	<channel>
		<title><![CDATA[Smart Home Automation Forum - KinCony Server-Mini / Server-16 Raspberry Pi4 relay module]]></title>
		<pubDate>Sun, 08 Nov 2026 08:48:49 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[It looks like it's broken.]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9857</link>
			<pubDate>Tue, 06 Oct 2026 09:39:02 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=4766">abc123</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9857</guid>
			<description><![CDATA[ACT PSU 继电器指示灯交替闪烁——短暂亮起然后熄灭——并且设备无法连接到 Home Assistant。]]></description>
			<content:encoded><![CDATA[ACT PSU 继电器指示灯交替闪烁——短暂亮起然后熄灭——并且设备无法连接到 Home Assistant。]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Getting inconsistent/wrong sensor readings from N20 over RS485 Modbus RTU]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9850</link>
			<pubDate>Thu, 01 Oct 2026 14:27:51 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11963">Abubakar506</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9850</guid>
			<description><![CDATA[Getting inconsistent/wrong sensor readings from N20 over RS485 Modbus RTU — hoping for some guidance.<br />
<br />
Setup: N20 connected via RS485 to a Server16 running Home Assistant, using the Modbus RTU integration (baud 38400, matching the N20 Modbus protocol spec).<br />
<br />
Issue: Reading the temperature register (offset 64, float, Chip 1) gives inconsistent results. N20's own display shows 33.7°C, but Home Assistant reads back 24.38°C — sometimes correct, sometimes way off (even negative values occasionally). Current/power/energy readings on the integer registers seem fine, it's mainly the float-type registers (temperature, power factor) that come back wrong or inconsistent.<br />
<br />
I've already tried:<br />
- Different byte-swap orders (byte swap gives correct values sometimes, but not consistently)<br />
- Re-tightening A/B terminals<br />
<br />
Questions:<br />
1. Is there a known/confirmed byte order for the float registers (temp, PF) on N20? The protocol doc mentions "CDBA format" — is there a simpler way to interpret this?<br />
2. Any guidance on termination/grounding recommendations for the RS485 bus on N20 and Server16 specifically?<br />
3. Is there a minimum recommended polling interval to avoid read collisions?<br />
<br />
Any help appreciated — thanks!<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10570" target="_blank" title="">2.PNG</a> (Size: 42.79 KB / Downloads: 91)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10571" target="_blank" title="">code.txt</a> (Size: 422 bytes / Downloads: 63)
			<content:encoded><![CDATA[Getting inconsistent/wrong sensor readings from N20 over RS485 Modbus RTU — hoping for some guidance.<br />
<br />
<br />
<br />
<br />
Questions:<br />
<br />
		</item>
		<item>
			<title><![CDATA[Server 16 issues]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8865</link>
			<pubDate>Wed, 31 Dec 2025 19:15:37 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10145">podlak</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8865</guid>
I started working over new home automation project and I bought Server 16 with raspberry pi &amp; nodered. Board is working fine with rs485 sensors, but I'm planning to use relays to control electric circuits and I have two major difficulties :<br />
1) by default I want to have circuits off (NC), I changed settings of all relays in nodered to invert switches, but when board starts it triggers all relays for a moment ON and after moment all goes to OFF. It means that all connected electric equipment will start for a less a second - this is very unwanted behaviour, how to avoid that?<br />
2) I'm planning to use digital inputs to control relays with momentary buttons, but input seams to be connected with relays and input has to be shorted with GND all the time, how to change that, so relay will be toggled wen button is pushed for a moment?  I don't want to use bistable buttons, as relay will be connected with nodered and homeassistant in parallel and wall buttons will have different state than circuit <br />
<br />
Beet regards <br />
Podlak]]></description>
<br />
Beet regards <br />
Podlak]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Connection Internet]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8680</link>
			<pubDate>Sun, 26 Oct 2025 18:51:42 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9012">shochif</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8680</guid>
			<description><![CDATA[can i using sim7600E for the main internet an i share the internet using switch base on HomeAssistant???]]></description>
			<content:encoded><![CDATA[can i using sim7600E for the main internet an i share the internet using switch base on HomeAssistant???]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[add webcam]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8630</link>
			<pubDate>Tue, 07 Oct 2025 11:30:12 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8630</guid>
			<description><![CDATA[can i add usb webcam to my kincony server 16?<br />
if can what type of webcam must i use cause when i try using obsbot camera on hardware not detected]]></description>
			<content:encoded><![CDATA[can i add usb webcam to my kincony server 16?<br />
if can what type of webcam must i use cause when i try using obsbot camera on hardware not detected]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Connect RS485 KC868-HAv2 to Server Mini]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8448</link>
			<pubDate>Wed, 13 Aug 2025 22:05:15 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9289">Mijoo</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8448</guid>
			<description><![CDATA[<span style="font-weight: bold;" class="mycode_b">Help: Connect RS485 I/O modules to the Raspberry Pi 4 Relay Board (Server Mini) + Home Assistant OS</span><br />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">Hardware</span><br />
<ul class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">Controller/board:</span> KinCony Raspberry Pi 4 Relay Board / <span style="font-style: italic;" class="mycode_i">Server Mini</span> (link: <a href="https://www.kincony.com/raspberry-pi-4-relay-board.html" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/raspberry-pi-4-relay-board.html</a>)<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Modules I want to add:</span> KinCony RS485 I/O modules (link: <a href="https://www.kincony.com/rs485-io-module.html" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/rs485-io-module.html</a>)<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Planned system:</span> Home Assistant <span style="font-weight: bold;" class="mycode_b">OS</span> (not Raspberry Pi OS), running on the Pi inside the board<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Use case:</span> Wired wall switches and I/O around the house → one RS485 bus, multiple modules, stable &amp; scalable for many installs<br />
</li>
</ul>
<br />
<span style="font-weight: bold;" class="mycode_b">Goal</span><br />
<ol type="1" class="mycode_list"><li>Daisy-chain several KinCony RS485 I/O modules to the Server Mini’s onboard RS485.<br />
</li>
<li>Control/monitor them from <span style="font-weight: bold;" class="mycode_b">Home Assistant OS</span> (HA Modbus if possible).<br />
</li>
<li>Best-practice for <span style="font-weight: bold;" class="mycode_b">addressing many modules</span> (bulk provisioning) without connecting a laptop each time.<br />
</li>
</ol>
<br />
<br />
<hr class="mycode_hr" />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">What I’ve found / tried so far</span><ul class="mycode_list"><li>The board exposes RS485 via the Pi’s UART (I see pins marked <span style="font-weight: bold;" class="mycode_b">GPIO14 = TX</span>, <span style="font-weight: bold;" class="mycode_b">GPIO15 = RX</span> on documentation/pins).<br />
</li>
<li>On Home Assistant <span style="font-weight: bold;" class="mycode_b">OS</span>, I cannot just edit /boot/config.txt like on Raspberry Pi OS, so I’m not sure about the correct way to <span style="font-weight: bold;" class="mycode_b">enable the UART</span> for the onboard RS485 under HA OS.<br />
</li>
<li>I tried using generic HA Modbus config but I’m not 100% sure about the <span style="font-weight: bold;" class="mycode_b">device path</span> (e.g. /dev/ttyAMA0, /dev/ttyS0, or /dev/serial/by-id/...) and <span style="font-weight: bold;" class="mycode_b">serial parameters</span> (baud, parity, stop bits) for KinCony’s RS485 port on this board.<br />
</li>
</ul>
<br />
<br />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">Questions</span><br />
<br />
<ol type="1" class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">Wiring</span><ul class="mycode_list"><li>Do I need a <span style="font-weight: bold;" class="mycode_b">120 Ω termination resistor</span> at the last device? Are there built-in <span style="font-weight: bold;" class="mycode_b">bias resistors</span> on the Server Mini’s RS485 transceiver, or should I add my own?<br />
</li>
<li>Any max bus length / topology recommendations? (I’ll use <span style="font-weight: bold;" class="mycode_b">daisy chain</span>, not star.)<br />
</li>
</ul>
<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Protocol &amp; parameters</span><ul class="mycode_list"><li>Do those <span style="font-weight: bold;" class="mycode_b">RS485 I/O modules</span> speak <span style="font-weight: bold;" class="mycode_b">Modbus RTU</span> out of the box? If yes, what are the <span style="font-weight: bold;" class="mycode_b">default serial parameters</span> (baud, parity, stopbits) and the <span style="font-weight: bold;" class="mycode_b">register map</span> (coils/inputs/holding)?<br />
</li>
<li>If it’s not Modbus RTU by default, is there a <span style="font-weight: bold;" class="mycode_b">Modbus firmware</span> or config mode I should use?<br />
</li>
</ul>
<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Addressing multiple modules</span><ul class="mycode_list"><li>How do I set <span style="font-weight: bold;" class="mycode_b">unique addresses</span> for each module? DIP switches? Command?<br />
</li>
<li>For <span style="font-weight: bold;" class="mycode_b">bulk installs</span>, is there a recommended workflow to assign addresses without hooking up each module to a PC? (Auto-addressing, scan/assign tool, etc.)<br />
</li>
</ul>
<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Home Assistant OS specifics</span><ul class="mycode_list"><li>On this KinCony board with HA <span style="font-weight: bold;" class="mycode_b">OS</span>, what is the <span style="font-weight: bold;" class="mycode_b">correct serial device path</span> for the onboard RS485 (e.g., /dev/ttyAMA0)?<br />
</li>
<li>What is the recommended way to <span style="font-weight: bold;" class="mycode_b">enable UART</span> on HA OS for this board (since /boot/config.txt is read-only under HA OS)? Any KinCony-specific steps or an add-on?<br />
</li>
<li>A minimal, known-good <span style="font-weight: bold;" class="mycode_b">Home Assistant modbus: YAML</span> example for one RS485 I/O module would be super helpful.<br />
</li>
</ul>
<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Examples</span><ul class="mycode_list"><li>Could you share <span style="font-weight: bold;" class="mycode_b">example register addresses</span> (coils/inputs) for:<ul class="mycode_list"><li>Reading digital inputs from a KinCony RS485 I/O module<br />
</li>
<li>Controlling a relay output (if the chosen module has relays)<br />
</li>
</ul>
</li>
<li>Any <span style="font-weight: bold;" class="mycode_b">sample configs</span> for more than one module on the same bus?<br />
</li>
</ul>
<br />
</li>
</ol>
]]></description>
			<content:encoded><![CDATA[<span style="font-weight: bold;" class="mycode_b">Help: Connect RS485 I/O modules to the Raspberry Pi 4 Relay Board (Server Mini) + Home Assistant OS</span><br />
<br />
<br />
</li>
</li>
</li>
</li>
</ul>
<br />
</li>
</li>
</li>
</ol>
<br />
<br />
<br />
<br />
</li>
</li>
</li>
</ul>
<br />
<br />
<br />
<br />
<br />
</li>
</li>
</ul>
<br />
</li>
</li>
</li>
</ul>
<br />
</li>
</li>
</li>
</ul>
<br />
</li>
</li>
</li>
</li>
</ul>
<br />
</li>
</li>
</li>
</ul>
</li>
</li>
</ul>
<br />
</li>
</ol>
		</item>
		<item>
			<title><![CDATA[Server-Mini and RS485 - IO Module – KC868-HAv2]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8447</link>
			<pubDate>Wed, 13 Aug 2025 21:44:50 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8447</guid>
			<description><![CDATA[Hello, friends.<br />
<br />
<br />
</li>
</li>
</li>
</li>
</ul>
<br />
<br />
<br />
</li>
</li>
</li>
</ol>
<br />
<br />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">What I’ve found / tried so far</span><br />
<br />
</li>
</li>
</li>
<li>I previously attempted the old rpi_gpio integration for direct GPIO, but HA OS doesn’t include that — so I want to use <span style="font-weight: bold;" class="mycode_b">RS485/Modbus</span> properly instead.<br />
</li>
</ul>
]]></description>
			<content:encoded><![CDATA[Hello, friends.<br />
<br />
<br />
</li>
</li>
</li>
</li>
</ul>
<br />
<br />
<br />
</li>
</li>
</li>
</ol>
<br />
<br />
<br />
<br />
<br />
</li>
</li>
</li>
</li>
</ul>
		</item>
		<item>
			<title><![CDATA[Kincony Server-16 new install]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8443</link>
			<pubDate>Wed, 13 Aug 2025 11:30:43 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8443</guid>
			<description><![CDATA[before install smart home assisstant we need to connect to server 16 <br />
but i cant connect, and when i check my connection to server 16 like this<br />
how i can fix this ?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8168" target="_blank" title="">RTO.jpg</a> (Size: 208.02 KB / Downloads: 751)
			<content:encoded><![CDATA[before install smart home assisstant we need to connect to server 16 <br />
		</item>
		<item>
			<title><![CDATA[Kincony Server-Mini]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8340</link>
			<pubDate>Thu, 24 Jul 2025 19:36:10 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9128">mst-28816</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8340</guid>
			<description><![CDATA[Hello, we just started with kincony, and need help to control the server-mini relay and i/O-ports.<br />
please send us a help to control these ports. Will it work with udp ?<br />
<br />
Thanks for short reply with solution to control these ports.]]></description>
			<content:encoded><![CDATA[Hello, we just started with kincony, and need help to control the server-mini relay and i/O-ports.<br />
<br />
Thanks for short reply with solution to control these ports.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[MCP23017 interrupt pin]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8311</link>
			<pubDate>Wed, 09 Jul 2025 22:03:20 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6982">rboers</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8311</guid>
			<description><![CDATA[I'm writing my own program in C/C++ and I was wondering if the interrupt pins of the MCP23017 chips are connected to the GPIO pins of the Raspberry Pi? If so, which GPIO pins are used?]]></description>
			<content:encoded><![CDATA[I'm writing my own program in C/C++ and I was wondering if the interrupt pins of the MCP23017 chips are connected to the GPIO pins of the Raspberry Pi? If so, which GPIO pins are used?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[CM5 compatible?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8309</link>
			<pubDate>Wed, 09 Jul 2025 15:56:39 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8309</guid>
			<description><![CDATA[I really like this server, but the CM4 is a bit slow for my project.<br />
Can a CM5 module be used in the Server-16 server?<br />
If not, will there be a CM5 compatible Server-16 in the near future?]]></description>
			<content:encoded><![CDATA[I really like this server, but the CM4 is a bit slow for my project.<br />
If not, will there be a CM5 compatible Server-16 in the near future?]]></content:encoded>
		</item>
		<item>
			<link>https://www.kincony.com/forum/showthread.php?tid=8296</link>
			<pubDate>Fri, 04 Jul 2025 12:22:28 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8296</guid>
			<description><![CDATA[cant connect to rasberry pi after i connect with LAN cable<br />
i try to type <a href="http://homeassistant.local:8123/" target="_blank" rel="noopener" class="mycode_url">http://homeassistant.local:8123/</a> &amp; <a href="http://homeassistant:8123/" target="_blank" rel="noopener" class="mycode_url">http://homeassistant:8123/</a> nothing happen already refresh 30 a hours already check the connection<br />
already check the tutorials <a href="https://youtu.be/oEjIZg6C_-Y" target="_blank" rel="noopener" class="mycode_url">https://youtu.be/oEjIZg6C_-Y</a> stop at 9 minutes videos<br />
please help me<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7948" target="_blank" title="">error web.png</a> (Size: 28.72 KB / Downloads: 662)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7949" target="_blank" title="">network.png</a> (Size: 57.1 KB / Downloads: 572)
			<content:encoded><![CDATA[cant connect to rasberry pi after i connect with LAN cable<br />
		</item>
		<item>
			<title><![CDATA[Kincony Server-16]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8295</link>
			<pubDate>Fri, 04 Jul 2025 11:50:14 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8295</guid>
			<description><![CDATA[hello sir<br />
i want to install home assistant using LAN connector but when i type <a href="http://homeassistant:8123/" target="_blank" rel="noopener" class="mycode_url">http://homeassistant:8123/</a> nothing happen<br />
my ethernet already connected but still unidentified network<br />
can someone help me?<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7947" target="_blank" title="">error.png</a> (Size: 69.89 KB / Downloads: 783)
			<content:encoded><![CDATA[hello sir<br />
		</item>
		<item>
			<title><![CDATA[Python code for digital inputs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7595</link>
			<pubDate>Mon, 10 Feb 2025 03:40:57 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7097">pietpoerrie</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7595</guid>
<br />
Is there a python code example for reading the digital inputs on the kincony server 16?<br />
<br />
Thanks in advance,<br />
Pieter]]></description>
<br />
<br />
Pieter]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Kincony Server 16 User Manual]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7120</link>
			<pubDate>Wed, 27 Nov 2024 13:12:18 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6699">electronics engineer</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7120</guid>
			<description><![CDATA[Is there a detailed user manual available for the Kincony Server 16 that includes the I/O port numbers or addresses? I need this information to utilize the device's pins and ports more efficiently for my application.]]></description>
			<content:encoded><![CDATA[Is there a detailed user manual available for the Kincony Server 16 that includes the I/O port numbers or addresses? I need this information to utilize the device's pins and ports more efficiently for my application.]]></content:encoded>
		</item>
	</channel>
</rss>
