Using RTS shutters saves me from having to buy a third relay board.
I’ve also opted for a dedicated physical network setup with a router and switch. It’s pricier, but I’m tempted by the UniFi ecosystem, which seems to simplify everything significantly.
24V 240W power supply. I’ve planned for two LED strips; at 15W/m, the wattage adds up fast. My planned 120 W would be cutting it too close .If I want to add a bit more, it won't work. So, I’m thinking of using that one instead.
It’s 113.5 mm thick. For now, I’m going with an empty 800x600x250 (or 300) metal enclosure, so depth won’t be an issue. I plan to arrange the modules and such just like in some of the Kincony videos.
Thanks for sharing photos of your setup! What’s the model number for that huge enclosure? (I was considering a 6-row, 24-module unit, but it didn't look very comfortable to work with given the height of the modules).
My panels will be side-by-side.
- On the left wall: a 19-inch rack for the network, mini PC, ISP box, etc.
- On the opposite wall: a standard Schneider 4-row, 18-module panel for the 230V circuits.
- On the same wall, right next to it: the home automation enclosure. (I would have liked the 19-inch rack on the right, but I don't have the space).
I’ve started working on my diagrams. I took the opportunity to scale the components correctly and have placed a few items. It’s not final, but I think the sizing is looking good. (I probably won't have the budget for cable trunking; it's impossible to find at a decent price unless you buy a whole pallet).
Regarding the diagrams, I honestly don’t know much about this. I just made something similar to what I’ve seen, adapting the connections to match the equipment I’m using.
I have 38 lighting circuits. There are still a few things I need to add, but it’s getting late! I’ll probably clean everything up and make it look nice at the end. Maybe! ?
I see new things every day, but I feel like I’m getting close to the finish line! (Well, regarding the shopping list for the hardware.
I’ve never touched anything related to electronics, like ESP32 or Home Assistant.)
Thank you, Regarding the AC, I still need to look into a few things and discuss it with the installers.
I would use a separate breaker and power block for the LEDs - in my view they should go on a 'lights' breakers, while the home automation should have its own separate breaker. I have a breaker for the home automation and its related network, another one for my own LAN network, and lights etc. on their own breakers.
Unifi is nice with regards to user interface, but once it's setup you will very rarely touch the home automation network again in the years to come. I would go with something cheap, durable, and as power-efficient as possible, and Unifi are not the best for that. I would use Unifi for the LAN though.
My electrical panel is a Hager of about 1900x560 mm. I don't have the reference, sorry. Have you considered using a single, much larger, electrical panel for the electricity and the home automation? I suppose it would simplify wiring and in the end use less floor space.
A 'detail': on the Kincony boards, you will need to distribute the power from one feed to several relays (all the lights on the same breaker for instance). You can use short wires, but it's much more convenient and tidy to use this kind of thing https://fr.aliexpress.com/item/1005004525861091.html. You can see the results in my pictures.
Also, do check the physical size of the Kincony boxes. In my setup they fit with just enough space between the rows to connect the wires.
As shipping delays are quite long, I bought an extra spare of all the 'critical' components, including the F32 box and additional relays.
Under the NF C 15-100 standard (France), my highest circuit breaker has to be at 1.80m and the lowest at 90cm. I have an access hatch underneath, and in any case, I wouldn't want my home automation gear right down at floor level.
I have a small utility closet dedicated to this, so spreading out horizontally isn't an issue—except for the wiring, of course. I can find double-wide cabinets, but then I wouldn't have a cover for my main distribution board.
I’ll do some more research, but for now, I haven't found anything better than two enclosures side-by-side.
I saw the results you got with those connectors—I’d actually added them to my list without looking into them yet. Thanks for the link; is the spacing standard?
I’m going to use a second 24V power supplies to isolate the boards and keep a clean light circuit.
I’ve got relays on my list, but since I’m trying to keep the budget down, I hadn't planned for a backup board. Do you think the risk is significant?
Regarding UniFi: I plan to add cameras and other gear later on. I’ll also need to segment the network for a potential rental unit.
I’ll likely be tinkering with it regularly since the rest of the setup will unfortunately happen piecemeal. I’m afraid standard managed switches would drive me crazy—even though they’re clearly the best choice financially (UniFi costs roughly 1.5 to 2 times as much). That said, I certainly wouldn't mind using a small standard switch for my home automation boards and configuring it manually.
You need these specific dimensions for the Kincony F24 (or F32). I found them on Aliexpress.
I have no idea of the durability of the boards, but if one dies I'll have half of the appartment unusable (lights, heating, shutters), so I chose to spend an extra 300€ to be on the safe side. For the same reason I bought a few spare Omron relays.
Will you install a central control panel? Like a tablet or similar. If yes you should plan at least for power, and possibly network/PoE.
Thanks for the source regarding the busbar dimensions.
I guess I'll have to live with this Sword of Damocles hanging over me for a while; for now, though, I've mostly set everything up for the lighting, so I don't have any critical equipment relying on those boards. I could easily move my water heater or a radiator if necessary.
I was planning to get a tablet as soon as possible. I admit I hadn't picked a main spot for it yet, but there aren't exactly endless options. A central location—if I can open up the kitchen—seems perfect (indicated by the big black arrow).
While I'm at it: blue marks standard power outlets; orange marks those connected to a UPS (19" rack and office computer/monitor outlets); red marks dedicated circuits (cooktop, oven, washing machine, etc.); and green marks RJ45 ports. The black box representing my utility room is in the basement.
Oh, and I decided to knock down an entire partition wall just today, so who knows what might change before the major work begins.
I started ordering my electrical gear today. I'm going with a 4x18-module unit for the main electrics and an 800x600x300 enclosure for the home automation system. The price-to-quality ratio is actually pretty good.
Blue marks standard power outlets; orange marks those connected to a UPS (19" rack and office computer/monitor outlets); red marks dedicated circuits (cooktop, oven, washing machine, etc.); and green marks RJ45 ports. The black box representing my utility room is in the basement.
My VMC has an RJ45 port, useful to integrate it in Home Assistant. I don't see one on the plan, it could be good to include it just in case.
Also I didn't plan a higher-up RJ45 port in any room, and it turned out that wifi coverage is way better if the access point is above the furniture and other obstacles. After the construction was done, I had to replace an electrical socket with an RJ45 above the kitchen furniture. This allowed to replace three access points with a single one.
I have some RJ45 lines in the attic that aren't shown on the socket diagram: two for outdoor camera locations, one for a ceiling-mounted Wi-Fi access point, and potentially one for a PoE Zigbee/Thread dongle and/or the RTS module for the shutters. That network cabling is going to get used up fast. In any case, I’ve planned for two empty conduits (keeping 230V separate from the network cabling).
As for the ventilation system (VMC), I’d happily run an extra network cable; however, since I’ve planned for a basic "Hygro B" system with very simple operation, a manual override switch at the distribution board—likely a global one rather than individual vent control—that I could program via certain light switches seems sufficient. I haven't really planned anything elaborate for that part.
You have a dual-flow system, I imagine? That would certainly make it much more relevant in your case.
I’m currently looking into how to control my domestic hot water tank via Home Assistant while keeping the basic Linky control as a backup in case the smart home system fails. A changeover contactor is the solution I'm currently considering (like Schneider A9E15535). What do you think?
It certainly looks great. As for the hot water tank, that’s a low priority. I’ll figure something out, or at worst, handle it later on.
I think I’ll add a small energy meter to my cart, just like you did.
I just need the AC LoRa Energy Meter – N10" unit and a few "Current Transformer CT For KinCony M30 M16 Energy Meter Board" units ? (1x60A for the main house feed and a few 25A ones for the circuits I want to monitor?).
DL-CT03CL2.0 aperture 5mm 0-25A cable length: 1 meter
DL-CT08CL10-2000/1 aperture 8.4mm 0-60A cable length: 16cm. It's ridiculously short. Are there rules, or can it be extended?
Regarding the wiring, for the lighting circuits, I will use 1.5 mm² cable through the Kincony relays and few 24V (like juste after the 24V power supply).
For everything else, like control wiring, internal wiring, 24V power supply for sensors and modules, what type and cable size would you recommend for.
