09-05-2026, 07:39 AM
I would use a separate breaker and power block for the LEDs - in my view they should go on a 'lights' breakers, while the home automation should have its own separate breaker. I have a breaker for the home automation and its related network, another one for my own LAN network, and lights etc. on their own breakers.
Unifi is nice with regards to user interface, but once it's setup you will very rarely touch the home automation network again in the years to come. I would go with something cheap, durable, and as power-efficient as possible, and Unifi are not the best for that. I would use Unifi for the LAN though.
My electrical panel is a Hager of about 1900x560 mm. I don't have the reference, sorry. Have you considered using a single, much larger, electrical panel for the electricity and the home automation? I suppose it would simplify wiring and in the end use less floor space.
A 'detail': on the Kincony boards, you will need to distribute the power from one feed to several relays (all the lights on the same breaker for instance). You can use short wires, but it's much more convenient and tidy to use this kind of thing https://fr.aliexpress.com/item/1005004525861091.html. You can see the results in my pictures.
Also, do check the physical size of the Kincony boxes. In my setup they fit with just enough space between the rows to connect the wires.
As shipping delays are quite long, I bought an extra spare of all the 'critical' components, including the F32 box and additional relays.
