br />
<a href="https://aliexpress.com/item/1005006338737673.html" target="_blank" rel="noopener" class="mycode_url">https://aliexpress.com/item/1005006338737673.html</a><br />
<br />
It's a two-wire sensor, but I can't find any examples of how this should be connected to the KC868-AIO?  As these work best with 24V should the KC868-AIO be powered with 24V also?]]></description>
			<content:encoded><![CDATA[I'm considering the KC868-AIO - I need several water level sensors and interested in using the 4-20mah version of this (as the accuracy is better over longer distances)<br />
<br />
It's a two-wire sensor, but I can't find any examples of how this should be connected to the KC868-AIO?  As these work best with 24V should the KC868-AIO be powered with 24V also?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[AIO board has failed]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=6671</link>
			<pubDate>Fri, 13 Sep 2024 05:06:57 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=6671</guid>
			<description><![CDATA[<span style="color: #000000;" class="mycode_color"><span style="font-size: x-large;" class="mycode_size"><span style="font-family: -apple-system, 'system-ui', 'Helvetica Neue', 'Segoe UI', Arial, sans-serif, 'Apple Color Emoji', 'Segoe UI Emoji', 'Segoe UI Symbol';" class="mycode_font">My 3 month old KC868-AIO board has failed. It no longer communicates with my Home Assistant over ethernet, doesn't appear on WIFI.  Can't connect via USB and the ESP chip on the board is VERY hot. There is no activity on the ethernet connector. Not sure what failed or why, because it was working perfectly even earlier today. The power supply is fine and measures 12.45 volts and the power LEDs are lit, but it appears to be brain dead. I powered it down and disconnected all the I/O plugs and there was no change. </span></span></span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-size: x-large;" class="mycode_size"><span style="font-family: -apple-system, 'system-ui', 'Helvetica Neue', 'Segoe UI', Arial, sans-serif, 'Apple Color Emoji', 'Segoe UI Emoji', 'Segoe UI Symbol';" class="mycode_font">-Telewizard 13 </span></span></span><br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=6027" target="_blank" title="">IMG_0001.JPG</a> (Size: 68.03 KB / Downloads: 472)
			<content:encoded><![CDATA[<span style="color: #000000;" class="mycode_color"><span style="font-size: x-large;" class="mycode_size"><span style="font-family: -apple-system, 'system-ui', 'Helvetica Neue', 'Segoe UI', Arial, sans-serif, 'Apple Color Emoji', 'Segoe UI Emoji', 'Segoe UI Symbol';" class="mycode_font">My 3 month old KC868-AIO board has failed. It no longer communicates with my Home Assistant over ethernet, doesn't appear on WIFI.  Can't connect via USB and the ESP chip on the board is VERY hot. There is no activity on the ethernet connector. Not sure what failed or why, because it was working perfectly even earlier today. The power supply is fine and measures 12.45 volts and the power LEDs are lit, but it appears to be brain dead. I powered it down and disconnected all the I/O plugs and there was no change. </span></span></span><br />
		</item>
		<item>
			<title><![CDATA[KC868-AIO User guide and other docs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=6470</link>
			<pubDate>Sun, 25 Aug 2024 01:41:46 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=5448">BigDaddyC</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=6470</guid>
			<description><![CDATA[Hi team,<br />
I am very new to home automation, &amp; have received my AIO board and was unable to find the user guide. Is it under a different name or the same as another that is already there?<br />
Does this apply to the software i load as well?<br />
			<content:encoded><![CDATA[Hi team,<br />
		</item>
	</channel>
</rss>
