05-17-2022, 01:28 AM
[Arduino IDE demo source code for KC868-E16S]--#05-KC868-E16S-LAN8720_UDP
[attachment=1011]
[attachment=1012]
[attachment=1011]
/*www.kincony.com */
/* KC868-E16S CODE OF LAN8720-UDP */
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR 0
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
WiFiUDP Udp; //Create UDP object
Serial.println();
Serial.println("Connected");
Serial.print("IP Address:");
if (packetSize) //if have received data
char buf[packetSize];
Serial.println();
Serial.print("Received: ");
Serial.println(buf);
Serial.print("From IP: ");
Serial.print("From Port: ");
Udp.print("Received: ");
Udp.endPacket(); //send data
