Full Version: KC868-A6
KC868-A6
Pages: 1 2 3
Threads
  1. Custom ESPHome firmware and Tuya integration (39 Replies)
  2. KC868-A6v3 ESP32-S3 6 channel LoRa relay module (1 Reply)
  3. RF fo KC868-A6 (5 Replies)
  4. Rs485 addresses for KC868-A6 relays (5 Replies)
  5. KC868-A6: Any accessible GPIO without hardware modification? (1 Reply)
  6. KC868-A6 with KC868-HAv2 (1 Reply)
  7. ompatibility of ACS712 with KC868‑A6 ADC Inputs (Arduino) (3 Replies)
  8. цифровые входы DI-1-6 на KinCony KC868-A6 (1 Reply)
  9. Digital inputs (6 Replies)
  10. Help needed: Bricked A6 v1.3 board (5 Replies)
  11. KC868-A6 - how to connect an optocoupler (10 Replies)
  12. Where to start (11 Replies)
  13. PCF8574 INT pin on KC868-A6 — Is it connected to ESP32? Schematic request. (3 Replies)
  14. how to use tasmota firmware with KC868-A6 (22 Replies)
  15. KC868-A6 Flow Control (3 Replies)
  16. MODBUS RTU comunication KC868 wich Siemens S1200 RS485 (3 Replies)
  17. DEBUG by JTAG (1 Reply)
  18. Cant connect to wifi STA (5 Replies)
  19. No AP appears (5 Replies)
  20. Power supply (1 Reply)
  21. Troubles using I2C/IIC bus (23 Replies)
  22. Troubles UART (12 Replies)
  23. UART KC868-A6 (1 Reply)
  24. DS18B20 temp sensor (7 Replies)
  25. How to use A6V3 with a momentary switch (3 Replies)
  26. PZEM-004T With A6 on Serial (11 Replies)
  27. Debug via USB in platformio (1 Reply)
  28. Does the KC868-A6 V1.4 board provide a 5V output for DS18B20 sensors? (1 Reply)
  29. kc868-a6 A fatal error occurred: MD5 of file does not match data in flash! (4 Replies)
  30. 868-A6 Tasmota "Reset" (1 Reply)
  31. Input 1-2 not working (6 Replies)
  32. Micropython (7 Replies)
  33. RTC stop working with button cell (15 Replies)
  34. Several controllers in one area (3 Replies)
  35. RS485 Modbus working ESPHome configuration (1 Reply)
  36. ESPhome homeassistant (17 Replies)
  37. using 5v-12v as input sensor (23 Replies)
  38. KC868-A6 - read RS232 data from KCS firmware (3 Replies)
  39. PCF8574 and SSD1306 (3 Replies)
  40. DAC on the KC868-a6 (5 Replies)
  41. 868-A6 Tasmota and DS18x20 (1 Reply)
  42. 868-A6 Tasmota and DS18x20 (1 Reply)
  43. board setup (5 Replies)
  44. KC868-A6 with waveshare LAN8720 (3 Replies)
  45. Better documentation? (7 Replies)
  46. CONECTAR A RED WIFI (2 Replies)
  47. Firmware install too fast (7 Replies)
  48. kc868-a6 communication fault (1 Reply)
  49. kc868-a6 define IO (1 Reply)
  50. Problem with DS1307 on KC868-A6 (20 Replies)
Pages: 1 2 3
