	<channel>
		<title><![CDATA[Smart Home Automation Forum - B8]]></title>
		<pubDate>Mon, 16 Nov 2026 04:22:35 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[B8 – Defective screw terminals and compatible 8-pin pluggable terminal]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9919</link>
			<pubDate>Wed, 28 Oct 2026 20:18:59 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=12228">chrisbati</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9919</guid>
<br />
I recently purchased a <span style="font-weight: bold;" class="mycode_b">KinCony B8 Smart Controller</span> and I'm experiencing a problem with the green screw terminal blocks used for the relay outputs (KA1–KA8 / KB1–KB8).<br />
When tightening a wire, the screw initially starts to grip, but the wire is not yet securely held. If I tighten it slightly more, the screw suddenly loses its grip and spins freely without tightening the wire anymore.<br />
<br />
I have already experienced this problem on several terminals out of the five I have tested.<br />
<br />
Since these terminals will be used to control <span style="font-weight: bold;" class="mycode_b">230 V AC lighting circuits</span>, I don't want to risk loose connections or overheating.<br />
<br />
I would appreciate your advice on the following questions:<br />
<ol type="1" class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">Is this a known issue with the KinCony B8 terminal blocks?</span> Is there a recommended solution?<br />
</li>
<li>Are the KA/KB terminal blocks soldered directly to the PCB, or can they be removed and replaced without soldering?<br />
</li>
<li>Is it possible to replace them with <span style="font-weight: bold;" class="mycode_b">8-pin pluggable screw terminal blocks</span>, so that the wiring can be disconnected more easily?<br />
</li>
<li>If so, could you provide the <span style="font-weight: bold;" class="mycode_b">exact compatible part number</span>, including the pitch (5.0 mm, 5.08 mm or another size), and where I can purchase these connectors?<br />
</li>
<li>If replacement requires soldering, is there another solution, such as obtaining a replacement board or having the unit replaced under warranty?<br />
</li>
</ol>
<span style="font-weight: bold;" class="mycode_b"><br />
<br />
Please note that I have no electronics or soldering experience.</span> I am comfortable with electrical wiring, but I cannot modify or solder components on a PCB myself.<br />
Ideally, I am looking for a simple, safe and reliable solution that does not require any electronics work.<br />
<br />
Thank you in advance for your help!]]></description>
<br />
<br />
<br />
<br />
</li>
</li>
</li>
</li>
</li>
</ol>
<br />
<br />
Thank you in advance for your help!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[B8 ADS1115 current inputs]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9705</link>
			<pubDate>Wed, 29 Jul 2026 02:12:02 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11326">jw1971</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9705</guid>
<br />
I am using Analog 1 and 2 for voltage inputs (A0_gnd and A1_gnd on the ADS1115) and these are working well.<br />
<br />
I am trying to add a 4-20ma sensor to Analog 3 or 4.  It is a 12VDC sensor with 2 wires.  Red to +12VDC power, and black to current sense.  This 12VDC supply is the same supply that powers the B8.<br />
<br />
The B8 on either Analog 3 or 4 doesn't show the current consumption - just sits at 1.49mA which is what it shows with nothing connected either.<br />
<br />
If I use a DMM on 20mA range between the black wire and 12VDC GND I get 9.9mA which is reasonable.<br />
<br />
Does the ADS1115 need some sort of ground bond to work in current mode?  What is the gnd return path for Analog 3 or 4?]]></description>
<br />
<br />
<br />
<br />
<br />
Does the ADS1115 need some sort of ground bond to work in current mode?  What is the gnd return path for Analog 3 or 4?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[B8 Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9249</link>
			<pubDate>Sat, 18 Apr 2026 10:34:41 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9249</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9642" target="_blank" title="">B8_wiring.jpg</a> (Size: 260.62 KB / Downloads: 380)
		</item>
		<item>
			<title><![CDATA[B8 Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9248</link>
			<pubDate>Sat, 18 Apr 2026 10:30:50 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9248</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9620" target="_blank" title="">KinCony-B8-smart-controller-diagram.png</a> (Size: 2.21 MB / Downloads: 421)
		</item>
		<item>
			<title><![CDATA[SHT30 temp/humidity i2c sensor to Kincony B8]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9148</link>
			<pubDate>Fri, 20 Mar 2026 17:13:14 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10598">zbarothi</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9148</guid>
<br />
I am trying to connect an SHT30 temperature and humidity i1c sensor to a Kincony B8 using free GPIOs 47 and 48. <a href="https://shop.kincony.com/products/sht30-temperature-and-humidity-sensor-probe-module-i2c-communication-cable" target="_blank" rel="noopener" class="mycode_url">https://shop.kincony.com/products/sht30-...tion-cable</a><br />
<br />
I have ESPHome firmware on the board with this config:<br />
<br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">i2c:<br />
<br />
  - id: bus_b<br />
    sda: GPIO47<br />
    scl: GPIO48<br />
    scan: true<br />
    frequency: 100kHz</span></span><br />
<br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">sensor:</span></span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">  - platform: sht3xd<br />
    i2c_id: bus_b<br />
    address: 0x44<br />
    update_interval: 60s<br />
    temperature:<br />
      device_class: "temperature"<br />
      state_class: "measurement"<br />
    humidity:<br />
      device_class: "humidity"<br />
      state_class: "measurement"</span></span><br />
<br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">I have tried many variations, switching the SDA and SCL etc but no luck. The device is not detected. Am I using the correct GPIOs?  (see attached photo)</span></span><br />
<br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">black -&gt; ground</span></span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">yellow -&gt; 47</span></span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">blueish green -&gt; 48</span></span><br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font">red -&gt; 3V</span></span><br />
<br />
<span style="color: #000000;" class="mycode_color"><span style="font-family: ui-monospace, SFMono-Regular, Menlo, Monaco, Consolas, 'Liberation Mono', 'Courier New', monospace, Consolas, 'Courier New', monospace;" class="mycode_font"><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9371" target="_blank" title="">20260319_164425.jpg</a> (Size: 402.11 KB / Downloads: 446)
<!-- end: postbit_attachments_attachment --> </span></span>]]></description>
<br />
<br />
<br />
<br />
  - id: bus_b<br />
    sda: GPIO47<br />
    scl: GPIO48<br />
    scan: true<br />
<br />
    i2c_id: bus_b<br />
    address: 0x44<br />
    temperature:<br />
    humidity:<br />
<br />
<br />
<br />
<!-- end: postbit_attachments_attachment --> </span></span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-11 digital INPUT trigger OUTPUT directly]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8237</link>
			<pubDate>Mon, 23 Jun 2025 13:02:04 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8237</guid>
 *<br />
 * This program reads 8 input states from a PCF8575 I/O expander and <br />
 * controls a corresponding 8-channel relay module. When an input pin <br />
 * is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 * When the input pin is HIGH, the corresponding relay is turned OFF.<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Library to control the PCF8575 I/O expander<br />
<br />
// Define I2C pins<br />
#define SDA 8         &nbsp;&nbsp;// SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// SCL pin<br />
<br />
// I2C addresses<br />
<br />
#define RELAY_I2C_ADDRESS 0x22 &nbsp;&nbsp;// I2C address for the relay PCF8575 module<br />
<br />
<br />
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575<br />
<br />
void setup() {<br />
  Wire.begin(SDA, SCL);<br />
  <br />
  Serial.begin(115200);<br />
  <br />
  // Initialize input and relay modules<br />
<br />
  pcf8575_RL.begin();<br />
  <br />
  // Turn off all relays at the start<br />
  for (int i = 8; i &lt; 16; i++) {<br />
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially<br />
  }<br />
  <br />
  Serial.println("System started: Input state controlling 8 relays");<br />
}<br />
<br />
void loop() {<br />
  uint16_t inputState = 0;<br />
<br />
  // Read the state of 16 inputs<br />
    if (pcf8575_RL.read(i)) {<br />
      inputState |= (1 &lt;&lt; i);  // If input is HIGH, set the corresponding bit<br />
    } else {<br />
      inputState &amp;= ~(1 &lt;&lt; i); // Otherwise, clear the corresponding bit<br />
    }<br />
  }<br />
  <br />
  // Control the relays based on the input state<br />
    if (inputState &amp; (1 &lt;&lt; i)) {<br />
      pcf8575_RL.write(i+8, HIGH);  // If input is HIGH, turn the relay OFF<br />
    } else {<br />
      pcf8575_RL.write(i+8, LOW); &nbsp;&nbsp;// If input is LOW, turn the relay ON<br />
    }<br />
  }<br />
<br />
  // Delay for 500 milliseconds<br />
  delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7828" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 968 bytes / Downloads: 758)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7829" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 192.21 KB / Downloads: 762)
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
  <br />
  <br />
<br />
  <br />
  }<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
    } else {<br />
    }<br />
  }<br />
  <br />
    } else {<br />
    }<br />
  }<br />
<br />
  delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8236</link>
			<pubDate>Mon, 23 Jun 2025 13:00:01 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8236</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7826" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 767)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7827" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 202.58 KB / Downloads: 670)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8235</link>
			<pubDate>Mon, 23 Jun 2025 12:58:36 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8235</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 16<br />
#define RXD_PIN 17<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7824" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 724)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7825" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 187.17 KB / Downloads: 748)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8234</link>
			<pubDate>Mon, 23 Jun 2025 12:56:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8234</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7822" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 778)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7823" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 191.06 KB / Downloads: 753)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8233</link>
			<pubDate>Mon, 23 Jun 2025 12:54:49 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8233</guid>
 *<br />
 *<br />
*<br />
 *<br />
 * Hardware Connections:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7820" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.56 KB / Downloads: 729)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7821" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 193.65 KB / Downloads: 676)
 *<br />
 *<br />
*<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8232</link>
			<pubDate>Mon, 23 Jun 2025 12:53:26 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8232</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7818" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 698)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7819" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 219.15 KB / Downloads: 699)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8231</link>
			<pubDate>Mon, 23 Jun 2025 12:48:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8231</guid>
 * ESP32 GPIO State Reader<br />
 * Reads the state of GPIO47, GPIO48, GPIO7, GPIO40, GPIO0, and GPIO5<br />
 * and prints the results to the serial monitor.<br />
 * <br />
 */<br />
<br />
#define GPIO_13  13<br />
#define GPIO_40  40<br />
#define GPIO_14  14<br />
#define GPIO_48  48<br />
#define GPIO_0 &nbsp;&nbsp;0<br />
#define GPIO_47  47<br />
#define GPIO_7  7<br />
#define GPIO_21  21<br />
<br />
<br />
    Serial.begin(115200); // Initialize serial communication at 115200 baud rate<br />
    <br />
    // Set GPIOs as input<br />
    pinMode(GPIO_13, INPUT);<br />
    pinMode(GPIO_40, INPUT);<br />
    pinMode(GPIO_14, INPUT);<br />
    pinMode(GPIO_48, INPUT);<br />
    pinMode(GPIO_0, INPUT);<br />
    pinMode(GPIO_47, INPUT);<br />
    pinMode(GPIO_7, INPUT);<br />
    pinMode(GPIO_21, INPUT);            <br />
}<br />
<br />
void loop() {<br />
    // Read GPIO states<br />
    int state_13 = digitalRead(GPIO_13);<br />
    int state_40 = digitalRead(GPIO_40);<br />
    int state_14  = digitalRead(GPIO_14);<br />
    int state_48 = digitalRead(GPIO_48);<br />
    int state_0  = digitalRead(GPIO_0);<br />
    int state_47 = digitalRead(GPIO_47);<br />
    int state_7 = digitalRead(GPIO_7);<br />
    int state_21 = digitalRead(GPIO_21);<br />
<br />
    // Print GPIO states to the serial monitor<br />
    Serial.printf("GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO0: %d, GPIO47: %d, GPIO7: %d, GPIO21: %d&#92;n",<br />
                  state_13, state_40, state_14, state_48, state_0, state_47, state_7, state_21);<br />
    <br />
    delay(1000); // Read GPIO states every second<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7816" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 682 bytes / Downloads: 718)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7817" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 181.54 KB / Downloads: 692)
 * <br />
 */<br />
<br />
<br />
<br />
    <br />
}<br />
<br />
void loop() {<br />
<br />
    <br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8230</link>
			<pubDate>Mon, 23 Jun 2025 12:43:46 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8230</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B8M!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7814" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 707)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7815" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 186.52 KB / Downloads: 686)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8229</link>
			<pubDate>Mon, 23 Jun 2025 12:40:28 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8229</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18  <br />
<br />
<br />
void setup(void) <br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7812" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 676)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7813" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 192.69 KB / Downloads: 724)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B8]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8228</link>
			<pubDate>Mon, 23 Jun 2025 12:36:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8228</guid>
 *<br />
 * Description:<br />
 * This Arduino program reads the state of a 16-channel PCF8575 I/O expander<br />
 * and prints the state of all input pins to the Serial Monitor. The state of <br />
 * each pin is represented as a bit in a 16-bit value, where each bit corresponds <br />
 * to an input pin. The program prints the input state in binary format.<br />
 *<br />
 * Pin Definitions:<br />
 * - PCF8575 I2C Address: 0x22<br />
 */<br />
<br />
#include "Arduino.h"<br />
#include "PCF8575.h"<br />
<br />
<br />
// Set I2C address<br />
PCF8575 pcf8575_IN1(0x22); // The I2C address of the PCF8575<br />
<br />
<br />
<br />
    pcf8575_IN1.begin(); // Initialize the PCF8575<br />
<br />
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");<br />
}<br />
<br />
void loop() {<br />
    uint16_t state = 0;<br />
<br />
    // Read the state of each pin (assuming 16 pins)<br />
    for (int pin = 0; pin &lt; 8; pin++) {<br />
        if (pcf8575_IN1.read(pin)) {<br />
            state |= (1 &lt;&lt; pin); // Set the bit for the active pin<br />
        }<br />
    }<br />
<br />
    Serial.println(state, BIN); // Print the state of inputs in binary<br />
<br />
    delay(500); // Delay 500ms<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7810" target="_blank" title="">2-digital-input.zip</a> (Size: 837 bytes / Downloads: 652)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=7811" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 192.29 KB / Downloads: 712)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
    }<br />
<br />
<br />
		</item>
	</channel>
</rss>
