	<channel>
		<title><![CDATA[Smart Home Automation Forum - N60]]></title>
		<pubDate>Sat, 07 Nov 2026 05:15:10 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[N60 Loss of kWh on reset]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9772</link>
			<pubDate>Fri, 28 Aug 2026 12:28:30 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=6885">chuyskywalker</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9772</guid>
			<description><![CDATA[I've had the N60 up and running for about a week now and something on it went sideways (stopped reporting to home assistant; not really sure what went wrong) so I turned it off and back on again. It rebooted and came back online, but all the kWh values had been reset to zero.<br />
<br />
I thought the system saved these values to flash and would reload them at boot so that kWh remains continuous across reboots. Is that understanding wrong?<br />
<br />
The reason I ask is because when an ESPHome device reports values of the type "total_increasing" to home assistant, values that go backwards are handled oddly. Worse, values that go to zero are considered reseting the sensor. It's all a bit quirky, but ideally the device would retain those values and restore them. If that's not the case, I'll figure out something.<br />
<br />
Thanks!]]></description>
			<content:encoded><![CDATA[I've had the N60 up and running for about a week now and something on it went sideways (stopped reporting to home assistant; not really sure what went wrong) so I turned it off and back on again. It rebooted and came back online, but all the kWh values had been reset to zero.<br />
<br />
<br />
<br />
Thanks!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N60 power supply - power cosumption]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9767</link>
			<pubDate>Tue, 25 Aug 2026 23:00:21 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11545">buttom3</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9767</guid>
			<description><![CDATA[What is the maximum power consumption of the N60? <br />
What power supply does it require, and how many watts are needed? <br />
Is a 12 V DC, 1.25 A (15 W) power supply sufficient to run it reliably? <br />
What power supply are you using to keep your N60 stable?]]></description>
			<content:encoded><![CDATA[What is the maximum power consumption of the N60? <br />
What power supply are you using to keep your N60 stable?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[CT Sensor Direction]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9735</link>
			<pubDate>Wed, 12 Aug 2026 08:40:58 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9735</guid>
			<description><![CDATA[From what I've read (and based on most other power monitoring systems) it's important to get the direction of the sensor correct. So, should it look like A or B?<br />
<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>A)<br />
             &nbsp;&nbsp;(  )---- Sense Leads ------<br />
Source &gt;-------(--)------------------------&gt; Load<br />
             &nbsp;&nbsp;(&nbsp;&nbsp;)<br />
<br />
B)<br />
       &nbsp;&nbsp;---- Sense Leads ------(  )<br />
Source &gt;------------------------(--)-------&gt; Load<br />
                                (&nbsp;&nbsp;)</code></div></div><br />
			<content:encoded><![CDATA[From what I've read (and based on most other power monitoring systems) it's important to get the direction of the sensor correct. So, should it look like A or B?<br />
<br />
<br />
B)<br />
		</item>
		<item>
			<title><![CDATA[N60 Voltage reference]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9729</link>
			<pubDate>Tue, 11 Aug 2026 05:46:10 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11411">Energizer</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9729</guid>
			<description><![CDATA[I'm in Texas, US with a normal 200a panel. <br />
If I wanted to monitor 40 branch circuit can you explain how and what to use for voltage reference? Is it one per each 10? or is it like iotawatt that you use just one per the whole unit.]]></description>
			<content:encoded><![CDATA[I'm in Texas, US with a normal 200a panel. <br />
If I wanted to monitor 40 branch circuit can you explain how and what to use for voltage reference? Is it one per each 10? or is it like iotawatt that you use just one per the whole unit.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[CRC Errors with ESP Home & N10203060_KU_V20_260324SP]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9347</link>
			<pubDate>Thu, 21 May 2026 11:10:58 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10309">edalquist</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9347</guid>
			<description><![CDATA[I updated the ARM firmware to N10203060_KU_V20_260324SP and then tried flashing the ESP Home config from <a href="https://www.kincony.com/forum/showthread.php?tid=9157" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9157</a><br />
<br />
I'm now not getting any data and the following logs repeating over and over:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>[20:07:41.184][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=100 count=68<br />
[20:07:41.189][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=200 count=68<br />
[20:07:41.189][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=600 count=68<br />
[20:07:41.412][W][modbus:063]: Stop waiting for response from 1 424ms after last send<br />
[20:07:41.447][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:41.455][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 3ms after last send<br />
[20:07:41.468][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:41.713][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:41.732][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:41.737][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:41.751][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:41.994][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:42.015][W][modbus:219]: CRC check failed 2ms after last send<br />
[20:07:42.021][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 5ms after last send<br />
[20:07:42.036][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 23ms after last send<br />
[20:07:42.402][W][modbus:063]: Stop waiting for response from 1 389ms after last send<br />
[20:07:42.423][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:42.429][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:42.443][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:42.684][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:42.705][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:42.710][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:42.726][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:42.969][W][modbus:063]: Stop waiting for response from 1 266ms after last send<br />
[20:07:43.007][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:43.012][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 3ms after last send<br />
[20:07:43.026][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:43.407][W][modbus:063]: Stop waiting for response from 1 401ms after last send<br />
[20:07:43.426][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:43.432][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:43.445][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:43.690][W][modbus:063]: Stop waiting for response from 1 265ms after last send<br />
[20:07:43.710][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:43.715][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:43.730][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:43.975][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:43.996][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:44.001][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:44.012][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:44.402][W][modbus:063]: Stop waiting for response from 1 411ms after last send<br />
[20:07:44.422][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:44.428][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send<br />
[20:07:44.441][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send<br />
[20:07:44.687][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:44.722][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:44.728][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 3ms after last send<br />
[20:07:44.741][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send<br />
[20:07:44.984][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:45.004][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:45.013][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send<br />
[20:07:45.024][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send<br />
[20:07:45.407][W][modbus:063]: Stop waiting for response from 1 403ms after last send<br />
[20:07:45.425][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:45.430][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send<br />
[20:07:45.444][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send<br />
[20:07:45.687][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:45.718][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:45.718][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send<br />
[20:07:45.727][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send<br />
[20:07:45.971][W][modbus:063]: Stop waiting for response from 1 264ms after last send<br />
[20:07:45.992][W][modbus:219]: CRC check failed 1ms after last send<br />
[20:07:45.998][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send<br />
[20:07:46.011][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send</code></div></div><br />
<br />
There are no other changes to the system, just completed that ARM firmware update and flashed the example ESP Home config]]></description>
			<content:encoded><![CDATA[I updated the ARM firmware to N10203060_KU_V20_260324SP and then tried flashing the ESP Home config from <a href="https://www.kincony.com/forum/showthread.php?tid=9157" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9157</a><br />
<br />
<br />
There are no other changes to the system, just completed that ARM firmware update and flashed the example ESP Home config]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N series Energy Meter for Loxone UDP Protocol]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9316</link>
			<pubDate>Mon, 04 May 2026 16:19:04 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9316</guid>
			<description><![CDATA[Energy Loxone Protocol<br />
=======================<br />
<br />
Overview<br />
--------<br />
This document describes the Loxone string protocol for Energy module.<br />
Default delimiter is comma (,). Chip ID: 1-6, Channel: 1-10.<br />
<br />
<br />
Commands<br />
--------<br />
<br />
1. GET_ENERGY_CURRENT - Get current (A) for specific channel<br />
  Request:  RELAY-GET_ENERGY_CURRENT-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_CURRENT-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_CURRENT-255,1,1<br />
    Response: RELAY-GET_ENERGY_CURRENT-255,1,1,2.350,OK<br />
<br />
2. GET_ENERGY_POWER - Get power (W) for specific channel<br />
  Request:  RELAY-GET_ENERGY_POWER-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_POWER-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_POWER-255,1,1<br />
    Response: RELAY-GET_ENERGY_POWER-255,1,1,512.5,OK<br />
<br />
3. GET_ENERGY_KWH - Get energy (kWh) for specific channel<br />
  Request:  RELAY-GET_ENERGY_KWH-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_KWH-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_KWH-255,1,1<br />
    Response: RELAY-GET_ENERGY_KWH-255,1,1,1250,OK<br />
<br />
4. GET_ENERGY_VOLT - Get voltage (V) for chip<br />
  Request:  RELAY-GET_ENERGY_VOLT-255,{chip}<br />
  Response: RELAY-GET_ENERGY_VOLT-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_VOLT-255,1<br />
    Response: RELAY-GET_ENERGY_VOLT-255,1,220.50,OK<br />
<br />
5. GET_ENERGY_FREQ - Get frequency (Hz) for chip<br />
  Request:  RELAY-GET_ENERGY_FREQ-255,{chip}<br />
  Response: RELAY-GET_ENERGY_FREQ-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_FREQ-255,1<br />
    Response: RELAY-GET_ENERGY_FREQ-255,1,50.00,OK<br />
<br />
6. GET_ENERGY_TEMP - Get temperature &copy; for chip<br />
  Request:  RELAY-GET_ENERGY_TEMP-255,{chip}<br />
  Response: RELAY-GET_ENERGY_TEMP-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_TEMP-255,1<br />
    Response: RELAY-GET_ENERGY_TEMP-255,1,35.5,OK<br />
<br />
7. GET_ENERGY_PF - Get power factor for chip<br />
  Request:  RELAY-GET_ENERGY_PF-255,{chip}<br />
  Response: RELAY-GET_ENERGY_PF-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_PF-255,1<br />
    Response: RELAY-GET_ENERGY_PF-255,1,0.95,OK<br />
<br />
8. GET_ENERGY_SUM - Get total energy (kWh) for chip<br />
  Request:  RELAY-GET_ENERGY_SUM-255,{chip}<br />
  Response: RELAY-GET_ENERGY_SUM-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_SUM-255,1<br />
    Response: RELAY-GET_ENERGY_SUM-255,1,12500,OK<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9756" target="_blank" title="">Nx-Energy-meter-udp-loxone.png</a> (Size: 141.99 KB / Downloads: 314)
protocol download:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9757" target="_blank" title="">Nx-energy_loxone_protocol.txt</a> (Size: 2.34 KB / Downloads: 167)
			<content:encoded><![CDATA[Energy Loxone Protocol<br />
<br />
Overview<br />
--------<br />
<br />
<br />
Commands<br />
--------<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
		</item>
		<item>
			<title><![CDATA[N60 smart energy meter ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9303</link>
			<pubDate>Sat, 02 May 2026 19:46:42 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9303</guid>
			<description><![CDATA[N60 smart energy meter ESP32 system block diagram<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9731" target="_blank" title="">KinCony-N60-smart-energy-meter-diagram.png</a> (Size: 1.64 MB / Downloads: 324)
			<content:encoded><![CDATA[N60 smart energy meter ESP32 system block diagram<br />
		</item>
		<item>
			<title><![CDATA[N60 Sensor channel label]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9236</link>
			<pubDate>Tue, 14 Apr 2026 22:44:57 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10735">marekd1</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9236</guid>
<br />
Is there a way to assign custom label to each channel defining monitoring node function on local N60.  <br />
<br />
As far as I know I think you can do this on Kincony Cloud page but I am looking to do this at local N60 node level.  Example Chanel 1  Server, Channel 2 Sump, etc...<br />
<br />
If not could this be added in the update firmware release?<br />
<br />
thank you!]]></description>
<br />
<br />
<br />
<br />
thank you!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Current and Power not adding up for some sensors]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9231</link>
			<pubDate>Sun, 12 Apr 2026 23:42:18 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9231</guid>
			<description><![CDATA[I'm working on getting my N60 wired up. I'm using the ESPHome YAML plus firmware update from <a href="https://www.kincony.com/forum/showthread.php?tid=9157" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9157</a><br />
<br />
The listed watts does not line up with the calculated Volts * Amps for each sensor and some of them are significantly off.<br />
<br />
Looking at just some sensors<br />
<br />
L1 1 - 0.135A * 124.98V = 16.8723W   - 10.1W shown (6W low)<br />
L1 2 - 0.664A * 124.98V = 82.98672W - 82.1W shown (accurate)<br />
L1 3 - 0.134A * 124.98V = 16.74732W - 8.9W shown (7W low)<br />
L1 4 - 2.791A * 124.98V = 348.81918W - 202W shown (146W low)<br />
L1 5 - 1.138A * 124.98V = 142.22724W - 130.8W shown (12W low)<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9549" target="_blank" title="">Screenshot 2026-04-12 at 8.31.19 AM.png</a> (Size: 307.17 KB / Downloads: 531)
<br />
Here is the exact ESPHome config I'm using:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9550" target="_blank" title="">n60_base.txt</a> (Size: 67.34 KB / Downloads: 278)
			<content:encoded><![CDATA[I'm working on getting my N60 wired up. I'm using the ESPHome YAML plus firmware update from <a href="https://www.kincony.com/forum/showthread.php?tid=9157" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9157</a><br />
<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[N60 wire case diagram for 1 phase load]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9195</link>
			<pubDate>Wed, 01 Apr 2026 10:47:33 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9195</guid>
			<description><![CDATA[N60 wire case diagram for 1 phase load<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9496" target="_blank" title="">N60-1-phase.JPG</a> (Size: 92.63 KB / Downloads: 269)
			<content:encoded><![CDATA[N60 wire case diagram for 1 phase load<br />
		</item>
		<item>
			<title><![CDATA[N60 wire case diagram for 3 phase load]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9194</link>
			<pubDate>Wed, 01 Apr 2026 10:46:58 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9194</guid>
			<description><![CDATA[N60 wire case diagram for 3 phase load<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9495" target="_blank" title="">N60-3-phase.JPG</a> (Size: 119.53 KB / Downloads: 279)
			<content:encoded><![CDATA[N60 wire case diagram for 3 phase load<br />
		</item>
		<item>
			<title><![CDATA[N60 N30 N20 N10 ARM CPU firmware V20_260324SP]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9172</link>
			<pubDate>Tue, 24 Mar 2026 12:59:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9172</guid>
			<description><![CDATA[fixed bug can't remember energy data when power off.<br />
you can download by bootloader.exe tool by RS485.<br />
ARM BIN file download:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9483" target="_blank" title="">N10203060_KU_V20_260324SP.zip</a> (Size: 14.42 KB / Downloads: 412)
<br />
bootloader.exe tool: <br />
<img src="https://www.kincony.com/forum/images/attachtypes/zip.png" loading="lazy"  alt="[Image: zip.png]" class="mycode_img" />   <a href="https://www.kincony.com/forum/attachment.php?aid=8890" target="_blank" rel="noopener" class="mycode_url"><span style="color: #0072bc;" class="mycode_color">KC868 Controller Bootloader.zip</span></a> <br />
<img src="https://www.kincony.com/forum/attachment.php?aid=8891" loading="lazy"  alt="[Image: attachment.php?aid=8891]" class="mycode_img" />   <br />
1. set baud rate=38400bps.<br />
2. open com port.<br />
3. power on Nx board, during LED fast blink when the "bootloader Detect" button right now. Then board will go to bootloader mode.<br />
4. open BIN file<br />
5. press "Download" button, begin download firmware, after finished, press "Run" button, ARM CPU begin work.<br />
<img src="https://www.kincony.com/forum/attachment.php?aid=8892" loading="lazy"  alt="[Image: attachment.php?aid=8892]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[fixed bug can't remember energy data when power off.<br />
<br />
<img src="https://www.kincony.com/forum/attachment.php?aid=8892" loading="lazy"  alt="[Image: attachment.php?aid=8892]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[how to read BL0910 energy chip RAW data by modbus pull via RS485]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9162</link>
			<pubDate>Tue, 24 Mar 2026 10:13:44 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9162</guid>
			<description><![CDATA[1: open NX_chip.mbp in modbus pull software.<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9390" target="_blank" title="">modbus-open-config.png</a> (Size: 92.01 KB / Downloads: 366)
<br />
2: set COM port. you can use USB-RS485 adapter connect to your computer:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9391" target="_blank" title="">modbus-pull-COM-setting.png</a> (Size: 87.06 KB / Downloads: 391)
<br />
3: <br />
you can read BL0910-1 chip from address 100 , register count: 68<br />
you can read BL0910-2 chip from address 200 , register count: 68 <br />
you can read BL0910-3 chip from address 300 , register count: 68 <br />
you can read BL0910-4 chip from address 400 , register count: 68 <br />
you can read BL0910-5 chip from address 500 , register count: 68 <br />
you can read BL0910-6 chip from address 600 , register count: 68 <br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9392" target="_blank" title="">modbus-pull-read-BL0910-1.png</a> (Size: 96.25 KB / Downloads: 340)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9393" target="_blank" title="">modbus-pull-read-BL0910-2.png</a> (Size: 98.36 KB / Downloads: 393)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9394" target="_blank" title="">modbus-pull-read-BL0910-3.png</a> (Size: 94.91 KB / Downloads: 319)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9395" target="_blank" title="">modbus-pull-read-BL0910-4.png</a> (Size: 96.68 KB / Downloads: 366)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9396" target="_blank" title="">modbus-pull-read-BL0910-5.png</a> (Size: 95.49 KB / Downloads: 377)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9397" target="_blank" title="">modbus-pull-read-BL0910-6.png</a> (Size: 95.27 KB / Downloads: 318)
<br />
<img src="https://www.kincony.com/forum/attachment.php?aid=9381" loading="lazy"  alt="[Image: attachment.php?aid=9381]" class="mycode_img" /> <br />
<img src="https://www.kincony.com/forum/attachment.php?aid=9387" loading="lazy"  alt="[Image: attachment.php?aid=9387]" class="mycode_img" /><br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9389" target="_blank" title="">NX_chip.zip</a> (Size: 654 bytes / Downloads: 365)
			<content:encoded><![CDATA[1: open NX_chip.mbp in modbus pull software.<br />
<br />
<br />
3: <br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[N60 configure yaml for ESPhome 0.001kwh precision]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9157</link>
			<pubDate>Mon, 23 Mar 2026 09:58:16 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9157</guid>
			<description><![CDATA[note: ARM CPU firmware version should &gt;= V20_260305SP<br />
ARM CPU firmware download: <a href="https://www.kincony.com/forum/showthread.php?tid=9107" target="_blank" rel="noopener" class="mycode_url"><span style="color: #0072bc;" class="mycode_color">https://www.kincony.com/forum/showthread.php?tid=9107</span></a> <br />
  friendly_name: n60<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
  # baud_rate: 0<br />
<br />
api:<br />
<br />
ota:<br />
  platform: esphome<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO42<br />
  mosi_pin: GPIO43<br />
  miso_pin: GPIO44<br />
  cs_pin: GPIO41<br />
  interrupt_pin: GPIO2<br />
  reset_pin: GPIO1<br />
<br />
uart:<br />
  rx_pin: 9<br />
  tx_pin: 10<br />
  baud_rate: 115200<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
<br />
web_server:<br />
  port: 80<br />
<br />
text_sensor:<br />
  - platform: ethernet_info<br />
    ip_address:<br />
      name: ESP IP Address<br />
    dns_address:<br />
      name: ESP DNS Address<br />
    mac_address:<br />
      name: ESP MAC Address<br />
<br />
font:<br />
<br />
i2c:<br />
  sda: 18<br />
  scl: 17<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());<br />
<br />
modbus:<br />
  uart_id: uart_modbus<br />
<br />
modbus_controller:<br />
  - id: energy_meter<br />
    modbus_id: mb1<br />
    address: 1<br />
    update_interval: 5s<br />
    command_throttle: 200ms<br />
<br />
sensor:<br />
  # Protocol notes for this PR:<br />
  # - current: U_DWORD_R, scaled by 0.001 A<br />
  # - power: &nbsp;&nbsp;S_DWORD_R, scaled by 0.1 W<br />
  # - energy:  FP32_R, unit kWh<br />
  # - voltage/frequency remain U_WORD * 0.01<br />
  # - temperature remains FP32_R<br />
<br />
  - platform: modbus_controller<br />
    modbus_controller_id: energy_meter<br />
    address: 100<br />
    register_type: holding<br />
    unit_of_measurement: A<br />
    device_class: current<br />
    state_class: measurement<br />
    accuracy_decimals: 3<br />
    value_type: U_DWORD_R<br />
    filters:<br />
      - multiply: 0.001<br />
<br />
    address: 102<br />
    filters:<br />
<br />
    address: 104<br />
    filters:<br />
<br />
    address: 106<br />
    filters:<br />
<br />
    address: 108<br />
    filters:<br />
<br />
    address: 110<br />
    filters:<br />
<br />
    address: 112<br />
    filters:<br />
<br />
    address: 114<br />
    filters:<br />
<br />
    address: 116<br />
    filters:<br />
<br />
    address: 118<br />
    filters:<br />
<br />
    address: 120<br />
    unit_of_measurement: W<br />
    device_class: power<br />
    accuracy_decimals: 1<br />
    value_type: S_DWORD_R<br />
    filters:<br />
      - multiply: 0.1<br />
<br />
    address: 122<br />
    filters:<br />
<br />
    address: 124<br />
    filters:<br />
<br />
    address: 126<br />
    filters:<br />
<br />
    address: 128<br />
    filters:<br />
<br />
    address: 130<br />
    filters:<br />
<br />
    address: 132<br />
    filters:<br />
<br />
    address: 134<br />
    filters:<br />
<br />
    address: 136<br />
    filters:<br />
<br />
    address: 138<br />
    filters:<br />
<br />
    address: 140<br />
    unit_of_measurement: kWh<br />
    device_class: energy<br />
    state_class: total_increasing<br />
    value_type: FP32_R<br />
<br />
    address: 142<br />
<br />
    address: 144<br />
<br />
    address: 146<br />
<br />
    address: 148<br />
<br />
    address: 150<br />
<br />
    address: 152<br />
<br />
    address: 154<br />
<br />
    address: 156<br />
<br />
    address: 158<br />
<br />
    address: 160<br />
<br />
    address: 162<br />
    unit_of_measurement: V<br />
    device_class: voltage<br />
    accuracy_decimals: 2<br />
    value_type: U_WORD<br />
    filters:<br />
      - multiply: 0.01<br />
<br />
    address: 163<br />
    unit_of_measurement: Hz<br />
    device_class: frequency<br />
    filters:<br />
<br />
    address: 164<br />
    unit_of_measurement: °C<br />
    device_class: temperature<br />
<br />
    address: 166<br />
<br />
    address: 200<br />
    filters:<br />
<br />
    address: 202<br />
    filters:<br />
<br />
    address: 204<br />
    filters:<br />
<br />
    address: 206<br />
    filters:<br />
<br />
    address: 208<br />
    filters:<br />
<br />
    address: 210<br />
    filters:<br />
<br />
    address: 212<br />
    filters:<br />
<br />
    address: 214<br />
    filters:<br />
<br />
    address: 216<br />
    filters:<br />
<br />
    address: 218<br />
    filters:<br />
<br />
    address: 220<br />
    filters:<br />
<br />
    address: 222<br />
    filters:<br />
<br />
    address: 224<br />
    filters:<br />
<br />
    address: 226<br />
    filters:<br />
<br />
    address: 228<br />
    filters:<br />
<br />
    address: 230<br />
    filters:<br />
<br />
    address: 232<br />
    filters:<br />
<br />
    address: 234<br />
    filters:<br />
<br />
    address: 236<br />
    filters:<br />
<br />
    address: 238<br />
    filters:<br />
<br />
    address: 240<br />
<br />
    address: 242<br />
<br />
    address: 244<br />
<br />
    address: 246<br />
<br />
    address: 248<br />
<br />
    address: 250<br />
<br />
    address: 252<br />
<br />
    address: 254<br />
<br />
    address: 256<br />
<br />
    address: 258<br />
<br />
    address: 260<br />
<br />
    address: 262<br />
    filters:<br />
<br />
    address: 263<br />
    filters:<br />
<br />
    address: 264<br />
<br />
    address: 266<br />
<br />
    address: 300<br />
    filters:<br />
<br />
    address: 302<br />
    filters:<br />
<br />
    address: 304<br />
    filters:<br />
<br />
    address: 306<br />
    filters:<br />
<br />
    address: 308<br />
    filters:<br />
<br />
    address: 310<br />
    filters:<br />
<br />
    address: 312<br />
    filters:<br />
<br />
    address: 314<br />
    filters:<br />
<br />
    address: 316<br />
    filters:<br />
<br />
    address: 318<br />
    filters:<br />
<br />
    address: 320<br />
    filters:<br />
<br />
    address: 322<br />
    filters:<br />
<br />
    address: 324<br />
    filters:<br />
<br />
    address: 326<br />
    filters:<br />
<br />
    address: 328<br />
    filters:<br />
<br />
    address: 330<br />
    filters:<br />
<br />
    address: 332<br />
    filters:<br />
<br />
    address: 334<br />
    filters:<br />
<br />
    address: 336<br />
    filters:<br />
<br />
    address: 338<br />
    filters:<br />
<br />
    address: 340<br />
<br />
    address: 342<br />
<br />
    address: 344<br />
<br />
    address: 346<br />
<br />
    address: 348<br />
<br />
    address: 350<br />
<br />
    address: 352<br />
<br />
    address: 354<br />
<br />
    address: 356<br />
<br />
    address: 358<br />
<br />
    address: 360<br />
<br />
    address: 362<br />
    filters:<br />
<br />
    address: 363<br />
    filters:<br />
<br />
    address: 364<br />
<br />
    address: 366<br />
<br />
    address: 400<br />
    filters:<br />
<br />
    address: 402<br />
    filters:<br />
<br />
    address: 404<br />
    filters:<br />
<br />
    address: 406<br />
    filters:<br />
<br />
    address: 408<br />
    filters:<br />
<br />
    address: 410<br />
    filters:<br />
<br />
    address: 412<br />
    filters:<br />
<br />
    address: 414<br />
    filters:<br />
<br />
    address: 416<br />
    filters:<br />
<br />
    address: 418<br />
    filters:<br />
<br />
    address: 420<br />
    filters:<br />
<br />
    address: 422<br />
    filters:<br />
<br />
    address: 424<br />
    filters:<br />
<br />
    address: 426<br />
    filters:<br />
<br />
    address: 428<br />
    filters:<br />
<br />
    address: 430<br />
    filters:<br />
<br />
    address: 432<br />
    filters:<br />
<br />
    address: 434<br />
    filters:<br />
<br />
    address: 436<br />
    filters:<br />
<br />
    address: 438<br />
    filters:<br />
<br />
    address: 440<br />
<br />
    address: 442<br />
<br />
    address: 444<br />
<br />
    address: 446<br />
<br />
    address: 448<br />
<br />
    address: 450<br />
<br />
    address: 452<br />
<br />
    address: 454<br />
<br />
    address: 456<br />
<br />
    address: 458<br />
<br />
    address: 460<br />
<br />
    address: 462<br />
    filters:<br />
<br />
    address: 463<br />
    filters:<br />
<br />
    address: 464<br />
<br />
    address: 466<br />
<br />
    address: 500<br />
    filters:<br />
<br />
    address: 502<br />
    filters:<br />
<br />
    address: 504<br />
    filters:<br />
<br />
    address: 506<br />
    filters:<br />
<br />
    address: 508<br />
    filters:<br />
<br />
    address: 510<br />
    filters:<br />
<br />
    address: 512<br />
    filters:<br />
<br />
    address: 514<br />
    filters:<br />
<br />
    address: 516<br />
    filters:<br />
<br />
    address: 518<br />
    filters:<br />
<br />
    address: 520<br />
    filters:<br />
<br />
    address: 522<br />
    filters:<br />
<br />
    address: 524<br />
    filters:<br />
<br />
    address: 526<br />
    filters:<br />
<br />
    address: 528<br />
    filters:<br />
<br />
    address: 530<br />
    filters:<br />
<br />
    address: 532<br />
    filters:<br />
<br />
    address: 534<br />
    filters:<br />
<br />
    address: 536<br />
    filters:<br />
<br />
    address: 538<br />
    filters:<br />
<br />
    address: 540<br />
<br />
    address: 542<br />
<br />
    address: 544<br />
<br />
    address: 546<br />
<br />
    address: 548<br />
<br />
    address: 550<br />
<br />
    address: 552<br />
<br />
    address: 554<br />
<br />
    address: 556<br />
<br />
    address: 558<br />
<br />
    address: 560<br />
<br />
    address: 562<br />
    filters:<br />
<br />
    address: 563<br />
    filters:<br />
<br />
    address: 564<br />
<br />
    address: 566<br />
<br />
    address: 600<br />
    filters:<br />
<br />
    address: 602<br />
    filters:<br />
<br />
    address: 604<br />
    filters:<br />
<br />
    address: 606<br />
    filters:<br />
<br />
    address: 608<br />
    filters:<br />
<br />
    address: 610<br />
    filters:<br />
<br />
    address: 612<br />
    filters:<br />
<br />
    address: 614<br />
    filters:<br />
<br />
    address: 616<br />
    filters:<br />
<br />
    address: 618<br />
    filters:<br />
<br />
    address: 620<br />
    filters:<br />
<br />
    address: 622<br />
    filters:<br />
<br />
    address: 624<br />
    filters:<br />
<br />
    address: 626<br />
    filters:<br />
<br />
    address: 628<br />
    filters:<br />
<br />
    address: 630<br />
    filters:<br />
<br />
    address: 632<br />
    filters:<br />
<br />
    address: 634<br />
    filters:<br />
<br />
    address: 636<br />
    filters:<br />
<br />
    address: 638<br />
    filters:<br />
<br />
    address: 640<br />
<br />
    address: 642<br />
<br />
    address: 644<br />
<br />
    address: 646<br />
<br />
    address: 648<br />
<br />
    address: 650<br />
<br />
    address: 652<br />
<br />
    address: 654<br />
<br />
    address: 656<br />
<br />
    address: 658<br />
<br />
    address: 660<br />
<br />
    address: 662<br />
    filters:<br />
<br />
    address: 663<br />
    filters:<br />
<br />
    address: 664<br />
<br />
    address: 666<br />
    value_type: FP32_R</code></div></div> yaml download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9376" target="_blank" title="">n60_esphome.txt</a> (Size: 67.27 KB / Downloads: 329)
			<content:encoded><![CDATA[note: ARM CPU firmware version should &gt;= V20_260305SP<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ota:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
  rx_pin: 9<br />
  tx_pin: 10<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
<br />
web_server:<br />
  port: 80<br />
<br />
text_sensor:<br />
    ip_address:<br />
    dns_address:<br />
    mac_address:<br />
<br />
font:<br />
<br />
i2c:<br />
  sda: 18<br />
  scl: 17<br />
<br />
display:<br />
    address: 0x3C<br />
    lambda: |-<br />
<br />
modbus:<br />
<br />
    address: 1<br />
<br />
sensor:<br />
<br />
    address: 100<br />
    filters:<br />
<br />
    address: 102<br />
    filters:<br />
<br />
    address: 104<br />
    filters:<br />
<br />
    address: 106<br />
    filters:<br />
<br />
    address: 108<br />
    filters:<br />
<br />
    address: 110<br />
    filters:<br />
<br />
    address: 112<br />
    filters:<br />
<br />
    address: 114<br />
    filters:<br />
<br />
    address: 116<br />
    filters:<br />
<br />
    address: 118<br />
    filters:<br />
<br />
    address: 120<br />
    filters:<br />
<br />
    address: 122<br />
    filters:<br />
<br />
    address: 124<br />
    filters:<br />
<br />
    address: 126<br />
    filters:<br />
<br />
    address: 128<br />
    filters:<br />
<br />
    address: 130<br />
    filters:<br />
<br />
    address: 132<br />
    filters:<br />
<br />
    address: 134<br />
    filters:<br />
<br />
    address: 136<br />
    filters:<br />
<br />
    address: 138<br />
    filters:<br />
<br />
    address: 140<br />
<br />
    address: 142<br />
<br />
    address: 144<br />
<br />
    address: 146<br />
<br />
    address: 148<br />
<br />
    address: 150<br />
<br />
    address: 152<br />
<br />
    address: 154<br />
<br />
    address: 156<br />
<br />
    address: 158<br />
<br />
    address: 160<br />
<br />
    address: 162<br />
    filters:<br />
<br />
    address: 163<br />
    filters:<br />
<br />
    address: 164<br />
<br />
    address: 166<br />
<br />
    address: 200<br />
    filters:<br />
<br />
    address: 202<br />
    filters:<br />
<br />
    address: 204<br />
    filters:<br />
<br />
    address: 206<br />
    filters:<br />
<br />
    address: 208<br />
    filters:<br />
<br />
    address: 210<br />
    filters:<br />
<br />
    address: 212<br />
    filters:<br />
<br />
    address: 214<br />
    filters:<br />
<br />
    address: 216<br />
    filters:<br />
<br />
    address: 218<br />
    filters:<br />
<br />
    address: 220<br />
    filters:<br />
<br />
    address: 222<br />
    filters:<br />
<br />
    address: 224<br />
    filters:<br />
<br />
    address: 226<br />
    filters:<br />
<br />
    address: 228<br />
    filters:<br />
<br />
    address: 230<br />
    filters:<br />
<br />
    address: 232<br />
    filters:<br />
<br />
    address: 234<br />
    filters:<br />
<br />
    address: 236<br />
    filters:<br />
<br />
    address: 238<br />
    filters:<br />
<br />
    address: 240<br />
<br />
    address: 242<br />
<br />
    address: 244<br />
<br />
    address: 246<br />
<br />
    address: 248<br />
<br />
    address: 250<br />
<br />
    address: 252<br />
<br />
    address: 254<br />
<br />
    address: 256<br />
<br />
    address: 258<br />
<br />
    address: 260<br />
<br />
    address: 262<br />
    filters:<br />
<br />
    address: 263<br />
    filters:<br />
<br />
    address: 264<br />
<br />
    address: 266<br />
<br />
    address: 300<br />
    filters:<br />
<br />
    address: 302<br />
    filters:<br />
<br />
    address: 304<br />
    filters:<br />
<br />
    address: 306<br />
    filters:<br />
<br />
    address: 308<br />
    filters:<br />
<br />
    address: 310<br />
    filters:<br />
<br />
    address: 312<br />
    filters:<br />
<br />
    address: 314<br />
    filters:<br />
<br />
    address: 316<br />
    filters:<br />
<br />
    address: 318<br />
    filters:<br />
<br />
    address: 320<br />
    filters:<br />
<br />
    address: 322<br />
    filters:<br />
<br />
    address: 324<br />
    filters:<br />
<br />
    address: 326<br />
    filters:<br />
<br />
    address: 328<br />
    filters:<br />
<br />
    address: 330<br />
    filters:<br />
<br />
    address: 332<br />
    filters:<br />
<br />
    address: 334<br />
    filters:<br />
<br />
    address: 336<br />
    filters:<br />
<br />
    address: 338<br />
    filters:<br />
<br />
    address: 340<br />
<br />
    address: 342<br />
<br />
    address: 344<br />
<br />
    address: 346<br />
<br />
    address: 348<br />
<br />
    address: 350<br />
<br />
    address: 352<br />
<br />
    address: 354<br />
<br />
    address: 356<br />
<br />
    address: 358<br />
<br />
    address: 360<br />
<br />
    address: 362<br />
    filters:<br />
<br />
    address: 363<br />
    filters:<br />
<br />
    address: 364<br />
<br />
    address: 366<br />
<br />
    address: 400<br />
    filters:<br />
<br />
    address: 402<br />
    filters:<br />
<br />
    address: 404<br />
    filters:<br />
<br />
    address: 406<br />
    filters:<br />
<br />
    address: 408<br />
    filters:<br />
<br />
    address: 410<br />
    filters:<br />
<br />
    address: 412<br />
    filters:<br />
<br />
    address: 414<br />
    filters:<br />
<br />
    address: 416<br />
    filters:<br />
<br />
    address: 418<br />
    filters:<br />
<br />
    address: 420<br />
    filters:<br />
<br />
    address: 422<br />
    filters:<br />
<br />
    address: 424<br />
    filters:<br />
<br />
    address: 426<br />
    filters:<br />
<br />
    address: 428<br />
    filters:<br />
<br />
    address: 430<br />
    filters:<br />
<br />
    address: 432<br />
    filters:<br />
<br />
    address: 434<br />
    filters:<br />
<br />
    address: 436<br />
    filters:<br />
<br />
    address: 438<br />
    filters:<br />
<br />
    address: 440<br />
<br />
    address: 442<br />
<br />
    address: 444<br />
<br />
    address: 446<br />
<br />
    address: 448<br />
<br />
    address: 450<br />
<br />
    address: 452<br />
<br />
    address: 454<br />
<br />
    address: 456<br />
<br />
    address: 458<br />
<br />
    address: 460<br />
<br />
    address: 462<br />
    filters:<br />
<br />
    address: 463<br />
    filters:<br />
<br />
    address: 464<br />
<br />
    address: 466<br />
<br />
    address: 500<br />
    filters:<br />
<br />
    address: 502<br />
    filters:<br />
<br />
    address: 504<br />
    filters:<br />
<br />
    address: 506<br />
    filters:<br />
<br />
    address: 508<br />
    filters:<br />
<br />
    address: 510<br />
    filters:<br />
<br />
    address: 512<br />
    filters:<br />
<br />
    address: 514<br />
    filters:<br />
<br />
    address: 516<br />
    filters:<br />
<br />
    address: 518<br />
    filters:<br />
<br />
    address: 520<br />
    filters:<br />
<br />
    address: 522<br />
    filters:<br />
<br />
    address: 524<br />
    filters:<br />
<br />
    address: 526<br />
    filters:<br />
<br />
    address: 528<br />
    filters:<br />
<br />
    address: 530<br />
    filters:<br />
<br />
    address: 532<br />
    filters:<br />
<br />
    address: 534<br />
    filters:<br />
<br />
    address: 536<br />
    filters:<br />
<br />
    address: 538<br />
    filters:<br />
<br />
    address: 540<br />
<br />
    address: 542<br />
<br />
    address: 544<br />
<br />
    address: 546<br />
<br />
    address: 548<br />
<br />
    address: 550<br />
<br />
    address: 552<br />
<br />
    address: 554<br />
<br />
    address: 556<br />
<br />
    address: 558<br />
<br />
    address: 560<br />
<br />
    address: 562<br />
    filters:<br />
<br />
    address: 563<br />
    filters:<br />
<br />
    address: 564<br />
<br />
    address: 566<br />
<br />
    address: 600<br />
    filters:<br />
<br />
    address: 602<br />
    filters:<br />
<br />
    address: 604<br />
    filters:<br />
<br />
    address: 606<br />
    filters:<br />
<br />
    address: 608<br />
    filters:<br />
<br />
    address: 610<br />
    filters:<br />
<br />
    address: 612<br />
    filters:<br />
<br />
    address: 614<br />
    filters:<br />
<br />
    address: 616<br />
    filters:<br />
<br />
    address: 618<br />
    filters:<br />
<br />
    address: 620<br />
    filters:<br />
<br />
    address: 622<br />
    filters:<br />
<br />
    address: 624<br />
    filters:<br />
<br />
    address: 626<br />
    filters:<br />
<br />
    address: 628<br />
    filters:<br />
<br />
    address: 630<br />
    filters:<br />
<br />
    address: 632<br />
    filters:<br />
<br />
    address: 634<br />
    filters:<br />
<br />
    address: 636<br />
    filters:<br />
<br />
    address: 638<br />
    filters:<br />
<br />
    address: 640<br />
<br />
    address: 642<br />
<br />
    address: 644<br />
<br />
    address: 646<br />
<br />
    address: 648<br />
<br />
    address: 650<br />
<br />
    address: 652<br />
<br />
    address: 654<br />
<br />
    address: 656<br />
<br />
    address: 658<br />
<br />
    address: 660<br />
<br />
    address: 662<br />
    filters:<br />
<br />
    address: 663<br />
    filters:<br />
<br />
    address: 664<br />
<br />
    address: 666<br />
		</item>
		<item>
			<title><![CDATA[N60 N30 N20 N10 ARM CPU firmware V20_260305SP]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9107</link>
			<pubDate>Fri, 06 Mar 2026 16:17:47 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9107</guid>
			<description><![CDATA[1. support 0.001kwh precision.<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9280" target="_blank" title="">4.png</a> (Size: 519.75 KB / Downloads: 687)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9279" target="_blank" title="">N102030_KU_V20_260305SP.zip</a> (Size: 14.12 KB / Downloads: 423)
<br />
<img src="https://www.kincony.com/forum/images/attachtypes/zip.png" loading="lazy"  alt="[Image: zip.png]" class="mycode_img" />   <a href="https://www.kincony.com/forum/attachment.php?aid=8890" target="_blank" rel="noopener" class="mycode_url"><span style="color: #0072bc;" class="mycode_color">KC868 Controller Bootloader.zip</span></a> (Size: 8.56 KB / Downloads: 77)<br />
			<content:encoded><![CDATA[1. support 0.001kwh precision.<br />
<br />
		</item>
	</channel>
</rss>
