	<channel>
		<title><![CDATA[Smart Home Automation Forum - B24]]></title>
		<pubDate>Sat, 07 Nov 2026 04:46:04 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[B24 Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9257</link>
			<pubDate>Sat, 18 Apr 2026 10:48:05 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9257</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9630" target="_blank" title="">B24_wiring.jpg</a> (Size: 186.87 KB / Downloads: 416)
		</item>
		<item>
			<title><![CDATA[B24 Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9256</link>
			<pubDate>Sat, 18 Apr 2026 10:47:28 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9256</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9629" target="_blank" title="">KinCony-B24-smart-controller-diagram.png</a> (Size: 1.04 MB / Downloads: 285)
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-11 digital INPUT trigger OUTPUT directly]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8372</link>
			<pubDate>Thu, 31 Jul 2025 15:08:05 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8372</guid>
 *<br />
 * This program reads 24 input states from two PCF8575 I/O expanders and <br />
 * controls a corresponding 24-channel relay module. <br />
 * When an input pin is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 * When the input pin is HIGH, the corresponding relay is turned OFF.<br />
 *<br />
 * Pin Definitions:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
 * - Input I2C Address 1 (inputs 1-16): 0x24<br />
 * - Input/Relay I2C Address 2 (inputs 17-24 and relays 1-8): 0x26<br />
 * - Relay I2C Address 3 (relays 9-24): 0x25<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Library to control the PCF8575 I/O expander<br />
<br />
// Define I2C pins<br />
#define SDA 8            // SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// SCL pin<br />
<br />
// I2C addresses for the PCF8575 modules<br />
#define INPUT_I2C_ADDRESS_1 0x22 &nbsp;&nbsp;// I2C address for the first input PCF8575 module (inputs 1-16)<br />
#define INPUT_RELAY_I2C_ADDRESS_2 0x25 &nbsp;&nbsp;// I2C address for inputs 17-24 and relays 1-8<br />
#define RELAY_I2C_ADDRESS_3 0x24 &nbsp;&nbsp;// I2C address for relays 9-24<br />
<br />
PCF8575 pcf8575_IN1(INPUT_I2C_ADDRESS_1);    // Create an object for the first input PCF8575 (inputs 1-16)<br />
PCF8575 pcf8575_IN2(INPUT_RELAY_I2C_ADDRESS_2);    // Create an object for the second input PCF8575 (inputs 17-24 and relays 1-8)<br />
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS_3);    // Create an object for the relay PCF8575 (relays 9-24)<br />
<br />
void setup() {<br />
  Wire.begin(SDA, SCL);<br />
  <br />
  Serial.begin(115200);<br />
  <br />
  // Initialize input and relay modules<br />
  pcf8575_IN1.begin();  // For inputs 1-16<br />
  pcf8575_IN2.begin();  // For inputs 17-24 and relays 1-8<br />
  pcf8575_RL.begin(); &nbsp;&nbsp;// For relays 9-24<br />
  <br />
  // Turn off all relays at the start (LOW means OFF)<br />
  for (int i = 8; i &lt; 16; i++) {<br />
    pcf8575_IN2.write(i, HIGH);  // Turn off relays 1-8<br />
  }<br />
  for (int i = 0; i &lt; 16; i++) {<br />
    pcf8575_RL.write(i, HIGH);  // Turn off relays 9-24<br />
  }<br />
<br />
  Serial.println("System started: Input state controlling 24 relays");<br />
}<br />
<br />
void loop() {<br />
<br />
if (pcf8575_IN1.read(8)==0) pcf8575_IN2.write(8, LOW); else pcf8575_IN2.write(8, HIGH);<br />
if (pcf8575_IN1.read(9)==0) pcf8575_IN2.write(9, LOW); else pcf8575_IN2.write(9, HIGH);<br />
if (pcf8575_IN1.read(10)==0) pcf8575_IN2.write(10, LOW); else pcf8575_IN2.write(10, HIGH);<br />
if (pcf8575_IN1.read(11)==0) pcf8575_IN2.write(11, LOW); else pcf8575_IN2.write(11, HIGH);<br />
if (pcf8575_IN1.read(12)==0) pcf8575_IN2.write(12, LOW); else pcf8575_IN2.write(12, HIGH);<br />
if (pcf8575_IN1.read(13)==0) pcf8575_IN2.write(13, LOW); else pcf8575_IN2.write(13, HIGH);<br />
if (pcf8575_IN1.read(14)==0) pcf8575_IN2.write(14, LOW); else pcf8575_IN2.write(14, HIGH);<br />
if (pcf8575_IN1.read(15)==0) pcf8575_IN2.write(15, LOW); else pcf8575_IN2.write(15, HIGH);<br />
<br />
if (pcf8575_IN1.read(0)==0) pcf8575_RL.write(0, LOW); else pcf8575_RL.write(0, HIGH);<br />
if (pcf8575_IN1.read(1)==0) pcf8575_RL.write(1, LOW); else pcf8575_RL.write(1, HIGH);<br />
if (pcf8575_IN1.read(2)==0) pcf8575_RL.write(2, LOW); else pcf8575_RL.write(2, HIGH);<br />
if (pcf8575_IN1.read(3)==0) pcf8575_RL.write(3, LOW); else pcf8575_RL.write(3, HIGH);<br />
if (pcf8575_IN1.read(4)==0) pcf8575_RL.write(4, LOW); else pcf8575_RL.write(4, HIGH);<br />
if (pcf8575_IN1.read(5)==0) pcf8575_RL.write(5, LOW); else pcf8575_RL.write(5, HIGH);<br />
if (pcf8575_IN1.read(6)==0) pcf8575_RL.write(6, LOW); else pcf8575_RL.write(6, HIGH);<br />
if (pcf8575_IN1.read(7)==0) pcf8575_RL.write(7, LOW); else pcf8575_RL.write(7, HIGH);<br />
<br />
if (pcf8575_IN2.read(0)==0) pcf8575_RL.write(8, LOW); else pcf8575_RL.write(8, HIGH);<br />
if (pcf8575_IN2.read(1)==0) pcf8575_RL.write(9, LOW); else pcf8575_RL.write(9, HIGH);<br />
if (pcf8575_IN2.read(2)==0) pcf8575_RL.write(10, LOW); else pcf8575_RL.write(10, HIGH);<br />
if (pcf8575_IN2.read(3)==0) pcf8575_RL.write(11, LOW); else pcf8575_RL.write(11, HIGH);<br />
if (pcf8575_IN2.read(4)==0) pcf8575_RL.write(12, LOW); else pcf8575_RL.write(12, HIGH);<br />
if (pcf8575_IN2.read(5)==0) pcf8575_RL.write(13, LOW); else pcf8575_RL.write(13, HIGH);<br />
if (pcf8575_IN2.read(6)==0) pcf8575_RL.write(14, LOW); else pcf8575_RL.write(14, HIGH);<br />
if (pcf8575_IN2.read(7)==0) pcf8575_RL.write(15, LOW); else pcf8575_RL.write(15, HIGH);<br />
  // Delay for 500 milliseconds<br />
  delay(200);<br />
}</code></div></div> arduino ino file download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8052" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 1.18 KB / Downloads: 649)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8053" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 192.44 KB / Downloads: 673)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
  <br />
  <br />
  }<br />
  }<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
<br />
  delay(200);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8373</link>
			<pubDate>Thu, 31 Jul 2025 15:06:51 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8373</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8054" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 638)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8055" target="_blank" title="">10-oled-ssd1306.ino.merged.zip</a> (Size: 202.58 KB / Downloads: 656)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8374</link>
			<pubDate>Thu, 31 Jul 2025 15:05:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8374</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 39<br />
#define RXD_PIN 38<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8056" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 673)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8057" target="_blank" title="">9-tuya-wifi-config.ino.merged.zip</a> (Size: 187.17 KB / Downloads: 684)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8375</link>
			<pubDate>Thu, 31 Jul 2025 15:04:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8375</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CLK_PIN 1<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8058" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 624)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8059" target="_blank" title="">8-Ethernet-W5500.ino.merged.zip</a> (Size: 191.07 KB / Downloads: 612)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8376</link>
			<pubDate>Thu, 31 Jul 2025 15:02:48 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8376</guid>
 *<br />
 *<br />
 *<br />
 * Hardware Connections:<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8060" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.51 KB / Downloads: 677)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8061" target="_blank" title="">7-DS3231-RTC.ino.merged.zip</a> (Size: 193.66 KB / Downloads: 643)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8377</link>
			<pubDate>Thu, 31 Jul 2025 15:01:25 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8377</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8062" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 692)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8063" target="_blank" title="">6-SD.ino.merged.zip</a> (Size: 219.14 KB / Downloads: 646)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8378</link>
			<pubDate>Thu, 31 Jul 2025 15:00:13 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8378</guid>
 *<br />
 * GPIO Status Monitoring<br />
 *<br />
 * This program monitors the status (high or low) of multiple GPIO pins on the ESP32-S3.<br />
 * It prints the status of the pins to the serial monitor whenever a change is detected.<br />
 *<br />
 * GPIO Pins Monitored:<br />
 * - GPIO 13<br />
 * - GPIO 14<br />
 * - GPIO 21<br />
 * - GPIO 40<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 7<br />
 *<br />
 * Hardware Requirements:<br />
 * - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing<br />
 */<br />
<br />
// Define the GPIO pins to be monitored<br />
#define GPIO_PIN_13 13<br />
#define GPIO_PIN_14 14<br />
#define GPIO_PIN_21 21<br />
#define GPIO_PIN_40 40<br />
#define GPIO_PIN_48 48<br />
#define GPIO_PIN_47 47<br />
#define GPIO_PIN_7 &nbsp;&nbsp;7<br />
<br />
// Create an array to hold the GPIO pin numbers<br />
const int monitoredPins[] = {<br />
  GPIO_PIN_13,<br />
  GPIO_PIN_14,<br />
  GPIO_PIN_21,<br />
  GPIO_PIN_40,<br />
  GPIO_PIN_48,<br />
  GPIO_PIN_47,<br />
  GPIO_PIN_7<br />
};<br />
<br />
const int pinCount = sizeof(monitoredPins) / sizeof(monitoredPins[0]);<br />
<br />
// Store the previous state of the GPIO pins<br />
bool prevState[pinCount] = {false};<br />
<br />
  Serial.begin(115200);     &nbsp;&nbsp;// Initialize the serial monitor<br />
  while (!Serial);            // Wait for serial monitor to open<br />
<br />
  // Set each monitored pin as input<br />
  for (int i = 0; i &lt; pinCount; i++) {<br />
    pinMode(monitoredPins[i], INPUT);<br />
  }<br />
<br />
  Serial.println("GPIO Status Monitoring Started");<br />
}<br />
<br />
void loop() {<br />
    bool currentState = digitalRead(monitoredPins[i]);<br />
    if (currentState != prevState[i]) {<br />
      Serial.print("GPIO ");<br />
      Serial.print(monitoredPins[i]);<br />
      Serial.print(" changed to ");<br />
      Serial.println(currentState ? "HIGH" : "LOW");<br />
      prevState[i] = currentState;<br />
    }<br />
  }<br />
<br />
  delay(100); // Delay to reduce serial flooding<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8064" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 924 bytes / Downloads: 650)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8065" target="_blank" title="">5-free-gpio-state.ino.merged.zip</a> (Size: 181.63 KB / Downloads: 605)
 *<br />
 *<br />
 *<br />
 * - GPIO 13<br />
 * - GPIO 14<br />
 * - GPIO 21<br />
 * - GPIO 40<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 7<br />
 *<br />
 */<br />
<br />
<br />
  GPIO_PIN_13,<br />
  GPIO_PIN_14,<br />
  GPIO_PIN_21,<br />
  GPIO_PIN_40,<br />
  GPIO_PIN_48,<br />
  GPIO_PIN_47,<br />
  GPIO_PIN_7<br />
};<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
}<br />
<br />
void loop() {<br />
    }<br />
  }<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8379</link>
			<pubDate>Thu, 31 Jul 2025 14:58:51 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8379</guid>
 *<br />
 *<br />
 * The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 38<br />
#define RS485_TXD 39<br />
<br />
<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony B24!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8066" target="_blank" title="">4-RS485-Test.zip</a> (Size: 764 bytes / Downloads: 609)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8067" target="_blank" title="">4-RS485-Test.ino.merged.zip</a> (Size: 186.53 KB / Downloads: 660)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-03 Read ADS1115 analog input ports value]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8380</link>
			<pubDate>Thu, 31 Jul 2025 14:57:22 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8380</guid>
 *<br />
 *<br />
 */<br />
<br />
<br />
#define SDA_PIN 8  <br />
#define SCL_PIN 18 <br />
<br />
<br />
void setup(void) <br />
{<br />
<br />
<br />
<br />
<br />
<br />
    ads.setRate(eRATE_128);<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
void loop(void) <br />
{<br />
    if (ads.checkADS1115())<br />
    {<br />
<br />
        Serial.print("A0:");<br />
        Serial.print(adc0);<br />
<br />
        Serial.print("A1:");<br />
        Serial.print(adc1);<br />
<br />
        Serial.print("A2:");<br />
        Serial.print(adc2);<br />
<br />
        Serial.print("A3:");<br />
        Serial.print(adc3);<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8068" target="_blank" title="">3-ads1115_adc.zip</a> (Size: 1.2 KB / Downloads: 696)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8069" target="_blank" title="">3-ads1115_adc.ino.merged.zip</a> (Size: 192.69 KB / Downloads: 677)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
{<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
    ads.init();<br />
}<br />
<br />
{<br />
    {<br />
<br />
<br />
<br />
<br />
    }<br />
    else<br />
    {<br />
    }<br />
<br />
    delay(1000);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8381</link>
			<pubDate>Thu, 31 Jul 2025 14:55:49 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8381</guid>
 *<br />
 * Description:<br />
 * This Arduino program reads the state of two 16-channel PCF8575 I/O expanders<br />
 * and prints the state of all input pins (1-24) to the Serial Monitor. <br />
 *<br />
 * - PCF8575 I2C Address: 0x22 for inputs 1-16, 0x25 for inputs 17-24<br />
 */<br />
<br />
#include "Arduino.h"<br />
#include "PCF8575.h"<br />
<br />
<br />
// Set I2C addresses<br />
PCF8575 pcf8575_IN1(0x22); // The I2C address of the first PCF8575 (inputs 1-16)<br />
PCF8575 pcf8575_IN2(0x25); // The I2C address of the second PCF8575 (inputs 17-24)<br />
<br />
<br />
<br />
    // Initialize both PCF8575 modules<br />
    pcf8575_IN1.begin();<br />
    pcf8575_IN2.begin();<br />
<br />
    Serial.println("KinCony B24 24 channel input state 0:ON  1:OFF");<br />
}<br />
<br />
void loop() {<br />
<br />
if (pcf8575_IN1.read(8)==0) {Serial.print("DI1 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(9)==0) {Serial.print("DI2 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(10)==0) {Serial.print("DI3 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(11)==0) {Serial.print("DI4 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(12)==0) {Serial.print("DI5 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(13)==0) {Serial.print("DI6 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(14)==0) {Serial.print("DI7 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(15)==0) {Serial.print("DI8 state="); Serial.println("on");}<br />
<br />
if (pcf8575_IN1.read(0)==0) {Serial.print("DI9 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(1)==0) {Serial.print("DI10 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(2)==0) {Serial.print("DI11 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(3)==0) {Serial.print("DI12 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(4)==0) {Serial.print("DI13 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(5)==0) {Serial.print("DI14 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(6)==0) {Serial.print("DI15 state="); Serial.println("on");}<br />
if (pcf8575_IN1.read(7)==0) {Serial.print("DI16 state="); Serial.println("on");}<br />
<br />
if (pcf8575_IN2.read(0)==0) {Serial.print("DI17 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(1)==0) {Serial.print("DI18 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(2)==0) {Serial.print("DI19 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(3)==0) {Serial.print("DI20 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(4)==0) {Serial.print("DI21 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(5)==0) {Serial.print("DI22 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(6)==0) {Serial.print("DI23 state="); Serial.println("on");}<br />
if (pcf8575_IN2.read(7)==0) {Serial.print("DI24 state="); Serial.println("on");}<br />
<br />
<br />
    delay(1000); // Delay 500ms<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8070" target="_blank" title="">2-digital-input.zip</a> (Size: 880 bytes / Downloads: 648)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8071" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 192.64 KB / Downloads: 632)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for B24]-01 Turn ON/OFF OUTPUT]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8382</link>
			<pubDate>Thu, 31 Jul 2025 14:54:11 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8382</guid>
 *<br />
 * This program controls a 24-channel relay board via two PCF8575 I/O expanders.<br />
 * It sequentially turns on each relay and then turns them off in a loop.<br />
 * <br />
 * <br />
 * Delay Time:<br />
 * - 200 milliseconds between switching relays<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // Include the Wire library for I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Include the PCF8575 library to control the I/O expander<br />
<br />
#define SDA 8            // Define the SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// Define the SCL pin<br />
#define DELAY_TIME 200 &nbsp;&nbsp;// Define the delay time in milliseconds<br />
<br />
// Set I2C addresses of the PCF8575 modules<br />
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module<br />
#define I2C_ADDRESS_R2 0x24 // I2C address of the second PCF8575 module<br />
<br />
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)<br />
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)<br />
<br />
  Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)<br />
  <br />
  // Initialize serial communication for debugging (optional)<br />
  Serial.println("PCF8575 Relay Control: Starting...");<br />
<br />
  // Initialize the PCF8575 modules<br />
  pcf8575_R1.begin();<br />
  pcf8575_R2.begin();<br />
<br />
  // Turn off all relays initially (set all pins HIGH)<br />
<br />
    pcf8575_R1.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)<br />
  }<br />
<br />
    pcf8575_R2.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)<br />
  }<br />
}<br />
<br />
void loop() {<br />
  // Sequentially turn on each relay (1-24)<br />
  <br />
  // First control the relays on the second PCF8575 (relays 1-8)<br />
    pcf8575_R1.write(i, LOW); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
    delay(DELAY_TIME);          // Wait for DELAY_TIME milliseconds<br />
  }<br />
<br />
  // Then control the relays on the first PCF8575 (relays 9-24)<br />
    pcf8575_R2.write(i, LOW); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
  }<br />
<br />
  // Sequentially turn off each relay (1-24)<br />
  <br />
    pcf8575_R1.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)<br />
  }<br />
<br />
    pcf8575_R2.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8072" target="_blank" title="">1-relay.zip</a> (Size: 1.01 KB / Downloads: 600)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8073" target="_blank" title="">1-relay.ino.merged.zip</a> (Size: 192.11 KB / Downloads: 634)
 *<br />
 * <br />
 * <br />
 * Delay Time:<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
<br />
<br />
<br />
  }<br />
<br />
  }<br />
}<br />
<br />
void loop() {<br />
  <br />
  }<br />
<br />
  }<br />
<br />
  <br />
  }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[B24 ESPHome yaml for home assistant without tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8383</link>
			<pubDate>Thu, 31 Jul 2025 14:52:26 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8383</guid>
  friendly_name: b24<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO1<br />
  mosi_pin: GPIO2<br />
  miso_pin: GPIO41<br />
  cs_pin: GPIO42<br />
  interrupt_pin: GPIO43<br />
  reset_pin: GPIO44<br />
<br />
uart:<br />
  - id: uart_1    #RS485<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 39<br />
    rx_pin: 38<br />
<br />
i2c:<br />
 &nbsp;&nbsp;- id: bus_a<br />
   &nbsp;&nbsp;sda: 8<br />
   &nbsp;&nbsp;scl: 18<br />
   &nbsp;&nbsp;scan: true<br />
<br />
pcf8574:<br />
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_in_out_1'  # for digital input channel 17-24 &amp; ouptut 1-8<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
binary_sensor:<br />
  - platform: gpio<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
      inverted: true<br />
<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      pcf8574: pcf8574_hub_in_out_1<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 7<br />
    pin: <br />
      number: 13<br />
      inverted: false<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 0<br />
<br />
switch:<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
ads1115:<br />
  - address: 0x48<br />
sensor:<br />
  - platform: ads1115<br />
    multiplexer: 'A0_GND'<br />
    gain: 6.144<br />
    resolution: 16_BITS<br />
    update_interval: 5s<br />
    multiplexer: 'A1_GND'<br />
    gain: 6.144<br />
    multiplexer: 'A2_GND'<br />
    gain: 6.144<br />
    multiplexer: 'A3_GND'<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    i2c_id: bus_a<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 0, id(roboto), "KinCony B24");</code></div></div> download yaml file: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8074" target="_blank" title="">B24-HA-without Tuya.txt</a> (Size: 10.92 KB / Downloads: 375)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 39<br />
    rx_pin: 38<br />
<br />
i2c:<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 7<br />
    pin: <br />
      number: 13<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 0<br />
<br />
switch:<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
		<item>
			<title><![CDATA[B24 ESPHome yaml for home assistant with tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8384</link>
			<pubDate>Thu, 31 Jul 2025 14:51:23 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8384</guid>
  platformio_options:<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
external_components:<br />
  - source:<br />
      type: git<br />
      ref: v1.1.0<br />
<br />
#logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 39<br />
    rx_pin: 38<br />
<br />
  - id: tuya_mcu_uart<br />
    tx_pin: GPIO16<br />
    rx_pin: GPIO17<br />
<br />
i2c:<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
tuya_wifi_mcu:<br />
  # tuya mcu product id<br />
  product_id: vyznobv3bahs2pwl<br />
  uart_id: tuya_mcu_uart<br />
  wifi_reset_pin: 28<br />
  wifi_led_pin: 16<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
    dp_id: 125<br />
    bind_binary_sensor_id: b24_input01<br />
    internal: true<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
    dp_id: 126<br />
    bind_binary_sensor_id: b24_input02<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
    dp_id: 127<br />
    bind_binary_sensor_id: b24_input03<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
    dp_id: 128<br />
    bind_binary_sensor_id: b24_input04<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
    dp_id: 129<br />
    bind_binary_sensor_id: b24_input05<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
    dp_id: 130<br />
    bind_binary_sensor_id: b24_input06<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
    dp_id: 131<br />
    bind_binary_sensor_id: b24_input07<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
    dp_id: 132<br />
    bind_binary_sensor_id: b24_input08<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    dp_id: 133<br />
    bind_binary_sensor_id: b24_input09<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    dp_id: 134<br />
    bind_binary_sensor_id: b24_input10<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    dp_id: 135<br />
    bind_binary_sensor_id: b24_input11<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    dp_id: 136<br />
    bind_binary_sensor_id: b24_input12<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    dp_id: 137<br />
    bind_binary_sensor_id: b24_input13<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    dp_id: 138<br />
    bind_binary_sensor_id: b24_input14<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    dp_id: 139<br />
    bind_binary_sensor_id: b24_input15<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
    dp_id: 140<br />
    bind_binary_sensor_id: b24_input16<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    dp_id: 141<br />
    bind_binary_sensor_id: b24_input17<br />
<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    dp_id: 142<br />
    bind_binary_sensor_id: b24_input18<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    dp_id: 143<br />
    bind_binary_sensor_id: b24_input19<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    dp_id: 144<br />
    bind_binary_sensor_id: b24_input20<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    dp_id: 145<br />
    bind_binary_sensor_id: b24_input21<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    dp_id: 146<br />
    bind_binary_sensor_id: b24_input22<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    dp_id: 147<br />
    bind_binary_sensor_id: b24_input23<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
    dp_id: 148<br />
    bind_binary_sensor_id: b24_input24<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 7<br />
    pin: <br />
      number: 13<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 0<br />
<br />
switch:<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
    dp_id: 101<br />
    # bind other switch, sync state<br />
    bind_switch_id: "b24_output01"<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
    dp_id: 102<br />
    bind_switch_id: "b24_output02"<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
    dp_id: 103<br />
    bind_switch_id: "b24_output03"<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
    dp_id: 104<br />
    bind_switch_id: "b24_output04"<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
    dp_id: 105<br />
    bind_switch_id: "b24_output05"<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
    dp_id: 106<br />
    bind_switch_id: "b24_output06"<br />
<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
    dp_id: 107<br />
    bind_switch_id: "b24_output07"<br />
<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
    dp_id: 108<br />
    bind_switch_id: "b24_output08"<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
    dp_id: 109<br />
    bind_switch_id: "b24_output09"<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
    dp_id: 110<br />
    bind_switch_id: "b24_output10"<br />
<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
    dp_id: 111<br />
    bind_switch_id: "b24_output11"<br />
<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
    dp_id: 112<br />
    bind_switch_id: "b24_output12"<br />
<br />
<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
    dp_id: 113<br />
    bind_switch_id: "b24_output13"<br />
<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
    dp_id: 114<br />
    bind_switch_id: "b24_output14"<br />
<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
    dp_id: 115<br />
    bind_switch_id: "b24_output15"<br />
<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
    dp_id: 116<br />
    bind_switch_id: "b24_output16"<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
    dp_id: 117<br />
    bind_switch_id: "b24_output17"<br />
<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
    dp_id: 118<br />
    bind_switch_id: "b24_output18"<br />
<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
    dp_id: 119<br />
    bind_switch_id: "b24_output19"<br />
<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
    dp_id: 120<br />
    bind_switch_id: "b24_output20"<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
    dp_id: 121<br />
    bind_switch_id: "b24_output21"<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
    dp_id: 122<br />
    bind_switch_id: "b24_output22"<br />
<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
    dp_id: 123<br />
    bind_switch_id: "b24_output23"<br />
<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
    dp_id: 124<br />
    bind_switch_id: "b24_output24"<br />
<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8075" target="_blank" title="">B24-HA-with-Tuya.txt</a> (Size: 19.26 KB / Downloads: 411)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
  - source:<br />
      type: git<br />
      ref: v1.1.0<br />
<br />
#logger:<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 39<br />
    rx_pin: 38<br />
<br />
<br />
i2c:<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x22<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
    dp_id: 125<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
    dp_id: 126<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
    dp_id: 127<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
    dp_id: 128<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
    dp_id: 129<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
    dp_id: 130<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
    dp_id: 131<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
    dp_id: 132<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    dp_id: 133<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    dp_id: 134<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    dp_id: 135<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    dp_id: 136<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    dp_id: 137<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    dp_id: 138<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    dp_id: 139<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
    dp_id: 140<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
    dp_id: 141<br />
<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
    dp_id: 142<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
    dp_id: 143<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
    dp_id: 144<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
    dp_id: 145<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
    dp_id: 146<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
    dp_id: 147<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
    dp_id: 148<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 40<br />
<br />
    pin: <br />
      number: 7<br />
    pin: <br />
      number: 13<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 0<br />
<br />
switch:<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
    dp_id: 101<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
    dp_id: 102<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
    dp_id: 103<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
    dp_id: 104<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
    dp_id: 105<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
    dp_id: 106<br />
<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
    dp_id: 107<br />
<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
    dp_id: 108<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
    dp_id: 109<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
    dp_id: 110<br />
<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
    dp_id: 111<br />
<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
    dp_id: 112<br />
<br />
<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
    dp_id: 113<br />
<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
    dp_id: 114<br />
<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
    dp_id: 115<br />
<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
    dp_id: 116<br />
<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
    dp_id: 117<br />
<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
    dp_id: 118<br />
<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
    dp_id: 119<br />
<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
    dp_id: 120<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
    dp_id: 121<br />
<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
    dp_id: 122<br />
<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
    dp_id: 123<br />
<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
    dp_id: 124<br />
<br />
<br />
ads1115:<br />
sensor:<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
    gain: 6.144<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
	</channel>
</rss>
