	<channel>
		<title><![CDATA[Smart Home Automation Forum - B8M]]></title>
		<pubDate>Tue, 03 Nov 2026 03:47:13 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[B8M Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9251</link>
			<pubDate>Sat, 18 Apr 2026 10:36:41 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9251</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9643" target="_blank" title="">B8M_wiring.jpg</a> (Size: 286.01 KB / Downloads: 369)
		</item>
		<item>
			<title><![CDATA[B8M Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9250</link>
			<pubDate>Sat, 18 Apr 2026 10:35:53 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9250</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9623" target="_blank" title="">KinCony-B8M-smart-controller-diagram.png</a> (Size: 804.64 KB / Downloads: 310)
		</item>
		<item>
			<title><![CDATA[B8M Schematic]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8945</link>
			<pubDate>Fri, 16 Jan 2026 02:41:19 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10236">mikkojay</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8945</guid>
<br />
Is the schematic diagram available for the B8M?<br />
I am specifically looking to see if the INT pin 1 of the PCF8575 is connected to anything.<br />
I have used the PCF8575 IC in other applications, and prefer to use the interrupt when possible.<br />
<br />
Thank You]]></description>
<br />
<br />
Thank You]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Digital Input B8M Voltage Range?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8594</link>
			<pubDate>Thu, 02 Oct 2025 01:02:19 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9244">coconut</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8594</guid>
is it ok to directly attach 14V Signals (from car) to the digital inputs of B8M? If not, can I reduce the signal with a voltage-divider to &lt;5V and then attach to DI1-8?<br />
Thanks from switzerland!]]></description>
Thanks from switzerland!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-11 digital INPUT trigger OUTPUT directly]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8221</link>
			<pubDate>Sat, 21 Jun 2025 12:03:23 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8221</guid>
 *<br />
 * This program reads 16 input states from a PCF8575 I/O expander and <br />
 * controls a corresponding 16-channel relay module. When an input pin <br />
 * is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 * When the input pin is HIGH, the corresponding relay is turned OFF.<br />
 *<br />
 * Pin Definitions:<br />
 * - SDA: GPIO 38<br />
 * - SCL: GPIO 39<br />
 * - Input I2C Address: 0x24<br />
 * - Relay I2C Address: 0x25<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Library to control the PCF8575 I/O expander<br />
<br />
// Define I2C pins<br />
#define SDA 8         &nbsp;&nbsp;// SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// SCL pin<br />
<br />
// I2C addresses<br />
<br />
#define RELAY_I2C_ADDRESS 0x22 &nbsp;&nbsp;// I2C address for the relay PCF8575 module<br />
<br />
<br />
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575<br />
<br />
void setup() {<br />
  Wire.begin(SDA, SCL);<br />
  <br />
  Serial.begin(115200);<br />
  <br />
  // Initialize input and relay modules<br />
<br />
  pcf8575_RL.begin();<br />
  <br />
  // Turn off all relays at the start<br />
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially<br />
  }<br />
  <br />
  Serial.println("System started: Input state controlling 8 relays");<br />
}<br />
<br />
void loop() {<br />
  uint16_t inputState = 0;<br />
<br />
  // Read the state of 16 inputs<br />
  for (int i = 8; i &lt; 16; i++) {<br />
    if (pcf8575_RL.read(i)) {<br />
      inputState |= (1 &lt;&lt; i);  // If input is HIGH, set the corresponding bit<br />
    } else {<br />
      inputState &amp;= ~(1 &lt;&lt; i); // Otherwise, clear the corresponding bit<br />
    }<br />
  }<br />
  <br />
  // Control the relays based on the input state<br />
    if (inputState &amp; (1 &lt;&lt; i+8)) {<br />
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the relay OFF<br />
    } else {<br />
      pcf8575_RL.write(i, LOW); &nbsp;&nbsp;// If input is LOW, turn the relay ON<br />
    }<br />
  }<br />
<br />
  // Delay for 500 milliseconds<br />
  delay(500);<br />
}</code></div></div> arduino ino file download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7800" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 1,018 bytes / Downloads: 735)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7801" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 189.37 KB / Downloads: 702)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
  <br />
  <br />
<br />
  <br />
  }<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
    } else {<br />
    }<br />
  }<br />
  <br />
    } else {<br />
    }<br />
  }<br />
<br />
  delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8220</link>
			<pubDate>Sat, 21 Jun 2025 12:01:58 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8220</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7798" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 688)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7799" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 201.24 KB / Downloads: 683)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8219</link>
			<pubDate>Sat, 21 Jun 2025 12:00:46 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8219</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 16<br />
#define RXD_PIN 17<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7796" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 694)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7797" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 184.92 KB / Downloads: 688)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8218</link>
			<pubDate>Sat, 21 Jun 2025 11:59:20 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8218</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7794" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 644)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7795" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 188.94 KB / Downloads: 712)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8217</link>
			<pubDate>Sat, 21 Jun 2025 11:58:07 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8217</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7792" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 672)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7793" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 191.08 KB / Downloads: 698)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8216</link>
			<pubDate>Sat, 21 Jun 2025 11:56:46 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8216</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7790" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 671)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7791" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 221.25 KB / Downloads: 666)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8215</link>
			<pubDate>Sat, 21 Jun 2025 11:55:26 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8215</guid>
 * ESP32 GPIO State Reader<br />
 * Reads the state of GPIO47, GPIO48, GPIO7, GPIO40, GPIO0, and GPIO5<br />
 * and prints the results to the serial monitor.<br />
 * <br />
 */<br />
<br />
#define GPIO_13  13<br />
#define GPIO_40  40<br />
#define GPIO_14  14<br />
#define GPIO_48  48<br />
#define GPIO_0 &nbsp;&nbsp;0<br />
#define GPIO_47  47<br />
#define GPIO_7  7<br />
#define GPIO_21  21<br />
<br />
<br />
    Serial.begin(115200); // Initialize serial communication at 115200 baud rate<br />
    <br />
    // Set GPIOs as input<br />
    pinMode(GPIO_13, INPUT);<br />
    pinMode(GPIO_40, INPUT);<br />
    pinMode(GPIO_14, INPUT);<br />
    pinMode(GPIO_48, INPUT);<br />
    pinMode(GPIO_0, INPUT);<br />
    pinMode(GPIO_47, INPUT);<br />
    pinMode(GPIO_7, INPUT);<br />
    pinMode(GPIO_21, INPUT);            <br />
}<br />
<br />
void loop() {<br />
    // Read GPIO states<br />
    int state_13 = digitalRead(GPIO_13);<br />
    int state_40 = digitalRead(GPIO_40);<br />
    int state_14  = digitalRead(GPIO_14);<br />
    int state_48 = digitalRead(GPIO_48);<br />
    int state_0  = digitalRead(GPIO_0);<br />
    int state_47 = digitalRead(GPIO_47);<br />
    int state_7 = digitalRead(GPIO_7);<br />
    int state_21 = digitalRead(GPIO_21);<br />
<br />
    // Print GPIO states to the serial monitor<br />
    Serial.printf("GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO0: %d, GPIO47: %d, GPIO7: %d, GPIO21: %d&#92;n",<br />
                  state_13, state_40, state_14, state_48, state_0, state_47, state_7, state_21);<br />
    <br />
    delay(1000); // Read GPIO states every second<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7788" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 682 bytes / Downloads: 713)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7789" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 179.41 KB / Downloads: 677)
 * <br />
 */<br />
<br />
<br />
<br />
    <br />
}<br />
<br />
void loop() {<br />
<br />
    <br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8214</link>
			<pubDate>Sat, 21 Jun 2025 11:54:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8214</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B8M!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7786" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 664)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7787" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 184.35 KB / Downloads: 693)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8213</link>
			<pubDate>Sat, 21 Jun 2025 11:52:42 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8213</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18  <br />
<br />
<br />
void setup(void) <br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7784" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 647)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7785" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 190.05 KB / Downloads: 630)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8212</link>
			<pubDate>Sat, 21 Jun 2025 11:51:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8212</guid>
 *<br />
 * Description:<br />
 * This Arduino program reads the state of a 16-channel PCF8575 I/O expander<br />
 * and prints the state of all input pins to the Serial Monitor. The state of <br />
 * each pin is represented as a bit in a 16-bit value, where each bit corresponds <br />
 * to an input pin. The program prints the input state in binary format.<br />
 *<br />
 * - PCF8575 I2C Address: 0x22<br />
 */<br />
<br />
#include "Arduino.h"<br />
#include "PCF8575.h"<br />
<br />
<br />
// Set I2C address<br />
PCF8575 pcf8575_IN1(0x22); // The I2C address of the PCF8575<br />
<br />
<br />
<br />
    pcf8575_IN1.begin(); // Initialize the PCF8575<br />
<br />
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");<br />
}<br />
<br />
void loop() {<br />
    uint16_t state = 0;<br />
<br />
    // Read the state of each pin (assuming 16 pins)<br />
    for (int pin = 8; pin &lt; 16; pin++) {<br />
        if (pcf8575_IN1.read(pin)) {<br />
            state |= (1 &lt;&lt; pin); // Set the bit for the active pin<br />
        }<br />
    }<br />
<br />
    Serial.println(state, BIN); // Print the state of inputs in binary<br />
<br />
    delay(500); // Delay 500ms<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7782" target="_blank" title="">2-digital-input.zip</a> (Size: 839 bytes / Downloads: 667)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7783" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 189.5 KB / Downloads: 672)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
    }<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8M]-01 Turn ON/OFF OUTPUT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8211</link>
			<pubDate>Sat, 21 Jun 2025 11:49:44 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8211</guid>
 *<br />
 * This program controls a 16-channel relay board via a PCF8575 I/O expander.<br />
 * It sequentially turns on each relay and then turns them off in a loop.<br />
 * <br />
 * <br />
 * Delay Time:<br />
 * - 200 milliseconds between switching relays<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // Include the Wire library for I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Include the PCF8575 library to control the I/O expander<br />
<br />
#define SDA 8         &nbsp;&nbsp;// Define the SDA pin<br />
#define SCL 18          // Define the SCL pin<br />
#define DELAY_TIME 200 &nbsp;&nbsp;// Define the delay time in milliseconds<br />
<br />
// Set I2C address of the PCF8575 module<br />
#define I2C_ADDRESS 0x22 // I2C address of the PCF8575 module<br />
<br />
PCF8575 pcf8575_R1(I2C_ADDRESS); // Create a PCF8575 object with the specified I2C address<br />
<br />
  Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)<br />
  <br />
  // Initialize serial communication for debugging (optional)<br />
  Serial.println("PCF8575 Relay Control: Starting...");<br />
<br />
  // Initialize the PCF8575 module<br />
  pcf8575_R1.begin();<br />
<br />
  // Turn off all relays initially (set all pins HIGH)<br />
    pcf8575_R1.write(i, HIGH); // Set all relays to OFF (assuming HIGH means OFF for relays)<br />
  }<br />
}<br />
<br />
void loop() {<br />
  // Sequentially turn on each relay<br />
    pcf8575_R1.write(i, LOW); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
    delay(DELAY_TIME);          // Wait for DELAY_TIME milliseconds<br />
  }<br />
<br />
  // Sequentially turn off each relay<br />
    pcf8575_R1.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7780" target="_blank" title="">1-output.zip</a> (Size: 925 bytes / Downloads: 671)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7781" target="_blank" title="">1-output.ino.merged.zip</a> (Size: 189.23 KB / Downloads: 641)
 *<br />
 * <br />
 * <br />
 * Delay Time:<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
<br />
<br />
  }<br />
}<br />
<br />
void loop() {<br />
  }<br />
<br />
  }<br />
		</item>
	</channel>
</rss>
