08-24-2022, 12:42 AM
[Arduino IDE demo source code for KC868-A16]--#09-KC868-A16_Web_server_code
[attachment=1273]
[attachment=1274]
[attachment=1273]
[attachment=1274]
* Create Your own WebServer for KC868-A16 Smart Controller*
* https://www.kincony.com **
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0 // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
// Replace with your network credentials
/*******config the WIFI by phone*****************/
/* const char* ssid = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password*/
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
/*******Check the I2C address **********/
/********If your board was purchased earlier, use an older I2C**/
/********OLD A16 Board I2C address */
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_I2(&I2Cone,0x21,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
PCF8574 pcf8574_R2(&I2Cone,0x25,4,5);*/
// Set A16 digital input i2c address
/********NEW A16 Board I2C address */
PCF8574 pcf8574_I1(&I2Cone,0x3A,4,5);
PCF8574 pcf8574_I2(&I2Cone,0x39,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x3C,4,5);
PCF8574 pcf8574_R2(&I2Cone,0x3D,4,5);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state",
"relay5state","relay6state","relay7state","relay8state",
"relay9state","relay10state","relay11state","relay12state",
"relay13state","relay14state","relay15state","relay16state"
pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
for(int i=0;i<=7;i++)
pcf8574_R2.pinMode(i, OUTPUT);
pcf8574_R1.begin();
pcf8574_R2.begin();
pcf8574_I1.pinMode(i, INPUT);
pcf8574_I2.pinMode(i, INPUT);
pcf8574_I1.begin();
pcf8574_I2.begin();
pcf8574_R2.digitalWrite(i, HIGH);
WiFi.mode(WIFI_STA);
wm.setConfigPortalTimeout(timeout);
bool res;
res = wm.autoConnect("KC868-A16-AP"); // anonymous ap
if(!res) {
Serial.println("Failed to connect");
else {
Serial.println("connected...yeey :)");
Serial.println("");
Serial.println("WiFi connected.");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
Serial.println("New Client."); // print a message out in the serial port
currentTime = millis();
previousTime = currentTime;
Serial.write(c); // print it out the serial monitor
header += c;
client.println();
// turns 16 relays on and off
else if (header.indexOf("GET /2/on") >= 0) {relay2state = "on";pcf8574_R1.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /3/on") >= 0) {relay3state = "on";pcf8574_R1.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /4/on") >= 0) {relay4state = "on";pcf8574_R1.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /5/on") >= 0) {relay5state = "on";pcf8574_R1.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /6/on") >= 0) {relay6state = "on";pcf8574_R1.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /7/on") >= 0) {relay7state = "on";pcf8574_R1.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /8/on") >= 0) {relay8state = "on";pcf8574_R1.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /9/on") >= 0) {relay9state = "on";pcf8574_R2.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /10/on") >= 0) {relay10state = "on";pcf8574_R2.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /11/on") >= 0) {relay11state = "on";pcf8574_R2.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /12/on") >= 0) {relay12state = "on";pcf8574_R2.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /13/on") >= 0) {relay13state = "on";pcf8574_R2.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /14/on") >= 0) {relay14state = "on";pcf8574_R2.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /15/on") >= 0) {relay15state = "on";pcf8574_R2.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /16/on") >= 0) {relay16state = "on";pcf8574_R2.digitalWrite(P7, LOW);}
pcf8574_R2.digitalWrite(i, LOW);
// Display the HTML web page
client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;}");
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state);
else
// Web Page Heading
client.println("<body><h1>KC868-A16 Web Server</h1>");
if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07-ON </button></a>");
if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08-ON </button></a>");
if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
client.println("<a href=\"/all/on\"><button class=\"button\">All-ON</button></a>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
void ScanKey()
if(pcf8574_I1.digitalRead(i) == LOW) //key pressed
delay(20);
if(pcf8574_I1.digitalRead(i) == LOW) //key pressed again
pcf8574_R1.digitalWrite(i,!pcf8574_R1.digitalRead(i)); // toggle relay1 state
for(int j=0;j<=7;j++)
if(pcf8574_I2.digitalRead(j) == LOW) //key pressed
delay(20);
if(pcf8574_I2.digitalRead(j) == LOW) //key pressed again
pcf8574_R2.digitalWrite(j,!pcf8574_R2.digitalRead(j)); // toggle relay1 state
while(pcf8574_I2.digitalRead(j) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(j) == LOW) relaystate[j+8]="on";else relaystate[j+8]="off";
