	<channel>
		<title><![CDATA[Smart Home Automation Forum - KC868-A8v3]]></title>
		<pubDate>Mon, 12 Oct 2026 00:01:35 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[turn on one relay by mqtt sample on A8v3]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9624</link>
			<pubDate>Wed, 15 Jul 2026 08:26:13 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9624</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10205" target="_blank" title="">a8v3-mqtt-1.png</a> (Size: 60.2 KB / Downloads: 177)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10204" target="_blank" title="">a8v3-mqtt-2.png</a> (Size: 137.72 KB / Downloads: 192)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10203" target="_blank" title="">a8v3-mqtt-3.jpg</a> (Size: 406.16 KB / Downloads: 191)
		</item>
		<item>
			<title><![CDATA[KC868 A8v3 RF not working with A-OK roller blind motor]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8903</link>
			<pubDate>Mon, 12 Jan 2026 18:41:54 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10216">beegeenz</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8903</guid>
My KC-868 A8v3 is unable to learn the RF for my A-OK roller blinds.  Is there any special way to setup the RF in KC868 for roller blinds?<br />
<br />
The blinds work ok with the factory supplied remote controller. <br />
The KC868 A8v3 can learn the RF for my garage controller ok.<br />
<br />
Appreciate any help you can give.<br />
<br />
Regards]]></description>
<br />
<br />
<br />
Regards]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Kincony not started.]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8783</link>
			<pubDate>Mon, 01 Dec 2025 23:54:43 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9964">Proger</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8783</guid>
			<description><![CDATA[I have a Kincony KC868 A8 V3.1 board. After flashing the firmware and powering it on, the display shows "Kincony" and the yellow LED starts blinking. The board doesn't display the IP address. What's wrong with the board?]]></description>
			<content:encoded><![CDATA[I have a Kincony KC868 A8 V3.1 board. After flashing the firmware and powering it on, the display shows "Kincony" and the yellow LED starts blinking. The board doesn't display the IP address. What's wrong with the board?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[a8v3 - RXTX and 4 pulse counters]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8658</link>
			<pubDate>Sun, 19 Oct 2025 00:30:58 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9711">rockyhopper</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8658</guid>
<br />
I plan to buy a8v3 and use it with ESPhome.<br />
<br />
But, I would need:<br />
- RXTX (<a href="https://esphome.io/components/uart/#uart" target="_blank" rel="noopener" class="mycode_url">https://esphome.io/components/uart/#uart</a>) ideally on external connector<br />
- 4 Pulse Counters (PCNT, <a href="https://esphome.io/components/sensor/pulse_counter/" target="_blank" rel="noopener" class="mycode_url">https://esphome.io/components/sensor/pulse_counter/</a>) on external connector<br />
<br />
Could you confirm that:<br />
- for RXTX, I can re-assign pins used for Analog Input (AI-1 and AI-2) and map RXTX on it.<br />
  Would I lost any other feature (than ADS) from a8v3 in that case (I think that ESP32-S3 is limited to 2 end-user RXTX)? <br />
  If that's not possible, can I directly re-use the RS485 connector (for my RXTX pins) as I don't plan to use RS485.<br />
<br />
- for my 4 pulse counters, can I re-use the 4 "one-wire with pull-up" (S1 to S4)?<br />
  (I plan to add 1-wire over i2c -- DS2484 to support 1-wire sensors, then I don't need those S1-S4 pins).<br />
<br />
Thanks in advance for your support.]]></description>
<br />
<br />
<br />
<br />
<br />
Thanks in advance for your support.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[1-wire GPIOs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8554</link>
			<pubDate>Tue, 16 Sep 2025 16:08:05 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9271">JuDie07</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8554</guid>
			<description><![CDATA[KC868A8-V3 under ESPHome 2025.8.4<br />
<br />
Hello, <br />
Question: Can the 1-wire GPIOs be connected to the (with pull-up resistance on PCB): <br />
S1:GPIO40<br />
S2:GPIO13<br />
S3:GPIO48<br />
S4:GPIO14<br />
<br />
Can other sensors be connected that do not require a pull-up resistor?<br />
For example one:<br />
- platform: ledc<br />
  pin: GPIO40<br />
  inverted: false]]></description>
			<content:encoded><![CDATA[KC868A8-V3 under ESPHome 2025.8.4<br />
<br />
Hello, <br />
S1:GPIO40<br />
S2:GPIO13<br />
S3:GPIO48<br />
S4:GPIO14<br />
<br />
  pin: GPIO40<br />
  inverted: false]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-11 Digital input trigger relay output]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7982</link>
			<pubDate>Sun, 20 Apr 2025 14:46:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7982</guid>
 *<br />
 * This program reads 16 input states from a PCF8575 I/O expander and <br />
 * controls a corresponding 16-channel relay module. When an input pin <br />
 * is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 * When the input pin is HIGH, the corresponding relay is turned OFF.<br />
 *<br />
 * Pin Definitions:<br />
 * - SDA: GPIO 38<br />
 * - SCL: GPIO 39<br />
 * - Input I2C Address: 0x24<br />
 * - Relay I2C Address: 0x25<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Library to control the PCF8575 I/O expander<br />
<br />
// Define I2C pins<br />
#define SDA 8         &nbsp;&nbsp;// SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// SCL pin<br />
<br />
// I2C addresses<br />
<br />
#define RELAY_I2C_ADDRESS 0x22 &nbsp;&nbsp;// I2C address for the relay PCF8575 module<br />
<br />
<br />
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575<br />
<br />
void setup() {<br />
  Wire.begin(SDA, SCL);<br />
  <br />
  Serial.begin(115200);<br />
  <br />
  // Initialize input and relay modules<br />
<br />
  pcf8575_RL.begin();<br />
  <br />
  // Turn off all relays at the start<br />
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially<br />
  }<br />
  <br />
  Serial.println("System started: Input state controlling 8 relays");<br />
}<br />
<br />
void loop() {<br />
  uint16_t inputState = 0;<br />
<br />
  // Read the state of 16 inputs<br />
  for (int i = 8; i &lt; 16; i++) {<br />
    if (pcf8575_RL.read(i)) {<br />
      inputState |= (1 &lt;&lt; i);  // If input is HIGH, set the corresponding bit<br />
    } else {<br />
      inputState &amp;= ~(1 &lt;&lt; i); // Otherwise, clear the corresponding bit<br />
    }<br />
  }<br />
  <br />
  // Control the relays based on the input state<br />
    if (inputState &amp; (1 &lt;&lt; i+8)) {<br />
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the relay OFF<br />
    } else {<br />
      pcf8575_RL.write(i, LOW); &nbsp;&nbsp;// If input is LOW, turn the relay ON<br />
    }<br />
  }<br />
<br />
  // Delay for 500 milliseconds<br />
  delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7498" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 1,018 bytes / Downloads: 803)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7499" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 189.37 KB / Downloads: 704)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
  <br />
  <br />
<br />
  <br />
  }<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
    } else {<br />
    }<br />
  }<br />
  <br />
    } else {<br />
    }<br />
  }<br />
<br />
  delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7981</link>
			<pubDate>Sun, 20 Apr 2025 14:44:43 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7981</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7496" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 683)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7497" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 201.24 KB / Downloads: 723)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7980</link>
			<pubDate>Sun, 20 Apr 2025 14:43:06 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7980</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 16<br />
#define RXD_PIN 17<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7494" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 675)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7495" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 184.92 KB / Downloads: 714)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7979</link>
			<pubDate>Sun, 20 Apr 2025 14:41:31 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7979</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7492" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 694)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7493" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 188.94 KB / Downloads: 752)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7978</link>
			<pubDate>Sun, 20 Apr 2025 14:40:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7978</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7490" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 690)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7491" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 191.08 KB / Downloads: 681)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7977</link>
			<pubDate>Sun, 20 Apr 2025 14:38:32 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7977</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7488" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 733)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7489" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 221.25 KB / Downloads: 772)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7976</link>
			<pubDate>Sun, 20 Apr 2025 14:37:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7976</guid>
 * ESP32 GPIO State Reader<br />
 * Reads the state of GPIO47, GPIO48, GPIO7, GPIO40, GPIO0, and GPIO5<br />
 * and prints the results to the serial monitor.<br />
 * <br />
 */<br />
<br />
#define GPIO_13  13<br />
#define GPIO_40  40<br />
#define GPIO_14  14<br />
#define GPIO_48  48<br />
#define GPIO_0 &nbsp;&nbsp;0<br />
<br />
<br />
    Serial.begin(115200); // Initialize serial communication at 115200 baud rate<br />
    <br />
    // Set GPIOs as input<br />
    pinMode(GPIO_13, INPUT);<br />
    pinMode(GPIO_40, INPUT);<br />
    pinMode(GPIO_14, INPUT);<br />
    pinMode(GPIO_48, INPUT);<br />
    pinMode(GPIO_0, INPUT);<br />
}<br />
<br />
void loop() {<br />
    // Read GPIO states<br />
    int state_13 = digitalRead(GPIO_13);<br />
    int state_40 = digitalRead(GPIO_40);<br />
    int state_14  = digitalRead(GPIO_14);<br />
    int state_48 = digitalRead(GPIO_48);<br />
    int state_0  = digitalRead(GPIO_0);<br />
    <br />
    // Print GPIO states to the serial monitor<br />
    Serial.printf("GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO0: %d&#92;n",<br />
                  state_13, state_40, state_14, state_48, state_0);<br />
    <br />
    delay(1000); // Read GPIO states every second<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7486" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 621 bytes / Downloads: 698)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7487" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 179.32 KB / Downloads: 703)
 * <br />
 */<br />
<br />
<br />
<br />
    <br />
}<br />
<br />
void loop() {<br />
    <br />
    <br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7975</link>
			<pubDate>Sun, 20 Apr 2025 14:35:47 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7975</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B8M!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7484" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 714)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7485" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 184.35 KB / Downloads: 675)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-03 Read analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7974</link>
			<pubDate>Sun, 20 Apr 2025 14:34:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7974</guid>
 *<br />
 * Description:<br />
 * This Arduino program reads analog values from four analog input pins (A1, A2)<br />
 * and prints the values to the Serial Monitor. The analog inputs are defined with specific<br />
 * GPIO pins and the program reads the voltage levels from these pins every 2 seconds.<br />
 *<br />
 * - A1: GPIO 7<br />
 * - A2: GPIO 6<br />
<br />
 */<br />
<br />
#define ANALOG_A1 &nbsp;&nbsp;7 &nbsp;&nbsp;// Define GPIO pin for analog input A1<br />
#define ANALOG_A2 &nbsp;&nbsp;6 &nbsp;&nbsp;// Define GPIO pin for analog input A2<br />
<br />
<br />
void setup()<br />
{<br />
    delay(500); // Short delay to allow serial communication to start<br />
<br />
    pinMode(ANALOG_A1, INPUT); // Set GPIO 5 as an input for analog signal A1<br />
    pinMode(ANALOG_A2, INPUT); // Set GPIO 7 as an input for analog signal A2<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
    // Read and print analog values from the defined pins<br />
    Serial.print("A1="); <br />
    Serial.println(analogRead(ANALOG_A1)); // Read and print the value from A1<br />
    Serial.print("A2=");<br />
    Serial.println(analogRead(ANALOG_A2)); // Read and print the value from A2 &nbsp;&nbsp;<br />
    delay(2000); // Wait for 2 seconds before the next reading<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7482" target="_blank" title="">3-analog-input.zip</a> (Size: 698 bytes / Downloads: 700)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7483" target="_blank" title="">3-analog-input.ino.merged.zip</a> (Size: 184.59 KB / Downloads: 684)
 *<br />
 *<br />
<br />
 */<br />
<br />
<br />
<br />
void setup()<br />
{<br />
<br />
<br />
}<br />
<br />
void loop()<br />
{<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for A8v3]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7973</link>
			<pubDate>Sun, 20 Apr 2025 14:32:28 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7973</guid>
 *<br />
 * This Arduino program reads the state of a 16-channel PCF8575 I/O expander<br />
 * and prints the state of all input pins to the Serial Monitor. The state of <br />
 * each pin is represented as a bit in a 16-bit value, where each bit corresponds <br />
 * to an input pin. The program prints the input state in binary format.<br />
 *<br />
 * - PCF8575 I2C Address: 0x22<br />
 */<br />
<br />
#include "Arduino.h"<br />
#include "PCF8575.h"<br />
<br />
<br />
// Set I2C address<br />
PCF8575 pcf8575_IN1(0x22); // The I2C address of the PCF8575<br />
<br />
<br />
<br />
    pcf8575_IN1.begin(); // Initialize the PCF8575<br />
<br />
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");<br />
}<br />
<br />
void loop() {<br />
    uint16_t state = 0;<br />
<br />
    // Read the state of each pin (assuming 16 pins)<br />
    for (int pin = 8; pin &lt; 16; pin++) {<br />
        if (pcf8575_IN1.read(pin)) {<br />
            state |= (1 &lt;&lt; pin); // Set the bit for the active pin<br />
        }<br />
    }<br />
<br />
    Serial.println(state, BIN); // Print the state of inputs in binary<br />
<br />
    delay(500); // Delay 500ms<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7480" target="_blank" title="">2-digital-input.zip</a> (Size: 839 bytes / Downloads: 784)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7481" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 189.5 KB / Downloads: 699)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
    }<br />
<br />
<br />
		</item>
	</channel>
</rss>
