how to integrate KC868-A8 to home assistant by MQTT - Printable Version
+--- Thread: how to integrate KC868-A8 to home assistant by MQTT (/showthread.php?tid=7164)
Pages: 1 2 3 4 5
RE: how to integrate KC868-A8 to home assistant by MQTT - admin - 07-28-2025
if you want use DHT22, you can config by ESPHome, not use by KCS firmware, because KCS v3 support DHT22 sensor, KCS v2 not support directly.
RE: how to integrate KC868-A8 to home assistant by MQTT - ivann - 07-29-2025
(07-28-2025, 11:24 PM)admin Wrote: if you want use DHT22, you can config by ESPHome, not use by KCS firmware, because KCS v3 support DHT22 sensor, KCS v2 not support directly.
If I replace DHT22 with DHT11, will I be able to display it in Home Assistant without reflashing the ESP?
RE: how to integrate KC868-A8 to home assistant by MQTT - admin - 07-29-2025
if use by ESPHome, not need change code. it's same for DHT11 or DHT22 sensor.
(07-29-2025, 10:55 AM)admin Wrote: if use by ESPHome, not need change code. it's same for DHT11 or DHT22 sensor.
I don't use ESP, I use firmware v2.2.14 and connect to HA via mqtt.
If I replace the DHT22 sensor with DHT11, will I be able to see the temperature in HA without reflashing?
i am not sure, you can test.
RE: how to integrate KC868-A8 to home assistant by MQTT - ivann - 07-31-2025
(07-29-2025, 09:59 PM)admin Wrote: i am not sure, you can test.
Do I need to make any additional settings so that the sensor appears in Home Assistant? It is not registered anywhere.
RE: how to integrate KC868-A8 to home assistant by MQTT - admin - 07-31-2025
not need add another component, the port already include pull up resistance on PCB.
RE: how to integrate KC868-A8 to home assistant by MQTT - ivann - 08-01-2025
(07-31-2025, 11:28 PM)admin Wrote: not need add another component, the port already include pull up resistance on PCB.
Thank you. Tell me where to get instructions for setting up Tuya integration
RE: how to integrate KC868-A8 to home assistant by MQTT - admin - 08-01-2025
you need to buy tuya license use for KC868-A8.
how to buy see here: https://www.kincony.com/forum/showthread.php?tid=2544
how to set tuya license in KCS firmware, see here KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
RE: how to integrate KC868-A8 to home assistant by MQTT - ivann - 08-02-2025
(08-01-2025, 07:23 AM)admin Wrote: you need to buy tuya license use for KC868-A8.
The paid version is not suitable. What other ways are there to forward my temperature sensor to Home Assistant and leave the KCS 2 firmware?
