	<channel>
		<title><![CDATA[Smart Home Automation Forum - N30]]></title>
		<pubDate>Sat, 31 Oct 2026 07:01:21 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[N30 most recent ESPhome]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9898</link>
			<pubDate>Fri, 23 Oct 2026 18:31:05 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=7228">ThomasJS</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9898</guid>
			<description><![CDATA[Hello!<br />
<br />
I'm interested in buying the N30, but I see multiple issues on this forum about the current direction detection.<br />
<br />
I came accross this one on the forum:<br />
<a href="https://www.kincony.com/forum/attachment.php?aid=9375" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/attachment.php?aid=9375</a><br />
<br />
This one is on the webshop: (i guess this is the wrong one?)<br />
<a href="https://www.kincony.com/forum/attachment.php?aid=8460" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/attachment.php?aid=8460</a><br />
<br />
This one on ESPHOME: (also older one?)<br />
<a href="https://devices.esphome.io/devices/kincony-n30/" target="_blank" rel="noopener" class="mycode_url">https://devices.esphome.io/devices/kincony-n30/</a><br />
<br />
Which N30 ESPHome configuration correctly expose signed, bidirectional active power for each BL0910 CT channel? <br />
Which is the most recent ESPHOME config?]]></description>
			<content:encoded><![CDATA[Hello!<br />
<br />
<br />
<br />
<br />
<br />
Which is the most recent ESPHOME config?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N30 (KCS): energy counters of BL0910 #2 and #3 published as 0 kWh at boot]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9860</link>
			<pubDate>Fri, 09 Oct 2026 16:34:06 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11433">dominique_manas@hotmail.com</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9860</guid>
<br />
I found an issue with the energy counters on the N30 running KCS firmware (version: v3.27.2), integrated in Home Assistant through MQTT discovery.<br />
<br />
What happens:<br />
Each time the N30 restarts (firmware flash, power cut, reboot), the channels of BL0910 #2 and #3 (Energy 2 and Energy 3, all 10 channels each, plus energy_total) publish energy = 0 kWh for a moment, then the real value again a few seconds later.<br />
BL0910 #1 (Energy 1) does not do this. Its channels only go unavailable during the restart and come back with the correct value, never 0.<br />
<br />
The counters are not lost inside the N30: after the restart the values continue from where they were (e.g. 258.062 kWh -&gt; 0 -&gt; 258.062 kWh).<br />
<br />
Why it is a problem:<br />
Home Assistant treats energy sensors as increasing counters (state_class: total_increasing). A drop to 0 is seen as a meter reset, and the return to the real value is counted as new consumption.<br />
This morning the N30 restarted 3 times after a firmware flash. Each channel of Energy 2 and Energy 3 was counted as consuming its whole counter value 4 times. For example, one channel with 258 kWh got 1032 kWh of phantom consumption added in one morning. I had to correct the statistics by hand.<br />
<br />
Request:<br />
Please do not publish energy values until the real counters have been read from the BL0910 chips at boot. Publishing nothing (or keeping the previous retained value) is fine. Publishing 0 is not.<br />
It would also help to know why only chips #2 and #3 behave like this and not chip #1.<br />
<br />
Thank you.]]></description>
<br />
<br />
What happens:<br />
<br />
<br />
<br />
Request:<br />
<br />
Thank you.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Best way to read from N30]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9846</link>
			<pubDate>Fri, 25 Sep 2026 17:13:36 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11908">ChrisNZ</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9846</guid>
			<description><![CDATA[Hi all,<br />
<br />
I am building a new home setup, with a Proxmox server hosting Home Assistant, Mosquitto, VictoriaMetrics and Grafana. I am about to install an N30 into my switchboard, and would like to collect data from it into VictoriaMetrics, as well as use the energy data for Home Assistant dashboards and automations. Ideally the energy data would be recorded into VictoriaMetrics at one second intervals, while Home Assistant should deal with a lower frequency of data, e.g. every 30 seconds.<br />
<br />
What is the <span style="font-style: italic;" class="mycode_i">best</span> (not necessarily simplest) way to do this? I can't find much documentation on the relative merits and functionality of the ESPHome vs KCS v3 firmware, how quickly the energy data updates, or which protocol would be best suited. Note the N30 will be connected by Ethernet, and I also have an Elfin EE11 RS485-Ethernet adapter if that's helpful. I'm also happy to install extra software (e.g. Telegraf) into Proxmox if that provides a better solution.]]></description>
			<content:encoded><![CDATA[Hi all,<br />
<br />
<br />
What is the <span style="font-style: italic;" class="mycode_i">best</span> (not necessarily simplest) way to do this? I can't find much documentation on the relative merits and functionality of the ESPHome vs KCS v3 firmware, how quickly the energy data updates, or which protocol would be best suited. Note the N30 will be connected by Ethernet, and I also have an Elfin EE11 RS485-Ethernet adapter if that's helpful. I'm also happy to install extra software (e.g. Telegraf) into Proxmox if that provides a better solution.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Modbus 485 extender kcs V3 and lora and PCB eletechsup 10ioA12]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9818</link>
			<pubDate>Fri, 11 Sep 2026 13:18:15 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11709">lollo9710</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9818</guid>
			<description><![CDATA[Buongiorno vorrei capire se posso integrare in kcs V3 queste schede modbus 485 rele e input eletechsup 10ioA12, la scheda ha 12 relè e 12 input tramite modbus. Inoltre vorrei sapere se posso comandare una scheda a6 sempre con lora slave? Inoltre volevo sapere a quale distanza massima posso installare i CT dalla scheda?]]></description>
			<content:encoded><![CDATA[Buongiorno vorrei capire se posso integrare in kcs V3 queste schede modbus 485 rele e input eletechsup 10ioA12, la scheda ha 12 relè e 12 input tramite modbus. Inoltre vorrei sapere se posso comandare una scheda a6 sempre con lora slave? Inoltre volevo sapere a quale distanza massima posso installare i CT dalla scheda?]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Current direction detection incorrect on channels 2 and 3]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9742</link>
			<pubDate>Thu, 13 Aug 2026 18:49:03 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9742</guid>
I have also noticed another issue with the <span style="font-weight: bold;" class="mycode_b">KinCony N30</span> when using the current direction detection.<br />
My N30 has <span style="font-weight: bold;" class="mycode_b">three rows/modules</span>, and all of my current clamps are installed and wired <span style="font-weight: bold;" class="mycode_b">in exactly the same physical direction</span>.<br />
However, when I enable the <span style="font-weight: bold;" class="mycode_b">current direction detection</span>, I get inconsistent results:<ul class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">Module 1:</span> current direction is detected correctly and the power values are positive.<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Module 2:</span> the power values are negative.<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Module 3:</span> the power values are also negative.<br />
</li>
</ul>
This happens even though the clamps on modules 1, 2 and 3 are installed in exactly the same direction.<br />
Without current direction detection, the measured power values are otherwise consistent.<br />
This makes me suspect that there may be an issue with the <span style="font-weight: bold;" class="mycode_b">polarity/sign handling or current direction detection in the firmware for modules 2 and 3</span>.<br />
Could you please check whether the current direction detection is implemented identically for all three modules?<br />
In particular, I would like to know whether there is a firmware configuration or calibration parameter that could cause modules 2 and 3 to have their current direction inverted compared with module 1.<br />
The expected behavior is that, with all clamps physically oriented in the same direction, the three modules should report the same sign for the same direction of current.<br />
Thank you.<!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10322" target="_blank" title="">Capture d’écran 2026-08-13 à 12.48.33.png</a> (Size: 5.73 MB / Downloads: 213)
<!-- end: postbit_attachments_attachment --><!-- start: postbit_attachments_attachment -->
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10323" target="_blank" title="">Capture d’écran 2026-08-13 à 12.48.10.png</a> (Size: 5.36 MB / Downloads: 234)
</li>
</li>
</li>
</ul>
		</item>
		<item>
			<title><![CDATA[MQTT Discovery: missing state_class for power sensors in Home Assistant]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9741</link>
			<pubDate>Thu, 13 Aug 2026 18:41:45 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9741</guid>
I noticed an issue with the MQTT Discovery configuration generated by the N30 when the device is integrated into <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>.<br />
For example, Home Assistant creates the following entity:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>sensor.n30_d0cf13020244_energy2_ch2_power</code></div></div>The N30 publishes this MQTT Discovery payload:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>{<br />
  "uniq_id": "D0CF13020244_sensor_energy2_power_ch2",<br />
  "~": "homeassistant/sensor/D0CF13020244energy2_power_ch2",<br />
  "name": "energy2_ch2.power",<br />
  "device": {<br />
    "name": "N30-D0CF13020244",<br />
    "identifiers": "D0CF13020244",<br />
    "manufacturer": "KinCony",<br />
    "model": "N30"<br />
  },<br />
  "config_topic": "~/config",<br />
  "avty_t": "D0CF13020244/avail",<br />
  "unit_of_meas": "W",<br />
  "dev_cla": "power",<br />
  "val_tpl": "{{ value | float | round(1) }}",<br />
  "stat_t": "~/state"<br />
}</code></div></div>In <span style="font-weight: bold;" class="mycode_b">Home Assistant</span>, the entity is therefore detected with:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>device_class: power<br />
unit_of_measurement: W</code></div></div>but <span style="font-weight: bold;" class="mycode_b">without</span>:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>state_class: measurement</code></div></div>The missing field in the MQTT Discovery payload is:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>"stat_cla": "measurement"</code></div></div>Interestingly, some other N30 power sensors are correctly detected by Home Assistant with:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>state_class: measurement<br />
unit_of_measurement: W<br />
device_class: power</code></div></div>For example, <br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>sensor.n30_bl0910_1_power_6</code></div></div> already has the correct <br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>state_class</code></div></div>.<br />
This suggests that the issue is specific to some of the MQTT Discovery configurations generated by the N30 firmware, particularly the <br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>energy*_ch*_power</code></div></div> sensors.<br />
Could you please check the N30 firmware and add:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>"stat_cla": "measurement"</code></div></div>to the MQTT Discovery configuration of all instantaneous power sensors?<br />
The expected configuration would be:<br />
<div class="codeblock"><div class="title">Code:</div><div class="body" dir="ltr"><code>"unit_of_meas": "W",<br />
"stat_cla": "measurement"</code></div></div>This would allow <span style="font-weight: bold;" class="mycode_b">Home Assistant</span> to correctly identify these entities as power measurements and use them properly for statistics and energy-related features.<br />
  "device": {<br />
  },<br />
		</item>
		<item>
			<title><![CDATA[solar production and consomation]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9740</link>
			<pubDate>Thu, 13 Aug 2026 16:36:39 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9740</guid>
			<description><![CDATA[Current sensor does not detect current direction<br />
Hello,<br />
I have a question regarding the current/power sensor on my KinCony device.<br />
The circuit is connected to a <span style="font-weight: bold;" class="mycode_b">1100 W pump</span>, with approximately <span style="font-weight: bold;" class="mycode_b">1000 W peak solar PV production</span>.<br />
I expected the sensor to detect the <span style="font-weight: bold;" class="mycode_b">direction of the current</span> and therefore show negative power when the solar panels are producing energy and sending it back through the circuit.<br />
In the attached screenshot:<ul class="mycode_list"><li><span style="font-weight: bold;" class="mycode_b">Green area:</span> nighttime. The pump is running and consuming approximately <span style="font-weight: bold;" class="mycode_b">1100 W</span>. This is normal.<br />
</li>
<li><span style="font-weight: bold;" class="mycode_b">Red area:</span> daytime. The solar panels are producing around <span style="font-weight: bold;" class="mycode_b">400 W</span>, with <span style="font-weight: bold;" class="mycode_b">no consumption from the pump</span>. However, the sensor still reports the power as positive instead of negative.<br />
</li>
</ul>
So it appears that the sensor measures the current magnitude but does not detect its direction.<br />
Is this sensor supposed to be bidirectional?<br />
If so, is there a specific orientation for the current transformer/sensor, or does it require a particular configuration to detect the direction of the current?<br />
Could someone explain how the current direction is detected and how I should configure or install the sensor to obtain positive values for consumption and negative values for solar production?<br />
Thank you.<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=10321" target="_blank" title="">Greenshot 2026-08-13 10.31.05.png</a> (Size: 54.95 KB / Downloads: 188)
			<content:encoded><![CDATA[Current sensor does not detect current direction<br />
Hello,<br />
</li>
</li>
</ul>
Thank you.<br />
<br />
		</item>
		<item>
			<title><![CDATA[Can't make AC868-A6 V1.4Sp work with Arduino IDE]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9563</link>
			<pubDate>Thu, 02 Jul 2026 03:55:31 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11129">JL_M_88</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9563</guid>
			<description><![CDATA[I just acquired an AC868-A6 V1.4 board from Aliexpress.<br />
<br />
I downloaded the lastest KCS_KC868_A6_V2.2.20.bin firmware in it<br />
<br />
I want to give a try to Arduino IDE.<br />
I found some ''demo programs'' on the site, such as the one below: (by the way the comment ''Blink Led on PIN0 isn't appropriate !!!) <br />
Selected ESP32Dev Module board type <br />
I can compile and download the program.<br />
After downloading the program, the ESP32 will keep reseting indefintely ...<br />
getting this message in the serial monitor:<br />
<br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">rst:0x8 (TG1WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">configsip: 0, SPIWP:0xee</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">mode<img src="https://www.kincony.com/forum/images/smilies/biggrin.png" alt="Big Grin" title="Big Grin" class="smilie smilie_4" />IO, clock div:1</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">load:0x3fff0030,len:4876</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">ho 0 tail 12 room 4</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">load:0x40078000,len:16560</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-style: italic;" class="mycode_i"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">load:0x40080400,len:3500</span></span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">entry 0x400805b4</span></span></span><br />
<span style="color: #ff4136;" class="mycode_color"><span style="font-size: small;" class="mycode_size"><span style="font-family: Arial Black;" class="mycode_font">ets Jul 29 2019 12:21:46</span></span></span><br />
<br />
Any idea about what can be wrong there ?<br />
<br />
Thanks<br />
<br />
JL<br />
<br />
<br />
<span style="color: #dae3e3;" class="mycode_color"><span style="font-family: Consolas, 'Courier New', monospace;" class="mycode_font"><span style="color: #7f8c8d;" class="mycode_color">/*</span><br />
<span style="color: #7f8c8d;" class="mycode_color"> Blink led on PIN0</span><br />
<span style="color: #7f8c8d;" class="mycode_color"> by Mischianti Renzo &lt;http://www.mischianti.org&gt;</span><br />
<span style="color: #7f8c8d;" class="mycode_color"> <a href="https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/" target="_blank" rel="noopener" class="mycode_url">https://www.mischianti.org/2019/01/02/pc...asy-usage/</a></span><br />
<span style="color: #7f8c8d;" class="mycode_color">*/</span><br />
<span style="color: #c586c0;" class="mycode_color">#include</span> <span style="color: #7fcbcd;" class="mycode_color">"Arduino.h"</span><br />
<span style="color: #c586c0;" class="mycode_color">#include</span> <span style="color: #7fcbcd;" class="mycode_color">"PCF8574.h"</span><br />
<span style="color: #7f8c8d;" class="mycode_color">// Set i2c address</span><br />
PCF8574 <span style="color: #f39c12;" class="mycode_color">pcf8574</span>(0x<span style="color: #7fcbcd;" class="mycode_color">24</span>);<br />
<span style="color: #0ca1a6;" class="mycode_color">void</span> <span style="color: #f39c12;" class="mycode_color">setup</span>()<br />
{<br />
  <span style="color: #f39c12;" class="mycode_color">Wire</span>.<span style="color: #f39c12;" class="mycode_color">begin</span>(<span style="color: #7fcbcd;" class="mycode_color">12</span>, <span style="color: #7fcbcd;" class="mycode_color">11</span>);<span style="color: #7f8c8d;" class="mycode_color"> // SDA: GPIO12, SCL: GPIO11</span><br />
  <span style="color: #f39c12;" class="mycode_color">Serial</span>.<span style="color: #f39c12;" class="mycode_color">begin</span>(<span style="color: #7fcbcd;" class="mycode_color">115200</span>);<br />
<span style="color: #7f8c8d;" class="mycode_color">//  delay(1000);</span><br />
<span style="color: #7f8c8d;" class="mycode_color">  // Set pinMode to OUTPUT</span><br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">pinMode</span>(P0, OUTPUT);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">pinMode</span>(P1, OUTPUT);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">pinMode</span>(P2, OUTPUT);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">pinMode</span>(P3, OUTPUT);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">pinMode</span>(P4, OUTPUT);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">pinMode</span>(P5, OUTPUT);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P0, HIGH);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P1, HIGH);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P2, HIGH);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P3, HIGH);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P4, HIGH);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P5, HIGH);<br />
  <span style="color: #f39c12;" class="mycode_color">Serial</span>.<span style="color: #f39c12;" class="mycode_color">print</span>(<span style="color: #7fcbcd;" class="mycode_color">"Init pcf8574..."</span>);<br />
  <span style="color: #c586c0;" class="mycode_color">if</span> (<span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">begin</span>()){<br />
    <span style="color: #f39c12;" class="mycode_color">Serial</span>.<span style="color: #f39c12;" class="mycode_color">println</span>(<span style="color: #7fcbcd;" class="mycode_color">"OK"</span>);<br />
  }<span style="color: #c586c0;" class="mycode_color">else</span>{<br />
    <span style="color: #f39c12;" class="mycode_color">Serial</span>.<span style="color: #f39c12;" class="mycode_color">println</span>(<span style="color: #7fcbcd;" class="mycode_color">"KO"</span>);<br />
  }<br />
}<br />
<span style="color: #0ca1a6;" class="mycode_color">void</span> <span style="color: #f39c12;" class="mycode_color">loop</span>()<br />
{<br />
  <span style="color: #f39c12;" class="mycode_color">delay</span>(<span style="color: #7fcbcd;" class="mycode_color">300</span>);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P0, LOW);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P1, LOW);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P2, LOW);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P3, LOW);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P4, LOW);<br />
  <span style="color: #f39c12;" class="mycode_color">pcf8574</span>.<span style="color: #f39c12;" class="mycode_color">digitalWrite</span>(P5, LOW) <br />
}<br />
</span></span>]]></description>
			<content:encoded><![CDATA[I just acquired an AC868-A6 V1.4 board from Aliexpress.<br />
<br />
<br />
<br />
<br />
<br />
Thanks<br />
<br />
JL<br />
<br />
<br />
{<br />
  }<br />
}<br />
{<br />
}<br />
</span></span>]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N30 power supply]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9554</link>
			<pubDate>Sun, 28 Jun 2026 00:33:39 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=11094">Stanb</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9554</guid>
I just ordered N30, which I plan to power from a DIN rail power supply. <br />
But i cannot find how much power does the board actually need - only 12-24V.<br />
<br />
Anyone can help?<br />
<br />
BR,<br />
Stan]]></description>
<br />
<br />
BR,<br />
Stan]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Energy calculation for negative currents]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9337</link>
			<pubDate>Sun, 17 May 2026 20:22:20 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=10817">GWS</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9337</guid>
			<description><![CDATA[The energy calculation seems to be always positive and not take into account negatieve power.<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9867" target="_blank" title="">2026-05-17 111107_N30_Energy.png</a> (Size: 28.17 KB / Downloads: 257)
<br />
Although current was negatieve and power too the energy is positive.<br />
Also noticed that in a phase where current was pos at first and neg later the energy keeps adding which makes the energy calculation incorrect.<br />
<br />
Energy is defined as a 32-bit float so it should be able to handle pos and negatieve loads.]]></description>
			<content:encoded><![CDATA[The energy calculation seems to be always positive and not take into account negatieve power.<br />
<br />
<br />
<br />
Energy is defined as a 32-bit float so it should be able to handle pos and negatieve loads.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[Reset Total Energy only works per chip]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9332</link>
			<pubDate>Fri, 15 May 2026 03:00:22 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9332</guid>
<br />
I have made some changes to my setup and one of the reasons is that the calculations were not correct.<br />
<br />
Tried to reset the BL0910 chips  but Clear all does not seem to clear the Total Energy values <img src="https://www.kincony.com/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" /> . Just found out that "Clear Energy 1/2/3" so per chip did actually work.  <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" />]]></description>
<br />
<br />
Tried to reset the BL0910 chips  but Clear all does not seem to clear the Total Energy values <img src="https://www.kincony.com/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" /> . Just found out that "Clear Energy 1/2/3" so per chip did actually work.  <img src="https://www.kincony.com/forum/images/smilies/smile.png" alt="Smile" title="Smile" class="smilie smilie_1" />]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N series Energy Meter for Loxone UDP Protocol]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9315</link>
			<pubDate>Mon, 04 May 2026 16:19:04 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9315</guid>
			<description><![CDATA[Energy Loxone Protocol<br />
=======================<br />
<br />
Overview<br />
--------<br />
This document describes the Loxone string protocol for Energy module.<br />
Default delimiter is comma (,). Chip ID: 1-6, Channel: 1-10.<br />
<br />
<br />
Commands<br />
--------<br />
<br />
1. GET_ENERGY_CURRENT - Get current (A) for specific channel<br />
  Request:  RELAY-GET_ENERGY_CURRENT-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_CURRENT-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_CURRENT-255,1,1<br />
    Response: RELAY-GET_ENERGY_CURRENT-255,1,1,2.350,OK<br />
<br />
2. GET_ENERGY_POWER - Get power (W) for specific channel<br />
  Request:  RELAY-GET_ENERGY_POWER-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_POWER-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_POWER-255,1,1<br />
    Response: RELAY-GET_ENERGY_POWER-255,1,1,512.5,OK<br />
<br />
3. GET_ENERGY_KWH - Get energy (kWh) for specific channel<br />
  Request:  RELAY-GET_ENERGY_KWH-255,{chip},{channel}<br />
  Response: RELAY-GET_ENERGY_KWH-255,{chip},{channel},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_KWH-255,1,1<br />
    Response: RELAY-GET_ENERGY_KWH-255,1,1,1250,OK<br />
<br />
4. GET_ENERGY_VOLT - Get voltage (V) for chip<br />
  Request:  RELAY-GET_ENERGY_VOLT-255,{chip}<br />
  Response: RELAY-GET_ENERGY_VOLT-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_VOLT-255,1<br />
    Response: RELAY-GET_ENERGY_VOLT-255,1,220.50,OK<br />
<br />
5. GET_ENERGY_FREQ - Get frequency (Hz) for chip<br />
  Request:  RELAY-GET_ENERGY_FREQ-255,{chip}<br />
  Response: RELAY-GET_ENERGY_FREQ-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_FREQ-255,1<br />
    Response: RELAY-GET_ENERGY_FREQ-255,1,50.00,OK<br />
<br />
6. GET_ENERGY_TEMP - Get temperature &copy; for chip<br />
  Request:  RELAY-GET_ENERGY_TEMP-255,{chip}<br />
  Response: RELAY-GET_ENERGY_TEMP-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_TEMP-255,1<br />
    Response: RELAY-GET_ENERGY_TEMP-255,1,35.5,OK<br />
<br />
7. GET_ENERGY_PF - Get power factor for chip<br />
  Request:  RELAY-GET_ENERGY_PF-255,{chip}<br />
  Response: RELAY-GET_ENERGY_PF-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_PF-255,1<br />
    Response: RELAY-GET_ENERGY_PF-255,1,0.95,OK<br />
<br />
8. GET_ENERGY_SUM - Get total energy (kWh) for chip<br />
  Request:  RELAY-GET_ENERGY_SUM-255,{chip}<br />
  Response: RELAY-GET_ENERGY_SUM-255,{chip},{value},OK<br />
  Example:<br />
    Request:  RELAY-GET_ENERGY_SUM-255,1<br />
    Response: RELAY-GET_ENERGY_SUM-255,1,12500,OK<br />
<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9754" target="_blank" title="">Nx-Energy-meter-udp-loxone.png</a> (Size: 141.99 KB / Downloads: 269)
protocol download:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9755" target="_blank" title="">Nx-energy_loxone_protocol.txt</a> (Size: 2.34 KB / Downloads: 158)
			<content:encoded><![CDATA[Energy Loxone Protocol<br />
<br />
Overview<br />
--------<br />
<br />
<br />
Commands<br />
--------<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
  Example:<br />
<br />
		</item>
		<item>
			<title><![CDATA[N30 smart energy meter ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9304</link>
			<pubDate>Sat, 02 May 2026 19:47:55 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9304</guid>
			<description><![CDATA[N30 smart energy meter ESP32 system block diagram<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9732" target="_blank" title="">KinCony-N30-smart-energy-meter-diagram.png</a> (Size: 1.58 MB / Downloads: 396)
			<content:encoded><![CDATA[N30 smart energy meter ESP32 system block diagram<br />
		</item>
		<item>
			<title><![CDATA[KCS update and ARM CPU update]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9282</link>
			<pubDate>Mon, 20 Apr 2026 16:01:16 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=9845">HolyKirka</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9282</guid>
			<description><![CDATA[Hello.<br />
<br />
I want to upgrade my N30 (KCS v3.15.0) with KCS v3.24.3<br />
Do I need to make new ARM CPU update firmware (support 0.001kwh now <a href="https://www.kincony.com/forum/showthread.php?tid=9107" target="_blank" rel="noopener" class="mycode_url">https://www.kincony.com/forum/showthread.php?tid=9107</a>) before or not? Or KCS update is enougth?<br />
<br />
Best Regards.]]></description>
			<content:encoded><![CDATA[Hello.<br />
<br />
<br />
Best Regards.]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[N30 wire case diagram for 1 phase load]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9188</link>
			<pubDate>Tue, 31 Mar 2026 09:23:55 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9188</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9491" target="_blank" title="">N30-1-phase-1.JPG</a> (Size: 91.61 KB / Downloads: 323)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9492" target="_blank" title="">N30-1-phase-2.JPG</a> (Size: 91.76 KB / Downloads: 336)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9493" target="_blank" title="">N30-1-phase-3.JPG</a> (Size: 92.98 KB / Downloads: 326)
		</item>
	</channel>
</rss>
