Full Version: KC868-A4 static IP address
In my house I integrated the KC868 A4, A8 and A16 controllers (with KCS firmware) into the TapHome system. I used the Http Server for the connection. The static ip address is important here.
In the case of A8 and A16, the static ip can be set in the KCS, but in the A4 it is not available, as it only has wifi.
Is there a possibility for this? I ask for your help.
Regards, Zoltán
now wifi only work with DHCP in KCS. do you use mqtt integrate to your own system?
Hi Admin!
Thanks for your feedback!
I don't use MQTT integration in my own system, but I can run MQTT broker in my smart-home server. You think that I can use KC868-A4 as a client and there will be no problem that it works via dhcp?
Best regards,
Zoltán Szőke
you can config by ESPHome, use static IP work with your mqtt broker.
here is ESPHome mqtt online guide: https://esphome.io/components/mqtt.html
