Full Version: KC868-A Pins to HomeSpan HomeKit
Hello, I would like to use my controller for homekit control. I found out from the instructional videos that Relay 3 and 4 are on pins 2 and 15.
I would like to use more relays, and configure digital inputs as switches.
In further configuration I would like to use analog inputs and a temperature sensor.
you can add more relay channel by edit code, that just a example. which board model you are using?
