Hello everybody!
I am looking at adding a DS1307 RTC connected via I2C, anyone you can recommended that has been testet and easy to connect?
Presume source code are the same as for the KC868-A6.
(03-13-2023, 11:05 AM)admin Wrote: [ -> ]here is DS1307 RTC arduino demo code for KC868-A6:
https://www.kincony.com/forum/showthread.php?tid=1863
if you want to use DS1307 connect to IIC bus extender , also can use A6's code, just define the GPIOs for SDA and SCL pin.
Any DS1307 RTC you can recommend to use that will work on the KC868-A16 and are easy to connect
any DS1307 chip can use, just define correct I2C bus pins is ok.
I have finally received my KC868-A16 board and found that the I1C uses special plug
What type of plug is this as I need to connect RTC module see attached pictures.
attachment=2201][
attachment=2202]
you can use "DuPont Line" connect with each pins.
I have now got my DS1307 connected and RTClib.h including Adafruit BusIO (i2c) in my sketch
I have not been able to find in any demo code in the forum how to define SDA & SCL (4, 5 for the KC868-A16 board) in Arduino IDE
Tried the example from KC868-A6 -- #05-DS1307 demo
If I try IIC SDA:4 & IIC SCL:5 as in I-O pin define (KC868-A16 I-O pin define) it comes up with an error.
I think I found the solution, se below.
// Set i2c for RTC DS1307
#define SDA:4
#define SCL:5
or
#define IIC SDA:4
#define IIC SCL:5
or
#define i2c SDA:4
#define i2c SCL:5
Which one is the correct one???
IIC SDA:4
IIC SCL:5
you should set it in your arduino "pins_arduino.h" file set SDA and SCL pins.
(04-08-2023, 11:37 AM)admin Wrote: [ -> ]IIC SDA:4
IIC SCL:5
All good, but I don't see the use of a library "pins_arduino.h" in any of your source code examples.
Is there not a source code for KC868-A16 showing the complete pin-define for the board as that would be the first step to do when starting a sketch regardless of what you want to code so that all pins are available now and later on in a project.
Does anybody have an example including the complete pin-define for the KCS868-A16?????
