	<channel>
		<title><![CDATA[Smart Home Automation Forum - F8]]></title>
		<pubDate>Sat, 24 Oct 2026 22:38:31 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[F8 ESPHome yaml for home assistant with tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9714</link>
			<pubDate>Mon, 03 Aug 2026 07:00:09 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9714</guid>
  friendly_name: f8<br />
  platformio_options:<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
    <br />
<br />
external_components:<br />
  - source:<br />
      type: git<br />
      ref: v1.3.1<br />
<br />
# Enable logging<br />
<br />
  # hardware_uart: USB_SERIAL_JTAG<br />
api:<br />
  encryption:<br />
    key: "WeVOuL5oNhjXcfzXtTirlOwvtWvCD5yqIxd3oV4es1k="<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO42<br />
  mosi_pin: GPIO43<br />
  miso_pin: GPIO44<br />
  cs_pin: GPIO41<br />
  interrupt_pin: GPIO2<br />
  reset_pin: GPIO1<br />
<br />
i2c:<br />
 &nbsp;&nbsp;- id: bus_a<br />
   &nbsp;&nbsp;sda: 8<br />
   &nbsp;&nbsp;scl: 18<br />
   &nbsp;&nbsp;scan: true<br />
<br />
pcf8574:<br />
  - id: 'pcf8574_hub_in_1'  # for DI1-DI4 Relay1-Relay4<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
uart:<br />
  - id: uart_1    #RS485<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 16<br />
    rx_pin: 17<br />
<br />
  - id: tuya_mcu_uart<br />
    tx_pin: GPIO39<br />
    rx_pin: GPIO38<br />
<br />
tuya_wifi_mcu:<br />
  # tuya mcu product id<br />
  product_id: gk6ok3aysk6lw1bb<br />
  uart_id: tuya_mcu_uart<br />
  wifi_reset_pin: 28<br />
  wifi_led_pin: 16<br />
<br />
switch:<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
  - platform: gpio<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
      inverted: true<br />
    dp_id: 1<br />
    internal: true<br />
    # bind other switch, sync state<br />
    bind_switch_id: "f8_output01"<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
    dp_id: 2<br />
    bind_switch_id: "f8_output02"<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
    dp_id: 3<br />
    bind_switch_id: "f8_output03"<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
    dp_id: 4<br />
    bind_switch_id: "f8_output04"<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
    dp_id: 5<br />
    bind_switch_id: "f8_output05"<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
    dp_id: 6<br />
    bind_switch_id: "f8_output06"<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
    dp_id: 101<br />
    bind_switch_id: "f8_output07"<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
    dp_id: 102<br />
    bind_switch_id: "f8_output08"<br />
<br />
binary_sensor:<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    dp_id: 111<br />
    bind_binary_sensor_id: f8_input01<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    dp_id: 112<br />
    bind_binary_sensor_id: f8_input02<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    dp_id: 113<br />
    bind_binary_sensor_id: f8_input03<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    dp_id: 114<br />
    bind_binary_sensor_id: f8_input04<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    dp_id: 115<br />
    bind_binary_sensor_id: f8_input05<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    dp_id: 116<br />
    bind_binary_sensor_id: f8_input06<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    dp_id: 117<br />
    bind_binary_sensor_id: f8_input07<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
    dp_id: 118<br />
    bind_binary_sensor_id: f8_input08<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 15<br />
    pin: <br />
      number: 14<br />
      inverted:  false<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 0<br />
<br />
sensor:<br />
  - platform: adc<br />
    pin: 5<br />
    name: "f8 A1 Voltage"<br />
    update_interval: 5s<br />
    attenuation: 11db<br />
    filters:<br />
      - lambda:<br />
          if (x &gt;= 3.11) {<br />
            return x * 1.60256;<br />
          } else if (x &lt;= 0.15) {<br />
            return 0;<br />
          } else {<br />
            return x * 1.51;<br />
          }<br />
    pin: 7<br />
    name: "f8 A2 Voltage"<br />
    filters:<br />
      # - multiply: 1.51515<br />
      - lambda:<br />
            return 0;<br />
          } else {<br />
          }<br />
    pin: 6<br />
    name: "f8 A3 Current"<br />
    unit_of_measurement: mA<br />
    filters:<br />
      - multiply: 6.66666666<br />
    pin: 4<br />
    name: "f8 A4 Current"<br />
    filters:<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    i2c_id: bus_a<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 0, id(roboto), "KinCony f8");</code></div></div>esphome yaml:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10301" target="_blank" title="">F8-HA-tuya.txt</a> (Size: 8.68 KB / Downloads: 127)
esp32:<br />
  framework:<br />
    type: arduino<br />
    <br />
<br />
  - source:<br />
      type: git<br />
      ref: v1.3.1<br />
<br />
<br />
api:<br />
  encryption:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
i2c:<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 16<br />
    rx_pin: 17<br />
<br />
<br />
<br />
switch:<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
    dp_id: 1<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
    dp_id: 2<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
    dp_id: 3<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
    dp_id: 4<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
    dp_id: 5<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
    dp_id: 6<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
    dp_id: 101<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
    dp_id: 102<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    dp_id: 111<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    dp_id: 112<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    dp_id: 113<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    dp_id: 114<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    dp_id: 115<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    dp_id: 116<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    dp_id: 117<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
    dp_id: 118<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 15<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 0<br />
<br />
sensor:<br />
    pin: 5<br />
    filters:<br />
      - lambda:<br />
            return 0;<br />
          } else {<br />
          }<br />
    pin: 7<br />
    filters:<br />
      - lambda:<br />
            return 0;<br />
          } else {<br />
          }<br />
    pin: 6<br />
    filters:<br />
    pin: 4<br />
    filters:<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
		<item>
			<title><![CDATA[KinCony F8 + ESPHome: Unable to Enter Tuya Pairing Mode (Smart Config)]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9709</link>
			<pubDate>Sat, 01 Aug 2026 19:49:35 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11347">gdidonato</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9709</guid>
			<description><![CDATA[Hi!<br />
<br />
I'm trying to pair a KinCony F8 device with my Tuya account. I flashed it with an ESPHome firmware, and it is working perfectly with Home Assistant.<br />
<br />
Now I'd like to add Tuya connectivity. Based on the example code shared in this forum, I installed the firmware on my device, but I can't get it to enter pairing mode.<br />
<br />
One thing that seems unusual is that the Tuya module never appears to complete its initialization. As shown in the attached ESPHome logs, the message <span style="font-weight: bold;" class="mycode_b">"begin smart config"</span> is printed repeatedly about <span style="font-weight: bold;" class="mycode_b">every 50 ms</span>, making it look as if the module is continuously trying to enter Smart Config instead of staying in pairing mode. Could this indicate that the Tuya module is not responding correctly or that I'm missing an initialization step?<br />
<br />
I've attached the ESPHome firmware and the ESPHome logs.<br />
<br />
I would really appreciate your help identifying what I'm doing wrong and how to get it working.<br />
<br />
Thank you very much!<br />
Guillermo<br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10299" target="_blank" title="">test-logs.txt</a> (Size: 6.34 KB / Downloads: 158)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10300" target="_blank" title="">Kincony-F8-ESPHome-Tuya.txt</a> (Size: 4.14 KB / Downloads: 102)
			<content:encoded><![CDATA[Hi!<br />
<br />
<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[F8 Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9265</link>
			<pubDate>Sun, 19 Apr 2026 15:42:46 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9265</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9647" target="_blank" title="">F8_wiring.jpg</a> (Size: 335 KB / Downloads: 382)
		</item>
		<item>
			<title><![CDATA[F8 Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9264</link>
			<pubDate>Sun, 19 Apr 2026 15:41:51 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9264</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9646" target="_blank" title="">KinCony-F8-smart-controller-diagram.png</a> (Size: 792.15 KB / Downloads: 392)
		</item>
		<item>
			<title><![CDATA[F8 on device physical switches in ESPHome]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9120</link>
			<pubDate>Sun, 15 Mar 2026 04:07:51 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=8693">Vinceken</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9120</guid>
			<description><![CDATA[Hi - with esp-idf in ESPHome, how can I access the state of the physical on device switches?<br />
<br />
I can't seem to observe those on any GPIO pins.<br />
<br />
I would like to configure (in esphome) some of them to control their output relay directly, but for others for them to act as momentary switches. I can manage all the coding myself if I can work out where to observe their state...<br />
<br />
Thanks.]]></description>
			<content:encoded><![CDATA[Hi - with esp-idf in ESPHome, how can I access the state of the physical on device switches?<br />
<br />
<br />
<br />
Thanks.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[F8 N16R8]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8973</link>
			<pubDate>Fri, 30 Jan 2026 20:15:03 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7115">kulibin</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8973</guid>
			<description><![CDATA[Hi Gerarding model F8 N16R8 . There are have UART pin ?]]></description>
			<content:encoded><![CDATA[Hi Gerarding model F8 N16R8 . There are have UART pin ?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[F8 physical on device switches]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8904</link>
			<pubDate>Mon, 12 Jan 2026 18:54:34 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10215">asalhi</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8904</guid>
			<description><![CDATA[Hello KinCony,<br />
<br />
I have a question about the physical switch exists on the device itself, I need to be able to change their behavior to toggle switch instead of normal switch. I mean to toggle the relay state (on -&gt; off, or off -&gt; on) once it is flipped.<br />
<br />
btw, thank your for such awesome devices.]]></description>
			<content:encoded><![CDATA[Hello KinCony,<br />
<br />
<br />
btw, thank your for such awesome devices.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Delay Relay F8]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8579</link>
			<pubDate>Wed, 24 Sep 2025 14:13:35 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9281">abbasgts</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8579</guid>
			<description><![CDATA[<span style="font-size: 1pt;" class="mycode_size"><span style="font-family: Monaco, Consolas, Courier, monospace;" class="mycode_font">Pin Definitions:</span></span><br />
<span style="font-size: medium;" class="mycode_size">Subject: Request: Sequential 8-relay example for F8 (ESP32-S3), 1.5s step, reverse on shutdown<br />
</span><br />
<br />
<span style="font-size: medium;" class="mycode_size">Message:</span><br />
<span style="font-size: medium;" class="mycode_size">Hello KinCony team,</span><br />
<br />
<span style="font-size: medium;" class="mycode_size">I am using the KinCony F8 (ESP32-S3) board with the PCF8575 I/O expander to control 8 relays. I would like to have an Arduino example that performs the following:</span><br />
<span style="font-size: medium;" class="mycode_size">  •  Sequential ON: Relay1 → Relay8, with 1.5 seconds delay between each relay.</span><br />
<span style="font-size: medium;" class="mycode_size">  •  Sequential OFF: Relay8 → Relay1, with the same 1.5 seconds delay.</span><br />
<span style="font-size: medium;" class="mycode_size">  •  Arduino IDE, using I2C with SDA = GPIO8, SCL = GPIO18, and PCF8575 address = 0x24 (please confirm).</span><br />
<br />
<span style="font-size: medium;" class="mycode_size">My questions are:</span><br />
<span style="font-size: medium;" class="mycode_size">1. What is the exact GPIO mapping for each relay on the F8 hardware revision?</span><br />
<span style="font-size: medium;" class="mycode_size">2. Do you have an official Arduino example implementing this sequence?</span><br />
<span style="font-size: medium;" class="mycode_size">3. If there is a recommended library or header file for this board, could you please share the link?</span><br />
<br />
<span style="font-size: medium;" class="mycode_size">Here is a sample code I tested so far (for reference):</span><br />
<span style="font-size: medium;" class="mycode_size"><span style="font-family: Monaco, Consolas, Courier, monospace;" class="mycode_font">// I2C pins</span></span><br />
<span style="font-size: 1pt;" class="mycode_size"><span style="font-family: Monaco, Consolas, Courier, monospace;" class="mycode_font">#define SDA 8</span></span><br />
<span style="font-size: 1pt;" class="mycode_size"><span style="font-family: Monaco, Consolas, Courier, monospace;" class="mycode_font">#define SCL 18</span></span><br />
#include &lt;Wire.h&gt;<br />
#include &lt;PCF8575.h&gt;<br />
<br />
#define I2C_SDA 8<br />
#define I2C_SCL 18<br />
#define PCF8575_ADDR 0x24<br />
<br />
PCF8575 pcf(PCF8575_ADDR);<br />
const uint8_t RELAY_PINS[8] = {P0, P1, P2, P3, P4, P5, P6, P7};<br />
<br />
void setup() {<br />
  Serial.begin(115200);<br />
  if (!pcf.begin(I2C_SDA, I2C_SCL)) {<br />
    Serial.println("PCF8575 not found!");<br />
    while (1);<br />
  }<br />
    pcf.write(RELAY_PINS[i], HIGH);  // OFF at start<br />
  }<br />
}<br />
<br />
void loop() {<br />
  // Sequential ON<br />
    Serial.print("Relay ON: "); Serial.println(i+1);<br />
    pcf.write(RELAY_PINS[i], LOW);<br />
    delay(1500);<br />
  }<br />
<br />
  // Sequential OFF<br />
  for (int i = 7; i &gt;= 0; i--) {<br />
    Serial.print("Relay OFF: "); Serial.println(i+1);<br />
    pcf.write(RELAY_PINS[i], HIGH);<br />
    delay(1500);<br />
  }<br />
}]]></description>
			<content:encoded><![CDATA[<span style="font-size: 1pt;" class="mycode_size"><span style="font-family: Monaco, Consolas, Courier, monospace;" class="mycode_font">Pin Definitions:</span></span><br />
</span><br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    while (1);<br />
  }<br />
  }<br />
}<br />
<br />
void loop() {<br />
    delay(1500);<br />
  }<br />
<br />
    delay(1500);<br />
  }<br />
}]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-11 Digital input trigger relay output]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7995</link>
			<pubDate>Sun, 20 Apr 2025 15:28:23 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7995</guid>
 *<br />
 * This program reads 8 input states from a PCF8575 I/O expander and <br />
 * controls a corresponding 8-channel relay module. When an input pin <br />
 * is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 *<br />
 * Pin Definitions:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 * - PCF8575 I2C Address: 0x24<br />
 */<br />
<br />
<br />
// I2C pins<br />
#define SDA 8<br />
#define SCL 18<br />
<br />
// PCF8575 I2C address<br />
#define INPUT_I2C_ADDRESS 0x24 &nbsp;&nbsp;<br />
<br />
// Create PCF8575 object<br />
PCF8575 pcf8575_IN(INPUT_I2C_ADDRESS);<br />
<br />
  Wire.begin(SDA, SCL);<br />
<br />
  <br />
  // Initialize PCF8575<br />
  pcf8575_IN.begin();<br />
<br />
  // Turn off all relays first (assuming LOW activates the relay)<br />
  for (int i = 8; i &lt; 16; i++) {<br />
    pcf8575_IN.write(i, HIGH);  // Set to HIGH to turn off the relay<br />
  }<br />
<br />
  Serial.println("System started: Input state controlling 8 relays");<br />
}<br />
<br />
void loop() {<br />
  // Read 16-bit state from PCF8575<br />
  uint16_t inputState = pcf8575_IN.read16(); <br />
<br />
    bool state = bitRead(inputState, i); // Read digital input state<br />
<br />
    Serial.print("DI");<br />
    Serial.print(i + 1);<br />
    Serial.print(" State: ");<br />
    Serial.println(state ? "HIGH" : "LOW");<br />
<br />
    // Control relay (LOW activates the relay)<br />
    pcf8575_IN.write(8 + i, state ? HIGH : LOW);<br />
  }<br />
<br />
  Serial.println("---------------------");<br />
  delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7521" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 898 bytes / Downloads: 727)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7522" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 189.63 KB / Downloads: 690)
 *<br />
 *<br />
 */<br />
<br />
<br />
// I2C pins<br />
#define SDA 8<br />
<br />
<br />
<br />
<br />
  <br />
<br />
  }<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
<br />
  }<br />
<br />
  delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7994</link>
			<pubDate>Sun, 20 Apr 2025 15:21:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7994</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7519" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 682)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7520" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 201.24 KB / Downloads: 687)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7993</link>
			<pubDate>Sun, 20 Apr 2025 15:19:19 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7993</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 39<br />
#define RXD_PIN 38<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7517" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 745)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7518" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 184.92 KB / Downloads: 761)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7992</link>
			<pubDate>Sun, 20 Apr 2025 15:17:36 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7992</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CS_PIN  41<br />
#define W5500_RST_PIN 1<br />
#define W5500_INT_PIN 2<br />
#define W5500_CLK_PIN 42<br />
#define W5500_MOSI_PIN 43<br />
#define W5500_MISO_PIN 44<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7515" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 693)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7516" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 188.93 KB / Downloads: 707)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7991</link>
			<pubDate>Sun, 20 Apr 2025 15:15:16 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7991</guid>
 *<br />
 *<br />
 *<br />
 * Hardware Connections:<br />
 */<br />
<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7513" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.51 KB / Downloads: 688)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7514" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 191.08 KB / Downloads: 707)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7990</link>
			<pubDate>Sun, 20 Apr 2025 15:13:57 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7990</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7511" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 682)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7512" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 221.25 KB / Downloads: 681)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F8]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=7989</link>
			<pubDate>Sun, 20 Apr 2025 15:12:37 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=7989</guid>
			<description><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>/**<br />
 * @brief Example to read multiple digital inputs using ESP32<br />
 * @details This program reads the states of GPIO48, GPIO47, GPIO21, GPIO15, GPIO14, and GPIO40<br />
 *          and prints the results to the Serial Monitor.<br />
 *<br />
 */<br />
<br />
// Define the GPIO pins for digital inputs<br />
#define INPUT1_PIN 48  // GPIO48<br />
#define INPUT2_PIN 47  // GPIO47<br />
#define INPUT3_PIN 21  // GPIO21<br />
#define INPUT4_PIN 15  // GPIO15<br />
#define INPUT5_PIN 14  // GPIO14<br />
#define INPUT6_PIN 40  // GPIO40<br />
#define INPUT7_PIN 0  // GPIO0<br />
<br />
    // Initialize the serial communication for debugging<br />
    Serial.println("ESP32 Digital Input Read Example");<br />
<br />
    // Set the input pins as INPUT<br />
    pinMode(INPUT1_PIN, INPUT);<br />
    pinMode(INPUT2_PIN, INPUT);<br />
    pinMode(INPUT3_PIN, INPUT);<br />
    pinMode(INPUT4_PIN, INPUT);<br />
    pinMode(INPUT5_PIN, INPUT);<br />
    pinMode(INPUT6_PIN, INPUT);<br />
    pinMode(INPUT7_PIN, INPUT);<br />
}<br />
<br />
void loop() {<br />
    // Read the state of the digital inputs<br />
    int state1 = digitalRead(INPUT1_PIN);<br />
    int state2 = digitalRead(INPUT2_PIN);<br />
    int state3 = digitalRead(INPUT3_PIN);<br />
    int state4 = digitalRead(INPUT4_PIN);<br />
    int state5 = digitalRead(INPUT5_PIN);<br />
    int state6 = digitalRead(INPUT6_PIN);<br />
    int state7 = digitalRead(INPUT7_PIN);<br />
<br />
    // Print the states to the Serial Monitor<br />
    Serial.print("GPIO48 State: ");<br />
    Serial.println(state1);<br />
    Serial.print("GPIO47 State: ");<br />
    Serial.println(state2);<br />
    Serial.print("GPIO21 State: ");<br />
    Serial.println(state3);<br />
    Serial.print("GPIO15 State: ");<br />
    Serial.println(state4);<br />
    Serial.print("GPIO14 State: ");<br />
    Serial.println(state5);<br />
    Serial.print("GPIO40 State: ");<br />
    Serial.println(state6);<br />
    Serial.print("GPIO0 State: ");<br />
    Serial.println(state7);<br />
    // Wait for 500 milliseconds before reading again<br />
    delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7509" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 780 bytes / Downloads: 683)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7510" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 179.5 KB / Downloads: 692)
			<content:encoded><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>/**<br />
 *<br />
 */<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
    delay(500);<br />
		</item>
	</channel>
</rss>
