	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-A series and Uair Smart Controller]]></title>
		<pubDate>Sat, 07 Nov 2026 07:51:41 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[KC868-A4 – Relay 1 clicks repeatedly when WiFi Access Point (AP) is enabled]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9932</link>
			<pubDate>Mon, 02 Nov 2026 23:49:18 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=12276">Natravn</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9932</guid>
			<description><![CDATA[Hello KinCony team,<br />
I have a problem with my KC868-A4 board.<br />
<span style="font-weight: bold;" class="mycode_b">Problem:</span><br />
Relay 1 switches ON and OFF intermittently when WiFi Access Point (AP) mode is enabled.<br />
I have performed several tests using a simple Arduino sketch with no relay control code at all.<br />
<span style="font-weight: bold;" class="mycode_b">Test results:</span><br />
<ol type="1" class="mycode_list"><li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>WIFI_MODE_NULL</code></div></div> – WiFi disabled: No relay clicking.<br />
</li>
<li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>WIFI_STA</code></div></div> – Station mode, without connecting to any network: No relay clicking.<br />
</li>
<li><div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>WIFI_AP</code></div></div> – Access Point mode: Relay 1 starts clicking intermittently.<br />
</li>
</ol>
Additional information:<ul class="mycode_list"><li>The DS18B20 temperature sensor on GPIO13 works correctly in all tests.<br />
</li>
<li>I have tried a different power supply. The problem remains.<br />
</li>
<li>No external loads or devices are connected to the relay outputs.<br />
</li>
<li>Relay 1 is the only relay that clicks.<br />
</li>
<li>The LED for relay 4 stays constantly illuminated.<br />
</li>
</ul>
<span style="font-weight: bold;" class="mycode_b">My questions:</span><br />
<ol type="1" class="mycode_list"><li>Is this a known issue with the KC868-A4?<br />
</li>
<li>Could WiFi AP mode interfere with GPIO2 or the relay driver circuit?<br />
</li>
<li>Could this indicate a hardware fault on my board?<br />
</li>
<li>Is there a recommended solution?<br />
</li>
</ol>
I would appreciate your help in identifying the problem.<br />
Best regards<br />
Natravn]]></description>
			<content:encoded><![CDATA[Hello KinCony team,<br />
</li>
</li>
</li>
</ol>
</li>
</li>
</li>
</li>
</li>
</ul>
</li>
</li>
</li>
</li>
</ol>
Best regards<br />
Natravn]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Tuya doesn’t work]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9901</link>
			<pubDate>Mon, 26 Oct 2026 02:13:08 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7216">osis</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9901</guid>
			<description><![CDATA[I’m having a problem logging into Tuya. When I select Protocol -&gt; Tuya, the page goes back to the login page??? I’ve already updated the software to the latest version V2.2.21 and it’s still the same. Everything worked fine for over 2 years before???]]></description>
			<content:encoded><![CDATA[I’m having a problem logging into Tuya. When I select Protocol -&gt; Tuya, the page goes back to the login page??? I’ve already updated the software to the latest version V2.2.21 and it’s still the same. Everything worked fine for over 2 years before???]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A8 V1.7.1 — Complete Verified DS18B20 Sensor Connector Pinout and ESPHome YAML]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9876</link>
			<pubDate>Tue, 20 Oct 2026 00:48:31 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=12147">Raddad</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9876</guid>
			<description><![CDATA[KinCony KC868-A8 V1.7.1 — Verified DS18B20 Temperature Sensor Pinout and ESPHome Configuration<br />
<span style="font-weight: bold;" class="mycode_b">Hardware:</span> KinCony KC868-A8, PCB revision V1.7.1<br />
<span style="font-weight: bold;" class="mycode_b">Firmware:</span> ESPHome with ESP-IDF framework<br />
<span style="font-weight: bold;" class="mycode_b">Connection:</span> Wired Ethernet (LAN8720)<br />
<span style="font-weight: bold;" class="mycode_b">Sensors tested:</span> Konnected waterproof DS18B20 temperature probes<br />
<span style="font-weight: bold;" class="mycode_b">Verification date:</span> October 19, 2026<br />
1. Overview<br />
The KC868-A8 V1.7.1 has a six-position connector providing four independent DS18B20 temperature sensor data connections, 3.3 V power, and ground.<br />
The connector terminals are not individually labeled on this board revision. The following pinout was established through electrical measurements and successful operation of DS18B20 sensors using ESPHome.<br />
All four temperature inputs have been tested successfully.<br />
2. Verified connector pinout<br />
Terminal numbering begins with the terminal nearest the USB-C connector.<br />
Terminal<br />
Connection<br />
ESP32 GPIO<br />
Verification<br />
1<br />
+3.3 V<br />
—<br />
Continuity to 3V3 test point<br />
2<br />
S4<br />
GPIO33<br />
DS18B20 operational<br />
3<br />
S3<br />
GPIO32<br />
4<br />
S2<br />
GPIO13<br />
5<br />
S1<br />
GPIO14<br />
6<br />
GND<br />
—<br />
Continuity to power supply negative<br />
Physical terminal diagram<br />
The following diagram shows the connector with the USB-C socket at the bottom.<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>        KC868-A8 V1.7.1<br />
        Six-terminal block<br />
     &nbsp;&nbsp;┌──────────────────┐<br />
     &nbsp;&nbsp;│ 6 &nbsp;&nbsp;GND          │<br />
     &nbsp;&nbsp;├──────────────────┤<br />
     &nbsp;&nbsp;│ 5 &nbsp;&nbsp;S1  GPIO14 &nbsp;&nbsp;│<br />
     &nbsp;&nbsp;│ 4 &nbsp;&nbsp;S2  GPIO13 &nbsp;&nbsp;│<br />
     &nbsp;&nbsp;│ 3 &nbsp;&nbsp;S3  GPIO32 &nbsp;&nbsp;│<br />
     &nbsp;&nbsp;│ 2 &nbsp;&nbsp;S4  GPIO33 &nbsp;&nbsp;│<br />
     &nbsp;&nbsp;│ 1 &nbsp;&nbsp;+3.3 V     &nbsp;&nbsp;│<br />
     &nbsp;&nbsp;└──────────────────┘<br />
               &nbsp;&nbsp;│<br />
              USB-C</code></div></div>This represents the vertical orientation shown in the board photographs, with terminal 1 nearest USB-C.<br />
3. Electrical verification<br />
With the board disconnected from power:<ul class="mycode_list"><li>Terminal 1 showed continuity to the PCB's 3V3 test point.<br />
</li>
<li>Terminal 6 showed continuity to power supply ground.<br />
</li>
<li>Terminals 2, 3, 4, and 5 each measured approximately 4.7 kΩ to terminal 1.<br />
</li>
</ul>
With power applied and no temperature sensors connected:<ul class="mycode_list"><li>Terminals 1–5 each measured approximately 3.29 V relative to ground.<br />
</li>
</ul>
The four 4.7 kΩ resistances are consistent with pull-up resistors for DS18B20 OneWire communication.<br />
No additional external pull-up resistors were needed during testing.<br />
4. Sensor connections<br />
The Konnected waterproof DS18B20 probes used in testing have the following wire assignments:<br />
Probe wire<br />
Connection<br />
Red<br />
+3.3 V — terminal 1<br />
Yellow<br />
OneWire data — terminal 2, 3, 4, or 5<br />
Black<br />
GND — terminal 6<br />
All four temperature inputs share the same power and ground terminals.<br />
The wiring colors are specific to the probes tested. Verify the pinout of other manufacturers' probes before connecting them.<br />
5. ESPHome configuration<br />
The following is a complete example for the KC868-A8 V1.7.1, retaining all eight relays and eight optically isolated digital inputs while configuring S1–S4 as temperature inputs.<br />
Replace the API encryption key placeholder with your own existing key.<br />
  friendly_name: KC868-A8-Boiler outlets<br />
esp32:<br />
  variant: esp32<br />
  framework:<br />
    type: esp-idf<br />
logger:<br />
api:<br />
  encryption:<br />
    key: "YOUR_EXISTING_API_ENCRYPTION_KEY"<br />
ota:<br />
  - platform: esphome<br />
ethernet:<br />
  type: LAN8720<br />
  mdc_pin: GPIO23<br />
  mdio_pin: GPIO18<br />
  clk:<br />
    pin: GPIO17<br />
    mode: CLK_OUT<br />
  phy_addr: 0<br />
i2c:<br />
  sda: GPIO4<br />
  scl: GPIO5<br />
  scan: true<br />
pcf8574:<br />
  - id: pcf8574_hub_out_1<br />
    address: 0x24<br />
  - id: pcf8574_hub_in_1<br />
    address: 0x22<br />
# Eight relay outputs<br />
switch:<br />
  - platform: gpio<br />
    name: "Boiler Outlet 1"<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
      inverted: true<br />
    name: "Boiler Outlet 2"<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
    name: "Boiler Outlet 3"<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
    name: "Boiler Outlet 4"<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
    name: "Boiler Outlet 5"<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
    name: "Boiler Outlet 6"<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
    name: "Boiler Outlet 7"<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
    name: "Boiler Outlet 8"<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
# Eight optically isolated digital inputs<br />
binary_sensor:<br />
    name: "Boiler Input 1"<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    name: "Boiler Input 2"<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    name: "Boiler Input 3"<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    name: "Boiler Input 4"<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    name: "Boiler Input 5"<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    name: "Boiler Input 6"<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    name: "Boiler Input 7"<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    name: "Boiler Input 8"<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
# Four dedicated OneWire temperature inputs<br />
one_wire:<br />
    pin: GPIO14<br />
    pin: GPIO13<br />
    pin: GPIO32<br />
    pin: GPIO33<br />
# DS18B20 temperature sensors<br />
sensor:<br />
  - platform: dallas_temp<br />
    one_wire_id: boiler_temp_bus_1<br />
    name: "Boiler Temperature 1"<br />
    update_interval: 10s<br />
    one_wire_id: boiler_temp_bus_2<br />
    name: "Boiler Temperature 2"<br />
    one_wire_id: boiler_temp_bus_3<br />
    name: "Boiler Temperature 3"<br />
    one_wire_id: boiler_temp_bus_4<br />
    name: "Boiler Temperature 4"<br />
    update_interval: 10s</code></div></div>6. Test results<br />
Two Konnected DS18B20 probes were used for verification.<br />
S1 and S2 were successfully operated simultaneously, producing valid temperature readings in Home Assistant.<br />
The second probe was then moved between the S3 and S4 connections, and both were successfully detected using their respective GPIO assignments.<br />
All four data inputs are therefore confirmed operational.<br />
Because each input uses a separate OneWire bus, up to four temperature probes can be connected using this configuration, with one probe assigned to each input.<br />
7. Important observations<br />
<ol type="1" class="mycode_list"><li>The eight DI1–DI8 optically isolated inputs are separate from the four dedicated temperature inputs.<br />
</li>
<li>GPIO32 and GPIO33 must not be configured simultaneously as binary inputs and OneWire temperature inputs.<br />
</li>
<li>The connector's 3.3 V supply and ground are shared among the temperature sensors.<br />
</li>
<li>Other KC868-A8 board revisions may use different physical terminal arrangements.<br />
</li>
<li>This pinout was verified on PCB revision V1.7.1 and should not be assumed correct for other revisions without checking.<br />
</li>
</ol>
8. Conclusion<br />
The KC868-A8 V1.7.1 supports four independently connected DS18B20 temperature sensors using GPIO14, GPIO13, GPIO32 and GPIO33.<br />
The six-terminal sensor connector has now been electrically mapped and all four OneWire data connections have been verified through actual temperature sensor operation.<br />
These findings are provided to assist other KinCony KC868-A8 users and to supplement the manufacturer's existing documentation.<br />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">Suggested documentation title:</span><br />
KC868-A8 V1.7.1 — Complete Verified DS18B20 Sensor Connector Pinout and ESPHome YAML<br /><!-- start: postbit_attachments_attachment -->
<img src="https://www.kincony.com/forum/images/attachtypes/pdf.png" title="Adobe Acrobat PDF" border="0" alt=".pdf" />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10622" target="_blank" title="">Kincony KC868-a8 pin id.pdf</a> (Size: 445.27 KB / Downloads: 93)
			<content:encoded><![CDATA[KinCony KC868-A8 V1.7.1 — Verified DS18B20 Temperature Sensor Pinout and ESPHome Configuration<br />
1. Overview<br />
Terminal<br />
Connection<br />
ESP32 GPIO<br />
Verification<br />
1<br />
+3.3 V<br />
—<br />
2<br />
S4<br />
GPIO33<br />
3<br />
S3<br />
GPIO32<br />
4<br />
S2<br />
GPIO13<br />
5<br />
S1<br />
GPIO14<br />
6<br />
GND<br />
—<br />
               &nbsp;&nbsp;│<br />
</li>
</li>
</li>
</ul>
</li>
</ul>
Probe wire<br />
Connection<br />
Red<br />
Yellow<br />
Black<br />
esp32:<br />
  framework:<br />
    type: esp-idf<br />
logger:<br />
api:<br />
  encryption:<br />
ota:<br />
ethernet:<br />
  type: LAN8720<br />
  clk:<br />
    pin: GPIO17<br />
    mode: CLK_OUT<br />
  phy_addr: 0<br />
i2c:<br />
  sda: GPIO4<br />
  scl: GPIO5<br />
  scan: true<br />
pcf8574:<br />
    address: 0x24<br />
    address: 0x22<br />
switch:<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
one_wire:<br />
    pin: GPIO14<br />
    pin: GPIO13<br />
    pin: GPIO32<br />
    pin: GPIO33<br />
sensor:<br />
</li>
</li>
</li>
</li>
</li>
</ol>
8. Conclusion<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[KC868-A32 - TCP comunication problem]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9869</link>
			<pubDate>Wed, 14 Oct 2026 14:49:39 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=714">Dm81</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9869</guid>
			<description><![CDATA[Good morning<br />
I had to replace my kc868-H32B board (which worked for more than 4 years without problems) with the new kc868-32 board. The problem is that when I press the inputs a few times or turn the outputs on and off, the board loses connection (I observe this from the board's web server). The installed firmware is v2.2.14, and only the TCP server is active.<br />
I had already reported this problem in the past with the kc868-a8 board and it seemed to be resolved, but that one also used to freeze often.<br />
I can't understand where the problem is.<br />
Do you have any suggestions or software to test this problem?<br />
Thank you]]></description>
			<content:encoded><![CDATA[Good morning<br />
Thank you]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16 and Tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9861</link>
			<pubDate>Fri, 09 Oct 2026 16:35:34 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8059">newdos</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9861</guid>
			<description><![CDATA[Hi ,<br />
<br />
just got my board working now but I cannot use the tuya app.  Whenever i scan the QR code from within KCS I just get the message 'Device_already_bind' (see pic)  and therefore the board does appear in the app so rendering app of no use.  The licence is all enabled in KCS (see pic).  Thanks for your help.<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10593" target="_blank" title="">09-10-2026 09-23-55.jpg</a> (Size: 69.17 KB / Downloads: 108)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10594" target="_blank" title="">IMG_0215.PNG</a> (Size: 377.48 KB / Downloads: 116)
			<content:encoded><![CDATA[Hi ,<br />
<br />
		</item>
		<item>
			<title><![CDATA[Bricked KC868-A16]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9859</link>
			<pubDate>Wed, 07 Oct 2026 23:46:31 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9859</guid>
			<description><![CDATA[I seem to have totally bricked my KC868-A16 rev 1.6.   Was trying to download arduino code to it which it did but never worked so then tried to put KCS back on the board which Downloaded mok but the board appears dead no lights on ethernet port at all.  I have since done an erase and reload KCS with the download tool and no joy.  HELP!!!]]></description>
			<content:encoded><![CDATA[I seem to have totally bricked my KC868-A16 rev 1.6.   Was trying to download arduino code to it which it did but never worked so then tried to put KCS back on the board which Downloaded mok but the board appears dead no lights on ethernet port at all.  I have since done an erase and reload KCS with the download tool and no joy.  HELP!!!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Ceiling fan control not working with KC868-AGv3]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9820</link>
			<pubDate>Sat, 12 Sep 2026 23:23:31 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11763">mattst88</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9820</guid>
<br />
I received a KC868-AGv3 and installed KCS_AGV3_V3.27.2 on it. I'm struggling to get it to work with my ceiling fans (brand / model is CARRO USA Osborn).<br />
<br />
I can successfully listen and capture signals from the fan's remote, but transmitting them from the KC868-AGv3 doesn't work with the fan. I tried settings of 10, 30, and 100 for the "Adjust Repeat Count" option, without success.<br />
<br />
How can I debug this further?]]></description>
<br />
<br />
<br />
How can I debug this further?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[extend KC868-A16v3]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9816</link>
			<pubDate>Thu, 10 Sep 2026 21:22:07 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11738">robi932</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9816</guid>
<br />
I bought a KC868-A16v3 ESP32-S3 16 channel GPIO module and realised that I need 10 more outputs. What would be the best approach? buy another one and run both? or is there any alternative?<br />
I am using it to connect the outputs to SSR to have no mechanical noise on activation.<br />
<br />
Thanks]]></description>
<br />
<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[No ethernet communication]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9795</link>
			<pubDate>Wed, 02 Sep 2026 09:25:33 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=526">philippe</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9795</guid>
			<description><![CDATA[Hi, I just received a new  board. I cant accees it through ethernet. I guess the kcs comes with dhcp enabled. if yes, I cant see it with a scanner, I cant find it with the kincony scan tool. I reflashed with esp home and the A8 yaml file, no way. I reflash with the kincony flashing tool and kscv3, no way. The port I am using on the switch is fine, thats the one I am using for my PC . By the way, the board is V1.7.1, I is it the new board? I hope so, I just got it, expecting to use it with 1wire sensors expecting the kcs v3 to solve my 1wire instable sensors issue.<br />
Thanks<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10358" target="_blank" title="">Sans titre.jpg</a> (Size: 15.96 KB / Downloads: 185)
			<content:encoded><![CDATA[Hi, I just received a new  board. I cant accees it through ethernet. I guess the kcs comes with dhcp enabled. if yes, I cant see it with a scanner, I cant find it with the kincony scan tool. I reflashed with esp home and the A8 yaml file, no way. I reflash with the kincony flashing tool and kscv3, no way. The port I am using on the switch is fine, thats the one I am using for my PC . By the way, the board is V1.7.1, I is it the new board? I hope so, I just got it, expecting to use it with 1wire sensors expecting the kcs v3 to solve my 1wire instable sensors issue.<br />
Thanks<br />
		</item>
		<item>
			<title><![CDATA[Ethernet static address]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9632</link>
			<pubDate>Thu, 16 Jul 2026 09:42:01 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11241">MattMueller</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9632</guid>
			<description><![CDATA[I use a Board KC868-A16 Rev1.6.3 with tasmota firmware-en-a16.bin from <a href="https://www.kincony.com/forum/showthread.php?tid=1715" target="_blank" rel="noopener" class="mycode_url">here</a>. After installation I have two ip-addresses (via dhcp) one for wifi and one for ethernet.<br />
In the console I can change the wifi adress to a static address with the command ipaddress1 xxx.xxx.xxx.xxx , that works fine. <br />
But how can I change the ethernet-address to a static one?]]></description>
			<content:encoded><![CDATA[I use a Board KC868-A16 Rev1.6.3 with tasmota firmware-en-a16.bin from <a href="https://www.kincony.com/forum/showthread.php?tid=1715" target="_blank" rel="noopener" class="mycode_url">here</a>. After installation I have two ip-addresses (via dhcp) one for wifi and one for ethernet.<br />
But how can I change the ethernet-address to a static one?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Firmware for KCS 868 A8 v 1.7  board]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9569</link>
			<pubDate>Fri, 03 Jul 2026 23:10:58 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11115">zali</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9569</guid>
			<description><![CDATA[Hi support,<br />
<br />
I have a KC868 A8, after watching your video on Youtube I downloaded firmware KCS_KC868_A8_V1.9.1 and KCS_KC868_A8_V2.2.20. I am able to flash both versions but it doesn't show all option on its webpage or incomplete options. fx. I don't see the option to bind input and output port together.<br />
Could you please send me the ulr link to download the compatible firmware version.<br />
<br />
Best regards<br />
<br />
Zulfqar]]></description>
			<content:encoded><![CDATA[Hi support,<br />
<br />
<br />
Best regards<br />
<br />
Zulfqar]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Force sensitive sensor with kc868-A]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9547</link>
			<pubDate>Fri, 26 Jun 2026 14:16:31 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10077">Elgatoguiri</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9547</guid>
			<description><![CDATA[Hi!<br />
<br />
I have a Force sensitive resistor: <a href="https://www.aliexpress.com/p/order/index.html?spm=a2g0o.home.headerAcount.2.650c76dbGk3szT" target="_blank" rel="noopener" class="mycode_url">https://www.aliexpress.com/p/order/index...76dbGk3szT</a><br />
<br />
I'd like to know if it's possible to directly connect it to the board and use it as switch in esphome. <br />
<br />
Thanks!]]></description>
			<content:encoded><![CDATA[Hi!<br />
<br />
<br />
<br />
Thanks!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[The watch shows the wrong time in standalone mode.]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9492</link>
			<pubDate>Tue, 16 Jun 2026 04:06:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9349">rosnoteh</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9492</guid>
			<description><![CDATA[KC868-A16v3, firmware v3.25.0, battery 3,05V.<br />
The watch shows the wrong time in standalone mode. The controller is connected to a local network without internet access. Time zone - UTC+3.<br />
Turn on the controller. Click "Synchronize browser time". <br />
The controller's clock shows the same time as the computer's clock. Turn off the controller, and then turn on the controller. The controller clock shows the time 3 hours later.<br />
Turn off the controller again, and then turn on the controller. The controller clock shows the time 6 hours later.]]></description>
			<content:encoded><![CDATA[KC868-A16v3, firmware v3.25.0, battery 3,05V.<br />
Turn off the controller again, and then turn on the controller. The controller clock shows the time 6 hours later.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16v3 integration with 5V sensors and loads ?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9371</link>
			<pubDate>Fri, 29 May 2026 20:31:19 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10932">Alx</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9371</guid>
<br />
I am planning a project based on the KC868-A16 v3.1 (REV:1.6) board. My peripheral types include 5V digital sensors (TTL/CMOS) and low-power 5V loads.<br />
<br />
Could you please help me with the following technical questions:<br />
<ol type="1" class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">LO0 and LO1 with 5V:</span> The official documentation specifies 12V/24V for the LO0 and LO1 power supply. Is it safe and functionally possible to apply a 5V external voltage to these specific channels instead?<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Onboard 5V VCC Usage for LO0 and LO1:</span> Can I use the internal 5V VCC rail from the board to power the LO0 and LO1 loads? The total load current will be under 1A, which is within the XL1509-5 regulator capacity. Are there any internal limitations preventing this?<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">16 Digital Inputs with 5V logic:</span> How can I modify all 16 Digital Inputs (INPUT1 and INPUT2) to safely and accurately read active 5V digital signals (TTL/CMOS)? What is the exact hardware modification procedure for the PCB?<br />
</li>
</ol>
<br />
Thank you.]]></description>
<br />
<br />
</li>
</li>
</li>
</ol>
<br />
Thank you.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A16v3 schematic]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9369</link>
			<pubDate>Thu, 28 May 2026 19:25:58 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9369</guid>
			<description><![CDATA[Hello!<br />
<br />
Recently, I bought a KC868-A16v3.<br />
Could you please confirm whether this schematic is valid for my KC868-A16v3?<br />
<br />
<a href="https://www.kincony.com/download/KC868-A16-schematic.pdf" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/download/KC868-A...ematic.pdf</a><br />
<br />
Thank you in advance for your prompt reply.]]></description>
			<content:encoded><![CDATA[Hello!<br />
<br />
<br />
<br />
Thank you in advance for your prompt reply.]]></content:encoded>
		</item>
	</channel>
</rss>
