Full Version: KC868-A2
KC868-A2
Threads
  1. KC868-A2v3 (3 Replies)
  2. KC868-A2 SIM7600 with Tuya GPRS not work (45 Replies)
  3. Problema a cargar .bin al KC868-A2 (9 Replies)
  4. LAN8720 DHCP implementaion with mqtt arduino source code (1 Reply)
  5. KC868-A2 ESP32 I/O pin define (16 Replies)
  6. KC868-A2 + SIM7600 LTE + Home Assistant – Relays & Sensors over LTE? (3 Replies)
  7. Using KC868 A2 with Home Assistant / MQTT (1 Reply)
  8. KC868-A2 with SIM7600E – Unable to operate after multiple attempts (1 Reply)
  9. LAN connection lost sometimes (1 Reply)
  10. i2c lcd_pcf8574 not working (3 Replies)
  11. [Arduino source code for KC868-A2]-03 LAN8720_UDP (1 Reply)
  12. ESP32: ETH + RELAY (7 Replies)
  13. PCB dimensions & STP model (4 Replies)
  14. KC868-A2 watchdog (1 Reply)
  15. Protective diodes for relays (1 Reply)
  16. [Arduino source code for KC868-A2]-05 RS485 (5 Replies)
  17. KC868-A2 configure yaml for ESPhome (21 Replies)
  18. error on compling - ethenet (6 Replies)
  19. SHT30/DS18B20 errors and warnings in the logs (30 Replies)
  20. aduino and kc86822a to D1 (0 Replies)
  21. How to use D1 and D2 dry contacts ? (6 Replies)
  22. IP CAM (1 Reply)
  23. How use SIM800 on KC868-A2 (1 Reply)
  24. KC8686-A2 + SIM7070 GSM (1 Reply)
  25. [Arduino source code for KC868-A2]-05 RS485 modbus temperature humidity sensor (0 Replies)
  26. GSM CALL RELAY (9 Replies)
  27. No RS485 on output KC868 A2 (9 Replies)
  28. KC868-A2 V2.4 +SIM7600E-L1C (6 Replies)
  29. Sample code for SIM800L and schematics (10 Replies)
  30. KC868-A2 with ESP32 Cam (3 Replies)
  31. KC868-A2 and SIM7600G-H (1 Reply)
  32. KC868-A2 and SIM7600 (5 Replies)
  33. arduino demo code A2 with SIM800L 2G module test AT command by serial port (0 Replies)
  34. Issue with GSM Pin Connect (6 Replies)
  35. KC868-A2 wiring diagram (0 Replies)
  36. Which GND to use for sensors ? (1 Reply)
  37. Are the Other GPIO available in any way on the board ? (4 Replies)
  38. [Arduino source code for KC868-A2]-04 RELAY (0 Replies)
  39. [Arduino source code for KC868-A2]-02 INPUT (0 Replies)
  40. [Arduino source code for KC868-A2]-01 DS18B20 (0 Replies)
