08-11-2022, 06:46 AM
[attachment=1255]
platform: ESP32
sda: 16
scl: 15
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
address: 0x21
- id: 'pcf8574_hub_out_2' # for output channel 9-16
address: 0x25
# Individual outputs
pcf8574: pcf8574_hub_out_1
pcf8574: pcf8574_hub_out_2
pcf8574: pcf8574_hub_in_2
platform: ESP32
sda: 16
scl: 15
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
# manual_ip:
address: 0x21
address: 0x25
![[Image: media?url=https%3A%2F%2Fi.redd.it%2Fs4qu6ma3eacc1.jpeg]](https://www.reddit.com/media?url=https%3A%2F%2Fi.redd.it%2Fs4qu6ma3eacc1.jpeg)
