KC868-A4
Important Threads
- [Arduino source code for KC868-A4]-18 one GPIO with multiple DS18B20 sensor (4 Replies)
- KC868-A4 esphome yaml config for home assistant (6 Replies)
- [Arduino source code for KC868-A4]-17 homekit work with 4 relay and 4 switch buttons (8 Replies)
- [Arduino demo source code for KC868-A4]-15 internet control by ESP Rainmaker (30 Replies)
- [Arduino source code for KC868-A4]-21 Homekit with relay &DS18B20 &contact sensor (4 Replies)
- [Arduino source code for KC868-A4]-20 Apple Homekit 4pcs motion sensor (0 Replies)
- [Arduino source code for KC868-A4]-19 Apple Homekit with 10pcs DS18B20 (0 Replies)
- [Arduino demo source code for KC868-A4]-16 homekit with DS18B20 temperature sensor (2 Replies)
- [Arduino demo source code for KC868-A4]-12 web server by wifi (0 Replies)
- [Arduino demo source code for KC868-A4]-11 how to create wifi connection (8 Replies)
- [Arduino demo source code for KC868-A4]-07 voice control by alexa speaker (2 Replies)
- [Arduino demo source code for KC868-A4]-13 work with KBOX phone app (6 Replies)
- [Arduino demo source code for KC868-A4]-09 homekit work with 2 relay (0 Replies)
- [Arduino demo source code for KC868-A4]-08 control relay by BlueTooth (0 Replies)
- [Arduino demo source code for KC868-A4]-06 analog output (DAC) data (0 Replies)
- [Arduino demo source code for KC868-A4]-05 read analog input (ADC) data (0 Replies)
- [Arduino demo source code for KC868-A4]-04 read DS18B20 temperature sensor (0 Replies)
- [Arduino demo source code for KC868-A4]-03 send 433MHz RF signal (0 Replies)
- [Arduino demo source code for KC868-A4]-02 433MHz RF signal receive decode (0 Replies)
- [Arduino demo source code for KC868-A4]-01 config Arduino IDE for ESP32 module (0 Replies)
Threads
- Where to start? (16 Replies)
- Control an RS485 device with KC868_A6 from Home Assistant (3 Replies)
- Tasmota Download Issues (4 Replies)
- Kc868-A4 (1 Reply)
- ESPHome yaml for DS18B20 and ADC 1 ~ 4 (3 Replies)
- KC868-A4S-V1.4 - Sketch uses 1356618 bytes (103%) of program storage space (0 Replies)
- KC868-A4 - DHT 22 (7 Replies)
- KC-868-A4 0v-5v ADC no where near accurate (5 Replies)
- Question how to connect inductive proximity switch to KC868-A4 (1 Reply)
- coding support (1 Reply)
- 433MHz sender and recievers (1 Reply)
- 0-10v in analog input (3 Replies)
- KC868-A4 not compiling to Arduino (3 Replies)
- Nextion display work with KC868-A4 (5 Replies)
- KC868-A4 with Nextion 5 inch display issue (2 Replies)
- OLED display for A4 (6 Replies)
- Get PWM out, even by sacrificing other functionality (7 Replies)
- How to read data analog from 4-20mA port? (12 Replies)
- Dallas DS18b20 sensor is no longer found after the last ESPHOME update - KC868-A4 (10 Replies)
- KC868A-4 RF433MHz decoding. (17 Replies)
- KC868-A4 Bluetooth momentary Switch (3 Replies)
- KC868_A4 Tuya Bluetooth (5 Replies)
- KC868-A4 DIGITAL I/O (3 Replies)
- KC686-A4 0-10 ->PWM (1 Reply)
- KC868-A4 static IP address (3 Replies)
- KC868-A4 and A8 plastic enclosure 3D printer stl file (7 Replies)
- A4 supported power voltage range (4 Replies)
- DS18B20 (2 Replies)
- Which App is best to use with IOS and Android. (8 Replies)
- Contactor control (1 Reply)
- Defectiv Board? (1 Reply)
- KC868 4A control water from phone (7 Replies)
- DS18B20 (5 Replies)
- the frequency of the digital inputs (1 Reply)
- KC868-A4 Dip button (1 Reply)
- 4-20mA Scale for IFTTT is not Precise (3 Replies)
- IR LED extention cable (5 Replies)
- 5v sensor (1 Reply)
- BMP180/280 (2 Replies)
- KC868-A4 wiring diagram (7 Replies)
- Possibility of controlling with 2 relays (5 Replies)
- input A1 4-20mA ESPHome (3 Replies)
- KC868-A4 ESP32 I/O pin define in Arduino IDE (2 Replies)
- 12v Power Supply for Kincony. (8 Replies)
- Add i2c pins or RTC time (1 Reply)
- 868-A4 pins for SPI (1 Reply)
- A4s inaccurate voltage readings (1 Reply)
- ADC GPIOs (1 Reply)
- [Arduino demo source code for KC868-A4]-10 infrared signal receive and decoding (8 Replies)
- MQTT command for buzzer (3 Replies)
