	<channel>
		<title><![CDATA[Smart Home Automation Forum - F32]]></title>
		<pubDate>Tue, 10 Nov 2026 10:25:41 +0000</pubDate>
		<generator>MyBB</generator>
		<item>
			<title><![CDATA[F32 Smart Controller Wiring Examples]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9271</link>
			<pubDate>Sun, 19 Apr 2026 15:54:42 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9271</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9653" target="_blank" title="">F32_wiring.jpg</a> (Size: 320.38 KB / Downloads: 406)
		</item>
		<item>
			<title><![CDATA[F32 Smart Controller ESP32 system block diagram]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=9270</link>
			<pubDate>Sun, 19 Apr 2026 15:54:06 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=9270</guid>
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=9652" target="_blank" title="">KinCony-F32-smart-controller-diagram.png</a> (Size: 1.08 MB / Downloads: 264)
		</item>
		<item>
			<title><![CDATA[F32 and 433 Mhz]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8942</link>
			<pubDate>Thu, 15 Jan 2026 08:21:12 +0800</pubDate>
			<dc:creator><![CDATA[<a href="https://www.kincony.com/forum/member.php?action=profile&uid=4217">lulu01</a>]]></dc:creator>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8942</guid>
<br />
on the F32, if I want to use a Kincony 433 Mhz remote:<br />
<br />
- can I do this with ESPHome instead of KCS?<br />
- do I need to buy a RF433 MHz tx/rx module, or is it included in the board already?<br />
- with the ESPHome firmware, how do I learn the codes from the remote controller and associate them to relays?<br />
<br />
Thank you!]]></description>
<br />
<br />
<br />
Thank you!]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-11 digital INPUT trigger OUTPUT directly]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8708</link>
			<pubDate>Tue, 04 Nov 2025 07:33:42 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8708</guid>
 *<br />
 * This program reads 32 input states from three PCF8575 I/O expanders and <br />
 * controls a corresponding 32-channel relay module. <br />
 * When an input pin is LOW, the corresponding relay is turned ON (LOW means ON for the relay).<br />
 * When the input pin is HIGH, the corresponding relay is turned OFF.<br />
 *<br />
 * Pin Definitions:<br />
 * - SDA: GPIO 8<br />
 * - SCL: GPIO 18<br />
<br />
PCF8575:U27 (relay17-32) i2c address:0x25<br />
PCF8575:U23 (DI1-16) i2c address:0x24<br />
PCF8575:U49 i2c address: 0x26<br />
  PCF8575(pin number0-7):DI17-24<br />
  PCF8575(pin number8-11):relay13-16<br />
  PCF8575(pin number12-15):relay9-12<br />
<br />
PCF8575:U62 i2c address: 0x27<br />
  PCF8575(pin number0-7):DI25-32<br />
  PCF8575(pin number8-15):relay1-8<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Library to control the PCF8575 I/O expander<br />
<br />
// Define I2C pins<br />
#define SDA 8            // SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// SCL pin<br />
<br />
// I2C addresses for the PCF8575 modules<br />
#define INPUT_I2C_ADDRESS_1 0x24 &nbsp;&nbsp;<br />
#define INPUT_RELAY_I2C_ADDRESS_2 0x26  <br />
#define RELAY_I2C_ADDRESS_3 0x25  <br />
#define INPUT_RELAY_I2C_ADDRESS_3 0x27 &nbsp;&nbsp;<br />
<br />
PCF8575 pcf8575_IN1(INPUT_I2C_ADDRESS_1);    <br />
PCF8575 pcf8575_IN2(INPUT_RELAY_I2C_ADDRESS_2);    <br />
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS_3); &nbsp;&nbsp;<br />
PCF8575 pcf8575_IN3(INPUT_RELAY_I2C_ADDRESS_3); <br />
<br />
void setup() {<br />
  Wire.begin(SDA, SCL);<br />
  <br />
  Serial.begin(115200);<br />
  <br />
  // Initialize input and relay modules<br />
  pcf8575_IN1.begin();  <br />
  pcf8575_IN2.begin();  <br />
  pcf8575_IN3.begin(); <br />
  pcf8575_RL.begin();  <br />
  <br />
  // Turn off all relays at the start (LOW means OFF)<br />
  for (int i = 8; i &lt; 16; i++) {<br />
    pcf8575_IN2.write(i, HIGH); <br />
  }<br />
  for (int i = 0; i &lt; 16; i++) {<br />
    pcf8575_RL.write(i, HIGH); <br />
  }<br />
    pcf8575_IN3.write(i, HIGH);  <br />
  }<br />
  Serial.println("System started: Input state controlling 24 relays");<br />
}<br />
<br />
void loop() {<br />
    bool inputState;<br />
    inputState = pcf8575_IN1.read(0);  // input1 control relay1<br />
    if (inputState) {<br />
      pcf8575_IN3.write(8, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(8, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
  <br />
    inputState = pcf8575_IN1.read(1);  // input2 control relay2<br />
      pcf8575_IN3.write(9, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(9, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(2);  // input3 control relay3<br />
      pcf8575_IN3.write(10, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(10, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(3);  // input4 control relay4<br />
      pcf8575_IN3.write(11, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(11, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(4);  // input5 control relay5<br />
      pcf8575_IN3.write(12, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(12, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(5);  // input6 control relay6<br />
      pcf8575_IN3.write(13, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(13, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(6);  // input7 control relay7<br />
      pcf8575_IN3.write(14, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(14, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(7);  // input8 control relay8<br />
      pcf8575_IN3.write(15, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN3.write(15, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(8);  // input9 control relay9<br />
      pcf8575_IN2.write(12, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(12, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(9);  // input10 control relay10<br />
      pcf8575_IN2.write(13, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(13, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(10);  // input11 control relay11<br />
      pcf8575_IN2.write(14, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(14, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(11);  // input12 control relay12<br />
      pcf8575_IN2.write(15, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(15, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(12);  // input13 control relay13<br />
      pcf8575_IN2.write(8, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(8, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(13);  // input14 control relay14<br />
      pcf8575_IN2.write(9, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(9, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(14);  // input15 control relay15<br />
      pcf8575_IN2.write(10, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(10, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN1.read(15);  // input16 control relay16<br />
      pcf8575_IN2.write(11, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_IN2.write(11, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(0);  // input17 control relay17<br />
      pcf8575_RL.write(0, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(0, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(1);  // input18 control relay18<br />
      pcf8575_RL.write(1, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(1, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(2);  // input19 control relay19<br />
      pcf8575_RL.write(2, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(2, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(3);  // input20 control relay20<br />
      pcf8575_RL.write(3, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(3, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(4);  // input21 control relay21<br />
      pcf8575_RL.write(4, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(4, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(5);  // input22 control relay22<br />
      pcf8575_RL.write(5, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(5, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(6);  // input23 control relay23<br />
      pcf8575_RL.write(6, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(6, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN2.read(7);  // input24 control relay24<br />
      pcf8575_RL.write(7, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(7, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(0);  // input25 control relay25<br />
      pcf8575_RL.write(8, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(8, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(1);  // input26 control relay26<br />
      pcf8575_RL.write(9, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(9, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(2);  // input27 control relay27<br />
      pcf8575_RL.write(10, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(10, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(3);  // input28 control relay28<br />
      pcf8575_RL.write(11, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(11, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(4);  // input29 control relay29<br />
      pcf8575_RL.write(12, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(12, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(5);  // input30 control relay30<br />
      pcf8575_RL.write(13, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(13, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(6);  // input31 control relay31<br />
      pcf8575_RL.write(14, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(14, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
    inputState = pcf8575_IN3.read(7);  // input32 control relay32<br />
      pcf8575_RL.write(15, HIGH);  // If input is HIGH, turn the corresponding relay OFF<br />
    } else {<br />
      pcf8575_RL.write(15, LOW); &nbsp;&nbsp;// If input is LOW, turn the corresponding relay ON<br />
    }<br />
<br />
  // Delay for 500 milliseconds<br />
  delay(500);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8578" target="_blank" title="">11-input-trigger-output.zip</a> (Size: 1.54 KB / Downloads: 523)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8579" target="_blank" title="">11-input-trigger-output.ino.merged.zip</a> (Size: 198.09 KB / Downloads: 527)
 *<br />
 *<br />
<br />
<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
  <br />
  <br />
  }<br />
  }<br />
  }<br />
}<br />
<br />
void loop() {<br />
    } else {<br />
    }<br />
  <br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
    } else {<br />
    }<br />
<br />
  delay(500);<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-02 Read digital input ports state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8699</link>
			<pubDate>Tue, 04 Nov 2025 07:27:08 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8699</guid>
 *<br />
 *<br />
 * - PCF8575 I2C Address: 0x24 for inputs 1-16, 0x26 for inputs 17-24, 0x27 for inputs 18-25<br />
 */<br />
<br />
#include "Arduino.h"<br />
#include "PCF8575.h"<br />
<br />
<br />
// Set I2C addresses<br />
PCF8575 pcf8575_IN1(0x24); // The I2C address of the first PCF8575 (inputs 1-16)<br />
PCF8575 pcf8575_IN2(0x26); // The I2C address of the second PCF8575 (inputs 17-24)<br />
PCF8575 pcf8575_IN3(0x27); // The I2C address of the second PCF8575 (inputs 25-32)<br />
<br />
<br />
<br />
    // Initialize both PCF8575 modules<br />
    pcf8575_IN1.begin();<br />
    pcf8575_IN2.begin();<br />
    pcf8575_IN3.begin();<br />
<br />
    Serial.println("KinCony F32 32 channel input state 0:ON  1:OFF");<br />
}<br />
<br />
void loop() {<br />
    uint32_t state = 0; // Use a 32-bit variable to store the state of all 24 pins<br />
<br />
    // Read the state of each pin from the first PCF8575 (inputs 1-16)<br />
    for (int pin = 0; pin &lt; 16; pin++) {<br />
        if (pcf8575_IN1.read(pin)) {<br />
            state |= (1UL &lt;&lt; pin); // Set the bit for the active pin (inputs 1-16)<br />
        }<br />
    }<br />
<br />
    // Read the state of each pin from the second PCF8575 (inputs 17-24, corresponding to pins 0-7)<br />
    for (int pin = 0; pin &lt; 8; pin++) {<br />
        if (pcf8575_IN2.read(pin)) {<br />
            state |= (1UL &lt;&lt; (pin + 16)); // Set the bit for the active pin (inputs 17-24)<br />
        }<br />
    }<br />
<br />
    // Read the state of each pin from the second PCF8575 (inputs 25-32, corresponding to pins 0-7)<br />
        if (pcf8575_IN3.read(pin)) {<br />
            state |= (1UL &lt;&lt; (pin + 24));<br />
        }<br />
    }<br />
<br />
    // Print the state of all 24 inputs in binary format<br />
    Serial.println(state, BIN); // Print the state of inputs in binary<br />
<br />
    delay(500); // Delay 500ms<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8568" target="_blank" title="">2-digital-input.zip</a> (Size: 885 bytes / Downloads: 530)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8569" target="_blank" title="">2-digital-input.ino.merged.zip</a> (Size: 197.91 KB / Downloads: 495)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
    }<br />
<br />
        }<br />
    }<br />
<br />
        }<br />
    }<br />
<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-01 Turn ON/OFF relay]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8698</link>
			<pubDate>Tue, 04 Nov 2025 07:25:24 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8698</guid>
 *<br />
 * This program controls a 32-channel relay board via two PCF8575 I/O expanders.<br />
 * It sequentially turns on each relay and then turns them off in a loop.<br />
 * <br />
 * <br />
 * Delay Time:<br />
 * - 200 milliseconds between switching relays<br />
 */<br />
<br />
#include &lt;Wire.h&gt;        // Include the Wire library for I2C communication<br />
#include &lt;PCF8575.h&gt;   &nbsp;&nbsp;// Include the PCF8575 library to control the I/O expander<br />
<br />
#define SDA 8            // Define the SDA pin<br />
#define SCL 18         &nbsp;&nbsp;// Define the SCL pin<br />
#define DELAY_TIME 200 &nbsp;&nbsp;// Define the delay time in milliseconds<br />
<br />
// Set I2C addresses of the PCF8575 modules<br />
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module<br />
#define I2C_ADDRESS_R2 0x26 // I2C address of the second PCF8575 module<br />
#define I2C_ADDRESS_R3 0x27 // I2C address of the second PCF8575 module<br />
<br />
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 17-32)<br />
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 9-16)<br />
PCF8575 pcf8575_R3(I2C_ADDRESS_R3); // Create a PCF8575 object for the second module (for relays 1-8)<br />
<br />
  Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)<br />
  <br />
  // Initialize serial communication for debugging (optional)<br />
  Serial.println("PCF8575 Relay Control: Starting...");<br />
<br />
  // Initialize the PCF8575 modules<br />
  pcf8575_R1.begin();<br />
  pcf8575_R2.begin();<br />
  pcf8575_R3.begin();<br />
<br />
  // Turn off all relays initially (set all pins HIGH)<br />
    pcf8575_R1.write(i, HIGH); // Set relays 17-32 to OFF (assuming HIGH means OFF for relays)<br />
    pcf8575_R2.write(i, HIGH); // Set relays 9-16 to OFF (assuming HIGH means OFF for relays)<br />
  }<br />
<br />
    pcf8575_R3.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)<br />
  }<br />
<br />
}<br />
<br />
void loop() {<br />
  // Sequentially turn on each relay (1-32)<br />
<br />
  // First control the relays on the second PCF8575 (relays 1-8, corresponding to pins 8-15)<br />
    pcf8575_R3.write(i, LOW); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
    delay(DELAY_TIME);          // Wait for DELAY_TIME milliseconds<br />
  }<br />
<br />
  // First control the relays on the second PCF8575 (relays 9-16, corresponding to pins 8-15)<br />
    pcf8575_R2.write(i, LOW); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
  }<br />
<br />
  // Then control the relays on the first PCF8575 (relays 17-32)<br />
    pcf8575_R1.write(i, LOW); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
  }<br />
<br />
  // Sequentially turn off each relay (1-24)<br />
  <br />
    pcf8575_R3.write(i, HIGH); &nbsp;&nbsp;// Turn on the relay at pin i (LOW means ON for the relay)<br />
  }<br />
<br />
    pcf8575_R2.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)<br />
  }<br />
<br />
    pcf8575_R1.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8566" target="_blank" title="">1-relay.zip</a> (Size: 1.08 KB / Downloads: 482)
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8567" target="_blank" title="">1-relay.ino.merged.zip</a> (Size: 197.73 KB / Downloads: 492)
 *<br />
 * <br />
 * <br />
 * Delay Time:<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
<br />
<br />
  }<br />
<br />
  }<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
  }<br />
<br />
  }<br />
<br />
  }<br />
<br />
  <br />
  }<br />
<br />
  }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[F32 ESPHome yaml for home assistant without tuya]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8697</link>
			<pubDate>Tue, 04 Nov 2025 07:22:41 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8697</guid>
  friendly_name: f32<br />
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
    <br />
<br />
# Enable logging<br />
<br />
logger:<br />
  level: DEBUG  <br />
  hardware_uart: USB_CDC<br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
  clk_pin: GPIO42<br />
  mosi_pin: GPIO43<br />
  miso_pin: GPIO44<br />
  cs_pin: GPIO41<br />
  interrupt_pin: GPIO2<br />
  reset_pin: GPIO1<br />
<br />
<br />
i2c:<br />
 &nbsp;&nbsp;- id: bus_a<br />
   &nbsp;&nbsp;sda: 8<br />
   &nbsp;&nbsp;scl: 18<br />
   &nbsp;&nbsp;scan: true<br />
<br />
pcf8574:<br />
  - id: 'pcf8574_hub_out_1'  # for output channel 17-32<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_in_1'  # for digital input channel 1-16<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_out_in_2'  # for output channel 9-16  + (input 17-24)<br />
    i2c_id: bus_a<br />
    address: 0x26<br />
    pcf8575: true<br />
<br />
  - id: 'pcf8574_hub_out_in_3'  # for output channel 1-8  + (input 17-24)<br />
    i2c_id: bus_a<br />
    address: 0x27<br />
    pcf8575: true<br />
<br />
uart:<br />
  - id: uart_1    #RS485<br />
    baud_rate: 9600<br />
    debug:<br />
      direction: BOTH<br />
      dummy_receiver: true<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 16<br />
    rx_pin: 17<br />
<br />
switch:<br />
  - platform: uart<br />
    uart_id: uart_1<br />
    name: "RS485 Button"<br />
<br />
  - platform: gpio<br />
    pin:<br />
      pcf8574: pcf8574_hub_out_in_3<br />
      number: 8<br />
      mode: OUTPUT<br />
      inverted: true<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      pcf8574: pcf8574_hub_out_in_2<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
<br />
binary_sensor:<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 15<br />
    pin: <br />
      number: 13<br />
      inverted: false<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 40<br />
<br />
sensor:<br />
  - platform: adc<br />
    pin: 5<br />
    name: "f32 A1 Voltage"<br />
    update_interval: 5s<br />
    attenuation: 11db<br />
    filters:<br />
      - lambda:<br />
          if (x &gt;= 3.11) {<br />
            return x * 1.60256;<br />
          } else if (x &lt;= 0.15) {<br />
            return 0;<br />
          } else {<br />
            return x * 1.51;<br />
          }<br />
    pin: 7<br />
    name: "f32 A2 Voltage"<br />
    filters:<br />
      # - multiply: 1.51515<br />
      - lambda:<br />
            return 0;<br />
          } else {<br />
          }<br />
    pin: 6<br />
    name: "f32 A3 Current"<br />
    unit_of_measurement: mA<br />
    filters:<br />
      - multiply: 6.66666666<br />
    pin: 4<br />
    name: "f32 A4 Current"<br />
    filters:<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
  - platform: ssd1306_i2c<br />
    i2c_id: bus_a<br />
    model: "SSD1306 128x64"<br />
    address: 0x3C<br />
    lambda: |-<br />
      it.printf(0, 0, id(roboto), "KinCony F32");</code></div></div>download yaml file:<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8565" target="_blank" title="">F32-HA-without-tuya.txt</a> (Size: 14.25 KB / Downloads: 466)
<br />
esp32:<br />
  framework:<br />
    type: arduino<br />
    <br />
<br />
<br />
logger:<br />
  level: DEBUG  <br />
<br />
api:<br />
<br />
ethernet:<br />
  type: W5500<br />
<br />
<br />
i2c:<br />
<br />
pcf8574:<br />
    i2c_id: bus_a<br />
    address: 0x25<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x24<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x26<br />
    pcf8575: true<br />
<br />
    i2c_id: bus_a<br />
    address: 0x27<br />
    pcf8575: true<br />
<br />
uart:<br />
    debug:<br />
      after:<br />
        timeout: 10ms<br />
    tx_pin: 16<br />
    rx_pin: 17<br />
<br />
switch:<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: OUTPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: OUTPUT<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 8<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 9<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 10<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 11<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 12<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 13<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 14<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 15<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 0<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 1<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 2<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 3<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 4<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 5<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 6<br />
      mode: INPUT<br />
<br />
    pin:<br />
      number: 7<br />
      mode: INPUT<br />
<br />
    pin: <br />
      number: 48<br />
<br />
    pin: <br />
      number: 47<br />
<br />
    pin: <br />
      number: 21<br />
<br />
    pin: <br />
      number: 15<br />
    pin: <br />
      number: 13<br />
<br />
    pin: <br />
      number: 14<br />
<br />
    pin: <br />
      number: 40<br />
<br />
sensor:<br />
    pin: 5<br />
    filters:<br />
      - lambda:<br />
            return 0;<br />
          } else {<br />
          }<br />
    pin: 7<br />
    filters:<br />
      - lambda:<br />
            return 0;<br />
          } else {<br />
          }<br />
    pin: 6<br />
    filters:<br />
    pin: 4<br />
    filters:<br />
<br />
web_server:<br />
  port: 80<br />
<br />
font:<br />
<br />
display:<br />
    i2c_id: bus_a<br />
    address: 0x3C<br />
    lambda: |-<br />
		</item>
		<item>
			<title><![CDATA[F32 ESP32-S3 IO pins define]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8696</link>
			<pubDate>Tue, 04 Nov 2025 07:21:02 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8696</guid>
			<description><![CDATA[ANALOG_A1(0-5v)    GPIO5<br />
ANALOG_A2(0-5v)    GPIO7<br />
ANALOG_A3(4-20mA)  GPIO6<br />
ANALOG_A4(4-20mA)  GPIO4<br />
<br />
IIC SDA:GPIO8<br />
IIC SCL:GPIO18<br />
<br />
  PCF8575(pin number0-7) : DI17-24<br />
  PCF8575(pin number8-11) : relay13-16<br />
  PCF8575(pin number12-15) : relay9-12<br />
<br />
  PCF8575(pin number0-7) : DI25-32<br />
  PCF8575(pin number8-15) :relay1-8<br />
<br />
<br />
if config by ESPHome:<br />
<br />
relay9: pcf8575(U49) number:12<br />
relay10: pcf8575(U49) number:13<br />
relay11: pcf8575(U49) number:14<br />
relay12: pcf8575(U49) number:15<br />
relay13: pcf8575(U49) number:8<br />
relay14: pcf8575(U49) number:9<br />
relay15: pcf8575(U49) number:10<br />
relay16: pcf8575(U49) number:11<br />
<br />
RF433MHz wireless receiver: GPIO40<br />
------------------------<br />
<br />
Ethernet (W5500) I/O define:<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO17<br />
TXD:GPIO16<br />
Tuya module:<br />
RXD:GPIO38<br />
TXD:GPIO39<br />
<br />
Tuya network button: Tuya module's P28<br />
Tuya network LED: Tuya module's P16<br />
<br />
1-wire (pull-up resistance on PCB): <br />
1-wire1:GPIO48<br />
1-wire2:GPIO47<br />
1-wire3:GPIO21<br />
1-wire4:GPIO15<br />
<br />
1-wire (without resistance on PCB): <br />
1-wire1:GPIO13<br />
1-wire2:GPIO14<br />
SD Card:<br />
SPI-MOSI:GPIO10<br />
SPI-SCK:GPIO11<br />
SPI-MISO:GPIO12<br />
SPI-CS:GPIO9<br />
24C02 EPROM i2c address: 0x50<br />
DS3231 RTC i2c address: 0x68<br />
SSD1306 display: i2c address:0x3c]]></description>
			<content:encoded><![CDATA[ANALOG_A1(0-5v)    GPIO5<br />
<br />
IIC SDA:GPIO8<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
RS485: <br />
RXD:GPIO17<br />
TXD:GPIO16<br />
Tuya module:<br />
RXD:GPIO38<br />
TXD:GPIO39<br />
<br />
<br />
<br />
SD Card:<br />
SPI-CS:GPIO9<br />
SSD1306 display: i2c address:0x3c]]></content:encoded>
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-10 Print TEXT on SSD1306 OLED displayer]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8707</link>
			<pubDate>Thu, 28 Nov 2024 19:50:29 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8707</guid>
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
void page1() {<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8577" target="_blank" title="">10-oled-ssd1306.zip</a> (Size: 1.11 KB / Downloads: 809)
 * <br />
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
  u8g2.begin();<br />
  <br />
}<br />
<br />
void loop() {<br />
  do {<br />
    page1();<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-09 how to communication with Tuya WiFi module]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8706</link>
			<pubDate>Thu, 28 Nov 2024 19:49:35 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8706</guid>
 * <br />
 * <br />
 * Functionality:<br />
 */<br />
<br />
<br />
<br />
#define TXD_PIN 39<br />
#define RXD_PIN 38<br />
<br />
#define BAUD_RATE 9600<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
      if (bytesRead &lt; 7) {<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
        Serial.print(" ");<br />
      }<br />
      Serial.println();<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
    switch(packet[2]) {<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8576" target="_blank" title="">9-tuya-wifi-config.zip</a> (Size: 2 KB / Downloads: 767)
 * <br />
 * <br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
};<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
        }<br />
      }<br />
<br />
        return;<br />
      }<br />
<br />
      }<br />
<br />
<br />
    } else {<br />
      }<br />
    }<br />
  }<br />
<br />
  delay(100);<br />
}<br />
<br />
      case 0x00:<br />
        }<br />
        break;<br />
<br />
      default:<br />
        break;<br />
    }<br />
  }<br />
}<br />
<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-08 Ethernet W5500 chip work with TCP Server mode]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8705</link>
			<pubDate>Thu, 28 Nov 2024 19:48:30 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8705</guid>
 *<br />
 *<br />
 * Hardware connections:<br />
 * - CLK: GPIO42<br />
 * - MOSI: GPIO43<br />
 * - MISO: GPIO44<br />
 * - CS: GPIO41<br />
 * - RST: GPIO1<br />
 * - INT: GPIO2<br />
 *<br />
 * Gateway: 192.168.3.1<br />
 * DNS: 192.168.3.1<br />
 */<br />
<br />
#include &lt;SPI.h&gt;<br />
<br />
#define W5500_CS_PIN  41<br />
#define W5500_RST_PIN 1<br />
#define W5500_INT_PIN 2<br />
#define W5500_CLK_PIN 42<br />
#define W5500_MOSI_PIN 43<br />
#define W5500_MISO_PIN 44<br />
<br />
<br />
<br />
<br />
  while (!Serial) {<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
  server.begin();<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
        char c = client.read();<br />
        server.write(c);<br />
      }<br />
    }<br />
<br />
    client.stop();<br />
  }<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8575" target="_blank" title="">8-Ethernet-W5500.zip</a> (Size: 1.23 KB / Downloads: 742)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  if (client) {<br />
<br />
      }<br />
    }<br />
<br />
  }<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-07 how to DS3231 RTC clock]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8704</link>
			<pubDate>Thu, 28 Nov 2024 19:47:21 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8704</guid>
 *<br />
 *<br />
 *<br />
 * Hardware Connections:<br />
 */<br />
<br />
#include &lt;Wire.h&gt;<br />
<br />
<br />
typedef struct<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
} MY_DATE_STR;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
  Serial.print(year);<br />
  Serial.print("-");<br />
<br />
<br />
<br />
  Serial.print(":");<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
    while (num_read--)<br />
  }<br />
  else return;<br />
<br />
  serial_cmd_rcv.trim();<br />
<br />
  {<br />
    PrintfCurTime();<br />
    serial_cmd_rcv = "";<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
  GetSerialCmd(); <br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8574" target="_blank" title="">7-DS3231-RTC.zip</a> (Size: 1.51 KB / Downloads: 778)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
{<br />
  byte month;<br />
  byte day;<br />
  byte hour;<br />
  byte minute;<br />
  byte second;<br />
<br />
<br />
<br />
<br />
bool h12Flag;<br />
bool pmFlag;<br />
<br />
<br />
/**<br />
 */<br />
{<br />
<br />
<br />
<br />
}<br />
<br />
/**<br />
 */<br />
{<br />
  {<br />
    delay(100);<br />
  }<br />
  else return;<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
  {<br />
    return;<br />
  }<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
  <br />
 &nbsp;&nbsp;<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-06 How to use SD Card]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8703</link>
			<pubDate>Thu, 28 Nov 2024 19:46:16 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8703</guid>
 *<br />
 *<br />
 *<br />
 * - SCK: GPIO 11<br />
 * - MISO: GPIO 12<br />
 * - MOSI: GPIO 10<br />
 * - CS: GPIO 9<br />
 */<br />
<br />
#include "FS.h"<br />
#include "SD.h"<br />
#include "SPI.h"<br />
<br />
#define SCK  11<br />
#define MISO 12<br />
#define MOSI 10<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  if (fs.remove(path)) {<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  size_t len = 0;<br />
  uint32_t end = start;<br />
<br />
  if (file) {<br />
    len = file.size();<br />
    size_t flen = len;<br />
    while (len) {<br />
      size_t toRead = len;<br />
      if (toRead &gt; 512) {<br />
        toRead = 512;<br />
      }<br />
      file.read(buf, toRead);<br />
      len -= toRead;<br />
    }<br />
    end = millis() - start;<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
    file.write(buf, 512);<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
    Serial.println("MMC");<br />
    Serial.println("SDSC");<br />
    Serial.println("SDHC");<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
  // No operation in loop<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8573" target="_blank" title="">6-SD.zip</a> (Size: 1.53 KB / Downloads: 751)
 *<br />
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
  } else {<br />
  }<br />
  file.close();<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
  } else {<br />
  }<br />
}<br />
<br />
/**<br />
 * <br />
 */<br />
<br />
  if (file) {<br />
    while (len) {<br />
        toRead = 512;<br />
      }<br />
    }<br />
    file.close();<br />
  } else {<br />
  }<br />
<br />
  if (!file) {<br />
    return;<br />
  }<br />
<br />
  size_t i;<br />
  }<br />
  file.close();<br />
}<br />
<br />
  <br />
<br />
    return;<br />
  }<br />
<br />
<br />
    return;<br />
  }<br />
<br />
  } else {<br />
  }<br />
<br />
  delay(2000);<br />
<br />
}<br />
<br />
void loop() {<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-05 Read free GPIO state]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8702</link>
			<pubDate>Thu, 28 Nov 2024 19:45:17 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8702</guid>
 *<br />
 * GPIO Status Monitoring<br />
 *<br />
 * This program monitors the status (high or low) of multiple GPIO pins on the ESP32-S3.<br />
 * It prints the status of the pins to the serial monitor whenever a change is detected.<br />
 *<br />
 * GPIO Pins Monitored:<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 21<br />
 * - GPIO 15<br />
 * - GPIO 14<br />
 * - GPIO 13<br />
 * - GPIO 12<br />
 * - GPIO 40<br />
 *<br />
 * Hardware Requirements:<br />
 * - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing<br />
 */<br />
<br />
#define GPIO_PIN_48 48<br />
#define GPIO_PIN_47 47<br />
#define GPIO_PIN_21 21<br />
#define GPIO_PIN_15 15<br />
#define GPIO_PIN_14 14<br />
#define GPIO_PIN_13 13<br />
#define GPIO_PIN_12 12<br />
#define GPIO_PIN_40 40<br />
<br />
// Store the previous state of the GPIO pins<br />
bool prevState[8] = {false, false, false, false, false, false, false, false};<br />
<br />
void setup() {<br />
  // Initialize serial communication for debugging purposes<br />
  Serial.begin(115200); // Initialize the serial monitor at 115200 baud<br />
  while (!Serial);      // Wait for the serial monitor to open<br />
<br />
  // Initialize GPIO pins as inputs<br />
  pinMode(GPIO_PIN_48, INPUT);<br />
  pinMode(GPIO_PIN_47, INPUT);<br />
  pinMode(GPIO_PIN_21, INPUT);<br />
  pinMode(GPIO_PIN_15, INPUT);<br />
  pinMode(GPIO_PIN_14, INPUT);<br />
  pinMode(GPIO_PIN_13, INPUT);<br />
  pinMode(GPIO_PIN_12, INPUT);<br />
  pinMode(GPIO_PIN_40, INPUT);<br />
<br />
  Serial.println("GPIO Status Monitoring Started");<br />
}<br />
<br />
void loop() {<br />
  // Read the current state of each GPIO pin<br />
  bool currentState[8];<br />
  currentState[0] = digitalRead(GPIO_PIN_48);<br />
  currentState[1] = digitalRead(GPIO_PIN_47);<br />
  currentState[2] = digitalRead(GPIO_PIN_21);<br />
  currentState[3] = digitalRead(GPIO_PIN_15);<br />
  currentState[4] = digitalRead(GPIO_PIN_14);<br />
  currentState[5] = digitalRead(GPIO_PIN_13);<br />
  currentState[6] = digitalRead(GPIO_PIN_12);<br />
  currentState[7] = digitalRead(GPIO_PIN_40);<br />
<br />
  // Check for changes in GPIO pin states<br />
    if (currentState[i] != prevState[i]) {<br />
      // Print the pin number and its new state if it has changed<br />
      Serial.print("GPIO ");<br />
      Serial.print(i == 0 ? GPIO_PIN_48 : <br />
                 &nbsp;&nbsp;i == 1 ? GPIO_PIN_47 : <br />
                 &nbsp;&nbsp;i == 2 ? GPIO_PIN_21 : <br />
                 &nbsp;&nbsp;i == 3 ? GPIO_PIN_15 : <br />
                 &nbsp;&nbsp;i == 4 ? GPIO_PIN_14 : <br />
                 &nbsp;&nbsp;i == 5 ? GPIO_PIN_13 : <br />
                 &nbsp;&nbsp;i == 6 ? GPIO_PIN_12 : GPIO_PIN_40);<br />
      Serial.print(" changed to ");<br />
      Serial.println(currentState[i] ? "HIGH" : "LOW");<br />
      // Update the previous state<br />
      prevState[i] = currentState[i];<br />
    }<br />
  }<br />
<br />
  // Delay to avoid flooding the serial monitor<br />
  delay(100); // Adjust the delay as needed<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8572" target="_blank" title="">5-free-gpio-state.zip</a> (Size: 1.05 KB / Downloads: 777)
 *<br />
 *<br />
 *<br />
 * - GPIO 48<br />
 * - GPIO 47<br />
 * - GPIO 21<br />
 * - GPIO 15<br />
 * - GPIO 14<br />
 * - GPIO 13<br />
 * - GPIO 12<br />
 * - GPIO 40<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
}<br />
<br />
void loop() {<br />
<br />
    }<br />
  }<br />
<br />
		</item>
		<item>
			<title><![CDATA[[arduino code examples for F32]-04 RS485 communication test]]></title>
			<link>https://www.kincony.com/forum/showthread.php?tid=8701</link>
			<pubDate>Thu, 28 Nov 2024 19:44:19 +0800</pubDate>
			<guid isPermaLink="false">https://www.kincony.com/forum/showthread.php?tid=8701</guid>
 *<br />
 *<br />
 * The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.<br />
 */<br />
<br />
<br />
// Define RS485 pins<br />
#define RS485_RXD 17<br />
#define RS485_TXD 16<br />
<br />
<br />
  Serial.begin(115200);<br />
  while (!Serial);<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
  // Send a test message<br />
  rs485Serial.println("Hello from KinCony F16!");<br />
<br />
  delay(1000);<br />
<br />
      receivedMessage += c;<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
<!-- end: attachment_icon -->&nbsp;&nbsp;<a href="attachment.php?aid=8571" target="_blank" title="">4-RS485-Test.zip</a> (Size: 763 bytes / Downloads: 763)
 *<br />
 *<br />
 */<br />
<br />
<br />
<br />
<br />
<br />
  <br />
}<br />
<br />
void loop() {<br />
<br />
  delay(1000);<br />
<br />
    }<br />
  }<br />
<br />
  delay(2000);<br />
		</item>
	</channel>
</rss>
