	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-A2v3]]></title>
		<pubDate>Sat, 07 Nov 2026 14:58:19 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[CR battery]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9776</link>
			<pubDate>Sun, 30 Aug 2026 05:28:56 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8821">apps4check</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9776</guid>
			<description><![CDATA[Hi! Can I use a CR1225 battery or only a CR1220?]]></description>
			<content:encoded><![CDATA[Hi! Can I use a CR1225 battery or only a CR1220?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[MODBUS]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9355</link>
			<pubDate>Mon, 25 May 2026 16:39:11 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10918">frasanc</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9355</guid>
			<description><![CDATA[We have a question about reading Modbus RTU:<br />
<br />
With A2:<br />
RS485:<br />
RXD:35<br />
TXD:32<br />
<br />
With A2V3: <br />
RS485:<br />
RXD:GPIO15<br />
TXD:GPIO7<br />
<br />
With A2  can read, but not with A2V3. Any idea?<br />
<br />
// A2v3:<br />
HardwareSerial MBus(1);<br />
MBus.begin(9600, SERIAL_8N1, 15, 7);<br />
pinMode(4, INPUT);  // modo auto<br />
<br />
// A2:<br />
HardwareSerial MBus(2);<br />
MBus.begin(9600, SERIAL_8N1, 35, 32);<br />
<br />
ModbusMaster node;<br />
node.begin(1, MBus);<br />
uint8_t r = node.readInputRegisters(6, 2);  // FC04 @ PDU 6<br />
<br />
Someone could help us?]]></description>
			<content:encoded><![CDATA[We have a question about reading Modbus RTU:<br />
<br />
With A2:<br />
RS485:<br />
RXD:35<br />
TXD:32<br />
<br />
With A2V3: <br />
RS485:<br />
RXD:GPIO15<br />
TXD:GPIO7<br />
<br />
<br />
// A2v3:<br />
<br />
// A2:<br />
<br />
<br />
Someone could help us?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-A2v3 FILES]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9192</link>
			<pubDate>Tue, 31 Mar 2026 18:28:36 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10663">ridouane.othman@gmail.com</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9192</guid>
I am planning to design a custom case for the KC868-A2v3 board and would like to ensure accurate fitting.<br />
Could you please provide the mechanical drawings (including dimensions and mounting holes) and, if available, the 3D CAD files (STEP/STP format) for this board?]]></description>
Could you please provide the mechanical drawings (including dimensions and mounting holes) and, if available, the 3D CAD files (STEP/STP format) for this board?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[KC868-a8v3 IFTTT for Aircon use]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9115</link>
			<pubDate>Thu, 12 Mar 2026 18:59:17 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10216">beegeenz</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9115</guid>
			<description><![CDATA[I have KC868-a8v3.1 board loaded with the current firmware V3.23.2<br />
<br />
It is used for switching 24VAC to control AC ducts in conjunction with Home Assistant.<br />
<br />
My challenge is that the Rumpus room duct (controlled by DO8 on KC868) is fed from a master upstairs duct (controller by DO2 on KC868) so both ducts need to be open for AC to reach the Rumpus room.<br />
For ease of user operation I would like to setup the a IFTTT rule so that;<br />
1. when a user turns on the Rumpus duct (D08) the upstairs duct will also activate (D02) (turn on could by by HA or RF on the KC868)<br />
2. if the user subsequently turns off the Rumpus duct, the Upstairs duct will remain open.<br />
<br />
Also, if the Upstairs duct is turned off, there should be a rule to turn on the Rumpus room duct, this is necessary to reflect through to the HA dashboard.<br />
<br />
Using IFTTT I setup an IF condition on the DO8 which performs an action on D02.<br />
<br />
I found that this doesn't work properly and the KC web page status indicator for D02 and D08 are not linked corectly by the rule.  At one stage the KC868 crashed and I had to relead the formward with the formward loader tool.<br />
<br />
Can you please advise if IFTTT can be used for this sort of rules or is there another way on the KC868 to achieve this.<br />
<br />
Regards]]></description>
			<content:encoded><![CDATA[I have KC868-a8v3.1 board loaded with the current firmware V3.23.2<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Regards]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Error Flashing new KCS firmware using ESP32 Download Tool]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8316</link>
			<pubDate>Sat, 12 Jul 2025 15:36:36 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9067">steven22</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8316</guid>
			<description><![CDATA[Hi everyone, I'm new to Kincony products and this forum. I recently bought a Kincony A2V3.1 board to test these products and their integration with Home Assistant.<br />
Once the board arrived, I connected it to my router via LAN cable, but I cannot see any IP address on the A2V3 screen, nor can I find it on my network.<br />
<br />
For this reason, I tried to reflash the KCS v3 firmware using ESP32 Download Tool V3.9.2 and entering download mode (turn off → press S2 button → turn on power → release S2).<br />
However, when I press "start" on the ESP32 Download Tool, I get this error:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>1 kill<br />
test offset :  0 0x0<br />
case ok<br />
case ok<br />
<br />
Uploading stub...<br />
Running stub...<br />
[2025-07-12 09:22:45,885][ESP8266Loader_spi[1]][espDownloader.py][line:586][ERROR]: ESP32 Chip stub error esp_stub_and_set_baud.<br />
no log file output ...</code></div></div><br />
I already tested it with different USB cable, different PC and different power supply. But getting always same error.<br />
<br />
Here a screenshot from ESP32 Download Tool V3.9.2:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7971" target="_blank" title="">Screenshot 2025-07-12 092304.png</a> (Size: 63.1 KB / Downloads: 1097)
<br />
<br />
Can you please help me debugging this issue?<br />
<br />
regards,<br />
Stefano]]></description>
			<content:encoded><![CDATA[Hi everyone, I'm new to Kincony products and this forum. I recently bought a Kincony A2V3.1 board to test these products and their integration with Home Assistant.<br />
<br />
case ok<br />
case ok<br />
<br />
<br />
<br />
<br />
<br />
regards,<br />
Stefano]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-11 Digital input trigger relay output]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7969</link>
			<pubDate>Sun, 20 Apr 2025 14:07:04 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7969</guid>
			<description><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>/**<br />
 * @brief Example to control relays based on digital input states using ESP32<br />
 * @details This program reads the states of two digital inputs (GPIO16, GPIO17)<br />
 *          and controls two relays (GPIO40, GPIO39) accordingly.<br />
 *<br />
 */<br />
<br />
// Define the GPIO pins for digital inputs<br />
#define INPUT1_PIN 16  // GPIO16 for Digital Input 1<br />
#define INPUT2_PIN 17  // GPIO17 for Digital Input 2<br />
<br />
// Define the GPIO pins for relays<br />
#define RELAY1_PIN 40  // GPIO40 for Relay 1<br />
#define RELAY2_PIN 39  // GPIO39 for Relay 2<br />
<br />
void setup() {<br />
    // Initialize the serial communication for debugging<br />
    Serial.begin(115200);<br />
    Serial.println("ESP32 Input-Controlled Relay Example");<br />
<br />
    // Set the input pins as INPUT<br />
    pinMode(INPUT1_PIN, INPUT);<br />
    pinMode(INPUT2_PIN, INPUT);<br />
<br />
    // Set the relay pins as OUTPUT<br />
    pinMode(RELAY1_PIN, OUTPUT);<br />
    pinMode(RELAY2_PIN, OUTPUT);<br />
<br />
    // Turn off both relays at startup (assuming active LOW relays)<br />
    digitalWrite(RELAY1_PIN, HIGH);<br />
    digitalWrite(RELAY2_PIN, HIGH);<br />
}<br />
<br />
void loop() {<br />
    // Read the state of the digital inputs<br />
    int state1 = digitalRead(INPUT1_PIN);<br />
    int state2 = digitalRead(INPUT2_PIN);<br />
<br />
    // Control the relays based on input states<br />
    digitalWrite(RELAY1_PIN, state1 == HIGH ? LOW : HIGH); // Activate relay if input is HIGH<br />
    digitalWrite(RELAY2_PIN, state2 == HIGH ? LOW : HIGH); // Activate relay if input is HIGH<br />
<br />
    // Print the states to the Serial Monitor<br />
    Serial.print("Digital Input 1 State: ");<br />
    Serial.println(state1);<br />
    Serial.print("Digital Input 2 State: ");<br />
    Serial.println(state2);<br />
<br />
    // Wait for 100 milliseconds before reading again<br />
    delay(100);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7470" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 866 bytes / Downloads: 818)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7471" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 179.47 KB / Downloads: 779)
			<content:encoded><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>/**<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
<br />
    delay(100);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7968</link>
			<pubDate>Sun, 20 Apr 2025 14:04:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7968</guid>
 * <br />
 * <br />
 * - SCL (clock) on pin IO47<br />
 * - SDA (data) on pin IO48<br />
 * <br />
 */<br />
<br />
<br />
// Initialize the display using the software I2C method (SCL = IO47, SDA = IO48)<br />
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  47, 48, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7468" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.12 KB / Downloads: 778)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7469" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 201.24 KB / Downloads: 745)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7966</link>
			<pubDate>Sun, 20 Apr 2025 14:01:46 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7966</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CS_PIN  41<br />
#define W5500_RST_PIN 1<br />
#define W5500_INT_PIN 2<br />
#define W5500_CLK_PIN 42<br />
#define W5500_MOSI_PIN 43<br />
#define W5500_MISO_PIN 44<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7466" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 803)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7467" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 188.93 KB / Downloads: 726)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7965</link>
			<pubDate>Sun, 20 Apr 2025 14:00:17 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7965</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 48<br />
 * - SCL: GPIO 47<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
#define SDA_PIN &nbsp;&nbsp;48<br />
#define SCL_PIN &nbsp;&nbsp;47<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
  Serial.print(" ");<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7464" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 752)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7465" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 191.09 KB / Downloads: 744)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7964</link>
			<pubDate>Sun, 20 Apr 2025 13:58:47 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7964</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 13<br />
 * - MISO: GPIO 14<br />
 * - MOSI: GPIO 12<br />
 * - CS: GPIO 11<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  13<br />
#define MISO 14<br />
#define MOSI 12<br />
#define CS &nbsp;&nbsp;11<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7462" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 744)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7463" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 221.25 KB / Downloads: 719)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7963</link>
			<pubDate>Sun, 20 Apr 2025 13:57:11 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7963</guid>
 * @brief Simple example to read multiple digital inputs using ESP32<br />
 * @details This program demonstrates how to read digital input states<br />
 *          from GPIO18, GPIO8, GPIO4, GPIO5, GPIO6, and GPIO38 of an ESP32 development board.<br />
 *<br />
 */<br />
<br />
#define INPUT1_PIN 18  // GPIO18<br />
#define INPUT2_PIN 8 &nbsp;&nbsp;// GPIO8<br />
#define INPUT3_PIN 4 &nbsp;&nbsp;// GPIO4<br />
#define INPUT4_PIN 5 &nbsp;&nbsp;// GPIO5<br />
#define INPUT5_PIN 6 &nbsp;&nbsp;// GPIO6<br />
#define INPUT6_PIN 38  // GPIO38<br />
<br />
    Serial.println("ESP32 Digital Input Read Example");<br />
<br />
    pinMode(INPUT3_PIN, INPUT);<br />
    pinMode(INPUT4_PIN, INPUT);<br />
    pinMode(INPUT5_PIN, INPUT);<br />
    pinMode(INPUT6_PIN, INPUT);<br />
}<br />
<br />
void loop() {<br />
    int state3 = digitalRead(INPUT3_PIN);<br />
    int state4 = digitalRead(INPUT4_PIN);<br />
    int state5 = digitalRead(INPUT5_PIN);<br />
    int state6 = digitalRead(INPUT6_PIN);<br />
<br />
    Serial.print("GPIO18 State: ");<br />
    Serial.print("GPIO8 State: ");<br />
    Serial.print("GPIO4 State: ");<br />
    Serial.println(state3);<br />
    Serial.print("GPIO5 State: ");<br />
    Serial.println(state4);<br />
    Serial.print("GPIO6 State: ");<br />
    Serial.println(state5);<br />
    Serial.print("GPIO38 State: ");<br />
    Serial.println(state6);<br />
<br />
    // Wait for 500 milliseconds before reading again<br />
    delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7458" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 773 bytes / Downloads: 729)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7459" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 179.48 KB / Downloads: 772)
 *<br />
 */<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
    delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7962</link>
			<pubDate>Sun, 20 Apr 2025 13:54:17 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7962</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 15<br />
#define RS485_TXD 7<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony A2v3!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7456" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 795)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7457" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 184.35 KB / Downloads: 730)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7961</link>
			<pubDate>Sun, 20 Apr 2025 13:50:59 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7961</guid>
 * @brief Simple example to read two digital inputs using ESP32<br />
 * @details This program demonstrates how to read two digital input states<br />
 *          from GPIO16 and GPIO17 of an ESP32 development board.<br />
 *<br />
 */<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
    delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7454" target="_blank" title="">2-digital-input.zip</a> (Size: 667 bytes / Downloads: 720)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7455" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 179.35 KB / Downloads: 728)
 *<br />
 */<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
    delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A2v3]-01 Turn ON/OFF OUTPUT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7960</link>
			<pubDate>Sun, 20 Apr 2025 13:48:14 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7960</guid>
 * @brief Simple example to control two relays using ESP32<br />
 * @details This program demonstrates how to control two relays connected to GPIO40 and GPIO39<br />
 *          of an ESP32 development board.<br />
 *<br />
 */<br />
<br />
// Define the GPIO pins for the relays<br />
<br />
    Serial.println("ESP32 Relay Control Example");<br />
<br />
    // Set the relay pins as output<br />
<br />
}<br />
<br />
void loop() {<br />
    Serial.println("Turning ON Relay 1");<br />
    digitalWrite(RELAY1_PIN, LOW); // Activate relay 1<br />
    delay(1000); // Wait for 1 second<br />
    <br />
    Serial.println("Turning OFF Relay 1");<br />
    digitalWrite(RELAY1_PIN, HIGH); // Deactivate relay 1<br />
    delay(1000);<br />
    <br />
    Serial.println("Turning ON Relay 2");<br />
    digitalWrite(RELAY2_PIN, LOW); // Activate relay 2<br />
    delay(1000);<br />
    <br />
    Serial.println("Turning OFF Relay 2");<br />
    digitalWrite(RELAY2_PIN, HIGH); // Deactivate relay 2<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7452" target="_blank" title="">1-output.zip</a> (Size: 683 bytes / Downloads: 742)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7453" target="_blank" title="">1-output.ino.merged.zip</a> (Size: 179.19 KB / Downloads: 793)
 *<br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
    <br />
    delay(1000);<br />
    <br />
    delay(1000);<br />
    <br />
    delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[KC868-A2v3 ESPHome yaml for home assistant]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7959</link>
			<pubDate>Sun, 20 Apr 2025 13:46:01 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7959</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7451" target="_blank" title="">A2v3-HA.png</a> (Size: 95.9 KB / Downloads: 1135)
  friendly_name: a2v3<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO42<br />
  mosi_pin: GPIO43<br />
  miso_pin: GPIO44<br />
  cs_pin: GPIO41<br />
  interrupt_pin: GPIO2<br />
  reset_pin: GPIO1<br />
<br />
i2c:<br />
   - id: bus_a<br />
     sda: 48<br />
     scl: 47<br />
     scan: true<br />
     frequency: 400kHz<br />
<br />
uart:<br />
  - id: uart_1<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 7<br />
    rx_pin: 15<br />
<br />
  - id: uart_sim7600<br />
    baud_rate: 115200<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
      sequence:<br />
        - lambda: UARTDebug::log_string(direction, bytes);<br />
    tx_pin: 10<br />
    rx_pin: 9<br />
<br />
switch:<br />
<br />
  - platform: gpio<br />
    pin: 40<br />
<br />
    pin: 39<br />
<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
    uart_id: uart_sim7600<br />
    name: "UART 4G"<br />
    data: "AT+CGSN&#92;r&#92;n" # read 4G SIM7600 ID<br />
<br />
binary_sensor:<br />
    pin: <br />
      number: 16<br />
      inverted: true<br />
<br />
    pin:<br />
      number: 17<br />
<br />
    pin:<br />
      number: 18<br />
<br />
    pin:<br />
      number: 8<br />
<br />
    pin:<br />
      number: 4<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
    pin:<br />
      number: 5<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
    pin:<br />
      number: 6<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
    pin:<br />
      number: 38<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    i2c_id: bus_a<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 0, id(roboto), "A2v3");</code></div></div> esphome yaml file download: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7450" target="_blank" title="">A2v3-HA.txt</a> (Size: 2.39 KB / Downloads: 582)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
i2c:<br />
   - id: bus_a<br />
     sda: 48<br />
     scl: 47<br />
     scan: true<br />
<br />
uart:<br />
  - id: uart_1<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 7<br />
    rx_pin: 15<br />
<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
      sequence:<br />
    tx_pin: 10<br />
    rx_pin: 9<br />
<br />
switch:<br />
<br />
    pin: 40<br />
<br />
    pin: 39<br />
<br />
<br />
<br />
    pin: <br />
      number: 16<br />
<br />
    pin:<br />
      number: 17<br />
<br />
    pin:<br />
      number: 18<br />
<br />
    pin:<br />
      number: 8<br />
<br />
    pin:<br />
      number: 4<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
    pin:<br />
      number: 5<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
    pin:<br />
      number: 6<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
    pin:<br />
      number: 38<br />
      mode:<br />
        input: true<br />
        pullup: true<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
	</channel>
</rss>
