01-05-2022, 05:26 AM
Before using KC868-A8, you need to set the parameters of the preference
Copy the following URL: https://dl.espressif.com/dl/package_esp32_index.json
[attachment=489]
Select the Board "NodeMCU -32S"
[attachment=490]
[attachment=511]
#define ANALOG_A1 34 updated in PCB V1.4
#define ANALOG_A2 35 updated in PCB V1.4
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x24
Relay1 = pcf8574.pinMode(P0, OUTPUT);
Relay2 = pcf8574.pinMode(P1, OUTPUT);
Relay3 = pcf8574.pinMode(P2, OUTPUT);
Relay4 = pcf8574.pinMode(P3, OUTPUT);
Relay5 = pcf8574.pinMode(P4, OUTPUT);
Relay6 = pcf8574.pinMode(P5, OUTPUT);
Relay7 = pcf8574.pinMode(P6, OUTPUT);
Relay8 = pcf8574.pinMode(P7, OUTPUT);
Input_IIC_address 0x22
Input1 = pcf8574.pinMode(P0, INPUT);
Input2 = pcf8574.pinMode(P1, INPUT);
Input3 = pcf8574.pinMode(P2, INPUT);
Input4 = pcf8574.pinMode(P3, INPUT);
Input5 = pcf8574.pinMode(P4, INPUT);
Input6 = pcf8574.pinMode(P5, INPUT);
Input7 = pcf8574.pinMode(P6, INPUT);
Input8 = pcf8574.pinMode(P7, INPUT);
DS18B20/DHT11/DHT21/LED strip -1: 14
DS18B20/DHT11/DHT21/LED strip -2: 13
DS18B20/DHT11/DHT21/LED strip -3: 32 updated in PCB V1.4
DS18B20/DHT11/DHT21/LED strip -4: 33 updated in PCB V1.4
RF433MHz wireless receiver: 15
#define ETH_ADDR 0
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
[attachment=489]
[attachment=490]
[attachment=511]
IIC SDA:4
IIC SCL:5
#define ETH_ADDR 0
