	<channel>
		<title><![CDATA[Smart Home Automation Forum - Getting Started with ESPHome and Home Assistant]]></title>
		<pubDate>Sat, 10 Oct 2026 21:30:17 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[KC868-AGv3]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9756</link>
			<pubDate>Thu, 20 Aug 2026 04:45:26 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11474">zalaking</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9756</guid>
			<description><![CDATA[Hi Kincony and community.<br />
<br />
I've just received my KC868-AGv3 RF/IR Smart Controller..<br />
<br />
is there an example ESPHome configuration posted anywhere - I've been searching for some time and cannot find a an example I can use to get me started... I've installed a base ESP32 config on it and I see it on my network etc.. but keen to get it fully worked with all the RF/IR/Buzzer features..<br />
<br />
Many thanks in advance.]]></description>
			<content:encoded><![CDATA[Hi Kincony and community.<br />
<br />
<br />
<br />
Many thanks in advance.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-HA-V21 24v supply]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9374</link>
			<pubDate>Sun, 31 May 2026 04:08:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=2810">Gerrit</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9374</guid>
			<description><![CDATA[<span style="font-family: 'Google Sans', Arial, sans-serif;" class="mycode_font"><span style="font-size: medium;" class="mycode_size">Hello,</span></span><br />
<span style="font-size: medium;" class="mycode_size"><span style="font-family: 'Google Sans', Arial, sans-serif;" class="mycode_font">I am planning to use about 15 KC868-HA-V21 modules behind 6-gang momentary switches throughout my whole house and connect them to the KC868-AP dimmer board. The LED strips I am using are 24V.</span></span><br />
<span style="font-size: medium;" class="mycode_size"><span style="font-family: 'Google Sans', Arial, sans-serif;" class="mycode_font">Can I also use this 24V supply to power the KC868-HA-V21 modules? The documentation states that it is supported, but I want to make sure it is a safe and reliable choice. Or, would it be better to use a separate 12V power supply for the modules?</span></span><br />
<span style="font-size: medium;" class="mycode_size"><span style="font-family: 'Google Sans', Arial, sans-serif;" class="mycode_font">Thank you for your advice!</span></span>]]></description>
			<content:encoded><![CDATA[<span style="font-family: 'Google Sans', Arial, sans-serif;" class="mycode_font"><span style="font-size: medium;" class="mycode_size">Hello,</span></span><br />
<span style="font-size: medium;" class="mycode_size"><span style="font-family: 'Google Sans', Arial, sans-serif;" class="mycode_font">Thank you for your advice!</span></span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[DM4 ESPHome yaml for home assistant with tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9373</link>
			<pubDate>Sat, 30 May 2026 21:35:50 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10935">pavel.hajn</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9373</guid>
is possible to use DM4 with ESPHome and Tuya ? B8M works fine, but DM4 has some trouble in tuya_wifi_mcu_light_output.cpp<br />
<br />
Here is the log:<br />
Reading CMake configuration...<br />
Dependency Graph<br />
|-- noise-c @ 0.1.11<br />
|-- Tuya_WiFi_MCU_SDK @ 0.0.3+sha.66c750a<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp.o<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/uart/uart_component_esp_idf.cpp.o<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/uart/uart_debugger.cpp.o<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/watchdog/watchdog.cpp.o<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/web_server/list_entities.cpp.o<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp: In member function 'virtual void esphome::tuya_wifi_mcu::TuyaWifiMcuLightOutput:<img src="https://www.kincony.com/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />etup()':<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp:10:28: error: 'class esphome::light::LightState' has no member named 'add_new_remote_values_callback'<br />
  10 |        this-&gt;bind_light_-&gt;add_new_remote_values_callback([this]() {<br />
      |                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp: In lambda function:<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp:15:47: warning: 'float esphome::gamma_uncorrect(float, float)' is deprecated: Use LightState::gamma_uncorrect_lut() instead. Removed in 2026.9.0. [-Wdeprecated-declarations]<br />
  15 |          this-&gt;tuya_bright_ = gamma_uncorrect(bright, this-&gt;bind_light_-&gt;get_gamma_correct()) * 100;<br />
      |                                ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br />
In file included from src/esphome/components/i2c/i2c.h:5,<br />
                from src/esphome/components/ads1115/ads1115.h:3,<br />
                from src/esphome.h:3,<br />
                from src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.h:3,<br />
                from src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp:1:<br />
src/esphome/core/helpers.h:1597:7: note: declared here<br />
1597 | float gamma_uncorrect(float value, float gamma);<br />
      |      ^~~~~~~~~~~~~~~<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp: In member function 'virtual void esphome::tuya_wifi_mcu::TuyaWifiMcuLightOutput::process_dp_data(const unsigned char*, short unsigned int)':<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp:33:47: warning: 'float esphome::gamma_correct(float, float)' is deprecated: Use LightState::gamma_correct_lut() instead. Removed in 2026.9.0. [-Wdeprecated-declarations]<br />
  33 |        this-&gt;output_-&gt;set_level(gamma_correct(bright, this-&gt;bind_light_-&gt;get_gamma_correct()));<br />
      |                                  ~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br />
src/esphome/core/helpers.h:1593:7: note: declared here<br />
1593 | float gamma_correct(float value, float gamma);<br />
      |      ^~~~~~~~~~~~~<br />
src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp:35:47: warning: 'float esphome::gamma_correct(float, float)' is deprecated: Use LightState::gamma_correct_lut() instead. Removed in 2026.9.0. [-Wdeprecated-declarations]<br />
  35 |        this-&gt;output_-&gt;set_level(gamma_correct(bright, 2.8));<br />
      |                                  ~~~~~~~~~~~~~^~~~~~~~~~~~~<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/web_server/web_server.cpp.o<br />
Compiling .pioenvs/kin-dm4/src/esphome/components/web_server_base/web_server_base.cpp.o<br />
*** [.pioenvs/kin-dm4/src/esphome/components/tuya_wifi_mcu/light/tuya_wifi_mcu_light_output.cpp.o] Error 1<br />
========================= [FAILED] Took 93.00 seconds =========================<br />
<br />
Kind Regards<br />
Pavel Hajn]]></description>
<br />
<br />
Kind Regards<br />
Pavel Hajn]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Instal ESP HA with ethernet]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9203</link>
			<pubDate>Fri, 03 Apr 2026 04:20:07 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7115">kulibin</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9203</guid>
			<description><![CDATA[Good day .<br />
 I have module ESP32 B24 with ethernet port. <br />
How I can install ESP HA ? <br />
Thanks]]></description>
			<content:encoded><![CDATA[Good day .<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[AS-ESP32-S3 won't initialize]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9143</link>
			<pubDate>Fri, 20 Mar 2026 02:49:56 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10592">scottq</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9143</guid>
			<description><![CDATA[I just purchased a AS-ESP32-S3 device to act as a voice assistant for my Home Assistant. When I received the unit, something inside it was rattling around loosely - like something had broken inside. Not sure if that's ultimately important or not. <br />
<br />
When I plugged the device into the HA server, all of the lights turned blue and a tone built up in about 3 steps to a steady tone. The tone continued without stopping for as long as I had the device plugged it (up to 15 minutes, when I unplugged it). It doesn't seem to me that it was flashed with any new firmware as described in this YouTube video: <a href="https://www.youtube.com/watch?v=g-KsrZjFljY" target="_blank" rel="noopener" class="mycode_url">https://www.youtube.com/watch?v=g-KsrZjFljY</a><br />
<br />
While the tone was sounding, I did try to configure the device in my home assistant. I selected "Add Device", saw ESPHome and selected it, and was presented with a modal asking for the host ip address, which I provided. I got a "Unable to connect to the ESPHome device. Make sure the device's YAML configuration includes an 'api' section." as shown in the attached screenshot. I have no way to access any YAML that the device might be using since I can't access the device and can't do anything with it in Home Assistant.<br />
<br />
What do I do to get this thing working?<br />
<br />
Scott<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9368" target="_blank" title="">ESPHome_add_device.png</a> (Size: 19.97 KB / Downloads: 262)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9369" target="_blank" title="">ESPHome_unable_to_connect.png</a> (Size: 33.32 KB / Downloads: 247)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9370" target="_blank" title="">IMG_4911.JPG</a> (Size: 3.77 MB / Downloads: 451)
			<content:encoded><![CDATA[I just purchased a AS-ESP32-S3 device to act as a voice assistant for my Home Assistant. When I received the unit, something inside it was rattling around loosely - like something had broken inside. Not sure if that's ultimately important or not. <br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[Device change after damage]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9105</link>
			<pubDate>Fri, 06 Mar 2026 05:09:34 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10520">OhnsorgeSebastian</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9105</guid>
			<description><![CDATA[Hi all. I have a question. I am using a B24M configured as MQTT with Home Assistant. After it was damaged, I bought a new device. How can I replace the device while keeping the existing integrations (so that a new device is not created, but it replaces the damaged one)?  From what I see, the device is identified using a UID in the MQTT broker, so I guess I would need to somehow replace that.]]></description>
			<content:encoded><![CDATA[Hi all. I have a question. I am using a B24M configured as MQTT with Home Assistant. After it was damaged, I bought a new device. How can I replace the device while keeping the existing integrations (so that a new device is not created, but it replaces the damaged one)?  From what I see, the device is identified using a UID in the MQTT broker, so I guess I would need to somehow replace that.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[TA with Home Assistant with Ethernet Only]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8981</link>
			<pubDate>Tue, 03 Feb 2026 06:54:07 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10350">upstream</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8981</guid>
			<description><![CDATA[How do I get the Tiny Alarm System (TA) to work with Home Assistant?<br />
<br />
The yaml example at this <a href="https://www.kincony.com/forum/showthread.php?tid=7897" target="_blank" rel="noopener" class="mycode_url">post</a> is set to use wifi. I want to use ethernet / poe only.<br />
<br />
However, if I remove the wifi components, this line: <br />
<div class="codeblock phpcodeblock"><div class="title">PHP Code:</div><div class="body"><div dir="ltr"><code><span style="color: #007700">-&nbsp;</span><span style="color: #0000BB">platform</span><span style="color: #007700">:&nbsp;</span><span style="color: #0000BB">tuya_wifi_mcu&nbsp;<br /></span></code></div></div></div><br />
is located all over the place.<br />
<br />
Does anyone have a complete yaml example without any wifi (ethernet only)?]]></description>
			<content:encoded><![CDATA[How do I get the Tiny Alarm System (TA) to work with Home Assistant?<br />
<br />
<br />
<br />
Does anyone have a complete yaml example without any wifi (ethernet only)?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Kincony KC868-A4  flashen   not work]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8749</link>
			<pubDate>Wed, 19 Nov 2025 15:35:43 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9873">jurgen2003</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8749</guid>
			<description><![CDATA[Beste forum, <br />
ik heb twee Kincony KC 868 A-serie IO-boards, één A4 die werkt met ESP Home en Home Assistant, maar de andere A4 ESP kan niet worden aangesloten. Het verbindingsboard is aangesloten via USB en blijft laden, het board schakelt relais en de zoemer om zonder resultaat. Moet dit board in de flashmodus worden gezet? Zo ja, hoe werkt dat?<br />
groet jurgen]]></description>
			<content:encoded><![CDATA[Beste forum, <br />
groet jurgen]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Operating WLAN and Ethernet together]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8520</link>
			<pubDate>Wed, 10 Sep 2025 15:53:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9271">JuDie07</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8520</guid>
			<description><![CDATA[<img src="https://www.kincony.com/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />  When I enter WLAN and Ethernet together in ESPHome, I get the following error message:<br />
<br />
Can you please provide a code example?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8313" target="_blank" title="">KC868-04.png</a> (Size: 29.37 KB / Downloads: 357)
			<content:encoded><![CDATA[<img src="https://www.kincony.com/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />  When I enter WLAN and Ethernet together in ESPHome, I get the following error message:<br />
<br />
		</item>
		<item>
			<title><![CDATA[Esphome + KC868-HA-V21]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8445</link>
			<pubDate>Wed, 13 Aug 2025 16:45:42 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9282">duranduy</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8445</guid>
			<description><![CDATA[Hello, friends. Thank you so much for your products—I’ve been using them with great pleasure. However, I’ve encountered an issue while trying to set up your KC868-HAv21 RS485.<br />
<br />
I connected it via RS485 to the KC868-A2, using the ESPHOME firmware. I added your component from GitHub, and the settings on the HAv2 are factory defaults. Controlling the digital outputs (D1-D6) works fine, but when it comes to changes in the state of the digital inputs, the ESPHome logs only show the following messages:<br />
<br />
text<br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=1<br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=2 <br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=3 <br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=4 <br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=5 <br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=6 <br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=7 <br />
dump kc868_ha config, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=8  <br />
found a kc868_ha board, target_relay_controller_addr=1, switch_adapter_addr=10, bind_output=1 (also bind output 1-8)  <br />
What am I doing wrong? Could it be due to incorrect bind_output parameters? If so, which numbers should I specify?<br />
<br />
I took the binary_sensor configuration from your GitHub and followed the instructions from your YouTube channel exactly. Thanks for your help!]]></description>
			<content:encoded><![CDATA[Hello, friends. Thank you so much for your products—I’ve been using them with great pleasure. However, I’ve encountered an issue while trying to set up your KC868-HAv21 RS485.<br />
<br />
<br />
text<br />
<br />
I took the binary_sensor configuration from your GitHub and followed the instructions from your YouTube channel exactly. Thanks for your help!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Need help choosing modules for 32-channel lighting control with Home Assistant]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8280</link>
			<pubDate>Mon, 30 Jun 2025 20:23:40 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8984">Karlis_LV</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8280</guid>
			<description><![CDATA[Hello everyone,<br />
I'm new to KinCony and Home Assistant. I would really appreciate your help.<br />
I want to control my house lighting using <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, and I need to manage <span style="font-weight: bold;" class="mycode_b">32+ channels</span>. I’m looking for a solution with the <span style="font-weight: bold;" class="mycode_b">best price/performance</span>.<br />
<span style="font-weight: bold;" class="mycode_b">Important:</span><ul class="mycode_list"><li>I am <span style="font-weight: bold;" class="mycode_b">not a programmer</span>, so I need a system that works <span style="font-weight: bold;" class="mycode_b">without writing code</span>, just ready firmware like <span style="font-weight: bold;" class="mycode_b">ESPHome</span> or KinCony’s firmware.<br />
</li>
<li>I <span style="font-weight: bold;" class="mycode_b">really like KinCony devices</span>, but unfortunately I can't find <span style="font-weight: bold;" class="mycode_b">compact and complete information</span> in one place that explains how to set up a <span style="font-weight: bold;" class="mycode_b">simple lighting project</span> using a few modules.<br />
</li>
<li>I prefer using <span style="font-weight: bold;" class="mycode_b">I/O extenders</span> (relay modules) that come in a <span style="font-weight: bold;" class="mycode_b">solid metal case</span> or at least with <span style="font-weight: bold;" class="mycode_b">mechanical protection</span>, not open PCB boards.<br />
</li>
</ul>
Could you please help me with:<br />
<ol type="1" class="mycode_list"><li>Which modules do I need to build a 32+ channel Home Assistant lighting control system?<br />
</li>
<li>Is there a <span style="font-weight: bold;" class="mycode_b">video or full guide</span> that shows everything: connection, flashing (if needed), and control via Home Assistant?<br />
</li>
<li>Can this setup work <span style="font-weight: bold;" class="mycode_b">without programming knowledge</span>?<br />
</li>
<li>What is the <span style="font-weight: bold;" class="mycode_b">best I/O expander module</span> with relays that includes a <span style="font-weight: bold;" class="mycode_b">metal or protected enclosure</span>?<br />
</li>
<li>Can the system run only on <span style="font-weight: bold;" class="mycode_b">Server16 with CM4 + some simple extender relay board</span>?<br />
</li>
</ol>
I want to build a <span style="font-weight: bold;" class="mycode_b">clean and reliable lighting automation system</span> with good enclosure protection and Home Assistant support.<br />
Thank you very much for your help!]]></description>
			<content:encoded><![CDATA[Hello everyone,<br />
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</li>
</ol>
Thank you very much for your help!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[B16M Outputs & HomeAssistant Firmware]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7861</link>
			<pubDate>Sun, 23 Mar 2025 11:06:47 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8241">akat</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7861</guid>
			<description><![CDATA[Hi all,<br />
 I've recently deployed a Kincony B16M and flashed it with the stock kincony-b16m.yaml config. <br />
<br />
I’m using the digital outputs to control HF41F relays mounted on 41F-1Z-C2-1 boards.<br />
Each relay coil is connected with a 1N4007 flyback diode across A1 and A2. Wiring is as follows:<br />
<ul class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">+12V DC</span> to A1<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">1N4007</span> across A1 and A2 (cathode on A1)<br />
</li>
<li>A2 wired to <span style="font-weight: bold;" class="mycode_b">DO1</span><br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">DC port</span> connected to -12V (to complete the circuit)<br />
</li>
</ul>
<br />
The issue:<br />
When the B16M boots, <span style="font-weight: bold;" class="mycode_b">DO1 immediately energizes the relay</span>, even though in the WebUI the output appears <span style="font-weight: bold;" class="mycode_b">OFF</span>. Toggling DO1 via the WebUI has no effect on the relay—it remains stuck on. I’ve tried both <br />
<br />
 inverted: true <br />
<br />
inverted: false in the YAML under  b16m-output01, but neither changes the behavior.<br />
<br />
Here's the relevant YAML snippet:<br />
<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>switch:<br />
  - platform: gpio<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
      inverted: true</code></div></div>At this point I’m trying to determine whether I’m dealing with a hardware issue or if there’s a nuance with the output logic I’ve missed. Any insights would be appreciated.<br />
Thanks in advance.]]></description>
			<content:encoded><![CDATA[Hi all,<br />
<br />
</li>
</li>
</li>
</li>
</ul>
<br />
The issue:<br />
<br />
<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
Thanks in advance.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Water supply automation]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7641</link>
			<pubDate>Tue, 18 Feb 2025 14:23:57 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7748">korvin</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7641</guid>
			<description><![CDATA[Do you have or can suggest any devices for water supply automation with Home Assistant support?<br />
<br />
I wonder if these can work<br />
<a href="https://vi.aliexpress.com/item/1005005837609233.html" target="_blank" rel="noopener" class="mycode_url">https://vi.aliexpress.com/item/1005005837609233.html</a><br />
<a href="https://vi.aliexpress.com/item/1005008250776238.html" target="_blank" rel="noopener" class="mycode_url">https://vi.aliexpress.com/item/1005008250776238.html</a><br />
<br />
But if you have something or maybe your partners have, I'd like to buy]]></description>
			<content:encoded><![CDATA[Do you have or can suggest any devices for water supply automation with Home Assistant support?<br />
<br />
<br />
But if you have something or maybe your partners have, I'd like to buy]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Error: Installing ESPHome on Windows without Home Assistant/Rasberry Pi]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7185</link>
			<pubDate>Fri, 06 Dec 2024 20:36:12 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6825">OrenaikeJ</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7185</guid>
			<description><![CDATA[When I attempted to install ESPHome on Windows PC without Home Assistant &amp; Rasberry Pi, on my Laptop, following your Youtube Instructional Guide, I got the error mesages seen in the attachment. Kindly assist me to successfully install the ESPHome on Windows without Home Assistant &amp; Rasberry Pi.<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=6603" target="_blank" title="">ESPHome Installation on Windows Error Message.PNG</a> (Size: 80.6 KB / Downloads: 918)
			<content:encoded><![CDATA[When I attempted to install ESPHome on Windows PC without Home Assistant &amp; Rasberry Pi, on my Laptop, following your Youtube Instructional Guide, I got the error mesages seen in the attachment. Kindly assist me to successfully install the ESPHome on Windows without Home Assistant &amp; Rasberry Pi.<br /><!-- start: postbit_attachments_attachment -->
		</item>
		<item>
			<title><![CDATA[Retain Switch status ESPHome after reboot and update / Ethernet setup]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=6869</link>
			<pubDate>Sun, 13 Oct 2024 18:15:57 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=1591">S.Krans</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=6869</guid>
			<description><![CDATA[Hi  <br />
<br />
if i update the boards A64 / A128 the outputs does not retain their status so if i have switch-1 on and reboot the switch-1 goes off<br />
<br />
<br />
<br />
<br />
i run ESPHome true Home Assistant and run the automations true node-red is there a possibility to have it retain the previous state before reboot or update<br />
<br />
<br />
<br />
Also i want to use my ethernet but it wont connect <br />
<br />
<br />
  friendly_name: Kincony KC868-A64-RK<br />
<br />
esp32:<br />
  board: esp32dev<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
  encryption:<br />
    key: "xxxx"<br />
<br />
ota:<br />
  password: "xxx"<br />
  platform: esphome<br />
<br />
#wifi:<br />
#  ssid: !secret wifi_ssid<br />
#  password: !secret wifi_password<br />
<br />
#  # Enable fallback hotspot (captive portal) in case wifi connection fails<br />
#  ap:<br />
#    ssid: "Kincony-Kc868-A64-Rk"<br />
#    password: !secret wifi_ap<br />
<br />
#captive_portal:<br />
<br />
<br />
<br />
<br />
# Example configuration entry<br />
i2c:<br />
  - id: bus_a<br />
    sda: 5<br />
    scl: 16<br />
    scan: true<br />
    frequency: 400kHz<br />
  - id: bus_b<br />
    sda: 15<br />
    scl: 4<br />
    scan: true<br />
 &nbsp;&nbsp;<br />
<br />
ethernet:<br />
  type: LAN8720<br />
  mdc_pin: GPIO23<br />
  mdio_pin: GPIO18<br />
  clk_mode: GPIO17_OUT<br />
  phy_addr: 0<br />
<br />
  # Optional manual IP<br />
  manual_ip:<br />
    static_ip: 20.20.20.192<br />
    gateway: 20.20.20.1<br />
    subnet: 255.255.255.0</code></div></div><br />
<br />
<br />
Thanks in advance<br />
Sijmen]]></description>
			<content:encoded><![CDATA[Hi  <br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
  encryption:<br />
    key: "xxxx"<br />
<br />
ota:<br />
<br />
#wifi:<br />
<br />
#  ap:<br />
<br />
<br />
<br />
<br />
<br />
i2c:<br />
  - id: bus_a<br />
    sda: 5<br />
    scl: 16<br />
    scan: true<br />
  - id: bus_b<br />
    sda: 15<br />
    scl: 4<br />
    scan: true<br />
 &nbsp;&nbsp;<br />
<br />
ethernet:<br />
  type: LAN8720<br />
  phy_addr: 0<br />
<br />
  manual_ip:<br />
<br />
<br />
Sijmen]]></content:encoded>
		</item>
	</channel>
</rss>
