01-07-2022, 05:27 AM
Code 9: //The demo code is IR-ReceiveAndSend2 You can copy the code to your Arduino IDE.
[attachment=553]
#include <Arduino.h>
#include "PinDefinitionsAndMore.h"
//#define EXCLUDE_EXOTIC_PROTOCOLS // saves around 900 bytes program space
#include <IRremote.h>
int SEND_BUTTON_PIN = APPLICATION_PIN;
int STATUS_PIN = LED_BUILTIN;
int DELAY_BETWEEN_REPEAT = 50;
// On the Zero and others we switch explicitly to SerialUSB
#if defined(ARDUINO_ARCH_SAMD)
#define Serial SerialUSB
#endif
// Storage for the recorded code
struct storedIRDataStruct {
IRData receivedIRData;
// extensions for sendRaw
uint8_t rawCode[RAW_BUFFER_LENGTH]; // The durations if raw
uint8_t rawCodeLength; // The length of the code
} sStoredIRData;
int lastButtonState;
void storeCode(IRData *aIRReceivedData);
void sendCode(storedIRDataStruct *aIRDataToSend);
#if defined(__AVR_ATmega32U4__) || defined(SERIAL_USB) || defined(SERIAL_PORT_USBVIRTUAL) || defined(ARDUINO_attiny3217)
delay(4000); // To be able to connect Serial monitor after reset or power up and before first print out. Do not wait for an attached Serial Monitor!
#endif
// Just to know which program is running on my Arduino
Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK); // Start the receiver, enable feedback LED, take LED feedback pin from the internal boards definition
IrSender.begin(IR_SEND_PIN, ENABLE_LED_FEEDBACK); // Specify send pin and enable feedback LED at default feedback LED pin
pinMode(STATUS_PIN, OUTPUT);
Serial.print(F("Ready to receive IR signals at pin "));
#if defined(ARDUINO_ARCH_STM32) || defined(ESP8266)
Serial.println(IR_RECEIVE_PIN_STRING);
#else
Serial.println(IR_RECEIVE_PIN);
#endif
Serial.print(F("Ready to send IR signals at pin "));
Serial.println(IR_SEND_PIN_STRING);
#else
Serial.print(IR_SEND_PIN);
#endif
Serial.print(F(" on press of button at pin "));
Serial.println(SEND_BUTTON_PIN);
// If button pressed, send the code.
int buttonState = digitalRead(SEND_BUTTON_PIN); // Button pin is active LOW
* Check for button just released in order to activate receiving
if (lastButtonState == LOW && buttonState == HIGH) {
// Re-enable receiver
Serial.println(F("Button released"));
IrReceiver.start();
* Check for static button state
if (buttonState == LOW) {
IrReceiver.stop();
* Button pressed send stored data or repeat
Serial.println(F("Button pressed, now sending"));
digitalWrite(STATUS_PIN, HIGH);
if (lastButtonState == buttonState) {
sStoredIRData.receivedIRData.flags = IRDATA_FLAGS_IS_REPEAT;
sendCode(&sStoredIRData);
digitalWrite(STATUS_PIN, LOW);
delay(DELAY_BETWEEN_REPEAT); // Wait a bit between retransmissions
* Button is not pressed, check for incoming data
} else if (IrReceiver.available()) {
storeCode(IrReceiver.read());
IrReceiver.resume(); // resume receiver
lastButtonState = buttonState;
// Stores the code for later playback in sStoredIRData
// Most of this code is just logging
void storeCode(IRData *aIRReceivedData) {
if (aIRReceivedData->flags & IRDATA_FLAGS_IS_REPEAT) {
Serial.println(F("Ignore repeat"));
return;
if (aIRReceivedData->flags & IRDATA_FLAGS_IS_AUTO_REPEAT) {
Serial.println(F("Ignore autorepeat"));
return;
if (aIRReceivedData->flags & IRDATA_FLAGS_PARITY_FAILED) {
Serial.println(F("Ignore parity error"));
return;
* Copy decoded data
sStoredIRData.receivedIRData = *aIRReceivedData;
if (sStoredIRData.receivedIRData.protocol == UNKNOWN) {
Serial.print(F("Received unknown code and store "));
Serial.print(IrReceiver.decodedIRData.rawDataPtr->rawlen - 1);
Serial.println(F(" timing entries as raw "));
IrReceiver.printIRResultRawFormatted(&Serial, true); // Output the results in RAW format
sStoredIRData.rawCodeLength = IrReceiver.decodedIRData.rawDataPtr->rawlen - 1;
* Store the current raw data in a dedicated array for later usage
IrReceiver.compensateAndStoreIRResultInArray(sStoredIRData.rawCode);
IrReceiver.printIRResultShort(&Serial);
sStoredIRData.receivedIRData.flags = 0; // clear flags -esp. repeat- for later sending
Serial.println();
void sendCode(storedIRDataStruct *aIRDataToSend) {
if (aIRDataToSend->receivedIRData.protocol == UNKNOWN /* i.e. raw */) {
// Assume 38 KHz
IrSender.sendRaw(aIRDataToSend->rawCode, aIRDataToSend->rawCodeLength, 38);
Serial.print(F("Sent raw "));
Serial.print(aIRDataToSend->rawCodeLength);
Serial.println(F(" marks or spaces"));
* Use the write function, which does the switch for different protocols
IrSender.write(&aIRDataToSend->receivedIRData, NO_REPEATS);
Serial.print(F("Sent: "));
printIRResultShort(&Serial, &aIRDataToSend->receivedIRData);
