KC868-A2 SIM7600 with Tuya GPRS not work
#41
(02-21-2026, 04:22 AM)admin Wrote: the time synchronization by your computer web browser.
причем тут мой браузер? у меня в системе точно не 1970 год. для синхронизации времени прописан NTP сервер и установлен часовой пояс. При подключении через LAN порт (выход в интернет через роутер) время синхронизируется, а вот через GPRS - нет.
can you take a video of your problem, send to whatsapp number: +86-15381188302
(02-21-2026, 11:17 AM)admin Wrote: can you take a video of your problem, send to whatsapp number: +86-15381188302
unfortunately, WhatsApp is not working.
And without a video, I explained the problem in sufficient detail.
If the connection to the Internet is only via GPRS, then in the application on the phone, the device remains offline, although when connected to the device via AP wifi (192.168.4.1) on the Monitor tab, it shows that
GPRS : connected
Tuya : connected
I also noticed that there is no time synchronization, although the NTP server is registered, the time zone is set - the clock counts down from January 1, 1970.
I also looked at the logs on the Tuya website - the device after rebooting connects to the Tuya cloud for just a couple of minutes and then falls off due to a timeout
take a video , upload to google driver, post at here.
Any Update on the Home Assistant Integration via Tuya?
(02-26-2026, 05:56 PM)WestfieldGhost Wrote: Any Update on the Home Assistant Integration via Tuya?
KCS v3 work on A2v3 pcb, can use for that. change tuya PID.
