	<channel>
		<title><![CDATA[Smart Home Automation Forum - News]]></title>
		<pubDate>Sun, 18 Oct 2026 02:54:18 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[KinCony CO16 ESP32S3 16 Channel Analog Input Controller released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9796</link>
			<pubDate>Wed, 02 Sep 2026 09:51:14 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9796</guid>
			<description><![CDATA[KinCony CO16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel relay output and 16 channel digital input ports, 16 channel ADS1115 16bit analog input ports. One SD card using SPI bus. CO16 include DS3231 high precision RTC clock chip. Color ST7789 TFT LCD display will show wifi and ethernet IP address and Tuya connection state. CO16 have SIM7600E 4G module slot and RS485 port. CO16 support MAX 4 channel PT100 RTD (Resistance Temperature Detector). You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. CO16 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.<br />
<img src="https://www.kincony.com/images/CO16/CO16-2.jpg" loading="lazy"  alt="[Image: CO16-2.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">Model No. KinCony CO16</span><br />
Description: KinCony ESP32-S3 16 Channel Analog Input Smart Controller – CO16<br />
Power supply: 12-24V DC<br />
Processor: ESP32-S3-WROOM-1U (N16R8)<br />
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,Tuya Module, 4G SIM7600<br />
RTC: DS3231 high precision chip (battery socket on PCB)<br />
SD Card: SPI bus<br />
Installation method: DIN RAIL<br />
TFT LCD: ST7789 SPI display<br />
<span style="font-weight: bold;" class="mycode_b">Outputs:</span><br />
16CH relay Outputs, every relay use by MAX AC250V/7A<br />
<span style="font-weight: bold;" class="mycode_b">Inputs:</span><br />
ADS1115 16bit ADC: 16CH analog input DC0-10V or 4-20mA (set by jumper)<br />
jumper: short UP: set for DC 0-10V signal.<br />
jumper: short DOWN: set for DC 4-20mA signal.<br />
16CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)<br />
3 buttons: 1:ESP32 Reset 2:ESP32 Download 3:Tuya config<br />
PT100 RTD: 4CH (read by MAX31865, switch channel by NX3L4051)<br />
<img src="https://www.kincony.com/images/CO16/CO16-1.jpg" loading="lazy"  alt="[Image: CO16-1.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">software solution:</span><br />
1. download KinCony KCS v3 firmware, so that work with multi protocol: HTTP, MQTT, Modbus(RS485/TCP), BACnet(RS485/TCP), DMX512, Tuya app, config OUTPUT for “momentary” and “interlock” group functions. use Tuya mobile phone app directly, support voice control by Alexa and Google home speaker directly. if you want local voice control without internet, you can add KinCony AS voice assistant. “KCS” support IFTTT function work locally without internet. It also support use by KinCony cloud server. KCS v3 support home assistant auto discovery function by MQTT, so without any config file for home assistant.<br />
2. download firmware by ESPHome, integrate to home assistant or use by web service.<br />
3. download tasmota firmware.<br />
4. write your own arudino or ESP-IDF code for your own requirements.<br />
5. It is recommended to use home assistant and Tuya mobile phone app at the same time. So that remote control by internet using Tuya app, local control by LAN using home assistant app.<br />
<img src="https://www.kincony.com/images/CO16/KinCony-CO16-smart-controller-diagram.jpg" loading="lazy"  alt="[Image: KinCony-CO16-smart-controller-diagram.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony CO16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel relay output and 16 channel digital input ports, 16 channel ADS1115 16bit analog input ports. One SD card using SPI bus. CO16 include DS3231 high precision RTC clock chip. Color ST7789 TFT LCD display will show wifi and ethernet IP address and Tuya connection state. CO16 have SIM7600E 4G module slot and RS485 port. CO16 support MAX 4 channel PT100 RTD (Resistance Temperature Detector). You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. CO16 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.<br />
<img src="https://www.kincony.com/images/CO16/KinCony-CO16-smart-controller-diagram.jpg" loading="lazy"  alt="[Image: KinCony-CO16-smart-controller-diagram.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony B2 Smart Controller released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9746</link>
			<pubDate>Mon, 17 Aug 2026 21:07:50 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9746</guid>
			<description><![CDATA[KinCony B2 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 2 channel relay output, 4 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B2 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B2 have I2C bus extender and RS485 port. B2 support use SIM7600E 4G module. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B2 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.<br />
<img src="https://www.kincony.com/images/B2/B2-2.jpg" loading="lazy"  alt="[Image: B2-2.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">Model No. KinCony B2</span><br />
Description: KinCony 2 Channel ESP32-S3 Smart Relay Controller – B2<br />
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,I2C,Tuya Module, 4G SIM7600<br />
LCD: SSD1306 I2C display<br />
2CH relay Outputs, every relay use by MAX AC270V/10A<br />
ADS1115 16bit ADC: 2CH analog input DC0-5V (A1,A2) 2CH analog input 4-20mA (A3,A4)<br />
2CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)<br />
1-Wire GPIO: 4CH (with pull-up resistance on PCB)<br />
<img src="https://www.kincony.com/images/B2/B2-1.jpg" loading="lazy"  alt="[Image: B2-1.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony B2 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 2 channel relay output, 4 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B2 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B2 have I2C bus extender and RS485 port. B2 support use SIM7600E 4G module. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B2 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.<br />
<img src="https://www.kincony.com/images/B2/B2-1.jpg" loading="lazy"  alt="[Image: B2-1.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony MT4 – 4CH ESP32 DC Motor Driver released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9615</link>
			<pubDate>Sat, 11 Jul 2026 11:01:07 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9615</guid>
			<description><![CDATA[KinCony MT4 ESP32-S3 4 Channel DC Motor Controller<br />
Overview<br />
KinCony <span style="font-weight: bold;" class="mycode_b">MT4</span> is a professional <span style="font-weight: bold;" class="mycode_b">4 Channel DC Motor Controller</span> based on the <span style="font-weight: bold;" class="mycode_b">ESP32-S3-WROOM-1 (N16R8)</span> module. It is designed for smart home automation, industrial automation, DIY IoT projects, motorized curtains, electric valves, linear actuators, robotic systems and other DC motor control applications.<br />
MT4 integrates <span style="font-weight: bold;" class="mycode_b">4 independent DC motor drivers</span>, <span style="font-weight: bold;" class="mycode_b">RS485</span>, <span style="font-weight: bold;" class="mycode_b">433MHz RF receiver</span>, <span style="font-weight: bold;" class="mycode_b">IR receiver</span>, <span style="font-weight: bold;" class="mycode_b">I²C expansion interface</span>, <span style="font-weight: bold;" class="mycode_b">1-Wire GPIO</span>, <span style="font-weight: bold;" class="mycode_b">WiFi</span>, <span style="font-weight: bold;" class="mycode_b">Bluetooth</span>, <span style="font-weight: bold;" class="mycode_b">USB-C</span>, and a <span style="font-weight: bold;" class="mycode_b">Tuya WiFi module</span> into one compact DIN Rail controller.<br />
Whether you are a developer, system integrator, or smart home enthusiast, MT4 provides multiple firmware options, including <span style="font-weight: bold;" class="mycode_b">KinCony KCS v3</span>, <span style="font-weight: bold;" class="mycode_b">ESPHome</span>, <span style="font-weight: bold;" class="mycode_b">Tasmota</span>, <span style="font-weight: bold;" class="mycode_b">Arduino</span>, <span style="font-weight: bold;" class="mycode_b">ESP-IDF</span>, and <span style="font-weight: bold;" class="mycode_b">MicroPython</span>.<br />
<hr class="mycode_hr" />
<img src="https://www.kincony.com/images/MT4/MT4-1.jpg" loading="lazy"  width="1000" height="1044" alt="[Image: MT4-1.jpg]" class="mycode_img" /><br />
Features<ul class="mycode_list"><li>ESP32-S3-WROOM-1 (N16R8) Dual-Core Processor<br />
</li>
<li>4 Channel DC Motor Driver (L298N)<br />
</li>
<li>Supports Forward / Reverse / Stop control<br />
</li>
<li>Maximum <span style="font-weight: bold;" class="mycode_b">2A load per motor channel</span><br />
</li>
<li>Built-in WiFi &amp; Bluetooth<br />
</li>
<li>Built-in Tuya WiFi module<br />
</li>
<li>RS485 interface (Modbus supported by KCS firmware)<br />
</li>
<li>USB Type-C programming interface<br />
</li>
<li>433MHz RF Receiver<br />
</li>
<li>IR Receiver<br />
</li>
<li>I²C Expansion Port<br />
</li>
<li>2 Channel 1-Wire GPIO<br />
</li>
<li>DIN Rail installation with plastic enclosure<br />
</li>
<li>Open-source hardware platform<br />
</li>
<li>Supports Arduino IDE<br />
</li>
<li>Supports ESP-IDF<br />
</li>
<li>Supports MicroPython<br />
</li>
<li>Supports ESPHome<br />
</li>
<li>Supports Tasmota<br />
</li>
<li>Home Assistant MQTT Auto Discovery<br />
</li>
<li>Apple HomeKit support (KCS v3 firmware)<br />
</li>
</ul>
Applications<br />
KinCony MT4 is suitable for various automation projects, including:<ul class="mycode_list"><li>Motorized Curtains<br />
</li>
<li>Roller Blinds<br />
</li>
<li>Window Openers<br />
</li>
<li>Electric Valves<br />
</li>
<li>Linear Actuators<br />
</li>
<li>Smart Furniture<br />
</li>
<li>Automatic Doors<br />
</li>
<li>Smart Agriculture<br />
</li>
<li>Industrial Automation<br />
</li>
<li>DIY IoT Projects<br />
</li>
<li>Home Automation Systems<br />
</li>
</ul>
Technical Specifications<br />
Item<br />
SpecificationModel<br />
KinCony MT4<br />
Processor<br />
ESP32-S3-WROOM-1 (N16R8)<br />
Power Supply<br />
DC 12V<br />
Motor Driver<br />
L298N<br />
Motor Outputs<br />
4 Channels<br />
Maximum Motor Current<br />
2A per Channel<br />
Communication<br />
WiFi / Bluetooth<br />
Interfaces<br />
RS485, USB-C, IR Receiver, 433MHz RF Receiver, I²C Expansion<br />
GPIO<br />
Installation<br />
DIN Rail<br />
PCB Size<br />
87 × 93 mm<br />
Hardware Interfaces<br />
Outputs<ul class="mycode_list"><li>4 × DC Motor Outputs<br />
</li>
<li>Maximum Load: <span style="font-weight: bold;" class="mycode_b">2A per channel</span><br />
</li>
</ul>
Inputs<ul class="mycode_list"><li>2 × 1-Wire GPIO<br />
</li>
<li>Built-in pull-up resistors<br />
</li>
</ul>
Buttons<ul class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">S1</span> – ESP32 Reset<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">S2</span> – Download Mode (GPIO0)<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">S3</span> – Tuya Configuration Button<br />
</li>
</ul>
Communication Interfaces<ul class="mycode_list"><li><ul class="mycode_list"><li>WiFi<br />
</li>
<li>Bluetooth<br />
</li>
<li>RS485<br />
</li>
<li>USB Type-C<br />
</li>
</li>
</li>
<li>I²C Expansion Interface<br />
</li>
</ul>
</li>
</ul>
<img src="https://www.kincony.com/images/MT4/KinCony-MT4-smart-controller-diagram.jpg" loading="lazy"  alt="[Image: KinCony-MT4-smart-controller-diagram.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony MT4 ESP32-S3 4 Channel DC Motor Controller<br />
Overview<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
Applications<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
Item<br />
KinCony MT4<br />
Processor<br />
Power Supply<br />
DC 12V<br />
Motor Driver<br />
L298N<br />
Motor Outputs<br />
4 Channels<br />
Communication<br />
Interfaces<br />
GPIO<br />
Installation<br />
DIN Rail<br />
PCB Size<br />
87 × 93 mm<br />
</li>
</li>
</ul>
</li>
</li>
</ul>
</li>
</li>
</li>
</ul>
</li>
<li>Bluetooth<br />
</li>
<li>RS485<br />
</li>
</li>
</li>
</li>
</li>
</ul>
</li>
</ul>
<img src="https://www.kincony.com/images/MT4/KinCony-MT4-smart-controller-diagram.jpg" loading="lazy"  alt="[Image: KinCony-MT4-smart-controller-diagram.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony Pi5M32 – Raspberry Pi CM5 IoT Gateway released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9542</link>
			<pubDate>Thu, 25 Jun 2026 18:40:06 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9542</guid>
			<description><![CDATA[KinCony Pi5M32 – Raspberry Pi CM5 DIN Rail 32-Channel MOSFET Controller for Smart Home &amp; Industrial Automation<br />
<img src="https://www.kincony.com/images/Pi5M32/Pi5M32-1.jpg" loading="lazy"  alt="[Image: Pi5M32-1.jpg]" class="mycode_img" /><br />
Product Overview<br />
<span style="font-weight: bold;" class="mycode_b">KinCony Pi5M32</span> is a powerful Raspberry Pi-based IoT gateway and automation controller designed for smart home, industrial automation, and IoT edge computing applications. Powered by the <span style="font-weight: bold;" class="mycode_b">Raspberry Pi Compute Module 5 (CM5)</span>, it integrates 32 MOSFET outputs, 32 optocoupler-isolated digital inputs, analog inputs, PWM outputs, RS232/RS485 communication interfaces, and expansion capabilities into a rugged DIN rail aluminum enclosure.<br />
The Raspberry Pi CM5 directly controls all MOSFET outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces. Users can easily deploy automation projects using <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, <span style="font-weight: bold;" class="mycode_b">Node-RED</span>, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.<br />
Pi5M32 is ideal for high-density DC load control applications such as LED lighting systems, solenoid valves, DC motors, industrial actuators, and custom automation equipment.<br />
<img src="https://www.kincony.com/images/Pi5M32/Pi5M32-5.jpg" loading="lazy"  alt="[Image: Pi5M32-5.jpg]" class="mycode_img" /><br />
Key Features<ul class="mycode_list"><li>Powered by Raspberry Pi Compute Module 5 (CM5)<br />
</li>
<li>32-channel MOSFET outputs<br />
</li>
<li>32-channel optocoupler-isolated digital inputs<br />
</li>
<li>Supports Home Assistant and Node-RED<br />
</li>
<li>RS232 and RS485 communication ports<br />
</li>
<li>2-channel PWM outputs<br />
</li>
<li>2 × DC 0-5V analog inputs<br />
</li>
<li>2 × 4-20mA analog inputs<br />
</li>
<li>20 free GPIO expansion pins<br />
</li>
<li>Gigabit Ethernet support<br />
</li>
<li>M.2 M-Key PCIe expansion socket<br />
</li>
<li>SSD1306 I2C OLED display<br />
</li>
<li>Industrial DIN rail aluminum enclosure<br />
</li>
<li>Designed for smart home and industrial automation systems<br />
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5M32/Pi5M32-7.jpg" loading="lazy"  alt="[Image: Pi5M32-7.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony Pi5M32 – Raspberry Pi CM5 DIN Rail 32-Channel MOSFET Controller for Smart Home &amp; Industrial Automation<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5M32/Pi5M32-7.jpg" loading="lazy"  alt="[Image: Pi5M32-7.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony Pi5R32 – Raspberry Pi CM5 IoT Gateway released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9537</link>
			<pubDate>Wed, 24 Jun 2026 22:54:51 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9537</guid>
			<description><![CDATA[KinCony Pi5R32 – Raspberry Pi CM5 DIN Rail 32-Channel Relay Controller for Smart Home &amp; Industrial Automation<br />
<img src="https://www.kincony.com/images/Pi5R32/Pi5R32-1.jpg" loading="lazy"  alt="[Image: Pi5R32-1.jpg]" class="mycode_img" />Product Overview<br />
<span style="font-weight: bold;" class="mycode_b">KinCony Pi5R32</span> is a powerful Raspberry Pi-based IoT gateway and automation controller designed for smart home, building automation, and industrial control applications. Powered by the <span style="font-weight: bold;" class="mycode_b">Raspberry Pi Compute Module 5 (CM5)</span>, it integrates 32 relay outputs, 32 optocoupler-isolated digital inputs, analog inputs, PWM outputs, RS232/RS485 communication interfaces, and multiple expansion interfaces into a rugged DIN rail aluminum enclosure.<br />
The Raspberry Pi CM5 directly controls all relay outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces. Users can easily deploy automation projects using <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, <span style="font-weight: bold;" class="mycode_b">Node-RED</span>, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.<br />
Pi5R32 is ideal for large-scale automation projects requiring high-density I/O control while maintaining the flexibility of a Raspberry Pi platform.<br />
<img src="https://www.kincony.com/images/Pi5R32/Pi5R32-3.jpg" loading="lazy"  alt="[Image: Pi5R32-3.jpg]" class="mycode_img" /><br />
</li>
<li>32-channel relay outputs<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5R32/Pi5R32-7.jpg" loading="lazy"  alt="[Image: Pi5R32-7.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony Pi5R32 – Raspberry Pi CM5 DIN Rail 32-Channel Relay Controller for Smart Home &amp; Industrial Automation<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5R32/Pi5R32-7.jpg" loading="lazy"  alt="[Image: Pi5R32-7.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony Pi5M8 – Raspberry Pi CM5 IoT Gateway released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9520</link>
			<pubDate>Sat, 20 Jun 2026 08:00:39 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9520</guid>
			<description><![CDATA[KinCony Pi5M8 – Raspberry Pi CM5 DIN Rail MOSFET Controller for Smart Home &amp; Industrial Automation<br />
<img src="https://www.kincony.com/images/Pi5M8/Pi5M8-1.jpg" loading="lazy"  alt="[Image: Pi5M8-1.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">KinCony Pi5M8</span> is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the <span style="font-weight: bold;" class="mycode_b">Raspberry Pi Compute Module 5 (CM5)</span>, it integrates 8-channel MOSFET outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and multiple expansion interfaces into a compact DIN rail aluminum enclosure.<br />
The Raspberry Pi CM5 directly manages MOSFET outputs, digital inputs, analog inputs, PWM outputs, and serial communication ports, making it easy to deploy automation solutions using <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, <span style="font-weight: bold;" class="mycode_b">Node-RED</span>, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.<br />
Pi5M8 is ideal for controlling DC loads such as LED strips, solenoid valves, DC motors, industrial actuators, and custom automation equipment.<br />
<img src="https://www.kincony.com/images/Pi5M8/Pi5M8-5.jpg" loading="lazy"  alt="[Image: Pi5M8-5.jpg]" class="mycode_img" /><br />
</li>
<li>8-channel MOSFET outputs<br />
</li>
<li>8 optocoupler-isolated digital inputs<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
<li>Designed for smart home and industrial automation applications<br />
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5M8/Pi5M8-7.jpg" loading="lazy"  alt="[Image: Pi5M8-7.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony Pi5M8 – Raspberry Pi CM5 DIN Rail MOSFET Controller for Smart Home &amp; Industrial Automation<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5M8/Pi5M8-7.jpg" loading="lazy"  alt="[Image: Pi5M8-7.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Programmation kc868-A8 & Axx]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9478</link>
			<pubDate>Sat, 13 Jun 2026 01:22:28 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10472">H_spadacini</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9478</guid>
			<description><![CDATA[Monsieur l'administrateur;<br />
vu que le KC868A8 est programmable par editor plc serait-il possible de faire de même avec son grand frere le KC868A16 ainsi que pour le kc868A32 car il semble que c'est les memes plateformes avec plus d'entrees et sorties sur le bus i2c en modifiant la boucle programmable en c++]]></description>
			<content:encoded><![CDATA[Monsieur l'administrateur;<br />
vu que le KC868A8 est programmable par editor plc serait-il possible de faire de même avec son grand frere le KC868A16 ainsi que pour le kc868A32 car il semble que c'est les memes plateformes avec plus d'entrees et sorties sur le bus i2c en modifiant la boucle programmable en c++]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony KC868-AGv3 ESP32S3 Smart IR RF Controller released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9467</link>
			<pubDate>Fri, 12 Jun 2026 04:32:52 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9467</guid>
			<description><![CDATA[ESP32-S3 Smart IR RF Controller – KinCony KC868-AGv3<br />
KinCony KC868-AGv3 is a smart IR controller designed for smart home automation and IoT projects. It is based on the ESP32-S3-WROOM-1U N16R8 module, with powerful performance and rich interfaces for infrared, RF433MHz, and custom GPIO expansion.<br />
KC868-AGv3 supports Home Assistant, ESPHome, Arduino IDE, MicroPython, and ESP-IDF development. With KinCony KCS v3 firmware, it also supports MQTT Home Assistant Auto Discovery, so users can integrate sensors and decoded IR signals into Home Assistant without writing configuration code.<br />
<img src="https://www.kincony.com/images/KC868-AGv3/KC868-AGv3-1.jpg" loading="lazy"  width="790" height="712" alt="[Image: KC868-AGv3-1.jpg]" class="mycode_img" /><br />
Main Features<ul class="mycode_list"><li>ESP32-S3-WROOM-1U N16R8 module<br />
</li>
<li>Built-in IR receiver<br />
</li>
<li>IR sending via 3 GPIO channels<br />
</li>
<li>2 independent IR extension cable ports<br />
</li>
<li>Built-in RF433MHz receiver<br />
</li>
<li>Built-in RF433MHz sender<br />
</li>
<li>Built-in buzzer<br />
</li>
<li>18 free GPIO ports on PCB<br />
</li>
<li>Supports Home Assistant<br />
</li>
<li>Supports ESPHome YAML configuration<br />
</li>
<li>Supports Arduino IDE, MicroPython, and ESP-IDF development<br />
</li>
<li>Supports KCS v3 firmware<br />
</li>
<li>MQTT Home Assistant Auto Discovery<br />
</li>
<li>Zero-code integration with Home Assistant using KCS firmware<br />
</li>
<li>Suitable for smart home, IoT, IR control, RF remote control, and automation projects<br />
</li>
</ul>
<img src="https://www.kincony.com/images/KC868-AGv3/KC868-AGv3-2.jpg" loading="lazy"  width="808" height="736" alt="[Image: KC868-AGv3-2.jpg]" class="mycode_img" /><br />
Home Assistant Integration<br />
KC868-AGv3 can be used with Home Assistant in two ways.<br />
Users can configure the device with ESPHome YAML for customized automation projects.<br />
It can also run KinCony KCS v3 firmware. With KCS v3 firmware, KC868-AGv3 supports MQTT Home Assistant Auto Discovery. Sensors and decoded IR signals can be automatically discovered in Home Assistant, making setup much easier without writing configuration code.<br />
IR and RF Control<br />
KC868-AGv3 includes both infrared and RF433MHz functions.<br />
The built-in IR receiver can be used to learn and decode infrared remote control signals. The IR sender can transmit IR signals through 3 GPIO channels, including onboard IR output and 2 independent IR extension cable ports.<br />
The RF433MHz receiver and sender allow the controller to work with 433MHz wireless remote controls, sensors, and RF devices.<br />
<img src="https://www.kincony.com/images/KC868-AGv3/KinCony-KC868-AGv3-Smart-Controller-diagram.jpg" loading="lazy"  width="1290" height="1000" alt="[Image: KinCony-KC868-AGv3-Smart-Controller-diagram.jpg]" class="mycode_img" /><br />
Hardware Specifications<br />
Item<br />
DescriptionModel<br />
Processor<br />
ESP32-S3-WROOM-1U N16R8<br />
Power Supply<br />
DC 5V via USB-C<br />
Free GPIOs<br />
18<br />
IR Receiver<br />
1<br />
IR Sender<br />
IR Extension Cable Ports<br />
2 independent ports<br />
RF433MHz Receiver<br />
1<br />
RF433MHz Sender<br />
1<br />
Buzzer<br />
1<br />
Size<br />
100mm × 100mm × 30mm<br />
<img src="https://www.kincony.com/images/KC868-AGv3/KC868-AGv3-6.jpg" loading="lazy"  width="1000" height="1000" alt="[Image: KC868-AGv3-6.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[ESP32-S3 Smart IR RF Controller – KinCony KC868-AGv3<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
Item<br />
Processor<br />
Power Supply<br />
Free GPIOs<br />
18<br />
IR Receiver<br />
1<br />
IR Sender<br />
1<br />
1<br />
Buzzer<br />
1<br />
Size<br />
<img src="https://www.kincony.com/images/KC868-AGv3/KC868-AGv3-6.jpg" loading="lazy"  width="1000" height="1000" alt="[Image: KC868-AGv3-6.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony Pi5R8 – Raspberry Pi CM5 IoT Gateway released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9461</link>
			<pubDate>Thu, 11 Jun 2026 12:32:03 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9461</guid>
			<description><![CDATA[KinCony Pi5R8 – Raspberry Pi CM5 DIN Rail Relay Controller for Smart Home &amp; Industrial Automation<br />
<img src="https://www.kincony.com/images/Pi5R8/Pi5R8-1.jpg" loading="lazy"  alt="[Image: Pi5R8-1.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">KinCony Pi5R8</span> is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the <span style="font-weight: bold;" class="mycode_b">Raspberry Pi Compute Module 5 (CM5)</span>, it integrates relay outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and expansion interfaces into a compact DIN rail aluminum enclosure.<br />
The Raspberry Pi CM5 directly manages relay outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces, making it easy to deploy automation solutions using <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, <span style="font-weight: bold;" class="mycode_b">Node-RED</span>, MQTT, Modbus, Docker, Python, and other Linux-based software.<br />
Pi5R8 is an ideal platform for smart homes, industrial automation, energy management systems, and IoT edge computing applications.<br />
<img src="https://www.kincony.com/images/Pi5R8/Pi5R8-5.jpg" loading="lazy"  alt="[Image: Pi5R8-5.jpg]" class="mycode_img" /><br />
</li>
<li>8-channel industrial relay outputs<br />
</li>
</li>
</li>
<li>RS232 and RS485 communication interfaces<br />
</li>
</li>
</li>
</li>
</li>
</li>
<li>M.2 PCIe expansion socket<br />
</li>
<li>SSD1306 OLED display<br />
</li>
<li>Industrial aluminum DIN rail enclosure<br />
</li>
<li>Ideal for smart home and industrial automation projects<br />
</li>
</ul>
]]></description>
			<content:encoded><![CDATA[KinCony Pi5R8 – Raspberry Pi CM5 DIN Rail Relay Controller for Smart Home &amp; Industrial Automation<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
		</item>
		<item>
			<title><![CDATA[KinCony Pi5M16 – Raspberry Pi CM5 IoT Gateway released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9435</link>
			<pubDate>Fri, 05 Jun 2026 08:00:19 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9435</guid>
			<description><![CDATA[KinCony Pi5M16 – Raspberry Pi CM5 DIN Rail MOSFET Controller for Smart Home &amp; Industrial Automation<br />
<img src="https://www.kincony.com/images/Pi5M16/Pi5M16-1.jpg" loading="lazy"  alt="[Image: Pi5M16-1.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">KinCony Pi5M16</span> is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the <span style="font-weight: bold;" class="mycode_b">Raspberry Pi Compute Module 5 (CM5)</span>, it integrates 16-channel MOSFET outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and multiple expansion interfaces into a compact DIN rail aluminum enclosure.<br />
Pi5M16 is an ideal solution for automation projects requiring reliable DC load control. The CM5 directly manages MOSFET outputs, digital inputs, analog inputs, PWM outputs, and serial communication ports, making it easy to develop applications using <span style="font-weight: bold;" class="mycode_b">Node-RED</span>, <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, Python, MQTT, Modbus, and other Linux-based software platforms.<br />
<img src="https://www.kincony.com/images/Pi5M16/Pi5M16-5.jpg" loading="lazy"  alt="[Image: Pi5M16-5.jpg]" class="mycode_img" /><br />
</li>
<li>16-channel MOSFET outputs<br />
</li>
<li>16-channel optocoupler-isolated digital inputs<br />
</li>
</li>
</li>
</li>
</li>
</li>
<li>20 free GPIO expansion ports<br />
</li>
</li>
</li>
<li>DIN rail installation<br />
</li>
</li>
<li>Industrial aluminum enclosure<br />
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5M16/Pi5M16-7.jpg" loading="lazy"  alt="[Image: Pi5M16-7.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony Pi5M16 – Raspberry Pi CM5 DIN Rail MOSFET Controller for Smart Home &amp; Industrial Automation<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5M16/Pi5M16-7.jpg" loading="lazy"  alt="[Image: Pi5M16-7.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KinCony Pi5R16 – Raspberry Pi CM5 IoT Gateway released]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9434</link>
			<pubDate>Thu, 04 Jun 2026 20:59:38 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9434</guid>
			<description><![CDATA[KinCony Pi5R16 – Raspberry Pi CM5 DIN Rail IoT Gateway for Smart Home &amp; Industrial Automation<br />
<img src="https://www.kincony.com/images/Pi5R16/Pi5R16-1.jpg" loading="lazy"  alt="[Image: Pi5R16-1.jpg]" class="mycode_img" /><br />
<span style="font-weight: bold;" class="mycode_b">KinCony Pi5R16</span> is a powerful Raspberry Pi–based IoT gateway designed for smart home automation and industrial control applications. Built around the <span style="font-weight: bold;" class="mycode_b">Raspberry Pi Compute Module 5 (CM5)</span>, it integrates relay outputs, opto-isolated digital inputs, analog inputs, RS232/RS485 communication, PWM outputs, and multiple expansion interfaces into a compact DIN rail aluminum enclosure.<br />
Pi5R16 is ideal for users who want to build local automation systems using platforms such as <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, <span style="font-weight: bold;" class="mycode_b">Node-RED</span>, MQTT, Modbus, or custom Linux applications.<br />
The CM5 module directly manages all relays, digital inputs, analog inputs, PWM outputs, and serial communication ports, making development and deployment simple and flexible.<br />
<img src="https://www.kincony.com/images/Pi5R16/Pi5R16-5.jpg" loading="lazy"  alt="[Image: Pi5R16-5.jpg]" class="mycode_img" /><br />
Key Features<ul class="mycode_list"><li>Raspberry Pi Compute Module 5 (CM5) integrated<br />
</li>
<li>16-channel relay outputs<br />
</li>
</li>
</li>
</li>
</li>
<li>Analog input support:<ul class="mycode_list"><li>2 × DC 0–5V<br />
</li>
<li>2 × 4–20mA<br />
</li>
</ul>
</li>
</li>
</li>
</li>
<li>DIN rail aluminum enclosure design<br />
</li>
</li>
<li>Designed for industrial and smart home automation<br />
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5R16/Pi5R16-7.jpg" loading="lazy"  alt="[Image: Pi5R16-7.jpg]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[KinCony Pi5R16 – Raspberry Pi CM5 DIN Rail IoT Gateway for Smart Home &amp; Industrial Automation<br />
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</li>
</li>
</li>
</ul>
<img src="https://www.kincony.com/images/Pi5R16/Pi5R16-7.jpg" loading="lazy"  alt="[Image: Pi5R16-7.jpg]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[problem with kc868 has v2]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9348</link>
			<pubDate>Fri, 22 May 2026 05:56:49 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10816">Gianfranco Pepi</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9348</guid>
			<description><![CDATA[<div style="text-align: justify;" class="mycode_align">Good morning, I also did some tests with the multimeter looking at your diagram and the board seems not to work, that is, the KC868 has v2. Using your tool to check and change the assignments of the inputs to the outputs, I don't know if it also shows the activation of the outputs, but every time I close and open the input, the RS485 adapter emits a signal and under the bar it shows me the last signal that arrived, so the inputs, so to speak, "work". Now I tried with the multimeter considering that I'm using only one 12 volt power supply for everything, so the grounds are equivalent! Here is the voltage between the +12 volts and the output, which according to your diagram should be negative, always remains at 6 volts without ever varying (I'm talking about an open circuit). I tried installing a classic relay that is powered by 12 volts and has a pilot input that can be set to receive either positive or negative inputs. Obviously, I set the input to negative and when I try to close the input, the result does n</div><br /><!-- start: postbit_attachments_attachment -->
<img src="https://www.kincony.com/forum/images/attachtypes/image.png" title="JPEG Image" border="0" alt=".jpeg" />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9874" target="_blank" title="">WhatsApp Image 2026-05-21 at 07.52.47 (1).jpeg</a> (Size: 60.51 KB / Downloads: 353)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9875" target="_blank" title="">WhatsApp Image 2026-05-21 at 07.52.47 (2).jpeg</a> (Size: 95.9 KB / Downloads: 323)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9876" target="_blank" title="">WhatsApp Image 2026-05-21 at 07.52.47.jpeg</a> (Size: 66.36 KB / Downloads: 339)
			<content:encoded><![CDATA[<div style="text-align: justify;" class="mycode_align">Good morning, I also did some tests with the multimeter looking at your diagram and the board seems not to work, that is, the KC868 has v2. Using your tool to check and change the assignments of the inputs to the outputs, I don't know if it also shows the activation of the outputs, but every time I close and open the input, the RS485 adapter emits a signal and under the bar it shows me the last signal that arrived, so the inputs, so to speak, "work". Now I tried with the multimeter considering that I'm using only one 12 volt power supply for everything, so the grounds are equivalent! Here is the voltage between the +12 volts and the output, which according to your diagram should be negative, always remains at 6 volts without ever varying (I'm talking about an open circuit). I tried installing a classic relay that is powered by 12 volts and has a pilot input that can be set to receive either positive or negative inputs. Obviously, I set the input to negative and when I try to close the input, the result does n</div><br /><!-- start: postbit_attachments_attachment -->
		</item>
		<item>
			<title><![CDATA[Python and arduino code]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9321</link>
			<pubDate>Fri, 08 May 2026 17:34:44 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=2217">Saif Kitany</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9321</guid>
<br />
I would like to have a video of explaining how to write arduino or python code for A32 pro.]]></description>
<br />
I would like to have a video of explaining how to write arduino or python code for A32 pro.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16V3 - what is the latest firmware please?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9298</link>
			<pubDate>Fri, 01 May 2026 03:36:48 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8035">useful21</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9298</guid>
			<description><![CDATA[I find it a bit hard to figure out what the latest firmware for downloading is for the KC868-A16V3 - kincony firmware.<br />
<br />
Thanks.]]></description>
			<content:encoded><![CDATA[I find it a bit hard to figure out what the latest firmware for downloading is for the KC868-A16V3 - kincony firmware.<br />
<br />
Thanks.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Http protocol]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9238</link>
			<pubDate>Wed, 15 Apr 2026 14:03:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9238</guid>
			<description><![CDATA[If i want to control relay controller by another relay controller with http protocol (for example: controlling B16 by A32 pro ), what i should write in the URL, what i should enable?<br />
<br />
I would like if you give full explanation.]]></description>
			<content:encoded><![CDATA[If i want to control relay controller by another relay controller with http protocol (for example: controlling B16 by A32 pro ), what i should write in the URL, what i should enable?<br />
<br />
I would like if you give full explanation.]]></content:encoded>
		</item>
	</channel>
</rss>
