	<channel>
		<title><![CDATA[Smart Home Automation Forum - N10]]></title>
		<pubDate>Sat, 26 Sep 2026 16:00:15 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[N10 with L1 and L2 support ?]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9835</link>
			<pubDate>Thu, 17 Sep 2026 06:12:32 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=1450">aredan</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9835</guid>
			<description><![CDATA[I am looking for a meter that supports split-phase or 3-phase; the N30 and others are too big for my project. Any chance the N10 supports split-phase?<br />
<br />
 Looking to monitor Grid-tied Inverter generation and grid consumption. I already have a Victron Meter VM-3P75CT and am in need of a second meter with the same capabilities (L1,L2 and L3) and cheaper. This will be integrated to Home-Assistant and Node-Red running on my CerboGX.<br />
<br />
 Maybe you can build an N5 with L1,L2 and L3 ? <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" />]]></description>
			<content:encoded><![CDATA[I am looking for a meter that supports split-phase or 3-phase; the N30 and others are too big for my project. Any chance the N10 supports split-phase?<br />
<br />
<br />
 Maybe you can build an N5 with L1,L2 and L3 ? <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N10 - ESPHome - ARM CPU streams continuously, Modbus requests never transmitted]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9811</link>
			<pubDate>Wed, 09 Sep 2026 16:39:27 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11714">luzozo13</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9811</guid>
<br />
I am trying to integrate a new N10 board with ESPHome (v2026.8.0) and Home Assistant. After extensive testing I have isolated the problem precisely and hope someone who has successfully set up an N10 with ESPHome can help, or that KinCony staff can clarify some undocumented behaviour.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">Board:</span> KinCony N10 (ESP32-S3-WROOM-1U N16R8, 16MB flash)<br />
<span style="font-weight: bold;" class="mycode_b">ESPHome version:</span> 2026.8.0<br />
<span style="font-weight: bold;" class="mycode_b">Chip:</span> Freshly erased with esptool before first flash<br />
<br />
<span style="font-weight: bold;" class="mycode_b"><span style="font-size: large;" class="mycode_size">SYMPTOM</span></span><br />
<br />
ESPHome's modbus_controller never transmits a single request to the BL0910 ARM CPU. The UART RX line (GPIO10) is flooded with data from the moment power is applied, before ESPHome sends anything. Because ESPHome's Modbus component sees a perpetually busy bus, its frame-guard logic refuses to ever transmit. Every log shows thousands of "Clearing buffer of 2 bytes — timeout after partial response" messages and zero TX lines.<br />
<br />
<span style="font-weight: bold;" class="mycode_b"><span style="font-size: large;" class="mycode_size">DIAGNOSTIC STEPS COMPLETED</span></span><br />
<br />
<span style="font-weight: bold;" class="mycode_b">1. Bare UART only (no modbus: component)</span><br />
RX line completely silent for 60+ seconds. Confirmed the ARM CPU does NOT stream data unprovoked.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">2. modbus: component, slave address 1, 115200 baud</span> (ESPHome Devices reference config)<br />
Continuous noise on RX, zero TX ever logged.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">3. modbus: component, slave address 100, 38400 baud</span> (per KinCony's own protocol document)<br />
Same continuous noise, BUT real data bursts appeared embedded in the RX stream. This is the only configuration where the ARM CPU visibly responds — confirmed it is responding to address 100, not address 1.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">4. All baud rates tested: 9600, 19200, 38400, 115200</span> with slave address 100.<br />
Best results at 38400 (real data bursts visible). Other baud rates produce background patterns consistent with framing mismatch.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">5. Boot drain lambda</span> (on_boot reads and discards all RX bytes before modbus_controller initialises)<br />
No effect, TX still never appears.<br />
<br />
<span style="font-weight: bold;" class="mycode_b"><span style="font-size: large;" class="mycode_size">WHAT I BELIEVE IS HAPPENING</span></span><br />
<br />
When ESPHome's modbus: component initialises, something causes the ARM CPU to enter a continuous streaming state. Once streaming starts, ESPHome can never transmit. Without the modbus: component, the ARM CPU stays completely quiet.<br />
<br />
<span style="font-weight: bold;" class="mycode_b"><span style="font-size: large;" class="mycode_size">QUESTIONS</span></span><br />
<br />
<span style="font-weight: bold;" class="mycode_b">1.</span> Does the N10 ARM CPU require the KCS factory firmware to run first and perform an initialisation before it will behave as a standard Modbus RTU slave? Has anyone successfully used ESPHome on a freshly-erased N10?<br />
<br />
<span style="font-weight: bold;" class="mycode_b">2.</span> Can anyone confirm the correct slave address? Our testing points to <span style="font-weight: bold;" class="mycode_b">100</span>, not 1 as shown in the ESPHome Devices reference config.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">3.</span> Can anyone confirm the correct baud rate? KinCony's protocol document says 38400; the ESPHome Devices reference says 115200. Our best results were at 38400.<br />
<br />
<span style="font-weight: bold;" class="mycode_b">4.</span> Is there a known way to suppress the ARM CPU's startup streaming from ESPHome, so the Modbus component can get its first request out?<br />
<br />
<span style="font-weight: bold;" class="mycode_b"><span style="font-size: large;" class="mycode_size">MINIMAL REPRODUCING CONFIG</span></span><br />
<br />
esp32:<br />
  variant: esp32s3<br />
  framework:<br />
    type: arduino<br />
logger:<br />
  hardware_uart: USB_SERIAL_JTAG<br />
api:<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO42<br />
  mosi_pin: GPIO43<br />
  miso_pin: GPIO44<br />
  cs_pin: GPIO41<br />
  interrupt_pin: GPIO2<br />
  reset_pin: GPIO1<br />
uart:<br />
  tx_pin: GPIO9<br />
  rx_pin: GPIO10<br />
  baud_rate: 38400<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
  debug:<br />
    direction: BOTH<br />
modbus:<br />
  uart_id: uart_bl0910<br />
modbus_controller:<br />
  - id: energy_meter<br />
    address: 100<br />
    update_interval: 30s<br />
sensor:<br />
  - platform: modbus_controller<br />
    modbus_controller_id: energy_meter<br />
    address: 162<br />
    register_type: holding<br />
    name: "Line Voltage"<br />
    unit_of_measurement: V<br />
    value_type: U_WORD<br />
    filters:<br />
      - multiply: 0.01</code></div></div><br />
Any help appreciated. Thank you.]]></description>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
logger:<br />
api:<br />
ethernet:<br />
  type: W5500<br />
uart:<br />
  tx_pin: GPIO9<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
  debug:<br />
modbus:<br />
    address: 100<br />
sensor:<br />
    address: 162<br />
    filters:<br />
Any help appreciated. Thank you.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N series Energy Meter for Loxone UDP Protocol]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9313</link>
			<pubDate>Mon, 04 May 2026 16:19:04 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9313</guid>
			<description><![CDATA[Energy Loxone Protocol<br />
=======================<br />
<br />
Overview<br />
--------<br />
This document describes the Loxone string protocol for Energy module.<br />
Default delimiter is comma (,). Chip ID: 1-6, Channel: 1-10.<br />
<br />
<br />
Commands<br />
--------<br />
<br />
1. GET_ENERGY_CURRENT - Get current (A) for specific channel<br />
  Request:  RELAY-GET_ENERGY_CURRENT-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_CURRENT-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_CURRENT-255,1,1<br />
    Response: RELAY-GET_ENERGY_CURRENT-255,1,1,2.350,OK<br />
<br />
2. GET_ENERGY_POWER - Get power (W) for specific channel<br />
  Request:  RELAY-GET_ENERGY_POWER-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_POWER-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_POWER-255,1,1<br />
    Response: RELAY-GET_ENERGY_POWER-255,1,1,512.5,OK<br />
<br />
3. GET_ENERGY_KWH - Get energy (kWh) for specific channel<br />
  Request:  RELAY-GET_ENERGY_KWH-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_KWH-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_KWH-255,1,1<br />
    Response: RELAY-GET_ENERGY_KWH-255,1,1,1250,OK<br />
<br />
4. GET_ENERGY_VOLT - Get voltage (V) for chip<br />
  Request:  RELAY-GET_ENERGY_VOLT-255,{chip}<br />
  Response: RELAY-GET_ENERGY_VOLT-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_VOLT-255,1<br />
    Response: RELAY-GET_ENERGY_VOLT-255,1,220.50,OK<br />
<br />
5. GET_ENERGY_FREQ - Get frequency (Hz) for chip<br />
  Request:  RELAY-GET_ENERGY_FREQ-255,{chip}<br />
  Response: RELAY-GET_ENERGY_FREQ-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_FREQ-255,1<br />
    Response: RELAY-GET_ENERGY_FREQ-255,1,50.00,OK<br />
<br />
6. GET_ENERGY_TEMP - Get temperature &copy; for chip<br />
  Request:  RELAY-GET_ENERGY_TEMP-255,{chip}<br />
  Response: RELAY-GET_ENERGY_TEMP-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_TEMP-255,1<br />
    Response: RELAY-GET_ENERGY_TEMP-255,1,35.5,OK<br />
<br />
7. GET_ENERGY_PF - Get power factor for chip<br />
  Request:  RELAY-GET_ENERGY_PF-255,{chip}<br />
  Response: RELAY-GET_ENERGY_PF-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_PF-255,1<br />
    Response: RELAY-GET_ENERGY_PF-255,1,0.95,OK<br />
<br />
8. GET_ENERGY_SUM - Get total energy (kWh) for chip<br />
  Request:  RELAY-GET_ENERGY_SUM-255,{chip}<br />
  Response: RELAY-GET_ENERGY_SUM-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_SUM-255,1<br />
    Response: RELAY-GET_ENERGY_SUM-255,1,12500,OK<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9750" target="_blank" title="">Nx-Energy-meter-udp-loxone.png</a> (Size: 141.99 KB / Downloads: 258)
protocol download:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9751" target="_blank" title="">Nx-energy_loxone_protocol.txt</a> (Size: 2.34 KB / Downloads: 138)
			<content:encoded><![CDATA[Energy Loxone Protocol<br />
<br />
Overview<br />
--------<br />
<br />
<br />
Commands<br />
--------<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
		</item>
		<item>
			<title><![CDATA[N10 smart energy meter ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9306</link>
			<pubDate>Sat, 02 May 2026 19:50:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9306</guid>
			<description><![CDATA[N10 smart energy meter ESP32 system block diagram<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9734" target="_blank" title="">KinCony-N10-smart-energy-meter-diagram.png</a> (Size: 1.53 MB / Downloads: 307)
			<content:encoded><![CDATA[N10 smart energy meter ESP32 system block diagram<br />
		</item>
		<item>
			<title><![CDATA[[SOLVED] N10 - no KWH shown]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9299</link>
			<pubDate>Fri, 01 May 2026 08:47:28 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10806">Lattkincon</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9299</guid>
			<description><![CDATA[Hi, I have just received my N10 and its all working - except the kwh is always zero in homeassistant and on the "monitor" page on kc3<br />
<br />
I have tried the ESPhome firmware and the KC3 firmware &gt; MQTT &gt; Homeassistant with the same results - screenshots below for reference<br />
<br />
When i used the ESPhome firmware i used this config file which mentions fixing the kwh  <a href="https://www.kincony.com/forum/attachment.php?aid=9373" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/attachment.php?aid=9373</a><br />
<br />
I found this post - <a href="https://www.kincony.com/forum/showthread.php?tid=9107" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9107</a>, and tried flashing via USBC port but it will not work - must this use the RS485? <br />
<br />
Thank you<br />
 <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9725" target="_blank" title="">Screenshot 2026-05-01 085712.png</a> (Size: 30.68 KB / Downloads: 331)
<!-- end: postbit_attachments_attachment --><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9726" target="_blank" title="">Screenshot 2026-05-01 085842.png</a> (Size: 10.55 KB / Downloads: 266)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9727" target="_blank" title="">Screenshot 2026-05-01 090209.png</a> (Size: 53.89 KB / Downloads: 286)
			<content:encoded><![CDATA[Hi, I have just received my N10 and its all working - except the kwh is always zero in homeassistant and on the "monitor" page on kc3<br />
<br />
<br />
<br />
<br />
Thank you<br />
 <br />
		</item>
		<item>
			<title><![CDATA[N10 wire case diagram for 1 phase load]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9206</link>
			<pubDate>Fri, 03 Apr 2026 08:22:52 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9206</guid>
			<description><![CDATA[N10 wire case diagram for 1 phase load<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9523" target="_blank" title="">N10-1-phase.JPG</a> (Size: 102.43 KB / Downloads: 221)
			<content:encoded><![CDATA[N10 wire case diagram for 1 phase load<br />
		</item>
		<item>
			<title><![CDATA[N60 N30 N20 N10 ARM CPU firmware V20_260324SP]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9169</link>
			<pubDate>Tue, 24 Mar 2026 12:59:27 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9169</guid>
			<description><![CDATA[fixed bug can't remember energy data when power off.<br />
you can download by bootloader.exe tool by RS485.<br />
ARM BIN file download:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9480" target="_blank" title="">N10203060_KU_V20_260324SP.zip</a> (Size: 14.42 KB / Downloads: 305)
<br />
bootloader.exe tool: <br />
<img src="https://www.kincony.com/forum/images/attachtypes/zip.png" loading="lazy"  alt="[Image: zip.png]" class="mycode_img" />   <a href="https://www.kincony.com/forum/attachment.php?aid=8890" target="_blank" rel="noopener" class="mycode_url"><span style="color: #0072bc;" class="mycode_color">KC868 Controller Bootloader.zip</span></a> <br />
<img src="https://www.kincony.com/forum/attachment.php?aid=8891" loading="lazy"  alt="[Image: attachment.php?aid=8891]" class="mycode_img" />   <br />
1. set baud rate=38400bps.<br />
2. open com port.<br />
3. power on Nx board, during LED fast blink when the "bootloader Detect" button right now. Then board will go to bootloader mode.<br />
4. open BIN file<br />
5. press "Download" button, begin download firmware, after finished, press "Run" button, ARM CPU begin work.<br />
<img src="https://www.kincony.com/forum/attachment.php?aid=8892" loading="lazy"  alt="[Image: attachment.php?aid=8892]" class="mycode_img" />]]></description>
			<content:encoded><![CDATA[fixed bug can't remember energy data when power off.<br />
<br />
<img src="https://www.kincony.com/forum/attachment.php?aid=8892" loading="lazy"  alt="[Image: attachment.php?aid=8892]" class="mycode_img" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[how to read BL0910 energy chip RAW data by modbus pull via RS485]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9163</link>
			<pubDate>Tue, 24 Mar 2026 10:13:44 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9163</guid>
			<description><![CDATA[1: open NX_chip.mbp in modbus pull software.<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9399" target="_blank" title="">modbus-open-config.png</a> (Size: 92.01 KB / Downloads: 306)
<br />
2: set COM port. you can use USB-RS485 adapter connect to your computer:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9400" target="_blank" title="">modbus-pull-COM-setting.png</a> (Size: 87.06 KB / Downloads: 286)
<br />
3: <br />
you can read BL0910-1 chip from address 100 , register count: 68<br />
you can read BL0910-2 chip from address 200 , register count: 68 <br />
you can read BL0910-3 chip from address 300 , register count: 68 <br />
you can read BL0910-4 chip from address 400 , register count: 68 <br />
you can read BL0910-5 chip from address 500 , register count: 68 <br />
you can read BL0910-6 chip from address 600 , register count: 68 <br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9401" target="_blank" title="">modbus-pull-read-BL0910-1.png</a> (Size: 96.25 KB / Downloads: 282)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9402" target="_blank" title="">modbus-pull-read-BL0910-2.png</a> (Size: 98.36 KB / Downloads: 340)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9403" target="_blank" title="">modbus-pull-read-BL0910-3.png</a> (Size: 94.91 KB / Downloads: 338)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9404" target="_blank" title="">modbus-pull-read-BL0910-4.png</a> (Size: 96.68 KB / Downloads: 311)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9405" target="_blank" title="">modbus-pull-read-BL0910-5.png</a> (Size: 95.49 KB / Downloads: 309)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9406" target="_blank" title="">modbus-pull-read-BL0910-6.png</a> (Size: 95.27 KB / Downloads: 352)
<br />
<img src="https://www.kincony.com/forum/attachment.php?aid=9381" loading="lazy"  alt="[Image: attachment.php?aid=9381]" class="mycode_img" /> <br />
<img src="https://www.kincony.com/forum/attachment.php?aid=9387" loading="lazy"  alt="[Image: attachment.php?aid=9387]" class="mycode_img" /><br /><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9398" target="_blank" title="">NX_chip.zip</a> (Size: 654 bytes / Downloads: 310)
			<content:encoded><![CDATA[1: open NX_chip.mbp in modbus pull software.<br />
<br />
<br />
3: <br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[N10 configure yaml for ESPhome 0.001kwh precision]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9154</link>
			<pubDate>Mon, 23 Mar 2026 09:54:55 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9154</guid>
			<description><![CDATA[note: ARM CPU firmware version should &gt;= V20_260305SP<br />
ARM CPU firmware download: <a href="https://www.kincony.com/forum/showthread.php?tid=9107" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9107</a><br />
  friendly_name: n10<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
  # baud_rate: 0<br />
<br />
api:<br />
<br />
ota:<br />
  platform: esphome<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
  rx_pin: 9<br />
  tx_pin: 10<br />
  baud_rate: 115200<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
<br />
web_server:<br />
  port: 80<br />
<br />
text_sensor:<br />
  - platform: ethernet_info<br />
    ip_address:<br />
      name: ESP IP Address<br />
    dns_address:<br />
      name: ESP DNS Address<br />
    mac_address:<br />
      name: ESP MAC Address<br />
<br />
font:<br />
<br />
i2c:<br />
  sda: 18<br />
  scl: 17<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());<br />
<br />
modbus:<br />
  uart_id: uart_modbus<br />
<br />
    modbus_id: mb1<br />
    address: 1<br />
    update_interval: 5s<br />
    command_throttle: 200ms<br />
<br />
sensor:<br />
  # Protocol notes for this PR:<br />
  # - current: U_DWORD_R, scaled by 0.001 A<br />
  # - power: &nbsp;&nbsp;S_DWORD_R, scaled by 0.1 W<br />
  # - energy:  FP32_R, unit kWh<br />
  # - voltage/frequency remain U_WORD * 0.01<br />
  # - temperature remains FP32_R<br />
<br />
    address: 100<br />
    unit_of_measurement: A<br />
    device_class: current<br />
    state_class: measurement<br />
    accuracy_decimals: 3<br />
    value_type: U_DWORD_R<br />
    filters:<br />
      - multiply: 0.001<br />
<br />
    address: 102<br />
    filters:<br />
<br />
    address: 104<br />
    filters:<br />
<br />
    address: 106<br />
    filters:<br />
<br />
    address: 108<br />
    filters:<br />
<br />
    address: 110<br />
    filters:<br />
<br />
    address: 112<br />
    filters:<br />
<br />
    address: 114<br />
    filters:<br />
<br />
    address: 116<br />
    filters:<br />
<br />
    address: 118<br />
    filters:<br />
<br />
    address: 120<br />
    unit_of_measurement: W<br />
    device_class: power<br />
    accuracy_decimals: 1<br />
    value_type: S_DWORD_R<br />
    filters:<br />
      - multiply: 0.1<br />
<br />
    address: 122<br />
    filters:<br />
<br />
    address: 124<br />
    filters:<br />
<br />
    address: 126<br />
    filters:<br />
<br />
    address: 128<br />
    filters:<br />
<br />
    address: 130<br />
    filters:<br />
<br />
    address: 132<br />
    filters:<br />
<br />
    address: 134<br />
    filters:<br />
<br />
    address: 136<br />
    filters:<br />
<br />
    address: 138<br />
    filters:<br />
<br />
    address: 140<br />
    unit_of_measurement: kWh<br />
    device_class: energy<br />
    state_class: total_increasing<br />
    value_type: FP32_R<br />
<br />
    address: 142<br />
<br />
    address: 144<br />
<br />
    address: 146<br />
<br />
    address: 148<br />
<br />
    address: 150<br />
<br />
    address: 152<br />
<br />
    address: 154<br />
<br />
    address: 156<br />
<br />
    address: 158<br />
<br />
    address: 160<br />
<br />
    address: 162<br />
    device_class: voltage<br />
    accuracy_decimals: 2<br />
    filters:<br />
      - multiply: 0.01<br />
<br />
    address: 163<br />
    unit_of_measurement: Hz<br />
    device_class: frequency<br />
    filters:<br />
<br />
    address: 164<br />
    unit_of_measurement: °C<br />
    device_class: temperature<br />
<br />
    address: 166<br />
    value_type: FP32_R</code></div></div> yaml download:  <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9373" target="_blank" title="">n10_esphome.txt</a> (Size: 12.27 KB / Downloads: 275)
			<content:encoded><![CDATA[note: ARM CPU firmware version should &gt;= V20_260305SP<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ota:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
  rx_pin: 9<br />
  tx_pin: 10<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
<br />
web_server:<br />
  port: 80<br />
<br />
text_sensor:<br />
    ip_address:<br />
    dns_address:<br />
    mac_address:<br />
<br />
font:<br />
<br />
i2c:<br />
  sda: 18<br />
  scl: 17<br />
<br />
display:<br />
    address: 0x3C<br />
    lambda: |-<br />
<br />
modbus:<br />
<br />
    address: 1<br />
<br />
sensor:<br />
<br />
    address: 100<br />
    filters:<br />
<br />
    address: 102<br />
    filters:<br />
<br />
    address: 104<br />
    filters:<br />
<br />
    address: 106<br />
    filters:<br />
<br />
    address: 108<br />
    filters:<br />
<br />
    address: 110<br />
    filters:<br />
<br />
    address: 112<br />
    filters:<br />
<br />
    address: 114<br />
    filters:<br />
<br />
    address: 116<br />
    filters:<br />
<br />
    address: 118<br />
    filters:<br />
<br />
    address: 120<br />
    filters:<br />
<br />
    address: 122<br />
    filters:<br />
<br />
    address: 124<br />
    filters:<br />
<br />
    address: 126<br />
    filters:<br />
<br />
    address: 128<br />
    filters:<br />
<br />
    address: 130<br />
    filters:<br />
<br />
    address: 132<br />
    filters:<br />
<br />
    address: 134<br />
    filters:<br />
<br />
    address: 136<br />
    filters:<br />
<br />
    address: 138<br />
    filters:<br />
<br />
    address: 140<br />
<br />
    address: 142<br />
<br />
    address: 144<br />
<br />
    address: 146<br />
<br />
    address: 148<br />
<br />
    address: 150<br />
<br />
    address: 152<br />
<br />
    address: 154<br />
<br />
    address: 156<br />
<br />
    address: 158<br />
<br />
    address: 160<br />
<br />
    address: 162<br />
    filters:<br />
<br />
    address: 163<br />
    filters:<br />
<br />
    address: 164<br />
<br />
    address: 166<br />
		</item>
		<item>
			<title><![CDATA[N10 port modbus]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9085</link>
			<pubDate>Tue, 03 Mar 2026 18:41:09 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10509">R43</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9085</guid>
			<description><![CDATA[There's no way to change the speed and port using Modbus. Please fix this or send me a firmware update with port 4 instead of the default 1. Thank you.]]></description>
			<content:encoded><![CDATA[There's no way to change the speed and port using Modbus. Please fix this or send me a firmware update with port 4 instead of the default 1. Thank you.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Problem when connecting USB-C]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8673</link>
			<pubDate>Fri, 24 Oct 2025 02:27:46 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9741">aym55</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8673</guid>
I just bought N10 module, i connected it to 24V power and it works. However when i try to put USB-C cable from computer to Kincony for download firmware it suddenly have short cut and my 24V power supply turn off , i must take off usb-c for it to work again, this situation is from early begining.I get deffective Unit ?<br />
<br />
Thanks.]]></description>
<br />
Thanks.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N10 configure yaml for ESPhome]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8645</link>
			<pubDate>Mon, 13 Oct 2025 18:22:57 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8645</guid>
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
# Enable logging<br />
logger:<br />
<br />
api:<br />
<br />
ota:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
  rx_pin: 9<br />
  tx_pin: 10<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
<br />
web_server:<br />
  port: 80<br />
<br />
text_sensor:<br />
    ip_address:<br />
      address_0:<br />
        name: ESP IP Address 0<br />
      address_1:<br />
        name: ESP IP Address 1<br />
      address_2:<br />
        name: ESP IP Address 2<br />
      address_3:<br />
        name: ESP IP Address 3<br />
      address_4:<br />
        name: ESP IP Address 4<br />
    dns_address:<br />
    mac_address:<br />
<br />
font:<br />
<br />
i2c:<br />
  sda: 18<br />
  scl: 17<br />
<br />
display:<br />
    address: 0x3C<br />
    lambda: |-<br />
<br />
modbus:<br />
<br />
  - address: 1<br />
<br />
sensor:<br />
    address: 100<br />
    filters:<br />
<br />
    address: 102<br />
    filters:<br />
<br />
    address: 104<br />
    filters:<br />
<br />
    address: 106<br />
    filters:<br />
<br />
    address: 108<br />
    filters:<br />
<br />
    address: 110<br />
    filters:<br />
<br />
    address: 112<br />
    filters:<br />
<br />
    address: 114<br />
    filters:<br />
<br />
    address: 116<br />
    filters:<br />
<br />
    address: 118<br />
    filters:<br />
<br />
    address: 120<br />
    filters:<br />
<br />
    address: 122<br />
    filters:<br />
<br />
    address: 124<br />
    filters:<br />
<br />
    address: 126<br />
    filters:<br />
<br />
    address: 128<br />
    filters:<br />
<br />
    address: 130<br />
    filters:<br />
<br />
    address: 132<br />
    filters:<br />
<br />
    address: 134<br />
    filters:<br />
<br />
    address: 136<br />
    filters:<br />
<br />
    address: 138<br />
    filters:<br />
<br />
    address: 140<br />
<br />
    address: 142<br />
<br />
    address: 144<br />
<br />
    address: 146<br />
<br />
    address: 148<br />
<br />
    address: 150<br />
<br />
    address: 152<br />
<br />
    address: 154<br />
<br />
    address: 156<br />
<br />
    address: 158<br />
<br />
    address: 160<br />
<br />
    address: 162<br />
    filters:<br />
<br />
    address: 163<br />
    filters:<br />
<br />
    address: 164<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8458" target="_blank" title="">N10-HA.txt</a> (Size: 10.03 KB / Downloads: 458)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
<br />
logger:<br />
<br />
api:<br />
<br />
ota:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
uart:<br />
  rx_pin: 9<br />
  tx_pin: 10<br />
  stop_bits: 1<br />
  data_bits: 8<br />
  parity: NONE<br />
<br />
web_server:<br />
  port: 80<br />
<br />
text_sensor:<br />
    ip_address:<br />
      address_0:<br />
      address_1:<br />
      address_2:<br />
      address_3:<br />
      address_4:<br />
    dns_address:<br />
    mac_address:<br />
<br />
font:<br />
<br />
i2c:<br />
  sda: 18<br />
  scl: 17<br />
<br />
display:<br />
    address: 0x3C<br />
    lambda: |-<br />
<br />
modbus:<br />
<br />
  - address: 1<br />
<br />
sensor:<br />
    address: 100<br />
    filters:<br />
<br />
    address: 102<br />
    filters:<br />
<br />
    address: 104<br />
    filters:<br />
<br />
    address: 106<br />
    filters:<br />
<br />
    address: 108<br />
    filters:<br />
<br />
    address: 110<br />
    filters:<br />
<br />
    address: 112<br />
    filters:<br />
<br />
    address: 114<br />
    filters:<br />
<br />
    address: 116<br />
    filters:<br />
<br />
    address: 118<br />
    filters:<br />
<br />
    address: 120<br />
    filters:<br />
<br />
    address: 122<br />
    filters:<br />
<br />
    address: 124<br />
    filters:<br />
<br />
    address: 126<br />
    filters:<br />
<br />
    address: 128<br />
    filters:<br />
<br />
    address: 130<br />
    filters:<br />
<br />
    address: 132<br />
    filters:<br />
<br />
    address: 134<br />
    filters:<br />
<br />
    address: 136<br />
    filters:<br />
<br />
    address: 138<br />
    filters:<br />
<br />
    address: 140<br />
<br />
    address: 142<br />
<br />
    address: 144<br />
<br />
    address: 146<br />
<br />
    address: 148<br />
<br />
    address: 150<br />
<br />
    address: 152<br />
<br />
    address: 154<br />
<br />
    address: 156<br />
<br />
    address: 158<br />
<br />
    address: 160<br />
<br />
    address: 162<br />
    filters:<br />
<br />
    address: 163<br />
    filters:<br />
<br />
    address: 164<br />
		</item>
		<item>
			<title><![CDATA[N10 Energy RS485 Modbus Protocol]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8642</link>
			<pubDate>Mon, 13 Oct 2025 10:04:32 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8642</guid>
			<description><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>N10 Energy Module Modbus Protocol Specification<br />
==============================================<br />
<br />
1. Overview<br />
-----------<br />
<br />
This document specifies the Modbus communication protocol for the N10 Energy Module.<br />
The device communicates using the Modbus RTU protocol and provides access to electrical<br />
measurement parameters including current, power, energy consumption, voltage, frequency,<br />
temperature, and power factor.<br />
<br />
2. Module Characteristics<br />
-------------------------<br />
<br />
- Energy Monitoring Chips: 1<br />
- Communication Protocol: Modbus RTU<br />
- Wireless Technology: Not applicable (wired connection)<br />
- Maximum Sensors Supported: 32<br />
- Board Features: Display, Ethernet (W5500), 4G, SD Card support<br />
- GPIO Availability: 2 free GPIOs (pins 15, 16)<br />
<br />
3. Communication Parameters<br />
---------------------------<br />
<br />
- Protocol: Modbus RTU<br />
- Baud Rate: 38400<br />
- Function Codes:<br />
  * 0x03: Read Holding Registers (for reading data)<br />
  * 0x05: Write Single Coil (for control operations)<br />
  * 0x10: Write Multiple Registers (for configuration)<br />
<br />
4. Chip Addressing<br />
<br />
The N10 Energy Module contains 1 measurement chip with base address:<br />
<br />
+-------------+--------------+--------------------+<br />
| Chip Number | Base Address | Physical Location  |<br />
| Chip 1      | 100          | Main board       &nbsp;&nbsp;|<br />
<br />
5. Data Structure<br />
<br />
The chip provides the following data (accessible via Function Code 0x03):<br />
<br />
5.1 Current Measurements (RMS)<br />
------------------------------<br />
<br />
+----------------+------------+-------+--------+---------------+<br />
| Register Offset| Parameter  | Units | Format | Resolution    |<br />
| 0              | RMS_1      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 2              | RMS_2      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 4              | RMS_3      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 6              | RMS_4      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 8              | RMS_5      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 10           &nbsp;&nbsp;| RMS_6      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 12           &nbsp;&nbsp;| RMS_7      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 14           &nbsp;&nbsp;| RMS_8      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 16           &nbsp;&nbsp;| RMS_9      | A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
| 18           &nbsp;&nbsp;| RMS_10   &nbsp;&nbsp;| A   &nbsp;&nbsp;| uint32 | 0.001A/LSB    |<br />
<br />
Example: To read RMS_1 from Chip 1, read registers 100 and 101 (2 registers for uint32).<br />
Display: Reading of 5432 represents 5.432A (5432 × 0.001A)<br />
<br />
5.2 Power Measurements (WATT)<br />
<br />
| 20           &nbsp;&nbsp;| WATT_1   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 22           &nbsp;&nbsp;| WATT_2   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 24           &nbsp;&nbsp;| WATT_3   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 26           &nbsp;&nbsp;| WATT_4   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 28           &nbsp;&nbsp;| WATT_5   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 30           &nbsp;&nbsp;| WATT_6   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 32           &nbsp;&nbsp;| WATT_7   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 34           &nbsp;&nbsp;| WATT_8   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 36           &nbsp;&nbsp;| WATT_9   &nbsp;&nbsp;| W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
| 38           &nbsp;&nbsp;| WATT_10    | W   &nbsp;&nbsp;| uint32 | 0.1W/LSB      |<br />
<br />
Example: To read WATT_1 from Chip 1, read registers 120 and 121 (2 registers for uint32).<br />
Display: Reading of 12345 represents 1234.5W (12345 × 0.1W)<br />
<br />
5.3 Energy Consumption Measurements<br />
-----------------------------------<br />
<br />
+----------------+-------------+-------+--------+---------------------+<br />
| Register Offset| Parameter &nbsp;&nbsp;| Units | Format | Resolution          |<br />
| 40           &nbsp;&nbsp;| Energy_1    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 42           &nbsp;&nbsp;| Energy_2    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 44           &nbsp;&nbsp;| Energy_3    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 46           &nbsp;&nbsp;| Energy_4    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 48           &nbsp;&nbsp;| Energy_5    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 50           &nbsp;&nbsp;| Energy_6    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 52           &nbsp;&nbsp;| Energy_7    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 54           &nbsp;&nbsp;| Energy_8    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 56           &nbsp;&nbsp;| Energy_9    | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 58           &nbsp;&nbsp;| Energy_10 &nbsp;&nbsp;| kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
| 60           &nbsp;&nbsp;| Energy_Sum  | kWh &nbsp;&nbsp;| uint32 | 1kWh/LSB            |<br />
<br />
Note: The maximum measurable energy per channel is 65535 kWh.<br />
<br />
5.4 Other Measurements<br />
<br />
| 62           &nbsp;&nbsp;| RMS_V     &nbsp;&nbsp;| V   &nbsp;&nbsp;| uint16 | 0.01V/LSB         &nbsp;&nbsp;|<br />
| 63           &nbsp;&nbsp;| Period      | Hz    | uint16 | 0.01Hz/LSB          |<br />
| 64           &nbsp;&nbsp;| TPS1        | °C    | float  | 0.1°C/LSB         &nbsp;&nbsp;|<br />
| 66           &nbsp;&nbsp;| PF          | -   &nbsp;&nbsp;| float  | Power Factor (0-1)  |<br />
<br />
6. Control Functions (Function Code 0x05)<br />
------------------------------------------<br />
<br />
The following control registers can be written to using the Modbus function code 0x05:<br />
<br />
+----------+------------------------------+--------------------------------------------+<br />
| Register | Function                   &nbsp;&nbsp;| Description                                |<br />
| 500      | Warm Reset                 &nbsp;&nbsp;| Resets the device                          |<br />
| 501      | Save Parameters to Flash   &nbsp;&nbsp;| Save communication parameters to flash   &nbsp;&nbsp;|<br />
| 503      | Save Coefficients to Flash &nbsp;&nbsp;| Save calibration coefficients to flash   &nbsp;&nbsp;|<br />
| 504      | Clear Coefficients         &nbsp;&nbsp;| Reset all coefficients to 1.0 (use caution)|<br />
| 510      | Restore Factory Settings   &nbsp;&nbsp;| Restore factory communication parameters &nbsp;&nbsp;|<br />
<br />
7. Energy Clearing Functions (Function Code 0x05)<br />
--------------------------------------------------<br />
<br />
The following registers clear energy consumption data when written with function code 0x05:<br />
<br />
7.1 Clear All Channels on the Chip<br />
<br />
+----------+--------------------------------+<br />
| Register | Function                     &nbsp;&nbsp;|<br />
| 520      | Clear all energy on Chip 1   &nbsp;&nbsp;|<br />
<br />
7.2 Clear Individual Channels<br />
<br />
+----------------+------------------------------------------------+<br />
| Register Range | Function                                     &nbsp;&nbsp;|<br />
| 526-535        | Clear energy on Chip 1, channels 1-10          |<br />
| 586            | Clear sum energy on Chip 1                   &nbsp;&nbsp;|<br />
<br />
8. Calibration Coefficients (Function Code 0x03 to read, 0x10 to write)<br />
------------------------------------------------------------------------<br />
<br />
All coefficients are stored as floating-point values in CDBA format.<br />
<br />
8.1 Current (RMS) Coefficients for Chip 1<br />
<br />
+----------+---------------------+---------+<br />
| Register | Parameter         &nbsp;&nbsp;| Default |<br />
| 3000   &nbsp;&nbsp;| FACTOR OF RMS1      | 1.0   &nbsp;&nbsp;|<br />
| 3002   &nbsp;&nbsp;| FACTOR OF RMS2      | 1.0   &nbsp;&nbsp;|<br />
| 3004   &nbsp;&nbsp;| FACTOR OF RMS3      | 1.0   &nbsp;&nbsp;|<br />
| 3006   &nbsp;&nbsp;| FACTOR OF RMS4      | 1.0   &nbsp;&nbsp;|<br />
| 3008   &nbsp;&nbsp;| FACTOR OF RMS5      | 1.0   &nbsp;&nbsp;|<br />
| 3010   &nbsp;&nbsp;| FACTOR OF RMS6      | 1.0   &nbsp;&nbsp;|<br />
| 3012   &nbsp;&nbsp;| FACTOR OF RMS7      | 1.0   &nbsp;&nbsp;|<br />
| 3014   &nbsp;&nbsp;| FACTOR OF RMS8      | 1.0   &nbsp;&nbsp;|<br />
| 3016   &nbsp;&nbsp;| FACTOR OF RMS9      | 1.0   &nbsp;&nbsp;|<br />
| 3018   &nbsp;&nbsp;| FACTOR OF RMS10   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
<br />
8.2 Power (WATT) Coefficients for Chip 1<br />
<br />
| 3020   &nbsp;&nbsp;| FACTOR OF WATT1   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3022   &nbsp;&nbsp;| FACTOR OF WATT2   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3024   &nbsp;&nbsp;| FACTOR OF WATT3   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3026   &nbsp;&nbsp;| FACTOR OF WATT4   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3028   &nbsp;&nbsp;| FACTOR OF WATT5   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3030   &nbsp;&nbsp;| FACTOR OF WATT6   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3032   &nbsp;&nbsp;| FACTOR OF WATT7   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3034   &nbsp;&nbsp;| FACTOR OF WATT8   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3036   &nbsp;&nbsp;| FACTOR OF WATT9   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3038   &nbsp;&nbsp;| FACTOR OF WATT10    | 1.0   &nbsp;&nbsp;|<br />
<br />
8.3 Energy Coefficients for Chip 1<br />
<br />
+----------+-----------------------+---------+<br />
| 3040   &nbsp;&nbsp;| FACTOR OF ENERGY1   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3042   &nbsp;&nbsp;| FACTOR OF ENERGY2   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3044   &nbsp;&nbsp;| FACTOR OF ENERGY3   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3046   &nbsp;&nbsp;| FACTOR OF ENERGY4   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3048   &nbsp;&nbsp;| FACTOR OF ENERGY5   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3050   &nbsp;&nbsp;| FACTOR OF ENERGY6   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3052   &nbsp;&nbsp;| FACTOR OF ENERGY7   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3054   &nbsp;&nbsp;| FACTOR OF ENERGY8   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3056   &nbsp;&nbsp;| FACTOR OF ENERGY9   &nbsp;&nbsp;| 1.0   &nbsp;&nbsp;|<br />
| 3058   &nbsp;&nbsp;| FACTOR OF ENERGY10    | 1.0   &nbsp;&nbsp;|<br />
| 3060   &nbsp;&nbsp;| FACTOR OF ENERGY SUM  | 1.0   &nbsp;&nbsp;|<br />
<br />
9. Programming Notes<br />
<br />
1. After modifying communication parameters, write to register 501 to save them to flash.<br />
2. After modifying calibration coefficients, write to register 503 to save them to flash.<br />
3. Read the entire data structure for the chip by reading 68 registers starting at base<br />
 &nbsp;&nbsp;address 100.<br />
4. For 32-bit values (uint32, float), read/write two consecutive registers.<br />
5. When writing float values, use the CDBA format.<br />
6. All energy measurements have a maximum value of 65535 kWh per channel.<br />
<br />
10. Comparison with Other N-Series Modules<br />
<br />
+------------------+------------------+------------------+------------------+<br />
| Feature          | N10           &nbsp;&nbsp;| N20              | N30              |<br />
| Communication    | Modbus RTU      | Modbus RTU     &nbsp;&nbsp;| Modbus RTU     &nbsp;&nbsp;|<br />
| Energy Chips   &nbsp;&nbsp;| 1             &nbsp;&nbsp;| 2                | 3                |<br />
| Channels       &nbsp;&nbsp;| 10              | 20             &nbsp;&nbsp;| 30             &nbsp;&nbsp;|<br />
| Base Addresses &nbsp;&nbsp;| 100           &nbsp;&nbsp;| 100, 200       &nbsp;&nbsp;| 100, 200, 300    |<br />
| Data Structure &nbsp;&nbsp;| Standard        | Dual-chip        | Triple-chip      |<br />
| Installation   &nbsp;&nbsp;| Wired         &nbsp;&nbsp;| Wired            | Wired            |<br />
<br />
11. Conclusion<br />
<br />
The N10 Energy Module provides single-chip energy monitoring with Modbus RTU<br />
communication, making it ideal for small-scale installations requiring precise<br />
electrical measurement and monitoring. The device offers 10 channels of current,<br />
power, and energy monitoring with comprehensive calibration and control capabilities.<br />
<br />
==============================================================================<br />
Document generated for N10 Energy Module Modbus Protocol<br />
For technical support, please contact Kincony support team.</code></div></div> protocol document download: <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8455" target="_blank" title="">N10_Energy_Modbus_Protocol.txt</a> (Size: 11.62 KB / Downloads: 375)
			<content:encoded><![CDATA[<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>N10 Energy Module Modbus Protocol Specification<br />
<br />
1. Overview<br />
-----------<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[N60/N30/N20/N10/M30 CT selection and Load MAX current formula]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8603</link>
			<pubDate>Thu, 04 Sep 2025 07:47:15 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8603</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8392" target="_blank" title="">CT-1.png</a> (Size: 47.07 KB / Downloads: 485)
every CT clamp input channel will have two resistance. for example, CT2 channel are R23, R24<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8393" target="_blank" title="">CT-2.png</a> (Size: 119.56 KB / Downloads: 511)
use the formula let input voltage &lt;700mV<br />
<br />
if your CT clamp sensor is 2000:1<br />
Load current=30A, <br />
input voltage = 5.1R*2*30A/2000=153mA (VIPN)<br />
<br />
so if input voltage &lt;700mA , use 5.1R resistance on PCB, 2000:1 MAX can detect 137A AC220V load.<br />
<br />
if you want support more large current, you can change the  resistance or change CT 2000:1 with other models. Just use by the  formula.]]></description>
<br />
<br />
<br />
if you want support more large current, you can change the  resistance or change CT 2000:1 with other models. Just use by the  formula.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N60 N30 N20 N10 firmware BL0910 energy chip register RAW data structure]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9164</link>
			<pubDate>Sun, 03 Aug 2025 11:31:20 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9164</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9407" target="_blank" title="">N60-meter-data-structure.png</a> (Size: 31.39 KB / Downloads: 544)
		</item>
	</channel>
</rss>
