KC868-A16
Important Threads
- KC868-A16 ethernet work with home assistant by ESPHome configure (30 Replies)
- [Arduino IDE demo source code for KC868-A16]--#11-KC868-A16_Ethernet_Web_server_code (16 Replies)
- How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO (67 Replies)
- KC868-A16 ESP32 I/O pin define (10 Replies)
- [Arduino IDE demo source code for KC868-A16]--#01-config Arduino IDE for ESP32 module (9 Replies)
- [Arduino IDE demo source code for KC868-A16]--#09-KC868-A16_Web_server_code (20 Replies)
- [Arduino IDE demo source code for KC868-A16]--#08-PCF8574-DO (17 Replies)
- [Arduino IDE demo source code for KC868-A16]--#04-ADC INPUT (2 Replies)
- [Arduino IDE demo source code for KC868-A16]--#10-KC868-A16_RS485_send and receive (9 Replies)
- [Arduino IDE demo source code for KC868-A16]--#07-PCF8574-DI (4 Replies)
- [Arduino IDE demo source code for KC868-A16]--#06-LAN8720-UDP (0 Replies)
- [Arduino IDE demo source code for KC868-A16]--#05-DS18B20 (0 Replies)
- [Arduino IDE demo source code for KC868-A16]--#03-RF receive (0 Replies)
- [Arduino IDE demo source code for KC868-A16]--#02-RF send (0 Replies)
Threads
- Complete Home Assistant configuration.yaml with yaml anchor for mqtt integration A16 (3 Replies)
- Kincony KC868-A16 (ESP32) - I2C PCF8574 entities visible in HA but not responding (I2 (3 Replies)
- A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec (1 Reply)
- KC868-A16 PCB DWG CAD file download (6 Replies)
- KC868-A16 - IP & PORT ?? Important !!! (22 Replies)
- power input 24v (7 Replies)
- Create light switch in home assistant using MQTT (5 Replies)
- Ethernetproblems (3 Replies)
- Voltage for KC868-16 (1 Reply)
- Replacing ESP32 with Kincony A16: Relay Control Issue (1 Reply)
- MODBUS TCP ETHERNET - SLAVE MODE - KC868-A16 (8 Replies)
- KC868-A16 rs485 (7 Replies)
- KC868-A16 HTTP request config (5 Replies)
- Mqtt a16 (8 Replies)
- KC868-A16 Analog readings on Home Assistant (5 Replies)
- Can no longer change User/PW (4 Replies)
- Problem with A16 inputs 9-16 (7 Replies)
- Esphome restart stand alone (3 Replies)
- can't connect the A16 board to anything (3 Replies)
- Analog Input NTC (3 Replies)
- receive data from switch by RS485 and control output of KC868-A16 (3 Replies)
- RS485 not receiving anything (26 Replies)
- how to connet relay - a16 (1 Reply)
- A16 crashing when using string driver (4 Replies)
- KC 868-A16 RS485 (1 Reply)
- KC868-A16 bind ports input/output (1 Reply)
- [Help] KC868-A16 stopped working with ESPhome (10 Replies)
- trouble programming my KC868-A16 (1 Reply)
- a16 tuya code not working (1 Reply)
- Failed Uploading (2 Replies)
- Board Boot Error (15 Replies)
- Kincony A16 does not enter programming mode (5 Replies)
- Question about i2c oled and KCS firmware (1 Reply)
- Communication between two A16 over RS485 on ESPHOME with uart not working (5 Replies)
- K868-A16 433 RF MHz receiver (59 Replies)
- KC868-A16 with KCS firmware (3 Replies)
- Home Assistant (1 Reply)
- How to send temperature sensor data via custom protocol (1 Reply)
- KC868-A16 Tuya (3 Replies)
- KC868-A16 Shutter with percentage (4 Replies)
- conexiones mqtt y node red (8 Replies)
- A16: IFTTT Time based actions not working (28 Replies)
- IFTT logic (2 Replies)
- KC868-A16 HC-SR04 (4 Replies)
- KC868-A16 board - wired security system (10 Replies)
- KC868-A16 IR Input (11 Replies)
- A16v3 low voltage inputs (8 Replies)
- KC868-A16 - Maximum output current per channel (1 Reply)
- Issues with STA mode (2 Replies)
- Low output voltage (6 Replies)
