	<channel>
		<title><![CDATA[Smart Home Automation Forum - TA]]></title>
		<pubDate>Sat, 07 Nov 2026 21:17:57 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[Cannot Load KCS v3.27.2 on TA]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9902</link>
			<pubDate>Mon, 26 Oct 2026 03:22:53 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=12208">maczrool</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9902</guid>
			<description><![CDATA[When I flash the official KCS_KC_TA_V3.27.2.bin firmware binary directly using the Espressif Flash Download Tool (v3.9.2) with the correct 16MB flash configuration size, the board fails to boot, fails to initialize any network interfaces, and does not pull an IP address.<br />
Initially, the board was caught in a continuous USB resetting loop. I resolved the USB dropping issue by ensuring the file row checkbox in the downloader program was properly selected. However, even though the USB connection now holds steady while plugged in, the firmware still completely fails to execute when the board is restarted. The board remains totally unresponsive on the network.<br />
<br />
What Works (Hardware Verification):<br />
<br />
The physical board hardware is completely healthy. When I flash a clean, standalone image compiled natively via the Arduino framework (bypassing the ESP-IDF KCS binary image), the board boots up perfectly fine, initializes its local interfaces, and connects to the local network switch cleanly. This confirms the physical hardware is fine, but the factory KCS file layout is failing to execute on this specific board variant.<br />
<br />
Technical Analysis:<br />
<br />
Because the KCS binary provided on the forum is an Application-only image, it is missing the necessary low-level bootloader and partition tables required to initialize the advanced memory/PSRAM boundaries of the ESP32-S3 chip from a completely erased state. When flashed alone to 0x0, the chip hangs silently on boot.<br />
<br />
My Request:<br />
<br />
I bought this KinCony hardware specifically to use the native KCS web interface and its dropdown IFTTT configuration features.<br />
Please provide the complete factory multi-file partition zip package for this specific board variant. I need the matching:<br />
1. bootloader.bin (compiled for address 0x0)<br />
2. partition-table.bin (compiled for address 0x8000)<br />
3. ota_data_initial.bin (compiled for address 0xd000)<br />
This will allow me to properly offset the main KCS application binary to 0x10000 so the ESP32-S3 can initialize its memory lanes on startup and boot into the KCS platform safely.<br />
<br />
Thanks for any suggestions and assistance.]]></description>
			<content:encoded><![CDATA[When I flash the official KCS_KC_TA_V3.27.2.bin firmware binary directly using the Espressif Flash Download Tool (v3.9.2) with the correct 16MB flash configuration size, the board fails to boot, fails to initialize any network interfaces, and does not pull an IP address.<br />
<br />
<br />
<br />
<br />
<br />
My Request:<br />
<br />
<br />
Thanks for any suggestions and assistance.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Tiny Alarm board after flashing seems to no longer working]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9477</link>
			<pubDate>Fri, 12 Jun 2026 21:29:03 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11007">algaema</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9477</guid>
			<description><![CDATA[Hi Kincony,<br />
<br />
I have tried to flash newer version firmware (tried KCS_KC_TA_V3.25.0.zip) from a Mac. Tried multiple methods, including the use of a Windows VM with the official tool, and web.esphome.io. But while both tool reported success, when I turn off and on the board it is not able to respond on network. I have even tried to use the method of removing power, pressing the DW button, and then attaching the power, and then used the official tool to copy firmware using a low (115200) baud rate, while the tool has reported success, after reset the board it is just not responding on network (I can verify that on the switch statistics, in which the "bytes sent" in switch has high values, however "bytes received" in switch is always showing 0, indicating that the Tiny Alarm board is not responding any packet at all. <br />
<br />
I have also tested to use USB C to USB A cable instead of a USB C to USB C cable as I see the youtube video is using one of that. <br />
<br />
May I ask how is there a way to troubleshoot a ESP32S3 board boot up message to see if the firmware is correctly copied?]]></description>
			<content:encoded><![CDATA[Hi Kincony,<br />
<br />
<br />
<br />
May I ask how is there a way to troubleshoot a ESP32S3 board boot up message to see if the firmware is correctly copied?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[New TA web interface unavailable]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9208</link>
			<pubDate>Fri, 03 Apr 2026 21:55:23 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10682">pbouwen</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9208</guid>
			<description><![CDATA[Hi everyone,<br />
<br />
Just received my first Kincony device; a Tiny Alarm system.<br />
<br />
Unfortunately, I don't succeed in accessing the web interface to set it up for use with Home Assistant.<br />
I powered it with PoE and looked up the assigned IP address in my router.<br />
When I try accessing that IP in my browser, I get the message that the page can't be reached.<br />
I can ping the IP however.<br />
<br />
Rebooting the device did not help.<br />
Holding the reset button for +10 seconds also did not change anything.<br />
<br />
What other steps can I take to troubleshoot this?<br />
Should I try to reflash it? I'm using a Mac so not my preferred option.<br />
<br />
Thanks in advance for your help!]]></description>
			<content:encoded><![CDATA[Hi everyone,<br />
<br />
<br />
<br />
<br />
<br />
Thanks in advance for your help!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[linux command line / bash scripting]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8899</link>
			<pubDate>Sun, 11 Jan 2026 14:49:40 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10204">almman</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8899</guid>
<br />
I currently use AD2USB to communicate with my Honeywell Vista alarm system. Together with ser2sock (serial to socket), in bash/Linux, I use:<br />
<br />
if exec 3&lt;/dev/tcp/localhost/444555 ; then<br />
  cat &lt;&amp;3 | while read -t12 msg ; do<br />
        # Print last keypad/console message.<br />
        # Example: ****DISARMED****  Ready to Arm<br />
        echo "&#36;msg"<br />
        sleep 1<br />
  done<br />
fi<br />
<br />
There are also functions to send commands to the alarm as if it were typed on the keypad.<br />
<br />
How does one send/receive to/from the TA ESP32-S3 via command line/bash scripts?<br />
<br />
Thanks]]></description>
<br />
<br />
        sleep 1<br />
  done<br />
fi<br />
<br />
<br />
<br />
Thanks]]></content:encoded>
		</item>
		<item>
			<title><![CDATA["SmartLife" wifi transmit]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8868</link>
			<pubDate>Sat, 03 Jan 2026 03:03:46 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10152">hinterland</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8868</guid>
			<description><![CDATA[My tiny alarm seems to be transmitting a wifi signal (AP?)  "SmartLife-C886" how do i disable that?]]></description>
			<content:encoded><![CDATA[My tiny alarm seems to be transmitting a wifi signal (AP?)  "SmartLife-C886" how do i disable that?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[TA details about RTC and RF]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8762</link>
			<pubDate>Sun, 23 Nov 2025 23:40:02 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9315">5310h</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8762</guid>
			<description><![CDATA[Hi. I am working on code for TA and have the following questions:<br />
<br />
What RTC is used?<br />
<br />
What is the RF Receiver type?<br />
<br />
			<content:encoded><![CDATA[Hi. I am working on code for TA and have the following questions:<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[TA needs fallback cellular for monitoring service]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8455</link>
			<pubDate>Tue, 19 Aug 2025 08:33:35 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8455</guid>
			<description><![CDATA[Hi<br />
In order to make the TA a complete security alarm system, it needs a method to communicate to a monitoring service when the Wifi / Internet is down.  Since Kincony already has the SIM7600e board that is used on other products, I would like to see it added to the TA ASAP.  Without it, the TA is just like all the other DIY products.  Really, it's the missing piece.]]></description>
			<content:encoded><![CDATA[Hi<br />
In order to make the TA a complete security alarm system, it needs a method to communicate to a monitoring service when the Wifi / Internet is down.  Since Kincony already has the SIM7600e board that is used on other products, I would like to see it added to the TA ASAP.  Without it, the TA is just like all the other DIY products.  Really, it's the missing piece.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Temp sensor]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8121</link>
			<pubDate>Fri, 30 May 2025 05:25:58 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6729">williemcvillage</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8121</guid>
<br />
Can I use temp sensor DS18B20 or temp/humidity DHT11 with this board?<br />
<br />
In case they're not compatible, which ones should work? <br />
<br />
How should be the wiring?<br />
<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[More inputs please]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8006</link>
			<pubDate>Sun, 20 Apr 2025 19:56:54 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=1480">kbo</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8006</guid>
<br />
I need more inputs for my alarm central. 32 inputs should be enough.<br />
Is there a larger (more inputs) version  planned ?<br />
<br />
Greetings,<br />
Kris B.]]></description>
<br />
<br />
Greetings,<br />
Kris B.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for TA]-08 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7905</link>
			<pubDate>Thu, 03 Apr 2025 14:55:44 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7905</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 16<br />
#define RXD_PIN 17<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
void setup() {<br />
  Serial.begin(115200);<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
}</code></div></div> arduino ino file download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7366" target="_blank" title="">8-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 794)
BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7367" target="_blank" title="">8-tuya-wifi-config.ino.merged.zip</a> (Size: 187.17 KB / Downloads: 795)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for TA]-07 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7904</link>
			<pubDate>Thu, 03 Apr 2025 14:54:00 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7904</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7364" target="_blank" title="">7-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 776)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7365" target="_blank" title="">7-Ethernet-W5500.ino.merged.zip</a> (Size: 191.07 KB / Downloads: 765)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for TA]-06 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7903</link>
			<pubDate>Thu, 03 Apr 2025 14:52:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7903</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7362" target="_blank" title="">6-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 697)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7363" target="_blank" title="">6-DS3231-RTC.ino.merged.zip</a> (Size: 193.66 KB / Downloads: 762)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for TA]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7902</link>
			<pubDate>Thu, 03 Apr 2025 14:50:38 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7902</guid>
 * ESP32 GPIO State Reader<br />
 * Reads the state of 12 GPIOs and prints the results to the serial monitor.<br />
 * <br />
 */<br />
<br />
#define GPIO_9 &nbsp;&nbsp;9<br />
#define GPIO_11  11<br />
#define GPIO_5 &nbsp;&nbsp;5<br />
#define GPIO_4 &nbsp;&nbsp;4<br />
#define GPIO_7 &nbsp;&nbsp;7<br />
#define GPIO_6 &nbsp;&nbsp;6<br />
#define GPIO_13  13<br />
#define GPIO_40  40<br />
#define GPIO_14  14<br />
#define GPIO_48  48<br />
#define GPIO_21  21<br />
#define GPIO_47  47<br />
<br />
    Serial.begin(115200); // Initialize serial communication at 115200 baud rate<br />
    <br />
    // Set GPIOs as input<br />
    pinMode(GPIO_9, INPUT);<br />
    pinMode(GPIO_11, INPUT);<br />
    pinMode(GPIO_5, INPUT);<br />
    pinMode(GPIO_4, INPUT);<br />
    pinMode(GPIO_7, INPUT);<br />
    pinMode(GPIO_6, INPUT);<br />
    pinMode(GPIO_13, INPUT);<br />
    pinMode(GPIO_40, INPUT);<br />
    pinMode(GPIO_14, INPUT);<br />
    pinMode(GPIO_48, INPUT);<br />
    pinMode(GPIO_21, INPUT);<br />
    pinMode(GPIO_47, INPUT);<br />
}<br />
<br />
void loop() {<br />
    // Read GPIO states<br />
    int state_9  = digitalRead(GPIO_9);<br />
    int state_11 = digitalRead(GPIO_11);<br />
    int state_5  = digitalRead(GPIO_5);<br />
    int state_4  = digitalRead(GPIO_4);<br />
    int state_7  = digitalRead(GPIO_7);<br />
    int state_6  = digitalRead(GPIO_6);<br />
    int state_13 = digitalRead(GPIO_13);<br />
    int state_40 = digitalRead(GPIO_40);<br />
    int state_14 = digitalRead(GPIO_14);<br />
    int state_48 = digitalRead(GPIO_48);<br />
    int state_21 = digitalRead(GPIO_21);<br />
    int state_47 = digitalRead(GPIO_47);<br />
<br />
    // Print GPIO states to the serial monitor<br />
    Serial.printf("GPIO9: %d, GPIO11: %d, GPIO5: %d, GPIO4: %d, GPIO7: %d, GPIO6: %d, GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO21: %d, GPIO47: %d&#92;n",<br />
                  state_9, state_11, state_5, state_4, state_7, state_6, state_13, state_40, state_14, state_48, state_21, state_47);<br />
    <br />
    delay(1000); // Read GPIO states every second<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7360" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 737 bytes / Downloads: 773)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7361" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 181.6 KB / Downloads: 782)
 * <br />
 */<br />
<br />
<br />
    <br />
}<br />
<br />
void loop() {<br />
<br />
    <br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for TA]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7901</link>
			<pubDate>Thu, 03 Apr 2025 14:45:36 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7901</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony TA!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7358" target="_blank" title="">4-RS485-Test.zip</a> (Size: 762 bytes / Downloads: 726)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7359" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 186.54 KB / Downloads: 733)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for TA]-03 RF433MHz signal decode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7900</link>
			<pubDate>Thu, 03 Apr 2025 14:43:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7900</guid>
  Simple example for receiving<br />
  <br />
  https://github.com/sui77/rc-switch/<br />
*/<br />
<br />
#include &lt;RCSwitch.h&gt;<br />
<br />
RCSwitch mySwitch = RCSwitch();<br />
<br />
  Serial.begin(9600);<br />
  mySwitch.enableReceive(digitalPinToInterrupt(12)); <br />
  Serial.print("begin test");<br />
}<br />
<br />
void loop() {<br />
  if (mySwitch.available()) {<br />
    <br />
    Serial.print("Received ");<br />
    Serial.print( mySwitch.getReceivedValue() );<br />
    Serial.print(" / ");<br />
    Serial.print( mySwitch.getReceivedBitlength() );<br />
    Serial.print("bit ");<br />
    Serial.print("Protocol: ");<br />
    Serial.println( mySwitch.getReceivedProtocol() );<br />
<br />
    mySwitch.resetAvailable();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7356" target="_blank" title="">3-433-decode.zip</a> (Size: 455 bytes / Downloads: 757)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7357" target="_blank" title="">3-433-decode.ino.merged.zip</a> (Size: 183.33 KB / Downloads: 770)
  <br />
*/<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
    <br />
<br />
  }<br />
		</item>
	</channel>
</rss>
