	<channel>
		<title><![CDATA[Smart Home Automation Forum - F16]]></title>
		<pubDate>Tue, 20 Oct 2026 06:28:46 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[Disconnect loop with Home Assistant MQTT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9840</link>
			<pubDate>Sun, 20 Sep 2026 16:25:05 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11852">MihaiX</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9840</guid>
			<description><![CDATA[Hello everyone,<br />
I have two F16 boards connected with HA that started to have connection issues.<br />
The output from the MQTT logs:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>2026-09-20 11:00:44: New connection from x.x.x.12:53372 on port 1883.<br />
2026-09-20 11:00:47: New client connected from x.x.x.12:53372 as &lt;MAC&gt; (p4, c1, k120, u'kincony12').<br />
2026-09-20 11:00:47: Client &lt;MAC&gt; [x.x.x.12:53372] disconnected: connection closed by client.<br />
2026-09-20 11:00:50: New connection from x.x.x.11:63968 on port 1883.<br />
2026-09-20 11:00:53: New client connected from x.x.x.11:63968 as kincony11_&lt;MAC&gt; (p4, c1, k120, u'kincony11').<br />
2026-09-20 11:00:53: Client kincony11_&lt;MAC&gt; [x.x.x.11:63968] disconnected: connection closed by client.</code></div></div>kincony11 is configured to use MQTT for Home Assistant while kincony12 is configured to use standard MQTT as I was trying different solutions but the result is the same: disconnect loop.<br />
kincony11 is on fw  v3.18.0<br />
kincony12 is on fw  v3.27.2<br />
<br />
Home Assistant details:<br />
    Installation method Home Assistant OS<br />
    Core 2026.9.3<br />
    Supervisor 2026.09.2<br />
    Operating System 18.3<br />
    Frontend 20260826.7<br />
MQTT v7.1.1<br />
<br />
As fw v3.27.2 has logging view, this is some output:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>W (1300036) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE<br />
E (1301096) mqtt_client: esp_mqtt_connect: mqtt_message_receive() returned 0<br />
E (1301096) mqtt_client: MQTT connect failed<br />
I (1301096) mqtt: MQTT_EVENT_DISCONNECTED<br />
I (1305036) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
E (1305236) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x108<br />
E (1305236) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).<br />
I (1305236) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
W (1305236) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE<br />
I (1305596) mqtt: Other event id:7<br />
I (1310236) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
E (1310436) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x108<br />
E (1310436) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).<br />
I (1310436) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
W (1310436) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE<br />
I (1315436) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
E (1315606) mqtt_client: esp_mqtt_connect: mqtt_message_receive() returned 0<br />
E (1315606) mqtt_client: MQTT connect failed<br />
I (1315606) mqtt: MQTT_EVENT_DISCONNECTED<br />
E (1315636) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x108<br />
E (1315636) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).<br />
I (1315636) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
W (1315636) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE<br />
I (1320106) mqtt: Other event id:7<br />
I (1320636) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
E (1320836) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x108<br />
E (1320836) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).<br />
I (1320836) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
W (1320836) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE<br />
I (1325836) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
E (1326036) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x108<br />
E (1326036) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).<br />
I (1326036) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
W (1326036) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE<br />
E (1330116) mqtt_client: esp_mqtt_connect: mqtt_message_receive() returned 0<br />
E (1330116) mqtt_client: MQTT connect failed<br />
I (1330116) mqtt: MQTT_EVENT_DISCONNECTED<br />
I (1331036) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
E (1331236) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x108<br />
E (1331236) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).<br />
I (1331236) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 <br />
W (1331236) sd: Failed to mount filesystem. Error: ESP_ERR_INVALID_RESPONSE</code></div></div><br />
<br />
Any help is much appreciated.]]></description>
			<content:encoded><![CDATA[Hello everyone,<br />
<br />
    Core 2026.9.3<br />
MQTT v7.1.1<br />
<br />
<br />
Any help is much appreciated.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Connecting sensors to KinCony F16]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9737</link>
			<pubDate>Wed, 12 Aug 2026 22:29:15 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11189">kostenko1954</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9737</guid>
			<description><![CDATA[<span style="font-size: x-large;" class="mycode_size"><span style="font-family: Arial;" class="mycode_font">- Without connecting the SHT30 temperature and humidity sensor, the LCD screen displays readings normally.</span></span><br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10311" target="_blank" title="">1.jpg</a> (Size: 309.65 KB / Downloads: 188)
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">- After connecting the SHT30 temperature and humidity sensor, the LCD screen displays distorted readings.</span></span><br />
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size"><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10313" target="_blank" title="">2.jpg</a> (Size: 290.54 KB / Downloads: 183)
<!-- end: postbit_attachments_attachment --></span></span><br />
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">- I tried setting the SHT30 address (I2C) to 0x44, but the address resets the next time the controller is polled.<br />
- I also connected the RS485 JTH-2D1 temperature and humidity sensor to the RS485 port. Its address is: Temperature – 768; Humidity – 769</span> </span><br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10314" target="_blank" title="">3.jpg</a> (Size: 67.67 KB / Downloads: 177)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10315" target="_blank" title="">4.jpg</a> (Size: 194.15 KB / Downloads: 170)
<!-- end: postbit_attachments_attachment --><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10316" target="_blank" title="">5.jpg</a> (Size: 67.67 KB / Downloads: 184)
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">- I also connected an analog soil moisture sensor to analog input A1, using an external 3.3V power supply.</span></span><br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10317" target="_blank" title="">6.jpg</a> (Size: 75.31 KB / Downloads: 170)
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">When the sensor is dry, the reading is <span style="font-weight: bold;" class="mycode_b">752</span>. </span></span><br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10318" target="_blank" title="">7.jpg</a> (Size: 66.83 KB / Downloads: 194)
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">When the sensor is submerged, the reading is <span style="font-weight: bold;" class="mycode_b">757</span>. </span></span><br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10319" target="_blank" title="">8.jpg</a> (Size: 70.13 KB / Downloads: 187)
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">When testing these sensors in an Arduino UNO R3, the readings are different. </span></span><br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10320" target="_blank" title="">9.jpg</a> (Size: 219.35 KB / Downloads: 195)
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">How do I configure them in the KinCony ESP32-S3 Tuya relay board – F16 (16A removable relay)? </span></span>]]></description>
			<content:encoded><![CDATA[<span style="font-size: x-large;" class="mycode_size"><span style="font-family: Arial;" class="mycode_font">- Without connecting the SHT30 temperature and humidity sensor, the LCD screen displays readings normally.</span></span><br />
<span style="font-family: 'Times New Roman', serif;" class="mycode_font"><span style="font-size: x-large;" class="mycode_size">How do I configure them in the KinCony ESP32-S3 Tuya relay board – F16 (16A removable relay)? </span></span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Questions about KinCony F16]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9342</link>
			<pubDate>Tue, 19 May 2026 18:58:08 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10888">yazeed</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9342</guid>
			<description><![CDATA[Hi KinCony,<br />
<br />
I want to buy the KinCony F16 16-Channel ESP32-S3 Removable Relay Controller for my car (offroad)<br />
<a href="https://shop.kincony.com/products/kincony-f16-16ch-esp32-s3-removable-relay-board?variant=44251712290981" target="_blank" rel="noopener" class="mycode_url">https://shop.kincony.com/products/kincon...1712290981</a><br />
<br />
I have watched all the videos by KinCony  engineer on YouTube, but I would like direct confirmation from you on the following questions:<br />
<br />
- Does the F16 work with DC lights and DC devices? What is the max amps or watts per channel in DC?<br />
<br />
- How much current can each channel handle on 12V DC continuously?<br />
<br />
- Is there Home Assistant integration, and can I connect the F16 to Home Assistant via WiFi?<br />
<br />
- Can the F16 tolerate heat of 60-70°C inside the vehicle?<br />
<br />
- The F16 needs 12V DC power. Can I connect it directly to my vehicle's 12V battery, or does it need an external Buck Converter / TVS Diode for protection against car voltage spikes (alternator load dump up to 100V)? If protection is needed, what product do you recommend for vehicle installation?<br />
<br />
- Can I connect an external switch to an input so it triggers the relay directly, without waiting for Home Assistant?<br />
<br />
- Have any customers used the F16 in cars or vans before?<br />
<br />
Thanks,<br />
Yazeed]]></description>
			<content:encoded><![CDATA[Hi KinCony,<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Thanks,<br />
Yazeed]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[24V Pulse input]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9317</link>
			<pubDate>Mon, 04 May 2026 17:34:38 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9098">Onepointbrewing</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9317</guid>
			<description><![CDATA[I have a IFM SM7000 flow meter that is set to nPn pulse output for measuring the flow unit.<br />
<br />
It is a 24V unit (both the F16 and the flow meter)<br />
<br />
What input on the F16 can I wire this to in order to count the pulses..... Will the standard digital inputs work?<br />
<br />
<br />
Thanks]]></description>
			<content:encoded><![CDATA[I have a IFM SM7000 flow meter that is set to nPn pulse output for measuring the flow unit.<br />
<br />
<br />
<br />
<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[F16 relay stopped functioning]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9294</link>
			<pubDate>Mon, 27 Apr 2026 22:02:17 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9287">autolifetech</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9294</guid>
<br />
I have had the F16 for awhile now but over the past few weeks, the relays suddenly stopped working. I can control the relay functions in HA and can hear the click sound of the relay but the lights remained on (the relays are connected to light circuit). When I touch the board it is very hot.Is this normal? How to fix this issue?<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9683" target="_blank" title="">PXL_20260416_103808821.MP.jpg</a> (Size: 482.12 KB / Downloads: 285)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9684" target="_blank" title="">PXL_20260416_103722352.MP.jpg</a> (Size: 438.03 KB / Downloads: 279)
<br />
		</item>
		<item>
			<title><![CDATA[F16 Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9267</link>
			<pubDate>Sun, 19 Apr 2026 15:46:51 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9267</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9649" target="_blank" title="">F16_wiring.jpg</a> (Size: 255.77 KB / Downloads: 380)
		</item>
		<item>
			<title><![CDATA[F16 Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9266</link>
			<pubDate>Sun, 19 Apr 2026 15:46:22 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9266</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9648" target="_blank" title="">KinCony-F16-smart-controller-diagram.png</a> (Size: 884.88 KB / Downloads: 330)
		</item>
		<item>
			<title><![CDATA[F16 tuya reverse sw. function missing]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8963</link>
			<pubDate>Fri, 23 Jan 2026 04:21:50 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8984">Karlis_LV</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8963</guid>
Please help me with some information. I have two questions about the KinCony F16 module (software nr. V3.18.0)  and Tuya.<br />
I have connected simple momentary (non-latching) switches to the input channels to control lights. The switch has no fixation: one press turns the light ON, the next press turns it OFF.<br />
<span style="font-weight: bold;" class="mycode_b">Question:</span><br />
Why, in the Tuya app (Simple Device Scenario),  I can configure the <span style="font-weight: bold;" class="mycode_b">“Reverse Switch”</span> function only for channels 1–6, while the other channels only have <span style="font-weight: bold;" class="mycode_b">ON / OFF</span> options.WHY?<br />
<br />
<img src="https://i.postimg.cc/P5RjW0cm/tuya-kincony-f16-switch06.png" loading="lazy"  alt="[Image: tuya-kincony-f16-switch06.png]" class="mycode_img" /><br />
<br />
<br />
<br />
<br />
<br />
<span style="font-weight: bold;" class="mycode_b">Question 2:</span><br />
Why is there such a noticeable <span style="font-weight: bold;" class="mycode_b">delay / latency</span> between pressing the button and the relay switching ON? It is very uncomfortable to use.<br />
Is this a <span style="font-weight: bold;" class="mycode_b">Tuya cloud-related issue</span>, and if I use a <span style="font-weight: bold;" class="mycode_b">local server</span> (local control), will this delay be resolved?]]></description>
<br />
<br />
<br />
<br />
<br />
<br />
Is this a <span style="font-weight: bold;" class="mycode_b">Tuya cloud-related issue</span>, and if I use a <span style="font-weight: bold;" class="mycode_b">local server</span> (local control), will this delay be resolved?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[sample code to receive http get]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8843</link>
			<pubDate>Fri, 26 Dec 2025 23:37:52 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10097">telinda</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8843</guid>
			<description><![CDATA[Hello Admin,<br />
<br />
Have you ever created an example Arduino program to get results from API calls (HTTP/HTTPS Web Server)?<br />
Btw, I used Kincony F16 ESPS3 with Tuya. <br />
And I have already tested mostly features in the KCS V3 firmware.<br />
<br />
Thank you very much.]]></description>
			<content:encoded><![CDATA[Hello Admin,<br />
<br />
<br />
Thank you very much.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[F16]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8778</link>
			<pubDate>Fri, 28 Nov 2025 15:01:29 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=4507">fdcemb5</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8778</guid>
			<description><![CDATA[I am trying to configure my F16. But I came across your recommendation.  "4. It is recommended to use home assistant and Tuya mobile phone app at the same time. So that remote control by internet using Tuya app, local control by LAN using home assistant app"<br />
<br />
Which installation approach will yield the recommended result?]]></description>
			<content:encoded><![CDATA[I am trying to configure my F16. But I came across your recommendation.  "4. It is recommended to use home assistant and Tuya mobile phone app at the same time. So that remote control by internet using Tuya app, local control by LAN using home assistant app"<br />
<br />
Which installation approach will yield the recommended result?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Analog Inputs via MQTT HA Auto Discover]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8744</link>
			<pubDate>Sun, 16 Nov 2025 20:28:42 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7220">petermac</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8744</guid>
			<description><![CDATA[When using HA Auto Discover with KCS 3, should the analog inputs be detected and shown in Home Assistant?  I'm only getting the digital inputs.  Or do I need to use ESP Home?]]></description>
			<content:encoded><![CDATA[When using HA Auto Discover with KCS 3, should the analog inputs be detected and shown in Home Assistant?  I'm only getting the digital inputs.  Or do I need to use ESP Home?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[F16 Support/warranty]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8622</link>
			<pubDate>Fri, 03 Oct 2025 09:33:47 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8622</guid>
			<description><![CDATA[Dear Sir,<br />
<br />
I need some technical support/warranty help with a F16. I have sent you an email to web@kincony.com<br />
<br />
Could you please advise based on the contents of my email.<br />
<br />
			<content:encoded><![CDATA[Dear Sir,<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[Powering a DS18b20]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8577</link>
			<pubDate>Tue, 23 Sep 2025 13:58:55 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8577</guid>
			<description><![CDATA[Hello<br />
<br />
Is it possible to power (VCC) from a GPIO output? I need to be able to reset a DS18B20 by turning off the VCC to the sensor as they get out of timing sync often and only are able to re-sync from a power cycle - not from a node reset.<br />
<br />
Whats the max current the GPIO as an output that ic an supply]]></description>
			<content:encoded><![CDATA[Hello<br />
<br />
<br />
Whats the max current the GPIO as an output that ic an supply]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-E16v2]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8572</link>
			<pubDate>Sun, 21 Sep 2025 18:21:07 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=485">mcdave</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8572</guid>
			<description><![CDATA[Dear Admin,<br />
<br />
I have T64m Power 12V PSU.... What is the problem if KC868-E16v2 COM TO NO reading 11.7v thats why my siren 12V not trigger, Do I need to seperate 12V PSU for t64M and KC868-E16v2.?]]></description>
			<content:encoded><![CDATA[Dear Admin,<br />
<br />
I have T64m Power 12V PSU.... What is the problem if KC868-E16v2 COM TO NO reading 11.7v thats why my siren 12V not trigger, Do I need to seperate 12V PSU for t64M and KC868-E16v2.?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Reset line via GPIO output to 24v Flow meter.]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8494</link>
			<pubDate>Fri, 05 Sep 2025 09:59:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8494</guid>
<br />
Could you please post a picture of the cct for the GPIOs 13 14 and 40 pls. I will be configuring one of these as an output.<br />
<br />
I want to interface it to a 24v Flow meter that has a reset line when pulled low.<br />
<br />
Thank you]]></description>
<br />
<br />
<br />
Thank you]]></content:encoded>
		</item>
	</channel>
</rss>
