08-23-2022, 08:59 AM
[Arduino IDE demo source code for KC868-A6]--#12-Web_server_code
[attachment=1267]
[attachment=1268]
[attachment=1267]
[attachment=1268]
* Create Your own WebServer for KC868-A6 Smart Controller*
* https://www.kincony.com **
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0 // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
// Replace with your network credentials
/*******config the WIFI by phone*****************/
/* const char* ssid = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password*/
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
//set I2C of A6
PCF8574 pcf8574_I1(&I2Cone,0x22,4,15);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state",
"relay5state","relay6state"
pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
for(int i=0;i<=5;i++)
pcf8574_R1.begin();
pcf8574_I1.pinMode(i, INPUT);
pcf8574_I1.begin();
WiFi.mode(WIFI_STA);
wm.setConfigPortalTimeout(timeout);
bool res;
res = wm.autoConnect("KC868-A6-AP"); // anonymous ap
if(!res) {
Serial.println("Failed to connect");
else {
Serial.println("connected...yeey :)");
Serial.println("");
Serial.println("WiFi connected.");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
Serial.println("New Client."); // print a message out in the serial port
currentTime = millis();
previousTime = currentTime;
Serial.write(c); // print it out the serial monitor
header += c;
client.println();
// turns 16 relays on and off
else if (header.indexOf("GET /2/on") >= 0) {relay2state = "on";pcf8574_R1.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /3/on") >= 0) {relay3state = "on";pcf8574_R1.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /4/on") >= 0) {relay4state = "on";pcf8574_R1.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /5/on") >= 0) {relay5state = "on";pcf8574_R1.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /6/on") >= 0) {relay6state = "on";pcf8574_R1.digitalWrite(P5, LOW);}
// Display the HTML web page
client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;}");
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state);
else
// Web Page Heading
client.println("<body><h1>KC868-A6 Web Server</h1>");
if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
client.println("<a href=\"/all/on\"><button class=\"button\">All-ON</button></a>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
void ScanKey()
if(pcf8574_I1.digitalRead(i) == LOW) //key pressed
delay(20);
if(pcf8574_I1.digitalRead(i) == LOW) //key pressed again
pcf8574_R1.digitalWrite(i,!pcf8574_R1.digitalRead(i)); // toggle relay1 state
CF8574(TwoWire*, int, int, int)'
IO, clock div:1
